DK198
DK198
    C-TON
    PROCESS METER/VOLTMETER 0-10VDC
DK198 数据手册
DK190V LCD Digital Panel Meters Specifications Installation and Operating Instructions Epic Series - Adjustable Voltage Powered 3½ Digit LCD FEATURES }} }} }} }} }} }} }} SPECIFICATIONS DISPLAY Digits: Type: Backlighting: Polarity: Annunciators: Decimal Points: Overrange: INPUTS Ranges: Configuration: Impedence: PERFORMANCE Accuracy: Conversion Rate: Normal Mode Rejection: Adjustments: Warmup: Temperature Coeff.: Offset Range: Gain Range: ENVIRONMENT Operating Range: Storage Range: POWER SUPPLY Optional Backlight: MOUNTING CONNECTION Low-cost, high-performance replacement for many OEM DPMs Optional RED, GREEN or AMBER backlighting Snap-in bezel mount eliminates mounting hardware Resistant to RF and EMI 3½ digits with high-contrast LCD 12V or 24V DC voltage-powered User-selectable, displayed engineering units ORDERING INFO PART NUMBER 3 ½ digits (±1999 counts) 0.45" (11.4 mm) 7 segment LCD Optional Red Negative (red numbers/black background) Optional Green Negative (green numbers/black background) Optional Amber Negative (amber numbers/black background) automatic, “-” displayed °F, °C, PSI, %, user-selectable or V, A, KW, PF 3 position, user-selectable three lower order digits blank for inputs >1999 & < -1999 BACKLIGHT COLOR DK196*................................... NEG AMBER....................................... 24 VDC DK197*....................................NEG GREEN........................................ 24 VDC DK198*......................................NEG RED.......................................... 24 VDC DK199*................................. NO BACKLIGHT........................................NONE *Add (P) for Power Engineering Units V, A, KW, PF ACCESSORIES PW2-12.................................... Regulated 120V AC to 12V DC Power Supply PW2-24.................................... Regulated 120V AC to 24V DC Power Supply CVC...............................................................................................Calibrator 0-10 VDC, 0-5 VDC or 0-200 mV DC single ended 390 KΩ min. ±(0.1% fs + 2 count) 3 per second >30 dB @ 60 Hz span (gain) (2) (10V and 5V) and zero (offset) 10 minutes typical ± 100 ppm per °C typical -1999 to +1999 1-2000 counts above adjusted zero 0 to 50 °C -10 to 60 °C 12 VDC or 24 VDC regulated (selectable) 24 VDC at 35 mA typical snap-in bezel mount 4 screw terminal (6 with backlight) C-TON Industries BACKLIGHT POWER SNAP-IN: • PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com LCD Digital Panel Meters Specifications Installation and Operating Instructions DK190V Epic Series - Adjustable Voltage Powered 3½ Digit LCD DIMENSIONS WIRING C-TON Industries • PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com
DK198
物料型号:DK190V
器件简介:Epic系列的LCD数字面板表,可调节电压供电,3½位数字显示。
引脚分配:文档中未明确列出引脚分配图,但提供了输入范围、配置和阻抗等信息。
参数特性: - 显示:3½位数字,高对比度LCD - 背光:可选红色、绿色或琥珀色 - 供电:12V或24V直流电 - 输入:0-10VDC、0-5VDC或0-200mV DC单端 - 精度:>30dB@60Hz,±(0.1% fs + 2 count) - 转换率:每秒3次 - 温度系数:±100ppm/°C - 工作温度:0到50°C - 存储温度:-10到60°C
功能详解: - 用户可选择显示工程单位,如V、A、KW、PF。 - 3位可用户选择的下位数字,对于大于1999或小于-1999的输入将空白显示。 - 可选配件包括校准器和电源适配器。
应用信息:作为许多原始设备制造商DPM的低成本、高性能替代品。
封装信息:快装式边框安装,消除了安装硬件的需要。
制造商信息:C-TON Industries,位于美国田纳西州孟菲斯市。
DK198 价格&库存
很抱歉,暂时无法提供与“DK198”相匹配的价格&库存,您可以联系我们找货
