DK809AC
LCD Digital Panel Meters
Specifications Installation and Operating Instructions
Large 1" - 3½ Digit AC/DC Powered, Voltage Controlled LCD DPM
FEATURES
SPECIFICATIONS
DISPLAY
Digits:
Type:
Polarity:
Annunciators:
Decimal Points:
Overrange:
INPUTS
Voltage Ranges:
Configuration:
PERFORMANCE
Accuracy:
Conversion Rate:
Normal Mode Rejection:
Warmup:
Temperature Coeff.:
Adjustments:
Offset Range:
Gain Range:
ENVIRONMENT
Operating Range:
Storage Range:
POWER SUPPLY
MOUNTING
CONNECTION
Large 1”, 3½ digit display for easy viewing.
User-selectable decimal points
User-selectable engineering units
Optional AMBER, GREEN, RED or BLUE backlit LCD
Wide ZERO (Offset) & SPAN (Gain) adjustment
Standard 1/8 DIN package
Snap-in panel mounting
ORDERING INFO
PART NUMBER BACKLIGHT COLOR METER INPUT
3 ½ digits (±1999 counts)
1" (24.9 mm) 7 segment high contrast LCD
automatic, “-” displayed
°F, °C, PSI, %, user selectable
3 position, user selectable
three lower order digits blank for
inputs >1999 & < -1999
5 V, 10 V adjustable, 200mV fixed
single ended
METER POWER
DK809AC . ...................NONE..........................Voltage ..................24VAC/DC
DK809ACA.................. AMBER.........................Voltage ..................24VAC/DC
DK809ACB . .................BLUE..........................Voltage ..................24VAC/DC
DK809ACG...................GREEN.........................Voltage ..................24VAC/DC
DK809ACR.....................RED...........................Voltage ..................24VAC/DC
ACCESSORIES
CVC............................................................................................................. Calibrator
±(0.05% of full scale + 1 count)
3 per second
>30 dB @ 60 Hz
10 minutes typical
± 100 ppm per °C typical
25 turn potentiometers
-1999 to +1999
1 to 1999 (custom ranges available)
-10 to 50 °C
-10 to 75 °C
24 VAC/DC
snap-in panel mount
screw terminals
C-TON Industries
• PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com
DK809AC
DIMENSIONS
WIRING
Lower Board
C-TON Industries
Upper Board
很抱歉,暂时无法提供与“DK809AC”相匹配的价格&库存,您可以联系我们找货
