DK616
DK616
    C-TON
    VOLTMETER 20VDC LED PANEL MOUNT
DK616 数据手册
DK610 LED Digital Panel Meters Specifications Installation and Operating Instructions 3½ Digit LED Display for voltage inputs FEATURES }} }} }} }} }} Display hold function standard 3½ digits with 0.56” RED or GREEN LED 10 wire harness included Gasket and clamp provided for NEMA4, NEMA12 & IP66 applications User-selectable decimal points SPECIFICATIONS ORDERING INFO DISPLAY PART NUMBER Digits: Type: Digit Height: Polarity: Decimal Point: Overrange: 3 ½ (±1999 count) 7- segment LED (red or green) .56 in (14.2 mm) automatic “-” for neg input 3 position selectable three lower order digits blank for inputs >1999 & < -1999 SIGNAL INPUTS DK612 ....................................... GREEN ............................................. 2VDC DK613........................................ GREEN ........................................... 20VDC DK614.......................................... RED ....................................... 200mV DC DK615.......................................... RED ..............................................2V DC DK616.......................................... RED ............................................20V DC ACCESSORIES C10-5................................................5" - 10 Pin Connector / Wire Assembly J1C10..............................................12" - 10 Pin Connector / Wire Assembly PW2-5........................................ Regulated 120V AC to 5V DC Power Supply PW1.0..........................................................24V AC to adjustable DC output CPW1.5B......................................................24V AC to adjustable DC output CVC...............................................................................................Calibrator Sampling Rate: 3.3 readings / seconds Accuracy: ± (0.1% + 2 counts) typical ±(0.2% + 2 counts) max Warmup, typical: 10 min Temperature Drift, typical: 100 ppm / °C POWER SUPPLY Supply Voltage: Supply Current, typical: +5 VDC ±5% 200 mA ENVIRONMENT Operating Temperature: 0 to 50°C Storage Temperature: -10 to 60°C Relative Humidity: 0 to 95% non-condensing PHYSICAL Package Style: Dimensions: Panel Cutout: Weight: Connector: CONNECTION: NEMA bezel mount 3.09 x 1.5 x .66" 2.83 x 1.26" 1.0 oz J1C-10 or C10-5 optional 10 pin C-TON Industries METER POWER DK611 ....................................... GREEN ..................................... 200mV DC Configuration: bipolar, differential Full-Scale Input: ±200 mV, ±2 V, ±20 V Input Offset Adjustment: auto zero Input Impedance: >100 MΩ (±200 mV),‑1 MΩ (other ranges) Common Mode Range: ±1 VDC Common Mode Rejection: >86 dB Protection: ±350 VDC (±100 VDC for 200 mV range) Input Bias Current: 1 pA typical, 100 pA max Control Inputs: decimal point select, hold, span adjust trimpot PERFORMANCE METER COLOR • PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com LED Digital Panel Meters Specifications Installation and Operating Instructions DK610 3½ Digit LED Display for voltage inputs DIMENSIONS 1 10 WIRING Pin No. Pin Name Description 1 V+ +5V power supply 2 GND Power supply ground 3 DP COM Decimal point return 4 DP1 1XX.X (connect to DP COM to turn on) 5 DP2 1X.XX (connect to DP COM to turn on) 6 DP3 1.XXX (connect to DP COM to turn on) 7 INPUT(+) Positive input signal 8 INPUT(-) Negative input signal 9 NC No connection required 10 HOLD Hold last display C-TON Industries • PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com
DK616
### 物料型号 - DK610
### 器件简介 DK610是一款3½位LED数字面板表,用于电压输入显示,具有0.56英寸的红色或绿色7段LED显示。
### 引脚分配 - 1V+:+5V电源供应 - 2GND:电源地 - 3DP COM:小数点返回 - 4DP1:1XX.X(连接到DP COM以打开) - 5DP2:1X.XX(连接到DP COM以打开) - 6DP3:1.XXX(连接到DP COM以打开) - 7INPUT(+):正输入信号 - 8INPUT(-):负输入信号 - 9NC:无需连接 - 10HOLD:保持最后显示
### 参数特性 - 显示保持功能 - 3½位显示,0.56英寸红色或绿色LED - 10线束包括垫圈和夹具,适用于NEMA4、NEMA12和IP66应用 - 用户可选择的小数点位置
### 功能详解 - 3½位7段LED显示(红色或绿色) - 自动极性识别,负输入时显示“-” - 小数点位置可选择,三个低位数字在输入大于1999或小于-1999时空白 - 过载显示
### 应用信息 - 适用于需要电压输入显示的场合,如工业控制、测试和测量等。
### 封装信息 - NEMA面板安装 - 尺寸:3.09 x 1.5 x 0.66英寸 - 面板开口:2.83 x 1.26英寸 - 重量:1.0盎司 - 连接器:J1C-10或C10-5可选
DK616 价格&库存
很抱歉,暂时无法提供与“DK616”相匹配的价格&库存,您可以联系我们找货
