DK600
LED Digital Panel Meters
Specifications Installation and Operating Instructions
3½ Digit LED Display for voltage inputs
FEATURES
Display hold function standard
3½ digits with 0.56” RED or GREEN LED
Window mount with optional bezel
User-selectable decimal points
Optional NEMA case (see DK610 for details)
SPECIFICATIONS
ORDERING INFO
DISPLAY
PART NUMBER METER COLOR
Digits:
Type:
Digit Height:
Polarity Indication:
Decimal Point:
Overrange:
3 ½ (±1999 count)
7- segment LED (red or green)
.56 in (14.2 mm)
automatic “-” for neg input
3 position selectable
three lower order digits blank for
inputs >1999 & < -1999
DK601 ....................................... GREEN ..................................... 200mV DC
DK602 ....................................... GREEN ............................................. 2VDC
DK603 ....................................... GREEN ........................................... 20VDC
DK604.......................................... RED ....................................... 200mV DC
DK605 ......................................... RED ..............................................2V DC
DK606 ......................................... RED ............................................20V DC
SIGNAL INPUTS
Configuration:
bipolar, differential
Full-Scale Input:
±200 mV, ±2 V, ±20 V
Input Offset Adjustment: auto zero
Input Impedance:
>100 MΩ (±200 mV),‑1 MΩ
(other ranges)
Common Mode Range: ±1 VDC
Common Mode Rejection: >86 dB
Protection:
±350 VDC (±100 VDC for 200 mV range)
Input Bias Current:
1 pA typical, 100 pA max
Control Inputs:
decimal point select, hold,
span adjust trimpot
DK610................................................................................ NEMA Enclosure
ACCESSORIES
LED-B................................................................. Optional Bezel Mounting Kit
C10-5................................................5" - 10 Pin Connector / Wire Assembly
J1C10..............................................12" - 10 Pin Connector / Wire Assembly
PW2-5........................................ Regulated 120V AC to 5V DC Power Supply
CVC...............................................................................................Calibrator
PERFORMANCE
Sampling Rate:
3.3 readings / s
Accuracy:
± (0.1% + 2 counts) typical
±(0.2% + 2 counts) max
Warmup, typical:
10 min
Temperature Drift, typical: 100 ppm / °C
POWER SUPPLY
Supply Voltage:
Supply Current, typical:
+5 VDC ±5%
200 mA
ENVIRONMENT
Operating Temperature: 0 to 50°C
Storage Temperature:
-10 to 60°C
Relative Humidity:
0 to 95% non-condensing
PHYSICAL
Package Style:
Dimensions:
Panel Cutout:
Weight:
Connector:
Bezel:
CONNECTION:
METER POWER
window mount
2.52 x 1.10 x .73
2.05 x .81
0.7 oz (20 g)
J1C-10 or C10-5 optional
optional
10 pin
C-TON Industries
• PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com
DK600
DIMENSIONS
WIRING
PIN # PIN NAME DESCRIPTION
1
V+
+5V POWER SUPPLY
2
GND
POWER SUPPLY GROUND
3
DP COM DECIMAL POINT RETURN
4
DP1
1XX.X (CONNECT TO DP COM TO TURN ON)
5
DP2
1X.XX (CONNECT TO DP COM TO TURN ON)
6
DP3
1.XXX (CONNECT TO DP COM TO TURN ON)
7
INPUT(+) POSITIVE INPUT SIGNAL
8
INPUT(-) NEGATIVE INPUT SIGNAL
9
NC
NO CONNECTION REQUIRED
10 HOLD HOLD LAST DISPLAY
C-TON Industries
很抱歉,暂时无法提供与“DK603”相匹配的价格&库存,您可以联系我们找货
