DK173
DK173
    C-TON
    VOLTMETER 20VDC LCD PANEL MOUNT
DK173 数据手册
DK170 LCD Digital Panel Meters Specifications Installation and Operating Instructions Flat Pack 3½ Digit LCD FEATURES }} }} }} }} SPECIFICATIONS DISPLAY Digits: Type: Digit Height: Polarity Ind.: Annunciators: Decimal Points: Overrange: INPUTS Ranges: Configuration: Protection: Impedance: Bias Current: PERFORMANCE Accuracy: Conversion Rate: Normal Mode Rejection: Common Mode Range: Common Mode Rej.: Zero Adjustment: Warmup: Temperature Coeff.: ENVIRONMENT Operating Range: Storage Range: Relative Humidity: POWER SUPPLY 9V powered: +5V and -5V DC: +5V DC: MOUNTING Dimensions: Panel Cutout: Weight: CONNECTION Low-cost Ultra compact flat design Less than .25” deep 3½ digits with high-contrast LCD ORDERING INFO 3 ½ digits (±1999 counts) 0.5" (13mm) 7 segment reflective LCD .50" (12.7mm) automatic, “-” displayed “LoBat” when power 1999 ±200.0mV, ±2.000V, ±20.00V DC true differential input and reference 250 VDC or 150 V RMS continuous, 300 V intermittent max >100 MΩ on ± 200mV ; (>1 MΩ on 2V & 20V range) 1 pA typical, 10 pA max 15 pads PART NUMBER....................... METER INPUT ......................... METER POWER DK171........................................ 200mV.................................................. 9V DK172............................................2V...................................................... 9V DK173 ..........................................20V..................................................... 9V 13-pins PART NUMBER METER INPUT DK174 ....................................... 200mV.................................................. 9V DK175 ...........................................2V...................................................... 9V DK176 ..........................................20V..................................................... 9V ±(0.1% fs + 2 count) with +5 and ±5V power ±(0.1% rgd + 1 count) with 9 V power 2.5 per second >30 dB @ 60 Hz ±1 VDC max >86 dB automatic 10 min typical ±100 ppm per °C typical DK177 ....................................... 200mV........................................... +5VDC DK178 ...........................................2V............................................... +5VDC DK179 ..........................................20V.............................................. +5VDC ACCESSORIES B-1B................................................................................ Bezel Mounting Kit J1C13....................................................... 13 Pin Connector / Wire Assembly PW2-5........................................ Regulated 120V AC to 5V DC Power Supply PW2-12.................................... Regulated 120V AC to 12V DC Power Supply CVC...............................................................................................Calibrator 0 to 50 °C -10 to 60 °C 0 to 95% non-condensing 9 V isolated, 7.2-12 V at 150 µA ±5 V ±5% at 150 µA 5 V ±5% at 3 mA panel hole mounting, standard bezel mount (optional) 2.37 x 1.50 x .32 1.89 x .66 0.9 oz (25 g) 13 pins, 0.025" square - pin 3 missing 15 solder pads C-TON Industries METER POWER • PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com DK170 LCD Digital Panel Meters Specifications Installation and Operating Instructions Flat Pack 3½ Digit LCD DIMENSIONS 13 PINS 15 PADS BEZEL MOUNTING C-TON Industries • PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com
DK173
1. 物料型号: - DK170系列LCD数字面板表
2. 器件简介: - DK170系列是低成本、超紧凑型的平板设计LCD数字面板表,深度小于0.25英寸,拥有3½位数字的高对比度LCD显示屏。
3. 引脚分配: - 13个引脚,0.025平方英寸,缺少第3个引脚。
4. 参数特性: - 显示:3½位数字(±1999计数),0.5英寸(13mm)7段反射式LCD,自动极性指示,低电量显示“LoBat”。 - 输入:量程包括±200.0mV, ±2.000V, ±20.00V DC,真差分输入和参考,250VDC或150VRMS连续,300V间歇性最大,阻抗大于100MΩ。 - 性能:精度±(0.1% fs + 2计数),转换速率2.5次/秒,正常模式下60Hz的抑制>30dB,共模范围±1VDC最大,自动零点调整,预热时间10分钟,温度系数±100ppm/°C。 - 环境:工作范围0到50°C,存储范围-10到60°C,相对湿度0到95%非凝结。 - 电源:9V隔离电源,7.2-12V在150µA,±5V±5%在150µA,5V±5%在3mA面板孔安装。
5. 功能详解: - 该设备提供高精度的数字显示,支持多种输入量程,具有自动极性指示和低电量警告功能。具备高阻抗输入保护,确保信号完整性。同时,设备还具备自动零点调整功能和温度补偿,以提高测量精度。
6. 应用信息: - 适用于需要精确数字显示和多种输入量程的应用场合,如工业控制、测试和测量设备等。
7. 封装信息: - 尺寸:2.37 x 1.50 x 0.32英寸(高x宽x深),面板开口1.89 x 0.66英寸,重量0.9盎司(25克)。 - 安装方式:面板孔安装,标准边框安装(可选)。
DK173 价格&库存
很抱歉,暂时无法提供与“DK173”相匹配的价格&库存,您可以联系我们找货
