DK500
LCD Digital Panel Meters
Specifications Installation and Operating Instructions
3 1/2 Digit LCD - Snap-in Mount
FEATURES
SPECIFICATIONS
DISPLAY
Digits:
Type:
Polarity:
Decimal Points:
Overrange:
Hold:
INPUTS
Ranges:
Configuration:
Protection:
Impedance:
PERFORMANCE
Accuracy:
Conversion Rate:
Normal Mode Rejection:
Common Mode Range:
Common Mode Rej.:
Zero Adjustment:
Warmup:
Temperature Coefficient:
ENVIRONMENT
Operating Range:
Storage Range:
POWER SUPPLY
5V powered:
9V(±5V) powered:
MOUNTING
CONNECTION
Low-cost, high-performance replacement for many OEM DPMs
Mounting:
Snap-in bezel mount eliminates mounting hardware
Low power: choice of 180µA (9V) or 2.5mA (+5V)
Space-saving design: only 1" (25 mm) deep
Occupies less than 2.5 X 1.1 inches of front panel space
3 1/2 digits with high-contrast LCD
Optional loop powered 4 to 20mA process inputs available
(see DK590)
ORDERING INFO
3 ½ digits (±1999 counts)
0.5" (12mm) high-contrast reflective LCD
automatic, “-” displayed
3 position, user-selectable
three lower order digits blank for inputs
>1999 & < -1999
available OEM option, contact factory
PART NUMBER
BACKLIGHT COLOR
METER INPUT
METER POWER
BACKLIGHT POWER
DK500...........NO BACKLIGHT ....... 200mV ......... +5VDC . ....................NONE
DK501...........NO BACKLIGHT .......... 2V ............ +5VDC . ....................NONE
DK502 ..........NO BACKLIGHT ......... 20V ........... +5VDC . ....................NONE
DK503...........NO BACKLIGHT ....... 200mV ......... +9VDC . ....................NONE
DK504...........NO BACKLIGHT .......... 2V ............ +9VDC . ....................NONE
DK505 ..........NO BACKLIGHT ......... 20V ........... +9VDC . ....................NONE
±200.0 mV, ±2.000 V, ±20.00 VDC
bipolar & differential
±350 VDC, (±100 VDC on 200 mV range)
>10 MΩ, (>1 MΩ on 20 V range)
ACCESSORIES
J1C4........................................................... 4 Pin Connector / Wire Assembly
J1C13....................................................... 13 Pin Connector / Wire Assembly
±(0.1% +1 count) typical
±(0.1% + 2 counts) maximum
2.5 per second
>30 dB @ 60 Hz
±1 VDC
>86 dB
automatic
10 minutes typical
±100 ppm per °C typical
PW2-5........................................ Regulated 120V AC to 5V DC Power Supply
PW2-12.................................... Regulated 120V AC to 12V DC Power Supply
CVC...............................................................................................Calibrator
0 to 50 °C
-10 to 70 °C
+5 VDC (±5%) at 2.5 mA
+7.2 to +12 V at 180 µA
snap-in bezel mount
13 pins, 0.025" square on
0.1" centers - pin 3 missing
C-TON Industries
• PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com
DK500
PANEL CUTOUTS
BEZEL MOUNT DIMENSIONS
WIRING CONNECTIONS
PIN # PIN NAME DESCRIPTION
1
2
3
4
5
6
7
8
9
10
11
12
13
C-TON Industries
V+
POSITIVE DPM POWER SUPPLY
V-
NEG POWER FOR 9V OR ±5V DPMS
NC
NO PIN
GND
NEGATIVE POWER FOR +5V DPMS
COM
ANALOG COMMON
INLO
DISPLAY INPUTS: DISPLAY NEGATIVE
INHI
IF INHI IS LOWER THAN INLO
RFL (CLK) NEG REFERENCE INPUT
(AND OPTIONAL HOLD)
RFH
POSITIVE REFERENCE INPUT
ROH
INTERNAL REFERENCE OUTPUT
D3
DECIMAL POINT = 1XX.X*
D2
DECIMAL POINT = 1X.XX*
D1
DECIMAL POINT = 1.XXX*
*Connect to Pin 1
很抱歉,暂时无法提供与“DK504”相匹配的价格&库存,您可以联系我们找货
