DK809ACR
DK809ACR
    C-TON
    PROCESS METER 0-10VDC LCD PNL MT
DK809ACR 数据手册
DK809AC LCD Digital Panel Meters Specifications Installation and Operating Instructions Large 1" - 3½ Digit AC/DC Powered, Voltage Controlled LCD DPM FEATURES }} }} }} }} }} }} }} SPECIFICATIONS DISPLAY Digits: Type: Polarity: Annunciators: Decimal Points: Overrange: INPUTS Voltage Ranges: Configuration: PERFORMANCE Accuracy: Conversion Rate: Normal Mode Rejection: Warmup: Temperature Coeff.: Adjustments: Offset Range: Gain Range: ENVIRONMENT Operating Range: Storage Range: POWER SUPPLY MOUNTING CONNECTION Large 1”, 3½ digit display for easy viewing. User-selectable decimal points User-selectable engineering units Optional AMBER, GREEN, RED or BLUE backlit LCD Wide ZERO (Offset) & SPAN (Gain) adjustment Standard 1/8 DIN package Snap-in panel mounting ORDERING INFO PART NUMBER BACKLIGHT COLOR METER INPUT 3 ½ digits (±1999 counts) 1" (24.9 mm) 7 segment high contrast LCD automatic, “-” displayed °F, °C, PSI, %, user selectable 3 position, user selectable three lower order digits blank for inputs >1999 & < -1999 5 V, 10 V adjustable, 200mV fixed single ended METER POWER DK809AC . ...................NONE..........................Voltage ..................24VAC/DC DK809ACA.................. AMBER.........................Voltage ..................24VAC/DC DK809ACB . .................BLUE..........................Voltage ..................24VAC/DC DK809ACG...................GREEN.........................Voltage ..................24VAC/DC DK809ACR.....................RED...........................Voltage ..................24VAC/DC ACCESSORIES CVC............................................................................................................. Calibrator ±(0.05% of full scale + 1 count) 3 per second >30 dB @ 60 Hz 10 minutes typical ± 100 ppm per °C typical 25 turn potentiometers -1999 to +1999 1 to 1999 (custom ranges available) -10 to 50 °C -10 to 75 °C 24 VAC/DC snap-in panel mount screw terminals C-TON Industries • PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com LCD Digital Panel Meters Specifications Installation and Operating Instructions DK809AC Large 1" - 3½ Digit AC/DC Powered, Voltage Controlled LCD DPM DIMENSIONS WIRING Lower Board C-TON Industries Upper Board • PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com
DK809ACR 价格&库存
很抱歉,暂时无法提供与“DK809ACR”相匹配的价格&库存,您可以联系我们找货
