DK204
DK204
    C-TON
    VOLTMETER 2VDC LCD PANEL MOUNT
DK204 数据手册
DK200 LCD Digital Panel Meters Specifications Installation and Operating Instructions Miniature Bezel Mount 3½ Digit LCD FEATURES }} }} }} }} }} }} SPECIFICATIONS DISPLAY Digits: Type: Polarity: Decimal Points: Annunciators: Overrange: Hold: INPUTS Ranges: Configuration: Protection: Impedance: PERFORMANCE Accuracy: Conversion Rate: Normal Mode Rejection: Common Mode Range: Common Mode Rej.: Zero Adjustment: Warmup: Temperature Coeff.: ENVIRONMENT Operating Range: Storage Range: POWER SUPPLY 5V powered: 9V powered: MOUNTING CONNECTION Low-cost, high-performance miniature snap-in DPM with annunciators Snap-in bezel mount eliminates mounting hardware Space-saving design: only .5” deep Occupies less than 1.75 X .95 inches of front panel space 3½ digits with high-contrast LCD Annunciators and decimal points ORDERING INFO PART NUMBER 3 ½ digits (±1999 counts) 0.38" (9 mm) high-contrast reflective LCD automatic, “-” displayed 3 position, user-selectable BAT, °C, °F, ~, m, µ, MΩ, KΩ, V, A, HOLD, user-selectable three lower order digits blank for inputs >1999 & < -1999 available OEM option, contact factory ±200.0 mV, ±2.000 V bipolar differential ±350 VDC, (±100 VDC on 200 mV range) >10 MΩ, (>1 MΩ, on 2 V range) METER INPUT DK202............................................2V............................................... +5VDC DK203........................................ 200mV.............................................. 9VDC DK204............................................2V.................................................. 9VDC ACCESSORIES PW2-5........................................ Regulated 120V AC to 5V DC Power Supply PW2-12.................................... Regulated 120V AC to 12V DC Power Supply CVC...............................................................................................Calibrator ±(0.1% +1 count) typical ±(0.1% + 2 counts) maximum 2.5 per second >30 dB @ 60 Hz ±1 VDC >86 dB automatic 10 minutes typical ±100 ppm per °C typical 0 to 50 °C -10 to 70 °C +5 VDC (± 5%) at 5 mA +7.2-12 VDC at 300 µA snap-In bezel mount 26 pins, in 2 rows C-TON Industries METER POWER DK201........................................ 200mV........................................... +5VDC • PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com DK200 LCD Digital Panel Meters Specifications Installation and Operating Instructions Miniature Bezel Mount 3½ Digit LCD DIMENSIONS & WIRING MINI 26-PIN DPM CONNECTIONS CONNECTION DESCRIPTIONS PIN # PIN NAME DESCRIPTION 1 NO CONNECTION 2 °C ANNUNCIATOR 3 KΩ ANNUNCIATOR 4 °F ANNUNCIATOR 5 MΩ ANNUNCIATOR 6 HOLD1 CONNECT TO VDD TO HOLD DISPLAY 7 C ANALOG COMMON 8 RL REFERENCE LOW TERMINAL 9 RH REFERENCE HIGH TERMINAL 10 GD NEG POWER SUPPLY FOR 5V DPMS 11 VDD POSITIVE DPM POWER SUPPLY 12 HOLD2 "HOLD" ANNUNCIATOR 13 BAT ANNUNCIATOR 14 m ANNUNCIATOR 15 V ANNUNCIATOR 16 A ANNUNCIATOR 17 µ ANNUNCIATOR 18 IH POSITIVE INPUT SIGNAL 19 IL NEGATIVE INPUT SIGNAL 20 VSS NEGATIVE POWER SUPPLY FOR 9V 21 BP LCD BACKPLANE 22 XBP ANNUNCIATOR & DECIMAL POINT DRIVER 23 ~ ANNUNCIATOR 24 D1 1.XXX DECIMAL 25 D2 1X.XX POINT 26 D3 1XX.X } C-TON Industries • PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com
DK204
物料型号: - DK200系列
器件简介: - DK200系列是一款低成本、高性能的微型快装式数字面板表,具有指示器功能。
引脚分配: - 该系列具有26个引脚,分为两排。 - 引脚功能包括电源、信号输入、显示保持、指示器和LCD背板等。
参数特性: - 显示:3½位数字(±1999计数),0.38英寸高对比度反射式LCD。 - 极性:自动,显示“-”。 - 小数点:3位置,用户可选。 - 指示器:包括BAT, °C, °F, ~, m, µ, MΩ, KΩ, V, A, HOLD等,用户可选。 - 超量程:输入>1999或<-1999时,最低有效数字空白。 - 保持功能:可选的OEM选项,需联系工厂。
功能详解: - 输入范围:±200.0 mV, ±2.000 V,双极性差分配置。 - 保护:±350 VDC(200 mV范围±100 VDC)。 - 阻抗:>10 MΩ(2 V范围>1 MΩ)。 - 性能:典型精度±(0.1% +1计数),最大精度±(0.1% + 2计数)。 - 转换速率:每秒2.5次。 - 正常模式抑制:60 Hz时>30 dB。 - 共模范围:±1 VDC。 - 共模抑制:>86 dB。 - 零调整:自动。 - 预热时间:典型10分钟。 - 温度系数:典型±100 ppm/°C。
应用信息: - 操作范围:0至50°C。 - 存储范围:-10至70°C。 - 电源:5V供电:+5 VDC(±5%)在5 mA;9V供电:+7.2-12 VDC在300 µA。
封装信息: - 快装式前面板安装。 - 尺寸仅0.5英寸深,占用前面板空间小于1.75 x 0.95英寸。
DK204 价格&库存
很抱歉,暂时无法提供与“DK204”相匹配的价格&库存,您可以联系我们找货
