DK190F
DK190F
    C-TON
    PROCESS METER 4-20MA LCD PNL MT
DK190F 数据手册
DK190F LCD Digital Panel Meters Specifications Installation and Operating Instructions 3½ Digit Flat Pack LCD with Loop Powered Adder Board FEATURES }} }} }} }} }} SPECIFICATIONS DISPLAY Digits: Type: Polarity: Decimal Points: Overrange: INPUTS Ranges: Configuration: Protection: Loop Burden: PERFORMANCE Accuracy: Conversion Rate: Normal Mode Rejection: Adjustments: Warmup: Temperature Coeff.: ENVIRONMENT Operating Range: Storage Range: POWER SUPPLY MOUNTING CONNECTION Low-cost, high-performance replacement for many OEM DPMs Surface or inside panel mounting Resistant to RF and EMI 3½ digits with high-contrast LCD 4-20 mA loop powered input ORDERING INFO PART NUMBER 3 ½ digits (±1999 counts) 0.5" (12 mm) 7 segment LCD automatic, “-” displayed 3 position, user selectable three lower order digits blank for inputs >1999 & < -1999 4-20 mA  DC bipolar differential 30 mA max. 300Ω nominal DK190F ACCESSORIES PW2-12.................................... Regulated 120V AC to 12V DC Power Supply PW2-24.................................... Regulated 120V AC to 24V DC Power Supply PW1.0..........................................................24V AC to adjustable DC output PW1.5..........................................................24V AC to adjustable DC output CVC...............................................................................................Calibrator ±(0.1% fs + 2 count) 3 per second >30 dB @ 60 Hz span (gain) and zero (offset) 10 minutes typical ±100 ppm per °C typical 0 to 50 °C -10 to 70 °C powered by the milliamp control loop surface 2 screw terminal C-TON Industries • PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com LCD Digital Panel Meters Specifications Installation and Operating Instructions DK190F 4½ Digit LCD with Loop Powered Board DIMENSIONS JUMPER SELECTION & WIRING 1. DECIMAL SELECTION: 199.9 19.99 1.999 J6 J5 J4 2. J1, J2, J3 SELECTION: IF: OFFSET (ZERO) IS 0 or OFFSET (ZERO) > 0 and GAIN (SPAN) ÷ OFFSET (ZERO)≥ 5 J3 J2 J1 A B IF: OFFSET (ZERO) > 0 and GAIN (SPAN) ÷ OFFSET (ZERO) < 5 J3 J2 J1 A B C-TON Industries • PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com
DK190F 价格&库存
很抱歉,暂时无法提供与“DK190F”相匹配的价格&库存,您可以联系我们找货
