DK851A
DK851A
    C-TON
    VOLTMETER 200MVDC LED PANEL MT
DK851A 数据手册
DK800/900 LED Digital Panel Meters Specifications Installation and Operating Instructions Large 3½ Digit LED Digital Panel Meter FEATURES }} }} }} }} }} Large, 0.8”, 3½ digit, GREEN or RED display for easy viewing Standard 1/8 DIN package User-selectable decimal points Snap-in panel mounting - no tools or hardware required Gasket and clamp provided for NEMA4, NEMA12 & IP66 applications SPECIFICATIONS ORDERING INFO DISPLAY PART NUMBER Digits: Type: Polarity: Decimal Points: Overrange: Hold: INPUTS Ranges: Configuration: Protection: Impedance: PERFORMANCE Accuracy: Conversion Rate: Normal Mode Rejection: Common Mode Range: Common Mode Rej.: Zero Adjustment: Warmup: Temperature Coeff.: ENVIRONMENT Operating Range: Storage Range: 3 ½ digits (±1999 counts) 0.8” (20.3 mm) LED automatic, “-” displayed. 3 position, user selectable three lower order digits blank for inputs >1999 & < -1999 display hold function is standard ±200.0 mV, +/-2.000 V, +/-20.00 VDC bipolar, differential ±350 VDC, (±100 VDC on 200 mV range) >1 MΩ, (>10 MΩ on 200 mV range) POWER SUPPLY MOUNTING CONNECTION 13 pin male connection C-TON Industries DK851A ....................................... RED .............................................200mV DK852A ....................................... RED ................................................... 2V DK853A ....................................... RED ................................................. 20V DK951A...................................... GREEN ...........................................200mV DK952A ..................................... GREEN ................................................. 2V DK953A ..................................... GREEN ............................................... 20V ACCESSORIES J4C13....................................................... 13 Pin Connector / Wire Assembly PW2-5........................................ Regulated 120V AC to 5V DC Power Supply CVC...............................................................................................Calibrator ±(0.05% FS +1 counts) 3 per second >30 dB @ 60 Hz ±1V DC >86 dB automatic 10 minutes typical ±100 ppm per °C typical -10 to 50 °C -40 to 75 °C +5V DC (± 5%) 180 mA @ 5 V snap-in panel mount or clamp and gasket (included) METER COLOR METER INPUT • PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com LED Digital Panel Meters Specifications Installation and Operating Instructions DK800/900 Large 3½ Digit LED Digital Panel Meter DIMENSIONS WIRING PIN # DESCRIPTION 1 +5V POWER SUPPLY 2 NEGATIVE SUPPLY 3 INHI 4 INLO 5 DECIMAL COMMON 6 DECIMAL 000.0 WHEN CONNECTED TO DECIMAL COMMON 7 DECIMAL 00.00 WHEN CONNECTED TO DECIMAL COMMON 8 DECIMAL 0.000 WHEN CONNECTED TO DECIMAL COMMON 9 NO CONNECTION REQUIRED 10 NO CONNECTION REQUIRED 11 DISPLAY HOLD WHEN CONNECTED TO +5V 12 NO CONNECTION 13 NO CONNECTION * Note: Pins 2 &4 should be tied together for proper operation C-TON Industries • PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com
DK851A 价格&库存
很抱歉,暂时无法提供与“DK851A”相匹配的价格&库存,您可以联系我们找货
