DK801A
DK801A
    C-TON
    VOLTMETER 200MVDC LCD PANEL MT
DK801A 数据手册
DK800 LCD Digital Panel Meters Specifications Installation and Operating Instructions Large 1" - 3½ Digit LCD Digital Panel Meter FEATURES }} }} }} }} }} }} }} SPECIFICATIONS DISPLAY Digits: Type: Polarity: Decimal Points: Overrange: Hold: Annunciators: INPUTS Ranges: Configuration: Protection: Impedance: PERFORMANCE Accuracy: Conversion Rate: Normal Mode Rejection: Common Mode Range: Common Mode Rej.: Zero Adjustment: Warmup: Temperature Coeff.: ENVIRONMENT Operating Range: Storage Range: Large, 1”, 3½ digit display for easy viewing   Standard 1/8 DIN package User-selectable decimal points User-selectable engineering units Snap-in panel mounting - no tools or hardware required 13 pin connector / wiring harness included Gasket and clamp provided for NEMA 4, NEMA 12 & IP66 applications ORDERING INFO PART NUMBER METER INPUT 3 ½ Digits (±1999 counts) 1” ( 24.9 mm) high contrast LCD automatic, “-” displayed. 3 position, user-selectable three lower order digits blank for inputs >1999 & < -1999 display hold function is standard PSI, °F, °C, % user-selectable DK801A ........................................................................................... 200mV DK802A ..................................................................................................2V DK803A ................................................................................................20V ±200.0 mV, +/-2.000 V, +/-20.00 VDC bipolar, differential ±350 VDC, (±100 VDC on 200 mV range) >1 MΩ, (>10 MΩ on 200 mV range) ACCESSORIES J4C13....................................................... 13 Pin Connector / Wire Assembly PW2-5........................................ Regulated 120V AC to 5V DC Power Supply CVC...............................................................................................Calibrator ±(0.05% FS +1 counts) 3 per second >30 dB @ 60 Hz ±1 VDC >86 dB automatic 10 minutes typical ±100 ppm per °C typical -10 to 50 °C -10 to 75 °C POWER SUPPLY 5V powered: +5 VDC (±5%) 3 mA @ 5 V MOUNTING snap-in panel mount or clamp and gasket (included) CONNECTION 13 pin male connection C-TON Industries • PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com LCD Digital Panel Meters Specifications Installation and Operating Instructions DK800 Large 1" - 3½ Digit LCD Digital Panel Meter DIMENSIONS WIRING PIN # DESCRIPTION 1 +5V POWER SUPPLY 2 NEGATIVE SUPPLY 3 INHI 4 INLO 5 DECIMAL COMMON 6 DECIMAL 000.0 WHEN CONNECTED TO DECIMAL COMMON 7 DECIMAL 00.00 WHEN CONNECTED TO DECIMAL COMMON 8 DECIMAL 0.000 WHEN CONNECTED TO DECIMAL COMMON 9 NO CONNECTION REQUIRED 10 NO CONNECTION REQUIRED 11 DISPLAY HOLD WHEN CONNECTED TO +5V 12 NO CONNECTION 13 NO CONNECTION * Note: Pins 2 &4 should be tied together for proper operation C-TON Industries • PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com
DK801A
物料型号:DK800系列LCD数字面板表
器件简介: - 大尺寸1" - 3½位LCD数字面板表,易于查看。 - 标准1/8 DIN封装。 - 用户可选择的小数点。 - 用户可选择的工程单位。 - 无需工具或硬件即可快速安装到面板。 - 13针连接器/配线束包括在内,提供NEMA 4、NEMA 12和IP66应用的垫圈和夹具。
引脚分配: - 1号引脚:+5V电源 - 2号引脚:负电源 - 3号引脚:INHI(高电平有效) - 4号引脚:INLO(低电平有效) - 5号引脚:小数点公共端 - 6号引脚:小数点公共端 - 7号引脚:小数点公共端 - 8号引脚:显示保持功能,连接到+5V - 9号至12号引脚:无连接 - 13号引脚:无连接
参数特性: - 显示:3 ½位数字(±1999计数) - 极性:显示负号“-” - 超量程:标准显示保持功能 - 指示器:PSI、°F、°C、%用户可选择
功能详解: - 输入范围:±200.0 mV, +/-2.000 V, +/-20.00 VDC - 配置:双极性,差分 - 保护:±350 VDC(200 mV范围内±100 VDC) - 阻抗:>1 MΩ(200 mV范围内>10 MΩ) - 精度:±(0.05% FS +1计数) - 转换率:每秒3次 - 正常模式抑制:>30 dB @ 60 Hz - 共模范围:±1 VDC - 共模抑制:>86 dB - 零点调整:自动 - 预热时间:典型10分钟 - 温度系数:每°C典型±100 ppm
应用信息: - 适用于需要高精度和易于读取的数字显示的工业应用。
封装信息: - 尺寸:3.78"(96mm)x 3.62"(92mm) - 面板开孔尺寸:1.89"(48mm) - 安装支架轮廓:1.69"(43mm) - 后视图尺寸:4.45"(113mm)
其他信息: - 工作温度范围:-10至50°C - 存储温度范围:-10至75°C - 电源:+5 VDC(±5%),3 mA @ 5 V - 符合RoHS标准
DK801A 价格&库存
很抱歉,暂时无法提供与“DK801A”相匹配的价格&库存,您可以联系我们找货
