DK199-XEC
DK199-XEC
    C-TON
    PROCESS METER/VOLTMETER 0-10VDC
DK199-XEC 数据手册
DK190V-XEC LCD Digital Panel Meters Specifications Installation and Operating Instructions Adjustable Voltage Powered 3½ Digit FEATURES }} }} }} }} }} }} }} .45”, 3½ digit display User-selectable Decimal points User-selectable engineering units Non-backlit LCD or choice of AMBER, GREEN, RED or POS GREEN backlit LCD Wide ZERO (Offset) & SPAN (Gain) adjustment Snap-in panel mounting Gasket and clamp provided for NEMA 4, NEMA 12 & IP66 applications SPECIFICATIONS ORDERING INFO DISPLAY PART NUMBER Digits: Type: Polarity: Annunciators: Decimal Points: Overrange: INPUTS Voltage Ranges: Configuration: Impedance: PERFORMANCE Accuracy: Conversion Rate: Normal Mode Rejection: Warmup: Temperature Coeff.: Adjustments: Offset Range: Gain Range: 3 ½ digits (±1999 counts) .45" (11.4 mm) 7 segment high contrast LCD automatic, “-” displayed °F, °C, PSI, %, user selectable 3 position, user selectable three lower order digits blank for inputs >1999 & < -1999 5 V, 10 V adjustable, 200mV fixed single ended 390KΩ BACKLIGHT COLOR METER INPUT DK199-XEC ......... NO BACKLIGHT . ................Voltage....................12/24VDC DK196-XEC................. AMBER .......................Voltage....................12/24VDC DK197-XEC..................GREEN.........................Voltage....................12/24VDC DK198-XEC....................RED...........................Voltage....................12/24VDC DK200-XEC ............ POS GREEN.....................Voltage....................12/24VDC ACCESSORIES PW2-12.................................... Regulated 120V AC to 12V DC Power Supply PW2-24.................................... Regulated 120V AC to 24V DC Power Supply ±(0.05% of full scale + 1 count) 3 per second >30 dB @ 60 Hz 10 minutes typical ± 100 ppm per °C typical 25 turn potentiometers -1999 to +1999 1 to 1999 (custom ranges available) PW1.0..........................................................24V AC to adjustable DC output PW1.5..........................................................24V AC to adjustable DC output CVC...............................................................................................Calibrator ENVIRONMENT 10 to 50 °C -10 to 75 °C 12/24 DC MOUNTING snap-in panel mount or clamp and gasket (included) CONNECTION screw terminals Operating Range: Storage Range: POWER SUPPLY C-TON Industries METER POWER • PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com LCD Digital Panel Meters Specifications Installation and Operating Instructions DK190V-XEC Adjustable Voltage Powered 3½ Digit DIMENSIONS WIRING °F °C PSI % (lower) C-TON Industries • PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com
DK199-XEC 价格&库存
很抱歉,暂时无法提供与“DK199-XEC”相匹配的价格&库存,您可以联系我们找货
