DK191-XEC
DK191-XEC
    C-TON
    PROCESS METER 4-20MA LCD PNL MT
DK191-XEC 数据手册
DK190-XEC LCD Digital Panel Meters Specifications Installation and Operating Instructions 3½ Digit LCD with Loop Powered Board FEATURES }} }} }} }} }} }} }} SPECIFICATIONS DISPLAY Digits: Type: Backlighting: Polarity: Annunciators: Decimal Points: Overrange: INPUTS Ranges: Configuration: Impedance: PERFORMANCE Accuracy: Conversion Rate: Normal Mode Rejection: Common Mode Range: Common Mode Rej.: Adjustments: Warmup: Temperature Coeff.: ENVIRONMENT Operating Range: Storage Range: POWER SUPPLY Optional Backlight: MOUNTING CONNECTION Low-cost, high-performance replacement for many OEM DPMs Optional RED, GREEN, AMBER or POS GREEN backlit LCD Snap-in bezel mount eliminates mounting hardware Resistant to RF and EMI 3½ digits with high-contrast LCD 4-20 mA loop powered input User-selectable, displayed engineering units ORDERING INFO 3 ½ digits (±1999 counts) 0.45" (11.4 mm) 7 segment LCD Optional Red Negative (red numbers/black background) Optional Green Negative (green numbers/black background) Optional Amber Negative (amber numbers/black background) Optional Green Positive (black numbers/green background) automatic, “-” displayed °F, °C, PSI, % , user selectable 3 position, user selectable three lower order digits blank for inputs >1999 & < -1999 PART NUMBER BACKLIGHT COLOR BACKLIGHT POWER DK191-XEC........................... NO BACKLIGHT........................................NONE DK192-XEC............................. NEG AMBER........................................ 24VDC DK194-XEC................................NEG RED........................................... 24VDC DK193-XEC..............................NEG GREEN......................................... 24VDC DK195-XEC..............................POS GREEN......................................... 24VDC ACCESSORIES PW2-24.................................... Regulated 120V AC to 24V DC Power Supply PW1.0..........................................................24V AC to adjustable DC output PW1.5..........................................................24V AC to adjustable DC output CVC...............................................................................................Calibrator 4-20 mA  DC bipolar differential 300Ω nominal ±(0.1% fs + 2 count) 3 per second >30 dB @ 60 Hz ±1 VDC max >86 dB span (gain) and zero (offset) 10 minutes typical ± 100 ppm per °C typical 0 to 50 °C -10 to 70 °C powered by the milliamp control loop 24 VDC at 35 mA typical snap-in bezel mount or clamp and gasket 2 screw terminal (4 with backlight) C-TON Industries • PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com LCD Digital Panel Meters Specifications Installation and Operating Instructions DK190-XEC 3½ Digit LCD with Loop Powered Board DIMENSIONS WIRING 1. DECIMAL SELECTION: 1999 199.9 19.99 1.999 J7 J6 J5 J4 2. J1, J2, J3 SELECTION: IF: OFFSET (ZERO) IS 0 or OFFSET (ZERO) > 0 and GAIN (SPAN) ÷ OFFSET (ZERO)≥ 5 J3 J2 J1 A B IF: °F °C PSI % OFFSET (ZERO) > 0 and GAIN (SPAN) ÷ OFFSET (ZERO) < 5 J3 J2 J1 A B C-TON Industries (lower) • PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com
DK191-XEC 价格&库存
很抱歉,暂时无法提供与“DK191-XEC”相匹配的价格&库存,您可以联系我们找货
