DK200-XEC
DK200-XEC
    C-TON
    PROCESS METER/VOLTMETER 0-10VDC
DK200-XEC 数据手册
DK190V-XEC LCD Digital Panel Meters Specifications Installation and Operating Instructions Adjustable Voltage Powered 3½ Digit FEATURES }} }} }} }} }} }} }} .45”, 3½ digit display User-selectable Decimal points User-selectable engineering units Non-backlit LCD or choice of AMBER, GREEN, RED or POS GREEN backlit LCD Wide ZERO (Offset) & SPAN (Gain) adjustment Snap-in panel mounting Gasket and clamp provided for NEMA 4, NEMA 12 & IP66 applications SPECIFICATIONS ORDERING INFO DISPLAY PART NUMBER Digits: Type: Polarity: Annunciators: Decimal Points: Overrange: INPUTS Voltage Ranges: Configuration: Impedance: PERFORMANCE Accuracy: Conversion Rate: Normal Mode Rejection: Warmup: Temperature Coeff.: Adjustments: Offset Range: Gain Range: 3 ½ digits (±1999 counts) .45" (11.4 mm) 7 segment high contrast LCD automatic, “-” displayed °F, °C, PSI, %, user selectable 3 position, user selectable three lower order digits blank for inputs >1999 & < -1999 5 V, 10 V adjustable, 200mV fixed single ended 390KΩ BACKLIGHT COLOR METER INPUT DK199-XEC ......... NO BACKLIGHT . ................Voltage....................12/24VDC DK196-XEC................. AMBER .......................Voltage....................12/24VDC DK197-XEC..................GREEN.........................Voltage....................12/24VDC DK198-XEC....................RED...........................Voltage....................12/24VDC DK200-XEC ............ POS GREEN.....................Voltage....................12/24VDC ACCESSORIES PW2-12.................................... Regulated 120V AC to 12V DC Power Supply PW2-24.................................... Regulated 120V AC to 24V DC Power Supply ±(0.05% of full scale + 1 count) 3 per second >30 dB @ 60 Hz 10 minutes typical ± 100 ppm per °C typical 25 turn potentiometers -1999 to +1999 1 to 1999 (custom ranges available) PW1.0..........................................................24V AC to adjustable DC output PW1.5..........................................................24V AC to adjustable DC output CVC...............................................................................................Calibrator ENVIRONMENT 10 to 50 °C -10 to 75 °C 12/24 DC MOUNTING snap-in panel mount or clamp and gasket (included) CONNECTION screw terminals Operating Range: Storage Range: POWER SUPPLY C-TON Industries METER POWER • PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com LCD Digital Panel Meters Specifications Installation and Operating Instructions DK190V-XEC Adjustable Voltage Powered 3½ Digit DIMENSIONS WIRING °F °C PSI % (lower) C-TON Industries • PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com
DK200-XEC
物料型号:DK190V-XEC
器件简介:这是一款可调节电压供电的3½位数字面板表,具有0.45英寸的3½位显示,用户可选择的小数点位置,用户可选择的工程单位,非背光LCD或选择琥珀色、绿色、红色或正绿色背光LCD。
引脚分配:文档中未明确列出引脚分配图,但提供了一些跳线设置信息,例如J4、J5和J6跳线用于选择小数点位置。
参数特性: - 显示:3 ½位数字(±1999计数) - 类型:0.45英寸(11.4毫米)7段高对比度LCD - 极性:自动,“-”显示 - 计量单位:°F, °C, PSI, %,用户可选择 - 过范围:对于大于1999和小于-1999的输入,三个低位数字空白
功能详解: - 宽零点(偏移)和量程(增益)调整 - 快照式面板安装 - 为NEMA 4, NEMA 12和IP66应用提供垫片和夹具
应用信息:适用于需要精确测量和显示的工业环境。
封装信息: - 面板尺寸:3.09" x 2.83"(78.50mm x 71.77mm) - 面板开口:1.26" x 1.5"(32.02mm x 38.30mm) - 带垫片的NEMA 4安装尺寸:0.638"(6.21mm)
DK200-XEC 价格&库存
很抱歉,暂时无法提供与“DK200-XEC”相匹配的价格&库存,您可以联系我们找货
