DK798
DK798
    C-TON
    PROCESS METER 0-10VDC LCD PNL MT
DK798 数据手册
DK790V LCD Digital Panel Meters Specifications Installation and Operating Instructions Epic Series - Adjustable Voltage Powered 4½ Digit LCD FEATURES }} }} }} }} }} }} }} SPECIFICATIONS DISPLAY Digits: Type: Backlighting: Polarity: Annunciators: Decimal Points: Overrange: INPUTS Ranges: Configuration: Impedance: PERFORMANCE Accuracy: Conversion Rate: Normal Mode Rejection: Adjustments: Warmup: Temperature Coeff.: Offset Range: Gain Range: ENVIRONMENT Operating Range: Storage Range: POWER SUPPLY Optional Backlight: MOUNTING CONNECTION Low-cost, high-performance replacement for many OEM DPMs Optional RED, GREEN or AMBER backlighting Snap-in bezel mount eliminates mounting hardware Resistant to RF and EMI 4½ digits with high-contrast LCD 12V or 24V DC voltage-powered User-selectable, displayed engineering units ORDERING INFO PART NUMBER 4 ½ digits (±19999 counts) 0.45" (11.4 mm) 7 segment LCD Optional Red Negative (red numbers/black background) Optional Green Negative (green numbers/black background) Optional Amber Negative (amber numbers/black background) Optional Green Positive (black numbers/green background) automatic, “-” displayed °F, °C, PSI, %, user-selectable 4 position, user-selectable or V, A, KW, PF four lower order digits blank for inputs >19999 & < -19999 BACKLIGHT COLOR BACKLIGHT POWER DK796*................................... NEG AMBER........................................ 24VDC DK797*....................................NEG GREEN......................................... 24VDC DK798*......................................NEG RED........................................... 24VDC DK799*................................. NO BACKLIGHT........................................NONE DK800*....................................POS GREEN......................................... 24VDC *Add (P) for Power Engineering Units V, A, KW, PF ACCESSORIES PW2-12.................................... Regulated 120V AC to 12V DC Power Supply PW2-24.................................... Regulated 120V AC to 24V DC Power Supply CVC...............................................................................................Calibrator 0-10 VDC, 0-5 VDC or 0-200 mV DC single ended 390KΩ min. ±(0.1% fs + 2 count) 3 per second >30 dB @ 60 Hz span (gain) (2) (10V and 5V) and zero (offset) 10 minutes typical ±100 ppm per °C typical -19999 to +19999 1-20000 counts above adjusted zero 0 to 50 °C -10 to 60 °C 12 VDC or 24 VDC regulated (selectable) 24 VDC at 35 mA typical snap-in bezel mount 4 screw terminal (6 with backlight) C-TON Industries • PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com LCD Digital Panel Meters Specifications Installation and Operating Instructions DK790V Epic Series - Adjustable Voltage Powered 4½ Digit LCD DIMENSIONS WIRING C-TON Industries • PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com
DK798 价格&库存
很抱歉,暂时无法提供与“DK798”相匹配的价格&库存,您可以联系我们找货
