DK800-XEC
DK800-XEC
    C-TON
    PROCESS METER 0-10VDC LCD PNL MT
DK800-XEC 数据手册
DK790V-XEC LCD Digital Panel Meters Specifications Installation and Operating Instructions Adjustable Voltage Powered 4½ Digit FEATURES }} }} }} }} }} }} }} SPECIFICATIONS DISPLAY Digits: Type: Polarity: Annunciators: Decimal Points: Overrange: INPUTS Voltage Ranges: Configuration: Impedance: PERFORMANCE Accuracy: Conversion Rate: Normal Mode Rejection: Warmup: Temperature Coeff.: Adjustments: Offset Range: Gain Range: .45”, 4½ digit display User-selectable decimal points User-selectable engineering units Non-backlit LCD or choice of AMBER, GREEN, RED or POS GREEN backlit LCD Wide ZERO (Offset) & SPAN (Gain) adjustment Snap-in panel mounting Gasket and clamp provided for NEMA 4, NEMA 12 & IP66 applications ORDERING INFO PART NUMBER 4 ½ digits (±19999 counts) .45" (11.4 mm) 7 segment high contrast LCD automatic, “-” displayed °F, °C, PSI, %, user selectable 4 position, user selectable four lower order digits blank for inputs >19999 & < -19999 5 V, 10 V adjustable, 200mV fixed single ended 390KΩ ±(0.05% of full scale + 1 count) 3 per second >30 dB @ 60 Hz 10 minutes typical ± 100 ppm per °C typical 25 turn potentiometers -19999 to +19999 1 to 19999 (custom ranges available) BACKLIGHT COLOR METER INPUT DK796-XEC................. AMBER .......................Voltage....................12/24VDC DK797-XEC..................GREEN.........................Voltage....................12/24VDC DK798-XEC....................RED...........................Voltage....................12/24VDC DK800-XEC ............ POS GREEN.....................Voltage....................12/24VDC ACCESSORIES PW2-12.................................... Regulated 120V AC to 12V DC Power Supply PW2-24.................................... Regulated 120V AC to 24V DC Power Supply PW1.0..........................................................24V AC to adjustable DC output PW1.5..........................................................24V AC to adjustable DC output CVC...............................................................................................Calibrator ENVIRONMENT Operating Range: Storage Range: -10 to 50 °C -10 to 75 °C POWER SUPPLY 12/24 DC MOUNTING snap-in panel mount or clamp and gasket (included) CONNECTION screw terminals C-TON Industries METER POWER DK799-XEC ......... NO BACKLIGHT . ................Voltage....................12/24VDC • PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com LCD Digital Panel Meters Specifications Installation and Operating Instructions DK790V-XEC Adjustable Voltage Powered 4½ Digit DIMENSIONS WIRING °F °C PSI % (lower) C-TON Industries • PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com
DK800-XEC 价格&库存
很抱歉,暂时无法提供与“DK800-XEC”相匹配的价格&库存,您可以联系我们找货
