BDR-999B
BDR-999B
    C-TON
    PROCESS METER/VOLTMETER 20VDC
BDR-999B 数据手册
BDR Series LED Digital Panel Meters Specifications Installation and Operating Instructions 2.3” Numeral Multifunction Meter LARGE 3½ Digit LED Display FEATURES }} }} }} }} }} }} }} RED, GREEN OR BLUE LED Bezel mount or 180º bracket mounting in multiple planes Resistant to RF and EMI Durable metal case Highly visible 2.3" LED display Multifunction loop, set voltage, adjustable voltage inputs, all included Isolated AC/DC supply works in many control applications SPECIFICATIONS ORDERING INFO DISPLAY PART NUMBER Digits: Type: 3 ½ digits (±1999 counts) 2.3" (58.4mm) - 7 segment LED red, green or blue digits INPUTS Set Voltage Ranges: Configuration: Protection: Impedance: Adj. Voltage Ranges: Offset Range: Gain Range: 4-20mA Loop Ranges: Configuration: Protection: Loop Impedance: PERFORMANCE Accuracy: Conversion Rate: Normal Mode Rejection: Common Mode Rej.: Zero Adjustment: Warmup: Temperature Coeff.: ENVIRONMENT Operating Range: Storage Range: POWER SUPPLY BDR-999: BDR-924: MOUNTING CONNECTION ±200 mV, ± 2 V, ±20 VDC bipolar differential ±350 VDC, (±100 VDC on 200 mV range) >1 MΩ, (>10 MΩ on 200 mV range) 200 mV, 5 V, 10 VDC -1999 to +1999 1 to 1000 4 to 20mA DC bipolar differential ±30mA 300Ω nominal METER POWER BDR-999R.............................. 90 - 250 VAC.......................................... RED BDR-999G............................. 90 - 250 VAC....................................... GREEN BDR-999B.............................. 90 - 250 VAC......................................... BLUE BDR-924R........................... 10.5 - 30 VAC/DC....................................... RED BDR-924G.......................... 10.5 - 30 VAC/DC.................................... GREEN BDR-924B........................... 10.5 - 30 VAC/DC...................................... BLUE ACCESSORIES CVC...............................................................................................Calibrator ± (0.1% fs + 1 count) 3 per second >30 dB @ 60 Hz >86 dB automatic on set voltage ranges 10 minutes typical ±100 ppm per °C typical -10 to 50 °C -40 to 75 °C 90 to 250 VAC @ 12 VA 10.5 to 30 VAC/DC @ 6 VA 180° gimbal mounting with 30° stops, or bezel mount screw terminals C-TON Industries COLOR • PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com BDR Series LED Digital Panel Meters Specifications Installation and Operating Instructions 2.3” Numeral Multifunction Meter LARGE 3½ Digit LED Display DIMENSIONS WIRING & CALIBRATION 1. 2. 3. 4. 5. 6. Set function switch in correct position (LPI, VPI, DCV). Set voltage input range switch in correct position (200mV, 2V/5V, 20V/10V). Attach input wires to appropriate screw terminals. Attach power wires to AC/DC power screw terminals. Power unit up. Apply lowest input into meter, adjust correct zero pot for required reading (N/A on DCV function). 7. Apply highest input into meter, adjust correct span pot for required reading. 8. Recheck zero input and adjust again as needed. 9. Check reading at mid-point for required reading. 10. Select appropriate decimal as required. * LPI OFFSET PIN POSITIONS In "+" position enables user to have negative zero readings. In "-" position enables user to have positive zero readings. AC POWER [90V - 250V] AC AC (BDR-999) C-TON Industries OR AC POWER [10.5V - 30V] AC or DC (BDR-924) • PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com
BDR-999B 价格&库存
很抱歉,暂时无法提供与“BDR-999B”相匹配的价格&库存,您可以联系我们找货
