10826TCF
10826TCF
    AVENTOOLS(艾文)
    CUTTERSIDETPRDFLUSH5"
10826TCF 数据手册
Hard Wire Cutters Premium Hard Wire Cutters • Brazed Tungsten Carbide Inserts • Medical-Grade Mirror Finish • 80-82 HRC • Precision Box Joint Construction Comfortable Grip • ESD Safe Comfort Grips • Designed for all hand sizes • Dual Leaf Springs Cut Through Hard Wires With Ease Cut through hard wires with ease. Accu-Cut Hard Wire Cutters feature tungsten carbide blades and are designed for the most extreme cutting demands including piano, nickel and diode wires. Featuring box-joint construction for precise blade alignment through the life of the cutter. • Brazed tungsten carbide inserts. Cuts through hard The Right Cutters For The Right Job • 5 cutting models • Available with flush or semi-flush cutting blades wires with ease • Box construction for precise tip alignment • Ergonomic ESD safe comfort hand grips • Ultra-responsive leaf springs for reduced hand fatigue • Medical-grade polished mirror finish • 80-82 HRC • Made in Germany exclusively for Aven Flush Blade Semi-Flush Blade Email | sales@aveninc.com aveninc.com Phone | 734.973.0099 Head Style Image Part #(Semi Flush) Part# (Flush) Oval Head 10821TCS 10821TCF Tapered Head 10825TCS 10825TCF Mini Tapered Head 10826TCS 1026TCF Mini Oval Head 10827TCS 10827TCF Mini Tapered Head w/ Relief 10828TCS 10828TCF Hard Email | sales@aveninc.com Wire Line Drawing Cutters aveninc.com Phone | 734.973.0099
10826TCF 价格&库存
很抱歉,暂时无法提供与“10826TCF”相匹配的价格&库存,您可以联系我们找货
