516-280-300-001
516-280-300-001
    TOOL RACK & PANEL REPLCMENT TIP
516-280-300-001 数据手册
EDAC Canada - Online Catalogue Online Catalogue Series 516 Two-Piece Connector .150" (3.81mm) Contact Spacing, Rack-and-Panel, Plug and Receptacle FEATURES ● ● ● ● ● ● ● ● ● ● ● UL Recognized .150" (3.81mm) Contact Spacing x .130" (3.30mm) or .150" (3.81mm) Row Spacing with Staggered Grid Plug and Receptacle in 20, 38, 56, 90 or 120 Contact Sizes EDACON Hermaphroditic Contact Mating Design Contact Termination Options include Crimp, PC Tail, Wire Hole, Wire Wrap and Taper Tail Mating and Unmating Simplified with use of Actuating Screws Optional Covers with Cable Clamp Available in Plastic or Zinc Material for all Connector Sizes with Side or Top Cable Entry Versatile Metal Cover Design permits Assembly or Dis-assembly After Cabling is Complete plus Cable Entry Style Flexibility Actuating Screws, Locknuts, Polarizing Hardware, Covers and Contacts Suitable for either Plug or Receptacle Polarizing Hardware Adjustable for 288 Mating Combinations Tools Available for Contact Installation, Removal and Crimping and Polarizing Changes SPECIFICATIONS ● ● ● ● ● ● ● ● ● ● Insulator Material: Diallyl Phthalate or Thermoplastic Polyester, UL 94V-0, Colour: Green, or Polycarbonate, Colour: Grey Contact Material: Phosphor Bronze Alloy CA-510 Contact Plating: Gold over Nickel for Entire Contact Cover Material: Polycarbonate, Colour: Green, or Die-Cast Zinc, Finished with Grey Enamel Paint Current Rating: 8.5 Amperes Contact Resistance: 10 Milliohms Maximum Dielectric Withstanding Voltage: 2000 V AC rms at Sea Level Insulation Resistance: 5000 Megohms Minimum Operating Temperature: -65 to +125 Degrees C Insertion and Withdrawal Force: 2 to 16 oz (0.56 to 4.45 N) per Contact Position ORDERING CODE http://edac.net/en/Online/detail.cfm?ID=48 (1 of 4)03/02/2005 03:59:39 ã EDAC Canada - Online Catalogue Series 516 Total Number of Contacts 020, 038, 056, 090 or 120 Contact Code 1, 2 Description & Tail Size Tail Length "G" 000 No Contacts Assembled 500 Wire Hole .110" x .024" (2.79mm x 0.61mm) .245" (6.22mm) 501 Taper Tail .245" (6.22mm) 520 PC Tail .025" x .024" (0.64mm x 0.61mm) .215" (5.46mm) 540 Wire Wrap .050" x .024" (1.27mm x 0.61mm) .600" (15.24mm) 541 Wire Wrap .050" x 0.24" (0.64mm x 0.61mm) .620" (15.75mm) 542 Wire Wrap .050" x .024" (1.27mm x 0.61mm) .790" (20.07mm) 3 --- ---- Style Insulator Material 1 Plug Green Diallyl Phthalate 2 Receptacle Green Diallyl Phthalate 3 Plug Grey Polycarbonate 4 Receptacle Grey Polycarbonate 5 Plug Green Polyester 6 Receptacle Green Polyester Style and Material Cover Code 4, 5, 6, 7 Description 0 No Cover Assembled 1 Plastic Cover, Top Entry Standard Clamp 2 Plastic Cover, Side Entry Standard Clamp 3 Plastic Cover, Top Entry Large Clamp 4 Plastic Cover, Side Entry Large Clamp 5 Metal Cover, Side Entry 6 Metal Cover, Top Entry http://edac.net/en/Online/detail.cfm?ID=48 (2 of 4)03/02/2005 03:59:39 ã EDAC Canada - Online Catalogue Hardware Code 8 Description 0 No Hardware Assembled 1 Actuating Screw and Polarizing Hardware 2 Locknut and Polarizing Hardware 5 Actuating Screw with No Polarizing Hardware 6 Locknut with No Polarizing Hardware Ordering Code Notes 1) Crimp contacts are also available for the 516 series connectors. Contacts may be ordered separately for pre-wired or select position assembly. Part Number Description 516-290-500 Wire Hole 516-290-501 Taper Tail 516-290-520 PC Tail 516-290-540 Wire Wrap 516-290-541 Wire Wrap 516-290-542 Wire Wrap 516-290-590 Crimp - Loose 516-290-591 Crimp - 1800 Contacts per reel Silhouette 2) For contact installation, removal and crimping tools click here. 3) Grey polycarbonate insulator material is not available for the 120 pin size connector. 4) The 20 pin connector cover will not accept the length of the wire wrap contacts. 5) Plastic covers with large clamps are only available for the 38 and 56 pin size connectors. 6) Metal covers with side entry may be converted to top entry by removing side plate and changing clamp orientation. 7) Covers may be ordered separately. 8) Insulator design prevents improper mating of individual plug and receptacle. Polarizing hardware enables specific plug and receptacle mating combinations. CRIMP CHARACTERISTICS ● ● ● ● Contacts and Crimp Tools Accommodate from 28 AWG to 18 AWG, Solid or Stranded Conductor Diameters from .012" (0.30mm) to .049" (1.25mm) and an Insulation Diameter up to .074" (1.88mm) Multiple Smaller Gauge Wires may be Crimped Together Crimp Resistance from 0.5 Milliohms (18 AWG) to 1.5 Milliohms (28AWG) Crimp Tensile Strength for Wire Sizes http://edac.net/en/Online/detail.cfm?ID=48 (3 of 4)03/02/2005 03:59:39 ã EDAC Canada - Online Catalogue 18 AWG - 40 lbs (178 N) 20 AWG - 25 lbs (111 N) 22 AWG - 15 lbs (67 N) 24 AWG - 10 lbs (44 N) 26 AWG - 5 lbs (22 N) 28 AWG - 3 lbs (13 N) POLARIZING CODES ● ● ● Polarizing Hardware Changes allow 288 Mating Combinations Standard Code Supplied for Plugs PG1G1, for Receptacles RS1S1. Connectors with Special Polarizing Codes Available upon Request Example Polarizing Code: P G 4 S 2 Type of Connector = P P - Plug, R - Receptacle Large Diameter Hardware = G G - Guide Pin (at Contact Position "A" End) H - Guide Pin (at Last Contact Position End) S - Socket (at Contact Postion "A" End) T - Socket (at Last Contact Position End) Position of Large Diameter Keyway - 1 through 6 = 4 Small Diameter Hardware (Opposite End from Large Diameter) = S G - Guide Pin, S - Socket Position of Small Diameter Keyway - 1 through 6 = 2 This Example Mates with Code RS4G2 Connector Sizes and Dimensions For more information on these products, please contact us at "edac@edac.net", or visit our "Custom Solutions" page to help us better understand your needs. Home | About Us | Reps & Distributors | ISO 9001 Quality Assurance | Contact Us | Online Catalogue Press Releases | Sample Order Form | Product Search | Custom Solutions | User Sign-In | Site Map http://edac.net/en/Online/detail.cfm?ID=48 (4 of 4)03/02/2005 03:59:39 ã
516-280-300-001 价格&库存
很抱歉,暂时无法提供与“516-280-300-001”相匹配的价格&库存,您可以联系我们找货
  • 1+369.369501+47.04400
  • 5+298.945105+38.07450
库存:12
