516-280-600
516-280-600
    INSERTION TOOL RACK & PANEL
516-280-600 数据手册
TOOLS FOR 516 SERIES CONTACTS AND CONNECTOR Crimp Tools, Contact Insertion and Ejection Tools, Round Nut Driver CONTACT CRIMP MACHINE ● ● ● ● ● ● Part Number 516-280-100 Crimps Contact Part Number 516-290-591 Guards and Microswitches for Operator Safety Easy Access for Quick Crimp Setting Changes Foot Switch Operation to Initiate Machine Cycle Cycle Speed Control (with Set-up Speed Option) on Circuit Board ● Each Cycle Crimps Contact, Cuts the Contact Away from the Carrier and Feeds a New Contact into Position ● Separate Crimp Settings for Conductor and Insulation ● Infinite Adjustment to Crimp Setting Between 18 and 28 AWG ● High Mechanical Advantage with Reliable Toggle Action for Precise Crimp Dimensional Control, 1" (25.4) Die Stroke, Effective Capacity 3 Tons (9.8 kN) ● Mounts with Bolts to any Bench Surface ● 80 psi (552 kPa) Minimum Air Supply and 117 V, 50/60 Hz Electrical Supply Required, Step Down Voltage Tranformers Available upon Request CONTACT HAND CRIMP TOOL (1) ● ● ● ● ➊ Part Number 516-280-200 Crimps Contact Part Number 516-290-590 Precise Tool for Hand Crimping Loose Contacts Built-in Rachet to Prevent Under Crimping CONTACT EJECTION TOOL (2) ➌ ● Part Number 516-280-300 ● For Use with All 516 Series Contact Styles ● Provides Easy Positive Ejection without Damage to the Insulator ➋ CRIMP CONTACT INSERTION TOOL (3) ● Part Number 516-280-400 ● For Installing 516-290-590 & -591 Crimp Contacts ● Wire Groove Locates the Tool onto the End of the Crimp Form ➍ ➎ POLARIZING HARDWARE ROUND NUT DRIVER (4) ● Part Number 516-280-500 ● For Removing and Tightening Round Nuts when Changing Orientation of Metal Polarizing Guide Pins and Sockets WIRE WRAP & P.C. TAIL CONTACT INSERTION TOOL (5) ● Part Number 516-280-600 ● For Installing 516-290-520, -540, -541 & -542 Contacts ● Slender Tube Protects Contact Tail during Insertion without Interferring with Adjacent Contacts Page 96 Tel: (416) 754 - 3322
516-280-600 价格&库存
很抱歉,暂时无法提供与“516-280-600”相匹配的价格&库存,您可以联系我们找货
  • 1+498.644201+64.54240
  • 5+462.142435+59.81776
  • 10+447.2666010+57.89230
  • 25+428.3599025+55.44510
库存:5
516-280-600
