VDV205-039
VDV205-039
    KLEINTOOLS
    DIESET,INS.PINTERMS.ORNON-
VDV205-039 数据手册
VOICE/DATA/VIDEO Testers & Tools VOICE/DATA/VIDEO TESTERS & TOOLS VDV 1 PREPARATION CUT STRIP Klein Tools® introduces an extensive line of Voice/Data/Video (VDV) Testers and Tools that meet or exceed the needs of professionals. This new line of VDV Testers and Tools helps prepare, connect and test CATV, home theater, satellite, network, phone and security systems. PREP.............pages 4-10 CONNECT......pages 11-17 TEST.............pages 18-22 TOOLS..........pages 23-34 KITS..............page 35 2 CONNECTION 3 TESTING IDENTIFY VERIFY CRIMP TERMINATE VOICE/DATA/VIDEO PREP Voice/Data/Video Prep Electrician’s Scissors Stainless Steel Electrician’s Scissors – Stripping Notches  tainless steel blades to maintain blade • Sdurability and sharpness. • Notched upper blade for stripping 19 AWG & 23 AWG wire. • Blade is fully serrated for non-slip cutting action. • Free-fall snip feature for ease of use (2100-8). • Cuts electrical communication 19 AWG - 23 AWG wire. handle provides comfort and cutting leverage • Eforxtended wire cutting application (2100-8). • 56 HRC. Cat. No. 2100-7* 2100-8 2100-9 2101-1* Overall Length 5-1/4" (133 mm) 6-5/16" (160 mm) 5-1/4" (133 mm) 1-7/8" (48 mm) Cutting Length Weight (lbs.) 1-7/8" (48 mm) 1-7/8" (48 mm) 1-7/8" (48 mm) 6-5/16" (160 mm) .20 .21 .21 .21 2100-9 2100-8 * Nickel-plated carbon steel blades. All dimensions are in inches and (millimeters). 4 WARNING: Read carefully and understand instructions before using this tool. WARNING: NOT insulated. WARNING: Always wear approved eye protection. WARNING: Never use on or near live electrical circuits. Will NOT protect against electrical shock. Multi-Cable Cutter • Hardened steel precision-ground cutting blades for long life. opper curved cutter cleanly cuts round copper cable without • Ccompression or frayed ends. nvil cutter for solid and stranded copper wire up to 12 AWG • Aand stainless steel up to .032" (.81 mm) diameter. M  ild • steel cutter for conductors up to .080" (2 mm) diameter. cutter for solid and stranded copper wire • Cupurved to 8 AWG, multi-conductor cable • • 63020 up to 1/2" (13 mm) diameter and coaxial cable RG-6 Quad, RG-59, and RG-62. Coil spring provides fast self-opening action. Handy closure lock for convenient storage. Cat. No. Overall Length Screw Shearing Handle Color Weight (lbs.) 63020 7" (177 mm) 6-32 & 8-32 red .44 Cable Cutters — Coaxial able-gripping jaws quickly score jacket and insulation, • Cand easily cut through copper inner conductor. lades cleanly cut aluminum and copper coaxial cable • Bwithout compression and frayed ends. orged body with heat-treated and precision-ground steel • Fblades, withstands frequent cutting. H  ot-riveted design requires no adjustment while maintaining • a smooth, precise operation. H  andles are plastic-coated for maximum comfort and • gripping power. hen cutting drop wire with an inner steel conductor, • W we recommend Cat. No. D2000-28 diagonal-cutting pliers. 63028 VOICE/DATA/VIDEO PREP Cable Cutters 63030 WARNING: Do NOT use to cut steel or ACSR. Cat. No. Overall Length Soft Cable-Cutting Maximum Capacity Handle Color Weight (lbs.) 63028 8-1/4" (216 mm) .75" (19 mm) diameter yellow .80 63030 8-1/4" (216 mm) 1" (25 mm) diameter blue .83 Compact Cable Cutter recise, one-hand shearing action cuts 24 AWG copper, aluminum • Pmulti-strand cable and wire, and 100-pair telephone cable. pecial shear angle cuts cleanly without compression to cable • Sgeometry for telecom cable work. • Heat-treated, high-carbon steel shearing edges for long life. • Forged body with 3/8" (10 mm) case-hardened rivet. • Plastic-dipped handles for comfort. • Not designed for cutting steel or ACSR. 63055 WARNING: Do NOT use to cut steel or ACSR. Cat. No. Overall Length Maximum Cable Cutting Capacity Handle Color Weight (lbs.) 63055 8" (203 mm) 24 AWG copper, aluminum multi-strand cable and wire, and 100-pair telephone cable red .65 All dimensions are in inches and (millimeters). WARNING: Read carefully and understand instructions before using this tool. WARNING: NOT insulated. WARNING: Always wear approved eye protection. WARNING: Never use on or near live electrical circuits. Will NOT protect against electrical shock. 5 VOICE/DATA/VIDEO PREP Voice/Data/Video Tools Radial Stripper UTP/STP • One-step outer jacket stripping, 1-level, of category 3, 5, 5e, and 6 cables. • Durable high-carbon steel cutting blades are ground and honed for long life. emoves the outer jacket of twisted pair cable without • Rdamaging the conductors. trip and slit lengths may be varied to accommodate different • Sconnector requirements. • Recessed cutting surface slits long runs of twisted-pair cable. ultiple nest cavities allow the removal of a wide • M variety of jacket materials on twisted-pair cable. • Tension loop can be disengaged for thin-jacket cable. • One-piece construction ensures alignment for precise stripping. • Large finger loop promotes rotation during use. • Adjustable set-screw prevents twisted-pair conductor insulation scoring. • Bright, highly visible color for easy identification. UTP VDV120-006 Twisted Pair Cable STP Level(s) Cat. No. Color Strips or Slits VDV120-006 yellow unshielded twisted pair shielded twisted pair 1 Strip/Slit Dimensions Prepared Cable strip length varies by application Overall Length Weight (oz.) 4.4" (112 mm) 1.3 Coax Cable Stripper – 2-Level, Radial • Designed for easy single operation cable preparations. xclusive sliding depth gauge for easy debris clean-out • Eand variable stripping capability. D urable steel pre-set cutting-blades for precise, • accurate high-carbon cable stripping. • 2-level coaxial preparation – 5/16" x 1/4" (7.9 mm x 6.4 mm). • Finger loop promotes rotation during use. • Bright, highly visible color for easy identification. VDV110-061 Coax Cable 2 Level R59 RG6 RG6-QS Cat. No. Color Levels Strip Dimensions VDV110-061 yellow/black 2 5/16" x 1/4" (7.9 mm x 6.4 mm) Blade Configuration Prepared Cable Overall Length Weight (oz) 4.6" (116 mm) 1.2 All dimensions are in inches and (millimeters). 6 WARNING: Read carefully and understand instructions before using this tool. WARNING: NOT insulated. WARNING: Always wear approved eye protection. WARNING: Never use on or near live electrical circuits. Will NOT protect against electrical shock. Dual Cartridge Radial Stripper – 2 & 1 Level • 2-level coaxial preparation of 5/16" x 1/4" (7.9mm x 6.4mm). trips outer jacket of Unshielded Twisted-Pair (UTP) • Scables (category 3, 5, 5e and 6), 1-level preparation. • Designed for high-volume, multiple-type cable preparation environments. • Two "active" stripping cartridge-bays and third "storage" cartridge-bay. • One-piece construction ensures precise stripping and never requires adjustment. • Large finger loop promotes rotation during use. • Cartridges snap in from both sides for left or right-handed operation. • F-Connector "nest" assists with cable insertion. • Durable high-carbon steel cartridge cutting blades are ground and honed for long life. • Durable Delrin® resin for outstanding wear. Delrin is a registered • Replacement cartridges available. trademark of DuPont. VDV100-801 ® Cat. No. Twisted Pair Cable Overall Length Weight (oz.) Set Contains VDV100-801 5.6" (143 mm) Cat. No. RG6 RG59 RG6 QS UTP Description Color Level(s) Strip Dimensions Blade Configuration VDV100-001 dual cartridge radial yellow – stripper frame VDV110-003 RG59/RG6/RG6 black 2 QS coaxial cable 5/16" x 1/4" (7.9 mm x 6.4 mm) VDV120-005 UTP cable variable blue – 1 – – VDV110-802 ® Set Contains VDV110-802 Cat. No. RG6 RG6-QS RG59 Cat. No. Description VDV100-002 radial cartridge stripper frame VDV110-003 RG59/RG6/RG6 QS coaxial cable Color Level(s) Strip Dimensions Blade Configuration Prepared Cable – – yellow – – black 2 5/16" x 1/4" (7.9 mm x 6.4 mm) Coax Cable 3 Level Coax Cable 2 Level Overall Length Weight (oz.) 5.2" (133 mm) 2.1 Set Contains VDV113-804 Cat. No. RG58 RG59 RG62 Description Color VDV100-002 radial cartridge yellow stripper frame VDV113-021 RG58/RG59/RG62 green coaxial cable Level(s) Strip Dimensions Blade Configuration – – 3 0.235" x 0.235" x variable (6 mm x 6 mm x variable) 2.4 Prepared Cable Radial Cartridge Strippers -level coaxial preparation of 5/16” x 1/4” (7.9 mm x 6.4 mm) • 2(Cat. No. VDV110-802). 3  -level coaxial preparation of 0.235" x 0.235" (6 mm x 6 mm) • and trimming center conductor to desired length (Cat. No. VDV113-804). D  esigned for high-volume, cable preparation environments. • "  Active" stripping cartridge-bay and second "storage" cartridge-bay. • • One-piece construction ensures precise stripping and never requires adjustment. • Large finger loop promotes rotation during use. • Cartridges snap in from both sides for left or right-handed operation. steel cartridge cutting blades are ground and honed for long life. • Durable high-carbon • Durable Delrin® resin for outstanding wear. Delrin is a registered • Replacement cartridges available. trademark of DuPont. Cat. No. Coax Cable 2 Level – VOICE/DATA/VIDEO PREP Voice/Data/Video Tools Overall Length Weight (oz.) 5.2" (133 mm) 2.1 Prepared Cable – All dimensions are in inches and (millimeters). WARNING: Read carefully and understand instructions before using this tool. WARNING: NOT insulated. WARNING: Always wear approved eye protection. WARNING: Never use on or near live electrical circuits. Will NOT protect against electrical shock. 7 VOICE/DATA/VIDEO PREP Voice/Data/Video Tools Radial Stripper Cartridges Designed for use with: Dual Cartridge Radial Stripper (Cat. No. VDV100-801) Dual Cartridge Radial Stripper Frame (Cat. No. VDV100-001) Radial Cartridge Stripper (Cat. Nos. VDV110-802 & VDV113-804) Radial Cartridge Stripper Frame (Cat. No. VDV100-002) VDV110-003 re-set cutting blades for precise, accurate • Pand efficient cable stripping. D urable high-carbon steel cutting blades are • ground and honed for long life. P atented "V" notch eliminates scoring of the • center conductor.* • Color coded for easy identification. eets industry standards established by the SCTE • M (Society of Cable Telecommunication Engineers). made from glass filled polycarbonate • Cforartridges superior strength and extended durability. Coax Cable 2 Level VDV110-004 VDV110-020 Mini Coax Cable 2 Level Coax Cable 3 Level *All cartridges except for VDV120-005. VDV113-022 VDV113-021 Twisted Pair Cable 1 Level VDV120-005 Cable Illustration Cartidge Detail Weight (oz.) Cat No. Cable Color Level Cartridge Strip Dimensions VDV110-003 RG59/RG6/RG6 QS coaxial cable black 2 5/16" x 1/4" (7.9 mm x 6.4 mm) 0.1 VDV110-004 RG7/RG11 coaxial cable gray 2 5/16" x 1/4" (7.9 mm x 6.4 mm) 0.1 VDV120-005 UTP cable (category 3, 5, 5e and 6) blue 1 variable 0.1 VDV110-020 mini-coaxial cable green 2 1/4" x 1/4" (6.4 mm x 6.4 mm) 0.1 VDV113-021 RG58/RG59/RG62 coaxial cable green 3 0.235" x 0.235" x variable (6 mm x 6 mm x variable) 0.1 VDV113-022 RG58/RG59/RG62 coaxial cable brown 3 0.109" x 0.312" x variable (2.8 mm x 7.9 mm x variable) 0.1 All dimensions are in inches and (millimeters). 8 WARNING: Read carefully and understand instructions before using this tool. WARNING: NOT insulated. WARNING: Always wear approved eye protection. WARNING: Never use on or near live electrical circuits. Will NOT protect against electrical shock. Katapult® Coaxial Cable Stripper • Quick and easy RG6 coaxial cable stripping. action cable stripping – grip and strip • Cviaompound single action squeezing motion. recision, machined steel cutting blades • Pcleanly and easily strip RG6 coaxial cable. ension loaded wire-grip gently holds the • Tcable in place while retaining the cable geometry. R ecoil spring design returns tool to ready position • upon cycle completion. C ast alloy chassis with heavy-duty Ecoat finish • for corrosion resistance and durability. • Yellow grips enhance comfort and visibility, and allow quick identification. atapult® Wire Stripper – 8 – 22 AWG (Cat. No. 11063), • Kwire stop/gauge and replacement blade sets are also available. ® RG6 Cat. No. Color Strips Level(s) Overall Length Weight (oz.) VDV110-045 yellow/black RG6 1 center condutor, 1 outer jacket 6.6" (168 mm) 12.1 VDV110-045 Replacement Blades Sets VDV110-046 RG6 coaxial cable replacement blades .01 11073 8 – 22 AWG wire stripping blades .01 11074 16 – 26 AWG (1.0 mm2 – .14 mm2) .01 adjustable wire stop .01 Coax Cable Wire Stop/Gauge 11081 VOICE/DATA/VIDEO PREP Voice/Data/Video Tools Telecom Tools Diagonal Bell-System Pliers – “W” & “V” Notches • “W” notches to cleanly slit insulation. • “V” notch at the hinge for quick insulation crushing. • Tapered nose for easy working in confined areas and close tip cutting. Cat. No. Overall Length Jaw Length Jaw Width Jaw Thickness Cutting Knives Handle Finish Handle Color Weight (lbs.) D528V 13/16" (21 mm) 9/16" (14 mm) 3/8" (10 mm) standard plasticdipped red .20 5-3/16" (132 mm) D528V Diagonal Telephone Work Pliers – Type D-6 • Tapered nose for easy working in confined areas and close tip cutting. • Convenient .030" and .045" stripping holes. • “V” stripping notch in jaw for quick insulation slitting. • Serrated behind the hinge to crush insulation. Cat. No. Overall Length Jaw Length Jaw Width Jaw Thickness Cutting Knives Handle Finish Handle Color 72192 6-1/8" (156 mm) 13/16" (21 mm) 3/4" (19 mm) 7/16" (11 mm) standard plastic-dipped red Weight (lbs.) 72192 .33 All dimensions are in inches and (millimeters). WARNING: Read carefully and understand instructions before using this tool. WARNING: NOT insulated. WARNING: Always wear approved eye protection. WARNING: Never use on or near live electrical circuits. Will NOT protect against electrical shock. 9 VOICE/DATA/VIDEO PREP Telecom Tools Long-Nose Telephone Work Pliers – Stripping • Cleanly strips 22 (.34 mm2) to 24 (.25 mm2) AWG wire. • Convenient insulation crushing slot. • Curved handles provide greater tool control. Cat. No. Overall Length Jaw Length Jaw Width Jaw Thickness Point Thickness Handle Finish Handle Color Weight (lbs.) D2291 6" (152 mm) 1-1/4" (32 mm) 11/16" (18 mm) 3/8" (10 mm) 1/16" x 3/32" (1.6 mm x 2 mm) plasticdipped yellow .25 D2291 Long-Nose Telephone Work Pliers – Type L1 • Knurled jaw tips for greater gripping power. • Induction hardened side-cutting knives for long life. • Convenient .030" stripping hole. • Curved handles provide greater tool control. Cutting Knives Cuchillas Cat. No. Type Overall Length Jaw Length Jaw Width Jaw Thickness Knife Length Point Couteaux Thickness Handle Finish Handle Color Weight (lbs.) 71980 1-7/8" (48 mm) 11/16" (18 mm) 3/8" (10 mm) 1/2" (13 mm) 1/16" x 3/32" (1.6 mm x 2 mm) plasticdipped yellow .25 L1 6-5/8" (168 mm) 71980 Standard Long-Nose Pliers – Switchboard Work • Cleanly strips 19 & 22 AWG wire. • Induction hardened, long-lasting cutting knives. • Knurled jaws for sure wrapping and looping. • Curved handles provide greater tool control. Cutting Knives Cat. No. Overall Length Jaw Length Cuchillas Jaw Width Jaw Thickness Knife Length Point Thickness Handle Finish Handle Color Weight (lbs.) Couteaux D203-6H2 6-5/8" (168 mm) 1-7/8" (48 mm) 11/16" (18 mm) 3/8" (10 mm) 1/2" (13 mm) 3/32" (2 mm) plastic-dipped yellow D203-6H2 .26 Industrial Utility Snips High-Leverage Kevlar® Snip Spring Action Snip 24000 ickel chrome plating • Nresists corrosion and rusting. • One blade is serrated for non-slip cutting action. • Spring loaded for self opening action. • Handy closure lock for convenient storage (24000, 24001). • Compatible for right- and left-handed users. xcellent for cutting Kevlar® insulation in • Efiber optic applications (24000, 24001). • Excellent for cutting electronics and filaments (24005). Cat. No. Overall Length Cutting Length Weight (lbs.) 24000 24001 24005 6-1/2" (165 mm) 6-1/2" (165 mm) 5" (127 mm) 5/8" (16 mm) 1" (25 mm) 1" (25 mm) .28 .28 .22 24001 5" Electronic Filament Snip 24005 Kevlar® is a registered trademark of E.I. du Pont de Nemours and Company. All dimensions are in inches and (millimeters). 10 WARNING: Read carefully and understand instructions before using this tool. WARNING: NOT insulated. WARNING: Always wear approved eye protection. WARNING: Never use on or near live electrical circuits. Will NOT protect against electrical shock. Compression Crimper – Lateral, Multi Connector ne tool crimps most connectors to most coaxial cables – • OMinicoax, RG58, RG59, RG62, RG6, RG6QS, RG7, and RG11. U nique cable wheel eliminates the need to • change plungerselection tips saving time and not losing parts. eavy-duty zinc die-cast chassis for durable, • Hlong lasting performance. pen design with 180˚ capture mechanism provides easy • Oinsertion, complete compression and simple removal. • Integrated handle lock for easy storage. • Spring loaded return increases user comfort and ease of use. ellow and black contoured grips enhance comfort, • Yvisibility and allow quick identification. F Connector Mini-Coax BNC Connector R59 RCA Connector RG6 VOICE/DATA/VIDEO CONNECT Voice/Data/Video Connect VDV211-063 Coax Cable RG6-QS Cat. No Color Type Cable Connectors Overall Length Weight (oz.) VDV211-063 yellow/black compression crimper coaxial BNC F RCA 6.25" (158 mm) 18.5 All dimensions are in inches and (millimeters). WARNING: Read carefully and understand instructions before using this tool. WARNING: NOT insulated. WARNING: Always wear approved eye protection. WARNING: Never use on or near live electrical circuits. Will NOT protect against electrical shock. 11 VOICE/DATA/VIDEO CONNECT Voice/Data/Video Tools Compression Crimper − Compact, Multi-Connector • Fast, reliable multiple-type compression connector installations. • Crimps compression BNC, F and RCA connectors to coaxial cable. teel body with chrome finish resists corrosion • Sand extends tool life. universal plunger ensures accurate crimps • Aondjustable multiple types of connectors. pen design with 180˚ capture mechanism provides • Oeasy insertion, complete compression and simple removal of cable and connector. Compact tool with integrated handle lock for easy storage. Enhanced pivot point for smooth wobble free operation. Spring loaded return increases user comfort and ease of use. Intergrated F-connector "nest" assists with cable insertion. Yellow contoured grips enhance comfort, visibility and allow quick identification. VDV211-048 • • • • • F Connector Mini-Coax BNC Connector R59 RCA Connector RG6 Coax Cable RG6-QS Cat. No Color Type Cable Connectors Overall Length Weight (oz.) VDV211-048 yellow/chrome compression crimper coaxial BNC F RCA 5.6" (142 mm) 8.0 Compression Crimper – Vertical, Multi-Connector ast reliable tool for CATV, Home Theater, Satellite • Fand Security System applications where multiple-type connector installations are required. Crimps compression BNC, F and RCA connectors to minicoax RG59, RG6, and RG6-Quadshield coaxial cables. Vertical design for easy adjustment, insertion, crimping and removal of cable and connector. Adjustable universal plunger tips and crimp-height with locking-nut ensure accurate crimps on multiple types of connectors. Measuring guide beneath the plunger makes replicating the same compression setting efficient. Ratchet mechanism is designed to prevent the release of the connector prior to full compression. • • • VDV211-007 • • F Connector Mini-Coax R59 RG6 RG6-QS BNC Connector RCA Connector Coax Cable Cat. No. Color Type Cable Connectors Overall Length Weight (oz.) VDV211-007 yellow/black compression crimper coaxial BNC, F and RCA 7.8 (197 mm) 15.3 All dimensions are in inches and (millimeters). 12 WARNING: Read carefully and understand instructions before using this tool. WARNING: NOT insulated. WARNING: Always wear approved eye protection. WARNING: Never use on or near live electrical circuits. Will NOT protect against electrical shock. Compact, F-Connector • Fast, reliable F-Connector installation tool. teel body with black-oxide finish for corrosion • Sresistance and durability. F ixed plunger allows quick, easy insertion and • removal of cable and connector. • Fixed plunger accepts many common F-connector compression fittings. • Compact tool with integrated handle lock. • Yellow and black grips enhance comfort, visibility and allow quick identification. • Spring loaded return increases user comfort and ease of use. Mini-Coax R59 RG6 VDV212-008 RG6-QS F Connector Coax Cable Cat. No. Color Type Cable Connectors Overall Length Weight (oz.) VDV212-008 yellow/black compression crimper coaxial common F connectors 5.6" (142 mm) 9.8 Coaxial Cable All-In-One Tool achined steel cutting blades cleanly and • M easily cut RG6 and RG59 coaxial cable. iamond-shaped stripping nests efficiently • Dremove outer jacket of coaxial cable. recision ground stripping hole easily • Premoves inner dielectric insulation without damaging the center conductor. Two hex-crimping dies and a ring-crimping die quickly and accurately crimp connectors to coaxial cable. High carbon-steel body with black-oxide finish for corrosion resistance and durability. Yellow grips enhance comfort and visibility, and allow quick identification. • VDV010-019 • • R59 Hex BNC Connector RG6 HEX F Connector Coax Cable Coax Cable Cat. No. Color Type Cable Connectors Overall Length Weight (oz) VDV010-019 yellow/black cutter, stripper, hex-crimper coaxial BNC and F 8.5" (216 mm) 7.5 Cushion-Grip F-Connector Insertion/ Extraction Tool /8"-32 Threaded end holds • 3standard F-Connectors for cable insertion. 5 " long shaft with 7/16" socket extends reach • for connecting/removing F-connectors. • Cushion-Grip handle for greater torque and enhanced comfort. • Precision machined high-carbon steel is hardened for long life. • Durable chrome finish resists corrosion and extends tool life. VOICE/DATA/VIDEO CONNECT Voice/Data/Video Tools VDV312-012 F Connector Cat. No. Color Shank Tip Handle Tip Shank Length Finish Overall Length Weight (oz.) VDV312-012 yellow/black 7/16" open socket 3/8"-32 threaded male F-connector 5" (127 mm) chrome-plated 8.8" (222 mm) 7.5 All dimensions are in inches and (millimeters). WARNING: Read carefully and understand instructions before using this tool. WARNING: NOT insulated. WARNING: Always wear approved eye protection. WARNING: Never use on or near live electrical circuits. Will NOT protect against electrical shock. 13 VOICE/DATA/VIDEO CONNECT Voice/Data/Video Tools Ratcheting Crimper with Coaxial Hex-Crimp Die Set rofessional CATV, Electrical, Home-Theater, • PSatellite and Security System crimper is perfect for fast, reliable connector installations. recision full-cycle ratchet action assures • Pcomplete precise crimp every cycle. • Crimps meet or exceed UL Standards, where applicable. teel body with black-oxide finish for corrosion resistance • Sand durability. • Preset tension for optimum performance. ies manufactured from heat treated high-carbon steel for • Dexcellent performance and long life. • Quick change interchangeable die-sets. humb-screws secure die-sets for quick easy changes. • T(Optional Phillips screws available, see table below.) VDV212-034 crimp release helps eliminate rejected terminations due • Stoafety incorrect positioning. • Ratchet mechanism is designed to prevent the release of the connector prior to full compression. • Yellow and black grips enhance comfort, visibility, and allow quick identification. Cat. No. Set Contains: VDV212-803 Cat. No. Description Color Nest Dimensions Connector Type VDV212-034 hex crimp RG59/6 coaxial cable F-connectors black 0.255"/0.320"/0.350" 6.48/8.13/8.89 mm hex crimp BNC hex crimp F VDV200-010 VDV999-033 VDV205-035 VDV201-040 VDV205-036 VDV211-041 VDV211-037 VDV201-042 VDV212-803 Hex BNC Connector Coax Cable HEX F Connector Overall Length Weight (oz.) 8.8" (224 mm) 21.0 VDV211-038 VDV211-043 VDV205-039 VDV205-044 Cat. No. Description Nest Dimensions VDV200-010 VDV999-033 VDV212-034 VDV205-035 VDV205-036 VDV211-037 VDV211-038 VDV205-039 VDV201-040 VDV211-041 VDV201-042 VDV211-043 VDV205-044 ratcheting crimper frame (yellow/black) replacement screw set (pair thumb and pair Phillips) hex crimp RG59/6 coaxial cable F-connectors Insulated terminals, AWG 10-22 non-insulated terminal or open barrel terminal, AWG 10-20 hex crimp Connectors RG6/58/59/62 coaxial cable hex crimp RG58/59/62 coaxial cable insulated pin terminal or non-insulated ferrules, AWG 12-22 RG58/59/62/174 coaxial cable and fiber optic RG58/59/62/6 coaxial cable RG174/179/Belden 8218 coaxial cable and fiber optic RG8/11/174/179/213 non-insulated terminal, AWG 8-18 – – 0.255"/0.320"/0.350" (6.48/8.13/8.89 mm) AWG 22-18/16-14/12-10 (DIN 0.5-1.0/1.5-2.5/4-6 mm2) AWG 20-18/16-14/12-10 (DIN 0.5-1/1.5-2.5/4-6 mm2) 0.256"/0.319"/0.068"/0.213" (6.50/8.10/1.73/5.41 mm) 0.256"/0.068"/0.213" (6.50/1.73/5.41 mm) AWG 22/20/18/16/14/12 (DIN 0.5/0.75/1.0/1.5/2.5/4 mm2) 0.043"/0.068"/0.100"/0.137"/0.213"/0.255" (1.09/1.73/2.54/3.48/5.41/6.48 mm) 0.255"/0.213"/0.098"/0.068"/0.321" (6.48/5.41/2.49/1.73/8.15 mm) 0.042"/0.068"/0.078"/0.128"/0.151"/0.178" (1.07/7.73/1.98/3.25/3.84/4.52 mm) 0.100"/0.128"/0.429" (2.54/3.25/10.90 mm) AWG 18-16/14/12-10/8 (DIN 0.75-1.5/2.54/4-6/10 mm2) All dimensions are in inches and (millimeters). 14 WARNING: Read carefully and understand instructions before using this tool. WARNING: NOT insulated. WARNING: Always wear approved eye protection. WARNING: Never use on or near live electrical circuits. Will NOT protect against electrical shock. Punchdown Multi-Tool atent pending locking impact mechanism • Pallows non-impact operation and sure driving with a variety of optional WorkEnds™ driver bits. erminate and cut wire in one step with included • Tprecision ground combination 66 & 110 blade. ntegrated Hook and Spudger for fast, easy • Imanipulation of wire and small components. • Selectable (Hi/Low) impact-force settings meet industry standards. • Spring loaded for fast, low effort seating and terminating. ual material contoured chassis provides greater control • Dand enhances comfort. VDV427-807 lade storage compartment with spring loaded • Blocking mechanism. • Color coded yellow on the cut side of the tool. and Spudger neatly and compactly store • Hinook the chassis, out of the way when not in use. Twisted Pair Cable hardened high-carbon steel • Induction for durability and long life. at. No, VDV427-807 Includes WorkEnds™ Kit • Cwith WorkEnds™ adapter, reach extension, and 4 driver bits (#1 and #2 Phillips and 3/16" and 1/4" Slotted) in a convenient carrier. • Replacement blades/accessories available. Integrated Hook and Spudger for fast, easy manipulation of wire and small components. Cat. No Set Contains Overall Length Weight (oz.) VDV427-806 punchdown multi-tool with 110/66 blade 7.0" (176 mm) 5.6 7.88" (200 mm) 7.5 VDV427-807 Cat. No. Color Description Blade Configuration End 1 Blade Configuration End 2 VDV427-047 yellow/red/black punchdown multi-tool chassis – – VDV427-017 black punchdown tool blade combination 66/110 cut type 110 terminate & cut 66 terminate & cut Blade Configuration End 1 Blade Configuration End 2 punchdown multi-tool with 110/66 blade & WorkEnds™ Cat. No. Color Description VDV427-047 yellow/red/black punchdown multi-tool chassis - - VDV427-017 black punchdown tool blade combination 66/110 cut type 110 terminate & cut 66 terminate & cut VDV770-050 – WorkEnds™ kit – – VOICE/DATA/VIDEO CONNECT Voice/Data/Video Tools All dimensions are in inches and (millimeters). WARNING: Read carefully and understand instructions before using this tool. WARNING: NOT insulated. WARNING: Always wear approved eye protection. WARNING: Never use on or near live electrical circuits. Will NOT protect against electrical shock. 15 VOICE/DATA/VIDEO CONNECT Voice/Data/Video Tools Impact Punchdown Tools erminate cable in variety of cross-connect panels, • Tblocks and keystone jacks. • Spring loaded for fast, low effort seating and terminating. electable (Hi/Low) impact-force settings meet • Sindustry standards. ubber finger grips and boot provide greater control • Rand enhanced comfort. B  lade storage compartment with spring loaded locking mechanism. • C  olor coded yellow on the cut side of the tool. • B  ayonet style (twist & lock) socket accepts most manufacturers’ tools and blades. • I  nduction-hardened high-carbon steel for durability and long life. • R  eplacement blades available. • Cat. No. VDV427-800 Twisted Pair Cable Overall Length Weight (oz.) Set Contains: VDV427-800 7.0" (177 mm) Component No. Color VDV427-013 VDV427-017 yellow/black impact punchdown tool black punchdown tool blade combination 66/110 cut type Cat. No. Description Blade Configuration End 1 Blade Configuration End 2 – 66 terminate & cut – 110 terminate & cut Overall Length Weight (oz.) 7.1" (180 mm) 5.6 Set Contains: VDV427-805 Description Component No. Color Blade Configuration End 1 VDV427-013 VDV427-015 yellow/black impact punchdown tool – black punchdown tool blade - 110 type 110 terminate Punchdown Tool Blades & Accessories ompatible with Impact Punchdown Tool • C(VDV427-013), Punchdown Multi-Tool • • • • • 5.7 Blade Configuration End 2 – 110 terminate & cut VDV427-016 VDV427-015 (VDV427-047) and other bayonet style (twist & lock) socket punchdown tools. Terminate cable in variety of cross-connect panels, blocks and keystone jacks. Induction-hardened high-carbon steel for durability and long life. Reversible blades with termination/cutting ends and termination only ends (depending on blade type). Precision ground cutting-edge for clean, precise wire termination (depending on blade type). WorkEnds™ Kit converts the Punchdown Multi-Tool chassis (VDV427-047) into a multi-bit driver. Kit includes: WorkEnds™ adapter, reach extension, and 4 driver bits (#1 and #2 Phillips and 3/16” and 1/4” Slotted) in a convenient carrier.† VDV427-017 VDV427-018 Twisted Pair Cable VDV770-050† Cat. No. Color Description Blade Configuration End 1 Blade Configuration End 2 Overall Length Weight (oz.) VDV427-015 black punchdown tool blade – 110 type 110 terminate 110 terminate & cut 2.1" (52 mm) 0.5 VDV427-016 VDV427-017 VDV427-018 VDV770-050 black black black – punchdown tool blade – 66 type punchdown tool blade – combination 66/110 cut type punchdown tool reach extension WorkEndsTM adapter, reach extension, and 4 driver bits (#1 and #2 Phillips and 3/16" and 1/4" Slotted) in a convenient carrier† 66 terminate 66 terminate & cut bayonet style male proprietary magnetic hex 66 terminate & cut 110 terminate & cut bayonet style female 1/4" female hex 2.3" (58 mm) 2.2" (56 mm) 2.6" (67 mm) 3.2" (81 mm) 0.6 0.6 1.2 1.4 †WorkEnds™ is not compatible with VDV427-013, VDV427-800, VDV427-805. All dimensions are in inches and (millimeters). 16 WARNING: Read carefully and understand instructions before using this tool. WARNING: NOT insulated. WARNING: Always wear approved eye protection. WARNING: Never use on or near live electrical circuits. Will NOT protect against electrical shock. Ratcheting Modular Crimper/Stripper reliable modular-crimp connector installation • Fforast,voice and data applications. ll-In-One Tool, cuts, strips and crimps paired-conductor • Acables (round STP/UTP and flat-satin phone cable). rimps 4, 6, and 8 position modular connectors • C(RJ22, RJ11/RJ12 and RJ45). • Crimping dies are precision ground from high-carbon steel. esigned for Western Electric (WE)/Stewart Stamping • D(SS)-type modular connectors. atchet safety-release and a blade-guard on cutting • Rand stripping knives reduce risk of injury. ratchet mechanism prevents the release • Fofull-cycle the connector prior to full compression. ellow and black grips enhance comfort, visibility, • Yand allow quick identification. hree crimping dies: • T8-position, 4-pair/8-conductor - RJ45 VDV226-011 Flat Cable Twisted Pair Cable Modular Connectors RJ22, RJ11/12 and RJ45 6-position, 2-pair/4-conductor - RJ11 & 3-pair/6-conductor - RJ12 4-position, 2-pair/4-conductor & 1-pair/2-conductor – headset RJ22. Cable parameters: 28-22 AWG (.08 - .34 mm2) flat or round; solid or stranded telephone & data. Not for use with AMP® connectors. Replacement blade set available (Cat. No. VDV999-064). • • • AMP® is a registered trademark of TYCO, Inc. Cat. No. Color Cuts & Strips Crimps Connectors Position/Pair/ Conductors Overall Length Weight (oz.) VDV226-011 yellow/black round STP/UTP, flat satin phone cable 22-28 AWG (0.08 - 0.34 mm2) RJ11, RJ12 RJ22 and RJ45 4/1-2/2-4, 6/2-3/4-6, 8/4/8 7.5" (191 mm) 11.3 Connector Crimping Long-Nose Pliers rimps UR/UY/UG insulation displacement • Cconnectors (IDC) – Scotchlok® type connectors. G rooved jaws for wire wrapping, looping and twisting. • C leanly strips 23 AWG and 24 AWG wire. • H ot-riveted joint ensures smooth action • and no handle wobble. • Induction hardened cutting knives for long life. ellow plastic grips enhance comfort, visibility • Yand allow quick identification. VOICE/DATA/VIDEO CONNECT Voice/Data/Video Tools VDV026-049 Scotchlok® is a registered trademark of 3M Corporation. UR IDC UY IDC UG IDC Cat. No Overall Length Jaw Length Jaw Width Jaw Thickness Knife Length Point Thickness Handle Finish Handle Color Weight (oz.) VDV026-049 6.80" (173 mm) 2.00" (51 mm) 0.70" (18 mm) 0.38" (10 mm) 0.44" (11 mm) 0.095 x 0.125 (2.0 x 3.0 mm) plastic-dipped yellow 4.5 Scotchlok® Connector Crimping Pliers • Crimps and seats UG, UR, and UY connectors. • Curved handles for greater control. • Induction hardened side-cutting knives for long life. Cutting Knives *Spring-loaded action for self-opening. Scotchlok® is a registered trademark of 3M. Cat. No. Overall Jaw Jaw Jaw All dimensions are in inches Length Lengthand (millimeters). Width Thickness Cuchillas Couteaux Knife Length Handle Finish D234-6 Handle Color Weight (lbs.) D234-6 5-13/16" 1-3/32" 11/16" 3/8" 1/2" plasticWARNING: Read carefully and understand instructions before using this tool. (148 mm) (28 mm) (18 mm) (10 mm) (13 mm) dipped yellow WARNING: .25 NOT insulated. D234-6C* 5-13/16" 1-3/32" 11/16" 3/8" WARNING: approved eye protection. (148 Always mm) wear (28 mm) (18 mm) (10 mm) yellow 1/2" (13 mm) plasticdipped Will NOT protect against electrical shock. .25 WARNING: Never use on or near live electrical circuits. UR IDC UY IDC UG IDC 17 VOICE/DATA/VIDEO TEST Voice/Data/Video Test All dimensions are in inches and (millimeters). 18 WARNING: Always wear approved eye protection. WARNING: Do NOT use on energized circuits. Coax Explorer™ Tester • Tests and verifies coaxial cable continuity. • C ompact size fits easily into pocket or pouch. • B right LED indicates cable status (good/open/short). • Simple push-button operation. • B atteries included. VDV512-057 Cat. No. Batteries VDV512-057 lithium non- replaceable Height Width Depth 2.7" (69 mm) 1.1" (28 mm) 0.7" 1.3 (18 mm) (37 g) Weight (oz.) Coax Explorer™ Plus Tester • Tests and verifies coaxial cable continuity. • Identifies/maps up to 4 locations. • Color coded remotes simplify identification. • Compact size fits easily into pocket or pouch. • Bright LED indicates status and location of cable. • Simple push-button operation. • Includes convenient remote holder. • Batteries included. Cat. No. Batteries VDV512-058 lithium non- replaceable Height Width 5.6" 1.1" (142 mm) (28 mm) Depth Weight (oz.) VOICE/DATA/VIDEO TEST Voice/Data/Video Test VDV512-058 0.6" 3.3 (16 mm) (94 g) LAN Scout™ Jr. Tester • Tests continuity on twisted pair data wiring (RJ45) connections. • Integrated tone generator supports multiple tones and control of pins carrying tone. • Heavy-duty ports are designed for long life and repeated connections. • Compact, contoured dual-material chassis fits comfortably in your hand. Features RJ-45 8-wire Cables Continuity Testing & Pass TIA-568A/B Crossover/Uplink Apo S VDV526-052 ● ● ● LCD Display ● Wiremap ● Open Fault ● Short Fault ● Miswire Fault ● Split Pair Fault ● Multiple Style Tone Generator Auto Power Off RJ45 Port VDV526-052 ● Self Storing Remote ● Low Battery ● Voltage Warning ● Shield Detection ● Self-Storing Remote ● Cat. No. Batteries VDV526-052 6V – 4 x LR44 alkaline included Height Width Depth 4.6" (117 mm) 2.3" (58 mm) 1.1" 4.0 (28 mm) (115 g) Weight (oz.) All dimensions are in inches and (millimeters). WARNING: Always wear approved eye protection. WARNING: Do NOT use on energized circuits. 19 VOICE/DATA/VIDEO TEST Voice/Data/Video Test VDV Scout™ Pro Tester Kit • Tests continuity on data (RJ45), voice (RJ11/12) and video (F-Connector Coax) connections. • Simultaneous testing of video and data cables saves time and improves efficiency. location ID remotes for locating cable runs to wall outlets; • Ifive ncludes RJ45 Remotes & five F-Connector Remotes. • Integrated tone generator supports multiple tones and control of pins carrying tone. • H eavy-duty ports are designed for long life and repeated connections. • C ontoured dual-material chassis fits comfortably in your hand. • R ecessed F-Connector port for improved reliability. Features VDV501-809 RJ-45 8-wire Cables ● RJ-11/12 6-wire Cables ● F-connector Coax Cables ● Continuity Testing & Pass TIA-568A/B Crossover/Uplink ID Apo S ● ● LCD Display ● Wiremap ● Open Fault ● Short Fault ● Miswire Fault ● Split Pair Fault ● Cable Identification – Up to 19 Locations Multiple Style Tone Generator Auto Power Off RJ45, F-Connector and RJ11/12 Port VDV501-809 Includes 5 Self Storing Remote ● ● Low Battery ● Voltage Warning ● Cat. No. Shield Detection ● Self-Storing Remote ● VDV501-809 9V alkaline included Batteries Height Width Depth Weight (oz.) Included Accessories 6.3" 2.8" 1.70" 9.0 (160 mm) (71.2 mm) (43.2 mm) (256 g) 5 location RJ45 remotes, 5 location F-Connector remotes, 1 F to F Barrel Connector, battery LanMap™ Kit for VDV Scout™ Pro Tester • Identify and map twisted-pair infrastructure (RJ45), up to 19 locations. • For use with VDV Scout™ Pro Tester (Cat. No. VDV501-053, VDV501-809). • H eavy-duty design for long life and repeated connections. • R emotes numbered 1 through 19 for fast and accurate identification. Cat. No. Height Width Depth Weight (oz.) VDV526-055 3.0" (76 mm) 3.3" (84 mm) 1.4" (36 mm) 1.9 (56 g) VDV526-055 CoaxMap™ Kit for VDV Scout™ Pro Tester • Identify and map coaxial cable infrastructure (F-Connector), up to 19 locations. • For use with VDV Scout™ Pro Tester (Cat. No. VDV501-053, VDV501-809). • H eavy-duty design for long life and repeated connections. • R emotes numbered 1 through 19 for fast and accurate identification. Cat. No. Height Width Depth Weight (oz.) VDV512-056 3.0" (76 mm) 3.3" (84 mm) 1.0" (26 mm) 5.2 (148 g) VDV512-056 All dimensions are in inches and (millimeters). 20 WARNING: Always wear approved eye protection. WARNING: Do NOT use on energized circuits. TraceAll™ Tone & Probe • Trace  wire paths and identify cables in common wiring systems. RJ11 jack on tone generator for • Hlong  eavy-duty life and repeated connections. adapter to convert tone • Igenerator ncludes RJ11 to an Alligator-clip configuration. • Dual material chassis fits comfortably in your hand . • Replacement tips available (Cat. No. VDV999-059). Replacement alligator-clip adapter available • (Cat. No. VDV999-067). Features VDV526-054 VDV526-054 Adjustable volume ● Tone generator, 2 Tones ● Self-storing remote ● Cat. No. Replaceable tip ● VDV526-054 6V – 4 x LR44 8.9" 1.7" alkaline included (226 mm) (43 mm) Self Storing Remote Batteries Height Width Adapter Depth Weight (oz.) Included Accessories 1.2" (31 mm) 5.0 (140 g) RJ11 to, alligator clip adapter, batteries TONEcube & PROBEplus Kit • Trace  wire paths and identify cables in common wiring systems. • TONEcube Tone Generator. • PROBEplus Tone Tracing Probe. carrying case with belt loop • Nand  ylonD-ring. VOICE/DATA/VIDEO TEST Voice/Data/Video Test VDV500-808 Cat. No. Set Contains: VDV500-808 ➢ Cat. No. Description Batteries Battery Life VDV500-051 TONEcube 9V 25 hours active 4 years standby VDV500-060 PROBEplus 9V 25 hours active 4 years standby – nylon pouch Overall Length Weight (oz.) ➢ 10.5" (267 mm) 12.8 (363 g) without batteries 16.0 (454 g) with batteries Height Width Depth Weight 2.7" (70 mm) 2.5" (63 mm) 1.42" (36 mm) 3.4 (96 g) without battery 5.0 (142 g) with battery 9.9" (252 mm) 2.00" (51 mm) 1.14" (29mm) 4.4 (125 g) without battery 6.0 (170 g) with battery 10.5" (267 mm) 4.75" (121 mm) 2.25" (57 mm) 4.8 (136 g) All dimensions are in inches and (millimeters). WARNING: Always wear approved eye protection. WARNING: Do NOT use on energized circuits. 21 VOICE/DATA/VIDEO TEST Voice/Data/Video Test TONEcube – Tone Generator • Trace  wire paths and identify cables in common wiring systems. F • ive discrete tracing tones. • Constant output level over useful battery life. leads with rugged dual-mode modular plug • Hfor  eavy-duty direct connection to both RJ11 & RJ45 jacks. • Momentary slide switches prevent accidental operation. for use with Klein Tools VDV test tools • D(Cat.  esigned No. VDV526-054, VDV500-060). • Works with many other manufacturers’ analog tone probes. Cat. No. Batteries VDV500-051 9V Battery Life Height Width Depth 120 hours active 4 years standby 2.7" (70 mm) 2.5" (63 mm) 1.42" 3.4 (96 g) without battery (36 mm) 5.0 (142 g) with battery Weight (oz.) VDV500-051 Features 5 Tones Apo VDV500-051 high-warble, low-warble, mono, ascending, descending Heavy-Duty Leads ● Rugged RJ11/RJ45 Modular Plug ● Continuity Testing ● Voltage Overload Protection ● Line Status & Polarity ● Power-On Flashing LED Indicator ● Auto Power-Off ● Low Battery Indicator ● Lanyard Attachment Loop ● PROBEplus – Tone Tracing Probe • Trace  wire paths and identify cables in common wiring systems. overload LED improves • Aaccuracy,  mplifierwarning against misreads. power button with • DPower-On  ual modeLED indicator – tap or hold. • Recessed buttons prevent accidental operation. for use with Klein Tools VDV test tools • D(Cat.  esigned No. VDV500-051, VDV526-054, VDV526-052, VDV500-060 VDV501-053, VDV501-809). Features •W  orks with many other manufacturers’ analog tone generators. • Replacement tips available (Cat. No. VDV999-065). Cat. No. Batteries ➢VDV500-060 ➢9V Amplifier Overload Indication Adjustable digital sensitivity control Battery Life Height Width Depth Weight (oz.) without battery 25 hours active 4 years standby 9.9" (252 mm) 2.0" (50 mm) 1.14" (29 mm) 4.4 (112 g) 6.0 (152 g) Apo WARNING: Always wear approved eye protection. ● ● Tap-Mode Operation ● Hold-Mode Operation ● Power-On LED Indicator ● Visual Notification ● Auto Power-Off ● Low Battery Indicator ● Replaceable Tip Lanyard Attachment Loop ● All dimensions are in inches and (millimeters). 22 VDV500-060 WARNING: Do NOT use on energized circuits. ● VOICE/DATA/VIDEO TOOLS Voice/Data/Video Tools Cushion-Grip Screwdriver Sets 4-Piece Miniature Cushion-Grip Screwdriver Set Additional Feature: Precision tips for exact fit and rigorous applications. • Cat No. Set Contains Weight (lbs.) 85484 .14 Cat. No. Tip Type Size Shank Tip Size Shank Length Overall Length 604-3 606-2 607-3 608-3 Phillips keystone cabinet cabinet No. 0 1/16" (1.6 mm) 3/32" (2.4 mm) 1/8" (3.2 mm) 3" (76 mm) 2" (51 mm) 3" (76 mm) 3" (76 mm) 5-3/4" (146 mm) 4-3/4" (121 mm) 5-3/4" (146 mm) 5-3/4" (146 mm) 85484 4-Piece Cushion-Grip Screwdriver Set Additional Features: The screwdrivers Professionals carry most often. Includes one Phillips-tip, two keystone-tip, one cabinet-tip screwdrivers. • • Cat. No. Set Contains Weight (lbs.) 85105 1.50 Cat. No. Description Blade Length Overall Length 603-4 round-shank, No. 2 Phillips-tip square-shank, keystone-tip* 4" (102 mm) 8-5/16" (211 mm) 4" (102 mm) 8-11/32" (212 mm) round-shank, cabinet-tip 6" (152 mm) 9-3/4" (248 mm) square-shank, keystone-tip* 6" (152 mm) 10-15/16" (278 mm) 600-4 601-6 600-6 All dimensions are in inches and (millimeters). WARNING: Always wear approved eye protection. 85105 WARNING: NOT insulated. Will NOT protect against electrical shock. WARNING: Do NOT use to pry or chisel. 23 VOICE/DATA/VIDEO TOOLS Cushion-Grip Screwdriver Sets 7-Piece Cushion-Grip Screwdriver Set Additional Features: General-purpose selection of the most frequently used screwdrivers. Includes three cabinet-tip, two Phillips-tip and two keystone-tip styles. • • Cat. No. Set Contains Weight (lbs.) 85076 1.50 Cat. No. Description Blade Length Overall Length 600-4 square-shank, keystone-tip* 4" (102 mm) 8-11/32" (212 mm) 602-6 round-shank, keystone-tip* 6" (152 mm) 10-15/16" (278 mm) 601-3 round-shank, cabinet-tip 3" (76 mm) 6-3/4" (171 mm) 601-6 round-shank, cabinet-tip 6" (152 mm) 9-3/4" (248 mm) 605-4 round-shank, cabinet-tip* 4" (102 mm) 8-11/32" (212 mm) 603-3 round-shank, No. 1 Phillips-tip 3" (76 mm) 6-3/4" (171 mm) 603-4 round-shank, No. 2 Phillips-tip 4" (102 mm) 8-5/16" (211 mm) 85076 * Heavy-duty models 8-Piece Cushion-Grip Screwdriver Set Additional Features: General-purpose selection of the most frequently used screwdrivers. Includes one cabinet-tip, three keystone-tip, four Phillips-tip styles. • • Cat. No. Set Contains Weight (lbs.) 85078 1.65 Cat. No. Description Shank Length Overall Length 600-1 round-shank, keystone-tip 1-1/2" (38 mm) 3-7/16" (87 mm) 601-3 round-shank, cabinet-tip 3" (76 mm) 6-3/4" (171 mm) 600-4 square-shank, keystone-tip* 4" (102 mm) 8-11/32" (212 mm) 602-6 round-shank, keystone-tip* 6" (152 mm) 10-15/16" (278 mm) 603-1 round-shank, No. 2 Philips-tip 1-1/2" (38 mm) 3-7/16" (87 mm) 603-3 round-shank, No. 1 Phillips-tip 3" (76 mm) 6-3/4" (171 mm) 603-4 round-shank, No. 2 Phillips-tip 4" (102 mm) 8-5/16" (211 mm) 603-6 round-shank, No. 3 Phillips-tip 6" (152 mm) 11" (279 mm) 85078 * Heavy-duty models 4-Piece Square Recess Cushion-Grip Screwdriver Set Additional Features: Color-coded handle ends with Tip-Ident® for quick and easy identification. Round shank with square-recess tip. Chrome-plated shank for corrosion resistance. Cushion-grip handle for greater torque and comfort. Works on most combination head receptacle, switch and panel screws. • • • • • Cat No. Set Contains Weight (lbs.) 85664 1.50 Cat. No. Point Size Color Code Shank Length Overall Length 660 No. 0 yellow 4" (102 mm) 7-3/4" (197 mm) 661 No. 1 green 4" (102 mm) 7-3/4" (197 mm) 662 No. 2 red 4" (102 mm) 8-5/16" (211 mm) 663 No. 3 black 4" (102 mm) 8-5/16" (211 mm) All dimensions are in inches and (millimeters). 24 WARNING: Always wear approved eye protection. 85664 WARNING: NOT insulated. Will NOT protect against electrical shock. WARNING: Do NOT use to pry or chisel. 5-Piece TORX® Cushion-Grip Screwdriver Set Additional Features: Color-coded handle ends with Tip-Ident® for quick and easy identification. TORX® drive systems transmit more torque to the work and reduce slippage, saving fasteners. Chrome plated shank for corrosion resistance. Cushion-grip handle for greater torque and comfort. • • • • Cat. No. Set Contains Weight (lbs.) 19555 1.20 Cat. No. TORX® Size Color Code Shank Length Overall Length 19542 T15 yellow 4" (102 mm) 7-3/4" (197 mm) 19543 T20 green 4" (102 mm) 7-3/4" (197 mm) 19544 T25 blue 4" (102 mm) 7-3/4" (197 mm) 19545 T27 brown 4" (102 mm) 8-5/16" (211 mm) 19546 T30 red 4" (102 mm) 8-5/16" (211 mm) 19555 TORX® is a registered trademark of Acument Intellectual Properties, LLC. 2-Piece Stubby Screwdriver Set Additional Feature: • Double wings inside handle provide solid, twist-resistant blade anchor. Cat. No. Set Contains Weight (lbs.) 85071 .30 Cat. No. Description Shank Length Overall Length 600-1 603-1 round-shank, keystone-tip round-shank, Phillips-tip 1-1/2" (38 mm) 1-1/2" (38 mm) 3-7/16" (87 mm) 3-7/16" (87 mm) 85071 Interchangeable Rapi-Driv® original Klein Cushion-Grip handle • Tforhesuperior comfort and torque! Interchangeable holder allows quick switching • between tip stylesbitand works with other standard size bits. rank action handle allows you to spin screws fast • Cwith one hand. • Blast finish bit provides firm grip on fasteners to reduce cam out. Cat. No. Contains Shaft Length Overall Length 67100 3/16" slotted, #2 Phillips 6" 9-3/4" VOICE/DATA/VIDEO TOOLS Cushion-Grip Screwdrivers 67100 Weight (lbs.) .26 2-in-1 Replacement Bit Cat. No. Fits DescrIption Quantity Weight (lbs.) 67101 2-in-1 Rapi-Driv®, 10-in-1, 11-in-1 and 10-Fold™ 3/16" slotted, #2 Phillips replacement bit contains 2 bits .012 Specialty Screwdrivers 5-in-1 Screwdriver/Nut Driver Additional Feature: End of handle is marked to quickly identify tool. • Cat. No. Contains Weight (lbs.) 32476 5/16" nut driver, #1 and #2 Phillips, 9/32" slotted and 3/16" slotted .35 All dimensions are in inches and (millimeters). WARNING: Always wear approved eye protection. 32476 WARNING: NOT insulated. Will NOT protect against electrical shock. WARNING: Do NOT use to pry or chisel. 25 VOICE/DATA/VIDEO TOOLS Specialty Screwdrivers 11-in-1 Screwdriver/Nut Driver Additional Feature: Integrated screwdriver/nut driver shaft holds 8 popular tips and converts to 3 nut driver sizes. End of handle is marked to quickly identify tool. • • 32500 Cat. No. Contains Weight (lbs.) 32500 3/8", 5/16" and 1/4" nut drivers, #1 and #2 Phillips, 1/4" and 3/16" slotted, T10 and T15 TORX®, #1 and #2 square-recess .44 Magnetic Screwdriver with 32-Piece Tamperproof Bit Set • Cushion-Grip handle for superior torque and comfort. turdy bit and screw holding magnet allows for • Sscrews to fit securely in place for easy use. I ncludes complete tamperproof bit set in block. • Cat. No. Set Contains Weight (lbs.) 32510 32510 .71 Non-Ratcheting Magnetic Screwdriver w/ 32 Piece Tamperproof Bit Set Bits Included TORX® – T7, T8, T10, T15, T20, T25, T27, T30 and T40 Fraction Hex – 3/32", 7/64", 1/8", 9/64", 5/32", and 3/16" Metric Hex – 2 mm, 2.5 mm, 3 mm, 4 mm, and 5 mm Spanner – 4, 6, 8, and 10 Tri-Wing® – 1, 2, 3 and 4 TORQ-SET® – 6, 8 and 10 1/4" square to 1/4" hex adapter to drive sockets TORX® is a registered trademark of Acument Intellectual Properties, LLC. TORQ-SET® and Tri-Wing® are registered trademarks of Phillips Screw Co. Magnetic Screwdriver Bit Sets 32-Piece Standard Tip Bit Set 32-Piece Tamperproof Tip Bit Set urable PVC gray • Dblock allows for urable PVC black • Dblock allows for easy storage of standard bits. Block slides over most screwdriver shafts for easy bit access and storage. Industrial strength, heat treated steel bits for long lasting use. • 32526 • Cat. No. Set Contains 32526 easy storage of tamperproof bits. Block slides over most screwdriver shafts for easy bit access and storage. • 32525 ndustrial strength, heat-treated • Isteel bits for long lasting use. Weight (lbs.) Cat. No. Set Contains Weight (lbs.) .425 32525 .425 Bits Included Bits Included Hex – 5/64", 3/32", 7/64", 1/8", 9/64", 5/32" and 3/16" Phillips – #0, #1, #2 (Qty. 3), and #3 Square Recess – #1, #2, and #3 TORX® – T6, T7, T8, T10, T15, T20 and T25 Slotted – 3-4, 5-6, 6-8, 8-10, 10-12, 12-14 screw sizes Clutch – 5/32" and 3/16" 1/4" square to 1/4" hex adapter to drive sockets TORX® – T7, T8, T10, T15, T20, T25, T27, T30 and T40 Fraction Hex – 3/32", 7/64", 1/8", 9/64", 5/32", and 3/16" Metric Hex – 2 mm, 2.5 mm, 3 mm, 4 mm, and 5 mm Spanner – 4, 6, 8, and 10 Tri-Wing® – 1, 2, 3 and 4 TORQ-SET ® – 6, 8 and 10 1/4" square to 1/4" hex adapter to drive sockets TORX® is a registered trademark of Acument Intellectual Properties, LLC. TORQ-SET® and Tri-Wing® are registered trademarks of Phillips Screw Co. All dimensions are in inches and (millimeters). 26 WARNING: Always wear approved eye protection. WARNING: NOT insulated. Will NOT protect against electrical shock. WARNING: Do NOT use to pry or chisel. 10-in-1 Folding Screwdriver/Nut Driver onveniently folds up for easy storage or fit into • Cyour pocket. driver arm contains four interchangeable • Ebitachstyles and two nut drivers. nfold each driver arm up to a full 180° for straight on • Udriving power, or at 90° for extra leverage on stubborn fasteners. • The quick release button easily unlocks a fully extended driver arm. TORX® TAMPERPROOF TORX® 32536 Cat. No. 32535 32536 32537 32538 32539 FRACTIONAL HEX 32537 32535 METRIC HEX 32538 32539 Handle Color Description Weight (lbs.) black green green red blue 5/16" & 1/4" nut drivers, #1 and #2 Phillips, 1/4" & 3/16" slotted, T10 & T15 TORX®, and #1 and #2 square-recess 0.37 0.37 0.37 0.37 0.37 5/16" & 1/4" nut drivers, T6, T7, T8, T10, T15, T20, T25, T27 Torx® 5/16" & 1/4" nut drivers, T7, T8, T9, T10, T15, T20, T25, T27 Torx® 5/16" & 1/4" nut drivers, 1/16", 5/64", 3/32", 7/64", 1/8", 9/64", 5/32", 3/16" standard hex 5/16" & 1/4" nut drivers, .9 mm, 1.3 mm, 1.5 mm, 2 mm, 2.5 mm, 3 mm, 4 mm, 5 mm metric hex TORX® is a registered trademark of Acument Intellectual Properties, LLC. Tapping Tools and Awls Cushion-Grip Triple Taps and Six-in-One Tap Tool uickly forms new threads, re-forms burred • Qthreads, and cleans out plaster obstructions. E ach tap size rethreads to next larger size if • threads are stripped. 626 Cat. No. Tap Sizes Overall Length Weight (lbs.) Replacement Taps 623-20 623-24 623-32 626 Triple Tap 10-24, 12-24, 1/4-20 Triple Tap 6-32, 8-32, 10-24 Triple Tap 6-32, 8-32, 10-32 6-in-1 Tap 6-32, 8-32, 10-32, 10-24, 12-24, 1/4-20 7-3/4" 7-3/4" 7-3/4" 7-3/4" .25 .25 .25 .25 628-20 626-24 626-32 Cushion-Grip Scratch Awl VOICE/DATA/VIDEO TOOLS Specialty Screwdrivers 10-24, 12-24, 1/4-20 6-32, 8-32, 10-24 6-32, 8-32, 10-32 replacement for 623-20, 626 replacement for 623-24 replacement for 623-32, 626 Steel Scratch Awl 650 • Professional, heavy-duty, hard-pointed awl. cribes metal, starts screw holes, • Sperforms a variety of piercing and punching jobs. igid, chrome-plated, heat-treated, tempered-steel shank • Rhas full reinforcing bolster at handle for extra strength and for handle impact reinforcement. Internal flanges provide solid shank anchor. Cushion-Grip handle allows for greater comfort. • • 66385 • One-piece forged-steel blade and bolstered shank. • Heat treated for long life. • Well-balanced for top efficiency during use. • Black finish for rust resistance. Cat. No. Blade Length Overall Length Weight (lbs.) Cat. No. Blade Length Overall Length Weight (lbs.) 650 3-1/2" (89 mm) 7-7/8" (200 mm) .25 66385 3-1/2" (89 mm) 7" (178 mm) .30 WARNING: Do NOT hammer on tool. All dimensions are in inches and (millimeters). WARNING: Always wear approved eye protection. WARNING: NOT insulated. Will NOT protect against electrical shock. WARNING: Do NOT use to pry or chisel. 27 VOICE/DATA/VIDEO TOOLS Spring Tool Set 2-Piece Recessed Can Light Tool Set the two tools needed for finishing • Contains can light installations in record time. ong reach, spring tool (Cat. No. ST6) makes • Lattaching difficult springs easy. C ompact, stubby nut driver (Cat. No. 610-1/4) even fits in smaller • cans to tighten hard to reach ceiling height adjustment screws. C ushion-Grip handles for greater torque and comfort. • Cat. No. Set Contains 65020 Weight (lbs.) 65020 .36 Cat. No. Description Shank Length Overall Length ST6 6" spring tool 610-1/4 1/4" stubby nut driver 6" (152 mm) 1-1/2" (38 mm) 9-3/4" (248 mm) 3-1/2" (89 mm) WARNING: NOT insulated. Will NOT protect against electrical shock. WARNING: Do NOT use to pry or chisel. Telecom Tools Can Wrench Bell System Type 68005 end opens telephone box fasteners, • Otheneother end tightens nuts on binding-post terminals. T he 7/16" has a black finish and the 3/8" socket • has a silversocket finish. • Heat-treated, alloy steel. ockets are 1-1/4" (32 mm) deep to fit over long binding • Sposts and are thin-walled for easy access into tight areas. ocket ends are color-coded for quick identification of • Ssocket sizes. H ex-socket • extra torque.design enables using a wrench to obtain Cat. No. Description 68005 Length Handle Diameter 3/8" and 7/16" hex nut 7" (178 mm) 1" (25 mm) 3146B imilar to standard lineman’s wrench, • Sbut with end openings sized to NEMA hardware specifications. • Silver painted finish. Cat. No. Description Length Weight (lbs.) 3146B Large end has 1-1/16" and 1-3/16" openings. Small end has 11/16" and 7/8" openings. 13" (330 mm) 1.76 Weight (lbs.) .350 WARNING: Read carefully and understand instructions before using this tool. WARNING: NOT insulated. WARNING: Always wear approved eye protection. WARNING: Never use on or near live electrical circuits. Will NOT protect against electrical shock. Saws & Blades Jab Saw • Cuts drywall, wallboard, plywood, and plastic. • Triple ground teeth for a fast cut. • Blade cuts in both directions (push and pull). • Hardened, carbon steel blade for durability. ardened, beveled blade point for scoring and • Hplunge cuts. C  omfort cushion grip with thumb groove. • H  andle structure designed for strength and durability. • • Flat-end grip for palming or punching through drywall. 725 Cat. No. Blade Length Overall Length Weight (lbs.) 725 6" (152 mm) 12" (305 mm) .31 WARNING: Never use blade as a prying device as blades may break & cause injury. All dimensions are in inches and (millimeters). 28 WARNING: Always wear approved eye protection. WARNING: Never use on or near live electrical circuits. High Strength 1/4" Wide Steel Fish Tapes F I N D E R Additional Features: Permanent, laser etched 1' increments on the tape allow you to more accurately measure the depth of conduit runs and determine the amount of tape left to pay out. Tempered, high quality tape keeps its stability as it glides between surfaces for effective pushing and pullings of wire under carpets, through insulated walls and over suspended ceilings. 25’ length is perfect for short wire runs associated with light commercial, residential and VDV installations (Cat. No. 56005). • • • 56005 56005 Has a No Snag Plastic Tip Cat. No. Tape Size Reel Diameter Weight (lbs.) 56005 56006 25' L x 1/4" W x .030" H (7 m L x 6.3 mm W x .7 mm H) 100' L x 1/4" W x .062" H (30 m L x 6.3 mm W x 1.5 mm H) 7" (178 mm) 13" (330 mm) 1.1 6.8 23' 24' 25' 1' Permanent Laser Etched Descending Increments. Fish Tape Accessories Glow Rods • Use to install wires above ceilings, through walls and under carpets and raised floors. • Luminescent rods glow in the dark and are rechargeable in most available light sources. • 3/16" diameter Glow Rods are extremely flexible to navigate tight bends and narrow openings. • Connect individual sections end-to-end to create a variety of lengths. • Threaded connectors are beveled on both ends to prevent snagging and hang ups on obstructions. • Cat. No. 56109, features 2 permanently affixed bull nose tips and offers the ultimate in flexibility. VOICE/DATA/VIDEO TOOLS Fish Tapes 56102 Cat. No. Description Set Contains Material Max. Diameter Weight (lbs.) 56102 15' (4.5 m) glow rod set luminescent fiberglass 3/16" (4 mm) 1.0 56109 56114 6' (1.8 m) glow rod 10 pc. bulk 5' (1.5 mm) glow rods (3ea.) 3/16" x 5' (4.8 mm x 1.5 m) glow rods (1ea.) bull nose attachment (1ea.) hook attachment – – luminescent fiberglass 5/32" (3 mm) 3/16" (4 mm) .09 .2 3-Piece Fish and Glow Rod Attachment Set hisk attachment helps guide rods over obstructions and • W can roll side-to-side to help "steer" left or right. ook attachment helps grab and retrieve wires or other • Hobjects from a distance. • Compatible with both 1/4" and 3/16" rod sizes. Cat. No. Set Contains Weight (lbs.) 56104 (1ea.) whisk attachment (1ea.) bull nose attachment (1ea.) hook attachment .1 All dimensions are in inches and (millimeters) unless otherwise specified. WARNING: Wear approved eye protection when feeding, pulling or 56104 WARNING: Do NOT use any fish tape on or near live circuits. Use extreme caution when working near any electrical equipment. rewinding fish tape. WARNING: Never remove screws while fish tape is coiled inside reel. WARNING: Use a safe work position to avoid loss of balance when using fish tape. 29 VOICE/DATA/VIDEO TOOLS Fish Tape Accessories Fish Rods • Use to install wires above ceilings, through walls and under carpets and raised floors. • 1/4" diameter Fish Rods are flexible, yet provide excellent rigidity for extended distance stand out. • Connect individual sections end-to-end to create a variety of lengths. • Threaded connectors are beveled on both ends to prevent snagging and hang ups on obstructions. • Sets contain (1ea.) steel "bullnose" and (1ea.) "J" hook accessory for attaching wires. • Cat. No. 56103 includes (1ea. X 3/16") 5' Glow Rod section to help guide Fish Rods into dark spaces. 56100 Cat. No. Description Set Contains Material Max. Diameter Weight (lbs.) 56100 12' (3.6 m) fish rod set (3ea.) 1/4" x 4' (6.3 mm x 1.2 m) fish rods (1ea.) bull nose attachment (1ea.) hook attachment fiberglass 1/4" (6 mm) 1.2 56101 24' (7.3 m) fish rod set (4ea.) 1/4" x 6' (6.3 mm x 1.8 m) fish rods (1ea.) bull nose attachment (1ea.) hook attachment 25' (7.6 m) fish and (5ea.) 1/4" x 4' (6.3 mm x 1.2 m) fish rods glow rod set (1ea) 3/16" x 5' (4.8 mm x 1.5 m) glow rod (1ea.) bull nose attachment (1ea.) hook attachment 10 pc. bulk 4' (1.2 m) fish rods − 10 pc. bulk 6' (1.8 m) fish rods − fiberglass 1/4" (6 mm) 2.2 fiberglass and luminescent rods 1/4" (6 mm) 2.7 fiberglass fiberglass 1/4" (6 mm) 1/4" (6 mm) .2 .2 56103 56111 56112 Extension Pole – WireSpanner™ • Push/Pull wires over long spans of suspended ceilings, sub-floors, crawl spaces and attics. • The durable 54" pole quickly and easily telescopes to a maximum of 22' long. • Each section locks securely into place and will not spin loose or collapse. • High quality, rigid fiberglass is sturdy, lightweight and slides easily over obstructions. • Large capacity hook/skid tip pulls multiple wires easily and has a separate eyelet for wire tie-on 56105 Cat. No. Description Collapsed Length Extended Length Max. Diameter Weight (lbs.) 56105 56118 WireSpanner™ installation tool WireSpanner™ carry case 54" (1.3 m) − 22' (6.7 m) − 2" (50 mm) − 4 0.4 Flexible Drill Bits Flex Bit Placement Tool olding design stores more • Fcompactly than standard tool. C ushion grip handle for • non-slip comfort. • For use with flexible drill bits. ositions flexible drill bits • Phorizontally or vertically 53715 within a wall. Cat. No. Length Weight (lbs.) 53715 11" (279 mm) 1.00 All dimensions are in inches and (millimeters) unless otherwise specified. WARNING: Wear approved eye protection when feeding, pulling or WARNING: Do NOT use any fish tape on or near live circuits. Use extreme caution when working near any electrical equipment. WARNING: Never remove screws while fish tape is coiled inside reel. WARNING: Use a safe work position to avoid loss of balance when using fish tape. rewinding fish tape. 30 Flex Bit Augers • Used to drill holes through wood within a wall. • Tapered back for easy bit retrieval. • Spring steel shaft resists deformation. • Screw point tip pulls the bit through wood. • Hole in tip allows for use with wire or cable pulling grip. 53719 53720 Cat. No. Length Weight (lbs.) 53719 53716 53717 53718 53719 53751 53720 3/8" x 54" (9.5 mm x 1372 mm) 3/8" x 72" (9.5 mm x 1829 mm) 9/16" x 54" (14 mm x 1372 mm) 3/4" x 54" (19 mm x 1372 mm) 3/4" x 72" (19 mm x 1829 mm) 1" x 54" (25 mm x 1829 mm) 1.00 1.00 1.00 2.00 2.00 2.00 53718 53716 Flex Bit Extensions • Connects to the end of a flex bit and extends the length. • For use with flex bits 3/4" and larger (Cat. No. 53722). • Connection diameter is 5/8" (Cat. No. 53722). • For use with flex bits 9/16" and smaller (Cat. No. 53723). • Connection diameter is 7/16" (Cat. No. 53723). 53722 Cat. No. Length Connection Diameter Weight (lbs.) 53722 53723 54" (1372 mm) 54" (1372 mm) 5/8" (14 mm) 7/16" (11 mm) 1.00 1.00 Pulling Grips VOICE/DATA/VIDEO TOOLS Flexible Drill Bits Pulling Grips • Clips to flex bit for pulling wire and cable. rip (Cat. No. KPS050) is used to pull up to 9/16" KPS075 • Gdiameter wire, cable or fish tape through walls; grip (Cat. No. KPS075) up to 1". • Pulling grip attaches to the hole in the tip of the flex bit; wire mesh holds the wire during the pull. • Swivel end helps reduce twisting. WARNING: Do not exceed maximum safe load as listed on the Cat. No. Capacity KPS050 KPS075 1/2" - 9/16" (12 mm - 14 mm) 100 lb 3/4" - 1" (19 mm - 25 mm) 185 lb Maximum Safe Load Weight (lbs.) 1.00 1.00 label attached to the product. WARNING: Always match proper size and type of grip to application. WARNING: Always inspect equipment before use. Flex Bit Kit Flex Bit Kit kit includes folding placement tool, 1/2"-9/16" O.D. pulling grip • 3andpiece 9/16" x 54" flexible drill bit. • Everything you need to pull up to 9/16" O.D. wire. • Complete kit used for drilling and pulling wire and cable. • Use placement tool (Cat. No. 53715) to guide bit through walls. • Flexible drill bit (Cat. No. 53718) makes 9/16" holes in wood. ulling grip (Cat. No. KPS050) attaches to the flexible drill bit • Pafter the hole has been made and pulls 1/2" – 9/16" wire and cable. Cat. No. Kit Contains Weight (lbs.) 53721 2.00 Cat. No. Description 53715 flex bit placement tool 53718 flex drill bit - 9/16" x 54" (14 mm x 1372 mm) KPS050 pulling grip - 1/2"–9/16" (12 mm - 14 mm) All dimensions are in inches and (millimeters) unless otherwise specified. WARNING: Always wear approved eye protection. 53721 WARNING: Never use on or near live electrical circuits. NOTE: Read and follow safety instructions in power tool owner's manual. 31 VOICE/DATA/VIDEO TOOLS Hole Saw Kits Hole Saw Kits Master Electrician’s Hole Saw Kit • Includes the most commonly used saws and arbors. • All components are packed in a metal carrying case. Cat. No. Set Contains Weight (lbs.) 31640 8.10 Hole Saws Arbors Cat. No. Size Cat. No. Size 31514 7/8" 31650 1/4" 31518 1-1/8" 31660 7/16" 31522 1-3/8" 31670 7/16" 31528 1-3/4" 31532 2" 31540 2-1/2" 31548 3" 31558 3-5/8" 31566 4-1/8" 31572 4-1/2" Note: Set pilot drill point 1/8" beyond tooth points. Note: Read and follow safety instructions in power tool owner’s manual. 31640 Large Size Hole Saw Kit • Contains the sizes necessary to upgrade an Electrician‘s Hole Saw Kit into a Master Electrician‘s set. • All components are packed in a metal carrying case. Cat. No. Set Contains Weight (lbs.) 31645 6.60 Hole Saws Arbors Cat. No. Size Cat. No. Size 31548 3" 31670 7/16" 31558 3-5/8" 31566 4-1/8" 31572 4-1/2" Journeyman’s Hole Saw Kit Note: Set pilot drill point 1/8" beyond tooth points. Note: Read and follow safety instructions in power tool owner’s manual. • Contains the most popular sizes for basic electrical work. ll components are packed in a rust-proof, molded plastic • Acarrying case. 4.50 Hole Saws Arbors Cat. No. Size 3/4" 31650 1/4" 31514 7/8" 31660 7/16" 31518 1-1/8" 31670 7/16" 31522 1-3/8" Size 31524 1-1/2" Arbor Extender 1-3/4" Cat. No. Size 31678 12" 2.60 Arbors Cat. No. 31635 Size Weight (lbs.) Size Weight (lbs.) 31512 31630 Cat. No. Set Contains Cat. No. Set Contains Hole Saws plastic carrying case. Cat. No. Electrician’s Hole Saw Kit Cat. No. • The most frequently used sizes and an arbor extension for hard to reach spots. • All components are packed in a rust-proof, molded 31514 7/8" 31660 7/16" 31528 31518 1-1/8" 31670 7/16" 31532 2" 2-1/4" 2-1/2" 31522 1-3/8" 31536 31528 1-3/4" 31540 31532 2" 31540 2-1/2" Note: Set pilot drill point 1/8" beyond tooth points. Note: Read and follow safety instructions in power tool owner’s manual. Note: Set pilot drill point 1/8" beyond tooth points. Note: Read and follow safety instructions in power tool owner’s manual. All dimensions are in inches and (millimeters) unless otherwise specified. 32 WARNING: Always ensure that you and persons in the vicinity wear approved eye protection. Carbide Grit Hole Saws • Available in the most common sizes for recessed can lights. • Carbide grit for smooth cuts and minimal tear out. • Long-lasting carbide grit won’t dull in abrasive materials. • Grit design reduces the kick when starting a cut in plywood. uts through drywall, ceiling tile, lathe/plaster, cement board, • Cand wood. Cat. No. Saw Diameter For Use with Arbor No. Weight (lbs.) 31605 6-3/8" (161 mm) 31168, 31665, 31670 1.65 31607 6-5/8" (168 mm) 31168, 31665, 31670 1.65 31611 6-7/8" (174 mm) 31168, 31665, 31670 1.75 31605 Note: Set pilot drill point 1/8" beyond tooth points. Note: Read and follow safety instructions in power tool owner’s manual. Quick Cutter® Adjustable Hole Saw saw blades adjust to cut holes from • H2 ole -1/2" to 7" in diameter. • Carbide coated blades for longer blade life. • Cuts holes in drywall and ceiling tile. • Dust shield included. Cat. No. Range Weight (lbs.) 53731 2-1/2" - 7" (64 mm - 177 mm) 1.00 Quick Cutter® is a registered trademark of Speare Tools. VOICE/DATA/VIDEO TOOLS Hole Saws NOTE: Read and follow safety instructions in power tool owner's manual. 53731 Ship-Auger Bits Ship-Auger Bits with Screw Point • Bits drill through nails, wood, vinyl, plastics, and heavy timber. 53429 pecial bit steel with machine-ground flutes and polished • Sedges for smooth, wobble-free boring. • Shanks are 7/16" hex to fit 1/2" and larger three-jaw chucks. • Feed-screw pilot draws bit into wood. Head and twist are ground to correct clearance for easy • removal • Full length is heat-treated and tempered. from hole. • Deep, open-throat design clears chips for faster, cleaner cuts. • For heavy construction and repair work in mines, on docks and bridges, and for electrical work. Cat. No. Bit Size Twist Length Overall Length Weight (lbs.) 53401 53402 53403 53404 53405 53406 53407 53408 53409 53410 53411 53426 53428 53429 53430 11/16" 3/4" 13/16" 7/8" 15/16" 1" 1-1/16" 1-1/8" 1-1/4" 1-3/8" 1-1/2" 3/4" 7/8" 1" 1-1/8" 4" (102 mm) 4" (102 mm) 4" (102 mm) 4" (102 mm) 4" (102 mm) 4" (102 mm) 4" (102 mm) 4" (102 mm) 4" (102 mm) 4" (102 mm) 4" (102 mm) 4-3/4" (121 mm) 4-3/4" (121 mm) 4-3/4" (121 mm) 4-3/4" (121 mm) 6" (152 mm) 6" (152 mm) 6" (152 mm) 6" (152 mm) 6" (152 mm) 6" (152 mm) 6" (152 mm) 6" (152 mm) 6" (152 mm) 6" (152 mm) 6" (152 mm) 7-3/4" (197 mm) 7-3/4" (197 mm) 7-3/4" (197 mm) 7-3/4" (197 mm)  .30  .40  .40  .50  .50  .50  .60  .80 1.00  .80 .90  .45  .60  .60  .80 Cat. No. Bit Size Twist Length Overall Length Weight (lbs.) 53431 53434 53435 53436 53437 53438 53439 53440 53441 53442 53443 53444 53445 53446 1-1/4" 9/16" 5/8" 11/16" 3/4" 13/16" 7/8" 15/16" 1" 1-1/16" 1-1/8" 1-1/4" 1-3/8" 1-1/2" 4-3/4" (121 mm) 15" (381 mm) 15" (381 mm) 15" (381 mm) 15" (381 mm) 15" (381 mm) 15" (381 mm) 15" (381 mm) 15" (381 mm) 15" (381 mm) 15" (381 mm) 15" (381 mm) 15" (381 mm) 15" (381 mm) 7-3/4" (197 mm) 18" (457 mm) 18" (457 mm) 18" (457 mm) 18" (457 mm) 18" (457 mm) 18" (457 mm) 18" (457 mm) 18" (457 mm) 18" (457 mm) 18" (457 mm) 18" (457 mm) 18" (457 mm) 18" (457 mm)  .90  .65  .80  .85  .95 1.05 1.20 1.50 1.70 1.95 1.80 2.20 2.80 3.45 All dimensions are in inches and (millimeters) unless otherwise specified. WARNING: Never use on or near live electrical circuits. WARNING: Always ensure that you and persons in the vicinity wear approved eye protection. 33 VOICE/DATA/VIDEO TOOLS Tool Bags Zipper Bag 5139 5139B 5139C • Constructed of No. 10 canvas with heavy-duty brass zipper. • Convenient storage for ®pliers, wrenches, screwdrivers, nut drivers, other tools, and spare parts. of Cordura ballistic nylon, a high-performance • Constructed fabric resistant to abrasions, tears, and scuffs Cat. No. Material Length • • • (Cat. Nos. 5139B, 5139, 5139C). Heavy-duty nylon zipper. (Cat. Nos. 5139B, 5139). Features the desert stalker digitized camouflage pattern for maximum concealment (Cat. Nos. 5139C). Heavy-duty nylon stitching and zipper ensure durability and long life (Cat. Nos. 5139C). Height Weight (lbs.) 5139 canvas 12-1/2" (318 mm) 7" (178 mm) .19 5139B Cordura® Ballistic Nylon 12-1/2" (318 mm) 7" (178 mm) .24 5139C Cordura® Camouflage 12-1/2" (318 mm) 7" (178 mm) .14 Cordura® is a registered trademark of INVISTA for durable fabrics. Zipper Bags – Canvas, 4-Pack four assorted colors (olive, orange, royal-blue, • Includes and yellow) to organize and categorize important tools. • Constructed of No. 10 canvas with heavy-duty brass zipper. storage for pliers, wrenches, screwdrivers, • Convenient nut drivers, other tools and spare parts. • Overall size: 12-1/2" (318 mm) long x 7" (178 mm) high. Cat No. Description Weight (lbs.) 5140 4 zipper bags - canvas .80 5140 Padded Cordura® Zipper Bag of Cordura®, a high performance • Constructed fabric resistant to abrasions, tears, and scuffs. padding provides additional • Three-layer protection to contents. • Heavy-duty nylon zipper. • Overall size: 12-1/2" (318 mm) x 7" (178 mm). 5139PAD Cordura® Length Height Color 12 -1/2" (318 mm) 7" (178 mm) black Nylon, Cordura® ye rs on cti adding and prote . la ee Material Foam T hr Cat. No. Felt of p Weight (lbs.) Cordura® is a registered trademark of INVISTA for durable fabrics. .28 Canvas Zipper Bags – Consumables • Constructed of No. 8 canvas, with heavy-duty brass zipper. • Convenient storage for wire nuts, connectors and other consumables. • 3-1/2" wide bottom for stability when standing; easy access when open. • Brass grommet for hanging or attaching to belt or clip. • Overall size: 10" (254 mm) long x 8" (203 mm) tall x 3-1/2" (89 mm) wide. 34 Cat. No. Material Length Height Width Color Weight (lbs.) 5539RED 5539BLU 5539YEL 5539NAT 5539CPAK canvas canvas canvas canvas canvas 10" (254 mm) 10" (254 mm) 10" (254 mm) 10" (254 mm) see above 8" (203 mm) 8" (203 mm) 8" (203 mm) 8" (203 mm) see above 3- 1/2" (89 mm) 3- 1/2" (89 mm) 3- 1/2" (89 mm) 3- 1/2" (89 mm) see above red blue yellow natural 3-pack: red, blue, yellow .25 .25 .25 .25 .75 All dimensions are in inches and (millimeters). 5139PAD 5539NAT 5539YEL 5539BLU 5539BLU 5539RED Coax Installer Starter Kit – F-Connectors ncludes the tools needed to prepare and • Iconnect F-Connectors. urable nylon tool pouch designed • Dspecifically for F-connector installation tools. A dditional pocket holds a screwdriver • or common AA battery flashlights. P ouch includes a closeable pocket that will hold • up to 25 compression F-connectors. • Tunnel-loop accommodates up to 2” belt. Cat. No. Set Contains Weight (lbs.) VDV012-811 1.44 Cat. No. Description 63020 VDV110-802 VDV212-008 Kit Exclusive Multi-Cable Cutter Radial Cartridge Stripper - Coaxial Cable, 2-Level Compression Crimper - Compact, F-Connector 5-Pocket Nylon Tool Pouch plus closeable consumables pocket VDV012-811 LAN Installer Starter Kit – Modular ncludes the tools needed to prepare, • Iconnect and test modular cables. nylon tool pouch designed specifically • Dforurable modular plug installation tools. wo additional pockets hold a screwdriver and • Tcommon AA battery flashlights. P ouch includes a closeable pocket that will hold • up to 25 RJ45 plugs. • Tunnel-loop accommodates up to 2” belt. Cat. No. Set Contains VOICE/DATA/VIDEO KITS Voice/Data/Video Kits Weight (lbs.) VDV026-812 1.5 Cat. No. Description 2100-8 VDV226-011 VDV526-052 98554 Kit Exclusive Stainless Steel Electrician’s Scissors - Free-Fall Ratcheting Modular Cutter/Crimper/Stripper LAN Scout™ Junior Tester Fine Point Permanent Marker 5-Pocket Nylon Tool Pouch plus closeable consumables pocket VDV026-812 VDV026-812 LAN Installer Starter Kit – Punchdown the tools needed to prepare and connect • I66ncludes type and 110 type punchdown terminal blocks. nylon tool pouch designed specifically • Dforurable punchdown installation tools. wo additional pockets hold a screwdriver and • Tcommon AA battery flashlights. • Tunnel-loop accommodates up to 2” belt. Cat. No. Set Contains Weight (lbs.) VDV027-813 .88 Cat. No. Description 2100-8 VDV427-047 VDV427-015 VDV427-017 98554 Kit Exclusive Stainless Steel Electrician's Scissors - Free-Fall Punchdown Multi-Tool Chassis Punchdown Tool Blade - 110 type Punchdown Tool Blade - combination 66/110 cut type Fine Point Permanent Marker 4-Pocket Nylon Tool Pouch VDV027-813 35 1 Voice/Data/Video • Testers & Tools PREPARATION CABLE TYPE CUT RG-59 COAX CABLE TWISTED PAIR CABLE RG-6 63020 RG-6 QUAD 63028 VDV110-802 2100-7 VDV100-801 2100-8 CAT 6 VDV120-006 CONNECTION CABLE TYPE CONNECTOR TERMINATE RG-59 COAX CABLE RG-6 F-Connector TWISTED PAIR CABLE CAT 3 RCA Connector VDV211-048 F MODULAR o r P r o f e s s i o n a l s . . . S i n c e PLUGS RJ11 CAT 5e CAT 6 VDV211-063 BNC Connector RG-6 QUAD 3 VDV110-061 CAT 3 CAT 5e 2 STRIP RJ22 1 8 5 7 ® RJ45 VDV226-011 TERMINAL PATCH PANELS B VDV427-807 TESTING CABLE TYPE COAX CABLE IDENTIFY / VERIFY RG-59 RG-6 VDV512-057 VDV500-060 RG-6 QUAD TWISTED PAIR CABLE VDV512-058 CAT 3 CAT 5e CAT 6 VDV501-809 VDV500-051 VDV526-054 VDV526-052 www.kleintools.com Klein Tools, Inc. • 450 Bond Street • Lincolnshire • IL 60069-1418 • phone: 847-821-5500 • fax: 800-553-4876 © 2011 Klein Tools, Inc. Printed in U.S.A. 96303
VDV205-039 价格&库存
很抱歉,暂时无法提供与“VDV205-039”相匹配的价格&库存,您可以联系我们找货
