34735
34735
    STEINEL
    Heat Gun 120V 750°F (399°C) 300W Black
34735 数据手册
HG 350 ESD Precision Hot Air Tools HG 350 ESD Specifications Item No. Temperature Airflow Element 34735 07730 includes nozzle 750°F (400°C) without reducer 930°F (500°C) with reducer 3.5 cfm DuraTherm™ heating element Output 300 watts Voltage 120 VAC / 50/60 Hz Amps 2.5 Power Cord Nozzle Diameter 1.50 lbs (24.00 oz) Dimensions 9.0” x 11.5” x 3.0” (l x w x d) Warranty Certifications Included HG 350 ESD Precision Hot Air Tool Key Features: The HG 350 ESD brings hot air to where it’s needed at any work place. The hot air tool is easy to use, lightweight and extremely comfortable to hold thanks to its ergonomically shaped soft grip. It is the ideal tool for soldering, de-soldering and heat-shrinking. Compact in design, it fits into any tool box or service case. • • Applications An integrated bright LED light illuminates even the darkest of work situations and acts as an “on” indicator. In stationary applications and noisy surroundings, this instantly lets you know what is happening. The integrated molded rests in the housing also add to safety by keeping the hot tool at a distance from the surface. Optimized Weight Balance for Fatigue-Free Operation Molded Safety Rests Soft Grip Handle • 0.75” (19 mm) Net Weight Single Sell Pack • • • • • • • industrial grade rubber, length: 6 ft dimensions: 11.0” x 10.0” x 4.0” weight: 2.05 lbs one year limited C-UL-UL Listed, RoHs Compliant, ISO 9001:2001 ESD Safe, Made in E.U. Targeted 3.5 CFM airflow 750°F Temperature (930°F with included 1/4” / 7 mm Reducer) LED light illuminates work area Sleek, balanced design for comfortable long-term use Compact, lightweight construction Built-in security hanger for overhead suspension HG 350 ESD is ESD safe LED serves as a convenient “on” indicator Safety rests help prevent surface contact with hot nozzle “Thermo-Signal” temperature indicator Integrated LED Light Provides Bright Illumination Toggle Switch 0 Off / 1 Cool / 2 Heat www.steinel.net HG 350 ESD Precision Hot Air Tool Cutting Edge STEINEL Technology Factory Sealed Motor Integral Security Hanger Durable Ceramic Encapsulated Element Built in LED Light Secure Cord Connection Stainless Steel Nozzle Industrial Grade Switch Connector Block Circuitry Rubber Power Cord STEINEL utilizes state-of-the-art SMD surface mount circuit boards which we design and manufacture for this specific application Accessories for a Variety of Applications 7 mm Reducer 1.0” x 0.8” x 0.8” No. 07730 www.steinel.net 5 mm Reducer w/ Guard 1.5” x 0.8” x 0.8” No. 07735 (800) 852-4343 40 mm Large Reflector 1.5” x 1.4” x 0.5” No. 07765 10 mm Small Reflector 1.1” x 0.8” x 0.8” No. 07755 9051 Lyndale Avenue South, Bloomington, MN 55420 10 mm Precision Reflector 1.4” x 0.8” x0.8” No. 07745 L-80350
34735
物料型号:HG 350 ESD,型号编号34735 07730。
器件简介: - HG 350 ESD热风工具易于使用、轻便,由于其符合人体工程学设计的软握把,握持非常舒适。 - 适合焊接、去焊和热缩工作。 - 紧凑设计,适合放入任何工具箱或服务箱中。
引脚分配:未提供,因为这是一个热风工具,不是电子元件。
参数特性: - 温度:750°F(400°C)无收缩器,930°F(500°C)带收缩器。 - 气流:3.5 cfm。 - 功率:300瓦,120 VAC / 50/60 Hz。 - 电源线:工业级橡胶,长度6英尺。 - 喷嘴直径:0.75英寸(19毫米)。 - 净重:1.50磅(24.00盎司)。 - 尺寸:9.0英寸×11.5英寸×3.0英寸(长×宽×深)。
功能详解: - 具有集成的明亮LED灯,照亮工作区域,并作为“开”指示。 - 安全休息设计,防止热喷嘴与表面接触。 - “Thermo-Signal”温度指示器优化了重量平衡,减轻操作疲劳。 - 软握把和集成LED灯,提供明亮照明。 - 具有安全挂钩,可悬挂在上方。
应用信息: - LED灯作为方便的“开”指示器,在固定应用和嘈杂环境中提供即时反馈。 - 安全休息帮助防止热喷嘴与表面接触。
封装信息: - HG 350 ESD是静电安全(ESD Safe)的。 - 符合C-UL-UL认证,RoHS合规,ISO 9001:2001认证,制造于欧盟。
配件信息: - 7毫米收缩器,尺寸1.0英寸×0.8英寸×0.8英寸,型号07730。 - 5毫米收缩器带防护,尺寸1.5英寸×0.8英寸×0.8英寸,型号07735。 - 40毫米大型反射器,尺寸1.5英寸×1.4英寸×0.5英寸,型号07765。 - 10毫米小型反射器,尺寸1.1英寸×0.8英寸×0.8英寸,型号07755。 - 10毫米精密反射器,尺寸1.4英寸×0.8英寸×0.8英寸,型号07745。
34735 价格&库存
很抱歉,暂时无法提供与“34735”相匹配的价格&库存,您可以联系我们找货
