17602
17602
    AVENTOOLS(艾文)
    HEATGUN1500WWITHDIGITALTEMP
17602 数据手册
Heat Gun With Adjustable Temperature Control Temperature Dial • Easy temperature selection Powerful Heat Application Aven’s Heat Gun with Adjustable Temperature Control features an easy-to-read, simple to use turn dial to select your temperature range. Airflow Switch • Alternate between high and low airflow settings The power switch offers high and low airflow settings that heat up quickly for use. Features a convenient flip-out stand to position the nozzle vertically along a work bench, perfect for applications where operators are required to use both hands. AVEN HEAT GUN 1500W w/ ADJUSTABLE TEMPERATURE CONTROL Nozzle Attachments • Includes 3 nozzle attachments to direct airflow as needed Email | sales@aveninc.com Item # 17601 Weight 2.05 lbs Voltage 120V / 1500W / 60Hz Power Output Low – 800W / High – 1500W Temperature Low: 50° C – 350° C / High: 200° – 500° C Airflow 450L/min aveninc.com Phone | 734.973.0099 Heat Gun With Digital Temperature Control Digital Temperature Dial • Easy temperature selection Powerful Heat Application Airflow Switch • Alternate between high and low airflow settings Aven’s Heat Gun With LCD Display offers precise heat control with a sharp LCD display. Exact temperatures in increments of 10 degrees can be chosen using the temperature controls on the back of the unit. Features high and low airflow settings, and is designed to use either by hand or placed vertically on a work bench. Includes 3 nozzle attachments. AVEN HEAT GUN 1500W w/ DIGITAL TEMPERATURE CONTROL Nozzle Attachments • Includes 3 nozzle attachments to direct airflow as needed Email | sales@aveninc.com Item # 17602 Weight 2.15 lbs Voltage 120V / 1500W / 60Hz Power Output Low – 800W / High – 1500W Temperature Low: 100° C – 300° C / High: 300° – 650° C Airflow 450L/min aveninc.com Phone | 734.973.0099
17602 价格&库存
很抱歉,暂时无法提供与“17602”相匹配的价格&库存,您可以联系我们找货
