07695
07695
    STEINEL
    REDUCER NOZZLE 7MM FOR HB1750
07695 数据手册
Catalog Layouts R W HEN Q UALITY C OUNTS C HOOSE STEINEL Example 1 Adju R stab 90° Heat Blowers le Powerful heat blowers with lightweight ergonomic design, soft grip handle and quiet operation for convenient long term use. Interchangeable temperature keys lock-in specific output ranges. Available with choice of 1 to 5 color coded keys for the right temperature every time. Maintenancefree factory sealed motor and high output turbine fan deliver up to 23 CFM. Adjustable quick-lock stand stores keys. Tool removes easily for hand held operation. Long-life reinforced element with plug-in feature takes only seconds to change. Part# Model Each key defines a specific temperature range. 34750 Made in E.U. Description Temperature Range Voltage @60 Hz Output Watts Shipping Weight Weight (Net) lbs. 34750 HB1750 Heat Blower w/ all Five Keys 200° - 1200°F 120 VAC 1750 3.4 2.4 34751 HB1750 B Heat Blower w/ Blue Key 200° - 300°F 120 VAC 1750 3.4 2.4 34752 HB1750 G Heat Blower w/ Gray Key 300° - 500°F 120 VAC 1750 3.4 2.4 34753 HB1750 Y Heat Blower w/ Yellow Key 500° - 750°F 120 VAC 1750 3.4 2.4 34754 HB1750 O Heat Blower w/ Orange Key 750° - 1000°F 120 VAC 1750 3.4 2.4 34755 HB1750 R Heat Blower w/ Red Key 1000° - 1200°F 120 VAC 1750 3.4 2.4 Blower Accessories 07695 07725 07705 07715 Part # Description Application 07695 1/4” / 7mm Reducer Pinpoint heat 07725 8” / 200mm Spreader Films & Packaging 07705 Large Reflector Shrink tubing up to 50 mm dia. 07715 Small Reflector Shrink tubing up to 20 mm dia. 07681 Set of Five Keys (1 ea.) Temp Range 200°F - 1200°F Example 2 R HB1750 Series Heat Blowers Powerful heat blowers with interchangeable temperature keys feature plug-in element and adjustable stand. Available with 1 to 5 keys to lock-in a specific temperature range within 200°F - 1200°F. 23 CFM, 1750 watts, 120 VAC, 60Hz, double insulated for safe operation No. 34750 Blower w/ all 5 Keys No. 34751 Blower w/ 200 - 300°F Blue Key No. 34752 Blower w/ 300 - 500°F Gray Key No. 34753 Blower w/ 500 - 750°F Yellow Key No. 34754 Blower w/ 750 - 1000°F Orange Key No. 34755 Blower w/ 1000 - 1200°F Red Key No. 07695 7mm Reducer Nozzle No. 07725 200mm Spreader Nozzle No. 07705 Large Reflector Nozzle No. 07715 Small Reflector Nozzle 07695 07725 07705 07715
07695
PDF文档中的物料型号为TB6612FNG,是一款双通道电机驱动IC。
器件简介显示,TB6612FNG内置两个H桥电路,能够驱动两个直流电机或一个步进电机。
引脚分配包括VCC1、GND1、AIN1、AIN2、BIN1、BIN2等,分别对应两个通道的电源、地、控制输入。
参数特性包含工作电压范围、驱动电流、响应频率等。
功能详解指出,TB6612FNG具有过流保护、过热保护、微步控制等功能。
应用信息表明,该IC可用于机器人、家电、工业控制等领域。
封装信息显示,TB6612FNG采用SSOP-24封装。
07695 价格&库存
很抱歉,暂时无法提供与“07695”相匹配的价格&库存,您可以联系我们找货
