PanaVise: Circuit Board Holders
BACK
PanaVise Circuit Board Holders help you work quicker and smarter.
The two moveable arms extend 6" (154mm) from the cross bar and
have "V" shaped grooves which securely hold the board edge. One
arm is spring tensioned to equalize holding pressure, and includes a
new lever which locks the internal spring "open" for quick board
insertion and removal. "V" notches positioned laterally near the arm
tips securely and conveniently hold small electronic parts. All our vises
and work holding devices come with a "lifetime warranty."
Circuit Board Holder - Model 315
http://www.panavise.com/nf/vises/vises_cbholders.html (1 of 4)2/8/2006 2:17:16 PM
Hold circuit boards from
1/8" (3.2mm) to
12" (304.8mm) wide and
5/32" (4mm) thick. Arms move
independently.
Add the 318 Accessory Cross
Bars and the bar width can be
extended from 14" (355.6mm)
to 30" (762mm) to hold boards
up to 28" (711.2mm) wide.
Arms move independently and
may be positioned adjacent to
each other. Additional sets of
arms (Model 316) are
available for dual or multiple
board use.
Ratcheted pivot for added
adjustability, holds board
horizontally, vertically or any
angle in between.
The stem is 5/8" (15.9mm) in
diameter and fits all 300
Series Bases.
Overall height (including stem)
is 10 7/8" (276.2mm)
Electronic Work Center - Model
324
http://www.panavise.com/nf/vises/vises_cbholders.html (2 of 4)2/8/2006 2:17:16 PM
The PanaVise Electronic
Work Center is a complete
and economical work bench
combination.
It delivers a set of circuit
board holders, all the "tilt, turn
and rotate" control of a 300
Standard Base, the
convenience of a 312 Tray
Base Mount and a 371 Solder
Station.
1/8" (3.2mm) to
independently.
board use.
All parts, tooling, wire,
soldering iron and PC Boards
are located exactly where you
want them. Sturdy and stable.
The 324 Electronic Work
Center stands 13
1/2" (342.9mm) tall and
weighs 4lbs. 8oz. (2kg).
Rapid Assembly Circuit Board
Holder - Model 333
http://www.panavise.com/nf/vises/vises_cbholders.html (3 of 4)2/8/2006 2:17:16 PM
The PanaVise Rapid
Holder features eight position
rotating adjustment, six
positive lock positions in the
vertical plane and height
adjustment for quick board
rotation speeds and
component insertion and
soldering.
1/8" (3.2mm) to
independently.
board use.
Weighted base is extremely
stable.
Weighs 6lbs. 7oz. (2.9kgs).
Height from base to top of
vertical shaft is 10" (254mm).
| Vises | Pana Press | CCTV | Cellular | Speaker Mounts | Sales Reps |
International | Trade Shows | History | Downloads | Purchase Spares | Site
Map | Product Search | Request Catalog | Contact PanaVise | Home |
Web Development - Flash, Graphics and Java Scripting by Global Studio
Send technical questions to info@globalstudio.com
Send questions about Site Content and about PanaVise Products to webmaster@panavise.
com
Copyright 1996 - 2006 by PanaVise Products, Inc.
http://www.panavise.com/nf/vises/vises_cbholders.html (4 of 4)2/8/2006 2:17:16 PM
很抱歉,暂时无法提供与“324”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1008.569341+131.06616
