74580
74580
    WIHA(威汉)
    TORXPOWERBITT6X150MM(5.9")
74580 数据手册
2019 PROFESSIONAL TOOLS COMPLETE TORX FOR TOOLING PROGRAM ® TorqueFix • TorqueVario • TorqueControl Blades • TorqueFix Wing EasyTorque • iTorque • Adapters • Cable Keys • Insulated TorqueVario ESD Safe TorqueVario • T-handle Torque • TorqueControl Sets • Micro Bits Toll Free: (800) 494-6104 2 TorxPlus® Index Torx® Index DESCRIPTION Page SoftFinish® 5 Cushion Grip 6 ESD Safe SoftFinish® Cushion Grip DESCRIPTION Page Wing Handle 16 Flag Handle 16 Insulated 7 PocketStar Fold Outs Cushion Grip MicroFinish Non-Slip Grip 7 SoftFinish® 17 8 T-handles 17 L-Keys Short/Long Arm 18 TorqueControl Blade 20-22 ESD Safe Precision 24 Powerhandle Proturn 8 Cushion Grip 3K Series 9 Drive-Loc VI Blades 10 Bit-Selectors 27 T-handle & ComfortGrip 13 L-Keys Offset Screwdrivers 12-13 11 PocketStar Fold Outs 11 14 Wing Handle Flag Handle 16 Insert Bits 34 Power Bits 34 Bit Sockets & Sets 35,37 14 TorqueControl Blades 20-22 Precision Tools Standard PicoFinish ESD Safe 23 23 24 Ball End Torx® Index SYSTEM 4 Blades 24 SYSTEM 4 Micro Bits 25 DESCRIPTION Page 26-27 SoftFinish Drivers L-Keys 15 Power Bits Bit Sets Insert & Power Bits 29-32 Bit Sockets & Sets 35-36 * Standard TORX® are not for use in TORXPlus® fasteners Cushion Grip 15 15 www.wihatools.com 3 Security Torx® Index Screwdrivers Index DESCRIPTION Page DESCRIPTION Page SoftFinish® 6,11 SoftFinish® CushionGrip 5-6,15,17,19 Cushion Grip & Insulated Torx®, Security Torx®, TorxPlus®, MagicSpring Drive-Loc VI Blades 10 L-Keys 12 ESD Safe SoftFinish® 6 Cushion Grip - Torx® Insulated 7,11 Torx® & Security Torx® PocketStar Fold Outs 11 MicroFinish SYSTEM 4 Micro Bits 25 Bit Sets 26-27 Insert Bits - 1/4” & 5/16” 33 Power Bits 33 Bit Sockets 35,37 7 Non-Slip Grip - Torx® Powerhandle- Torx® 8 Proturn - Torx® 8 3K Series - Torx® 8 Offset Screwdrivers 11 T-handle/ComfortGrip 13,17 Torx® & TorxPlus® MagicSpring Screw Holding Precision Tools Standard PicoFinish ESD Safe DESCRIPTION Page SoftFinish® Screw Holding 19 23 23 24 Cushion Grip 19 PicoFinish Soft Grip Screw Holding Drive-Loc VI Interchangeable L-keys Screw Holding 18 Wing Handle Screw Holding 19 TorqueControl Blades 20 Power Bits 34 Screw Holding Wing/Flag & L-keys Index DESCRIPTION Drive-Loc VI Handle Offset Screwdrivers Wing Handle 14,16,19 Torx®, TorxPlus® & MagicSpring Flag Handle Torx® & TorxPlus® 14,16 Drive-Loc VI Handle 10 Drive-Loc VI Handle 10 Drive-Loc VI Blades 10 ESD Safe Cushion Grip Page 11 10 SoftFinish® Cushion Grip MicroFinish Non-Slip Grip Torx / Security Torx ® L-Keys 12-13 DESCRIPTION Page ® Fold Outs Index DESCRIPTION Page PocketStars 11,16 Torx, Security Torx, TorxPlus Toll Free: (800) 494-6104 4 Bit Sets Index TorqueControl Index DESCRIPTION Page TorqueVario Handle 20 Torx® / TorxPlus® Blades 20 Insulated Torque Tools DESCRIPTION Page Six-in-One Bit Sets 26 Bit Selector Sets Power Bit Belt Packs 27 SYSTEM 4 Sets 25 27 21 Easy Torque Tools 21 ESD  Safe TorqueControl 22 ESD Safe Torx® Blades 22 T-handle Torque Tools 22 Interchangeable Blades For Torque T-handle 22 TorqueControl Sets Micro Bits & Interchangeable Blades XSelectors 27 See Bit Holders on Pg. 26-28 22 ESD Blade Set Index DESCRIPTION Page Standard Bits Index Interchangeable Blade Set 24-25 DESCRIPTION Page Torx® Insert/Power Bits 30-32 Sockets Index DESCRIPTION Page Torx® 1/4” Drive Specialty Bits Index DESCRIPTION Page Ball End Torx® 15 Torx Align Bits 32 ® Insert/Power Bits 33 TorxPlus® Bits 34 34 Security Torx ® Insert/Power Bits Insert/Power Bits Security Pentalobe 35-37 Torx® 3/8” Drive 35-37 Torx® 3/8” - 5/16” Bits 35-37 35,37 Security Torx® 3/8”, 1/2” External Torx® Sockets 36 1/4”, 3/8”, 1/2” 1/4” & 3/8” Drive 36 6” Bit Sockets Bit Socket Sets 36-37 www.wihatools.com 5 Wiha SoftFinish® Screwdrivers - Ergonomic Cushion Grip Handle Extra large diameter to achieve high torque Handle is molded directly onto the blade for a permanent bond Improved torque zone. For all working conditions with molded on soft cushion grips Flat surfaces give roll-off protection 362 Screwdriver, With Wiha-SoftFinish® Handle Round blade high alloy chrome-vanadium-molybdenum steel, hardened, hard chromed. Wiha-Chromtop finish on tips. Wiha-SoftFinish® handle, multi-component, cushion grips. Item No. Size mm Inch mm Inch mm Inch lbs. pkg. T5 60 2.4 2.5 .098 164 6.5 .05 10 36264 T6 60 2.4 3.5 .139 164 6.5 .06 10 36266 T7 60 2.4 3.5 .139 164 6.5 .06 10 36268 T8 60 2.4 3.5 .139 164 6.5 .06 10 36270 T9 60 2.4 4.0 .157 171 6.7 .10 10 36272 T10 80 3.1 4.0 .157 191 7.5 .11 10 36274 T15 80 3.1 4.0 .157 191 7.5 .11 10 36276 T20 100 3.9 4.0 .157 211 8.3 .11 10 36278 T25 100 3.9 4.5 .177 211 8.3 .12 10 36280 T27 115 4.5 5.5 .216 233 9.2 .19 10 36282 T30 115 4.5 6.0 .236 233 9.2 .20 10 36284 T40 130 5.1 7.0 .275 254 10.0 .27 10 36286 T45 130 5.1 8.0 .315 254 10.0 .31 10 36288 36291 6 Pcs. Set Round blade high alloy CVM steel, hardened, hard chromed. Wiha-Chromtop finish on tips. Wiha-SoftFinish® handle, multi-component, cushion grips. Item No. Size mm Size mm lbs. 36291 T6 60 T9 60 .77 T7 60 T10 80 T8 60 T15 80 36201 6 Pcs. Set Round blade high alloy CVM steel, hardened, hard chromed. Wiha-Chromtop finish on tips. Wiha-SoftFinish® handle, multi-component, cushion grips. Item No. Size mm Size mm lbs. 36201 T6 60 T15 80 .83 T8 60 T20 100 T10 80 T25 100 36294 8 Pcs. Set Round blade high alloy CVM steel, hardened, hard chromed. Wiha-Chromtop finish on tips. Wiha-SoftFinish® handle, multi-component, cushion grips. Item No. Size mm Size mm lbs. 36294 T6 60 T20 100 1.24 T8 60 T25 100 T10 80 T27 115 T15 80 T30 115 Set 12 Pcs. Round 36267 blade high alloy CVM steel, hardened, hard chromed. Wiha-Chromtop finish on tips. Wiha-SoftFinish® handle, multi-component, cushion grips. Item No. Size mm Size mm lbs. T5 60 T15 80 2.03 36267 T6 60 T20 100 T7 60 T25 100 T8 60 T27 115 T9 60 T30 115 T10 80 T40 130 Toll Free: (800) 494-6104 6 Wiha Security Drivers 362 Security Screwdriver With Wiha-SoftFinish® Handle Round blade high alloy CVM steel, hardened, hard chromed. Wiha-Chromtop finish on tips. Wiha-SoftFinish® handle, multi-component, cushion grips. Item No. Size mm Inch mm Inch mm Inch lbs. pkg. T7s 60 2.4 3.5 .139 164 6.5 .06 10 36269 T8s 60 2.4 3.5 .139 164 6.5 .06 10 36271 T9s 60 2.4 4.0 .157 171 6.7 .10 10 36273 T10s 80 3.1 4.0 .157 191 7.5 .11 10 36275 T15s 80 3.1 4.0 .157 191 7.5 .11 10 36277 T20s 100 3.9 4.0 .157 211 8.3 .11 10 36279 T25s 100 3.9 4.5 .177 211 8.3 .11 10 36281 T27s 115 4.5 5.5 .216 233 9.2 .19 10 36283 T30s 115 4.5 6.0 .236 233 9.2 .20 10 36285 T40s 130 5.1 7.0 .275 254 10.0 .28 10 36287 Wiha SoftFinish® ESD Safe Handle D 36298 7 Pcs. Security Set Item No. Size mm Size mm lbs. 36298 T7s 60 T15s 80 .95 T8s 60 T20s 100 T9s 60 T25s 100 T10s 80 36259 Item No. 36259 10 Pcs. Security Size mm Size T7s 60 T20s T8s 60 T25s T9s 60 T27s T10s 80 T30s T15s 80 T40s Set mm lbs. 100 1.5 100 115 115 130 ESD Safe (106-109 Ohm) ESD Safe Driver, Wiha-SoftFinish® Handle DIN EN 61340-5-1/61340-5-2 362 Round blade, CVM steel, hardened, hard chromed. Offers protection against electrostatic discharge. Dissipative SoftFinish® cushion grip handle, multi-component. Item No. Size mm Inch mm Inch mm Inch lbs. pkg. 36260 T3 60 2.4 3.5 .139 164 6.5 .06 10 36204 T4 60 2.4 3.5 .139 164 6.5 .06 10 36200 T5 60 2.4 3.5 .139 164 6.5 .06 10 36206 T6 60 2.4 3.5 .139 164 6.5 .06 10 36208 T8 60 2.4 3.5 .139 164 6.5 .06 10 36209 T9 60 2.4 4.0 .157 171 6.7 .10 10 36218 T10 80 3.1 4.0 .157 191 7.5 .11 10 36219 T15 80 3.1 4.0 .157 191 7.5 .11 10 36224 T20 100 3.9 4.0 .157 211 8.3 .11 10 D ESD Safe (106-109 Ohm) 36289 Set 6 Pcs. ESD Safe Screwdrivers Item No. T6, T8, T9, 36289 T10, T15, T20 lbs. .81 Wiha ESD Safe Interchangeable Blade Set In Durable Pouch D 10893 ESD Safe 5 Piece Interchangeable Blade Set Includes ESD Safe handle & 4 interchangeable blades. Item lbs. No. 10893 .75 TORX®: T6, T7, T8, T9, T10, T15, T20, T25 Wiha ESD Safe Handle www.wihatools.com 7 Wiha Insulated Screwdrivers 1000Volt 1000Volt Screwdriver, With Wiha-SoftFinish® Handle Insulation According to 325 ASTM F-1505-10, New VDE Specification 0682/part 201 and EN/IEC 60900, NFPA70E, up to 1000 Volt. Individually Tested. Blade high alloy cvm steel, hardened, black finish. Insulation molded directly onto blade. Item No. Size mm Inch mm Inch lbs. pkg. T5 60 2.4 164 6.5 .06 10 32505 T6 60 2.4 164 6.5 .06 10 32511 T7 60 2.4 164 6.5 .06 10 32516 T8 60 2.4 164 6.5 .06 10 32521 T9 60 2.4 164 6.5 .06 10 32526 T10 60 2.4 164 6.5 .06 10 32531 T15 80 3.1 191 7.5 .12 10 32536 T20 80 3.1 191 7.5 .12 10 32541 T25 80 3.1 198 7.8 .17 10 32546 T27 100 3.9 218 8.6 .20 10 32551 T30 100 3.9 218 8.6 .20 10 32556 T40 150 5.9 274 10.8 .30 10 32561 T45 150 5.9 274 10.8 .35 10 32566 Wiha Set 6 Pcs. Size mm lbs. T15 80 .83 T20 80 T25 80 1000Volt 32592 Set 10 Pcs. Item No. Size mm T6 60 32592 T7 60 T8 60 T9 60 T10 60 Size mm lbs. T15 80 1.2 T20 80 T25 80 T27 100 T30 100 MicroFinish Handle Non-Slip Grip Wiha MicroFinish handle has a patented non-slip surface it won’t peel, crack or deteriorate when exposed to petroleum solvents. Oil and moisture flow away from the handle surface for a powerful, non-slip grip. You get maximum force and comfort with dry, oily or wet hands. Exact fit precision ground tips 32590 Item No. Size mm T8 60 32590 T9 60 T10 60 Blades are hardened & hard chromed Safe, high density material, eliminates risk of sharp objects becoming embedded in the handle MicroFinish Handle with patented non-slip surface. Ergo handle shape for maximum comfort & exceptional torque transfer Screwdriver, With Wiha-MicroFinish Handle 527 Blade high alloy chrome-vanadium-molybdenum steel, hardened, hard chromed. Wiha-MicroFinish handle, cellulose-acetate, impact resistant, non-slip, oil and grease resistant. Round blades. Item No. Size mm Inch mm Inch mm Inch lbs. pkg. T9 60 2.4 4.0 .157 171 6.7 .15 10 52711 T10 80 3.1 4.0 .157 191 7.5 .15 10 52713 T15 80 3.1 4.0 .157 191 7.5 .15 10 52716 T20 100 3.9 4.0 .157 211 8.3 .15 10 52719 T25 100 3.9 4.5 .177 211 8.3 .16 10 52722 T27 115 4.5 5.5 .216 233 9.2 .25 10 52726 T30 115 4.5 6.0 .236 233 9.2 .27 10 52729 T40 130 5.1 7.0 .275 254 10.0 .40 10 52732 52790 Set 5 Pcs. Item No. Size mm Size mm lbs. T10 80 T25 100 1.0 52790 T15 80 T30 115 T20 100 52791 Set 8 Pcs. Item No. Size mm Size mm lbs. T9 60 T25 100 1.89 52791 T10 80 T27 115 T15 80 T30 115 T20 100 T40 130 Toll Free: (800) 494-6104 8 Wiha Powerhandle 362 Screwdriver, With Wiha-Powerhandle CVM steel blade, hardened, hard chromed. Wiha-powerhandle cellulose-acetate. Item No. Size mm Inch mm Inch mm Inch lbs. pkg. T5 50 2.0 2.5 .098 110 4.3 .03 10 36205 T6 50 2.0 3.5 .139 125 4.9 .06 10 36210 T7 50 2.0 3.5 .139 125 4.9 .06 10 36212 T8 60 2.4 3.5 .139 135 5.3 .06 10 36215 T9 60 2.4 4.0 .157 140 5.5 .09 10 36220 T10 80 3.1 4.0 .157 170 6.7 .13 10 36225 T15 80 3.1 4.0 .157 170 6.7 .13 10 36230 T20 100 3.9 4.0 .157 200 7.9 .17 10 36235 T25 100 3.9 4.5 .177 200 7.9 .18 10 36240 T27 115 4.5 5.5 .216 215 8.5 .20 10 36245 T30 115 4.5 6.0 .236 225 8.9 .28 10 36250 pro turn Wiha Through hardened for optimum wear resistance Screwdriver, With Wiha-Proturn Handle Blade high alloy CVM steel, hardened, black finish. Molded on ergonomic Wiha-Proturn handle, impact resistant. Size T6 T7 T8 T9 T10 T15 T20 T25 T27 T30 T40 T50 mm Inch 50 2.0 50 2.0 60 2.4 60 2.4 80 3.1 80 3.1 100 3.9 100 3.9 115 4.5 115 4.5 130 5.1 130 5.1 mm Inch 3.5 .139 3.5 .139 3.5 .139 4.0 .157 4.0 .157 4.0 .157 4.0 .157 4.5 .177 5.5 .216 6.0 .236 7.0 .275 9.0 .354 45591 Item No. 45591 6 Pcs. Set T7, T8, T9, T10, T15, T20 lbs. .72 High performance tool steel 455 Item No. 45505 45506 45511 45516 45521 45526 45531 45536 45541 45546 45551 45561 6 Pc. Set With Wiha36293 Powerhandle Item No. T6, T7, T8, T9, lbs. 36293 T10, T15 .78 Proturn Screwdrivers Molded on ergonomic handle proportioned to blade sizes Black finish blades 36292 8 Pc. Set With WihaPowerhandle Item No. T6, T8, T10, T15, lbs. T20, T25, T27, T30 1.45 36292 mm Inch 129 5.1 129 5.1 139 5.5 149 5.8 170 6.7 170 6.7 190 7.5 190 7.5 215 8.4 215 8.4 240 9.4 240 9.4 lbs. .05 .05 .06 .08 .10 .10 .11 .11 .11 .20 .28 .31 pkg. 10 10 10 10 10 10 10 10 10 10 10 10 45592 8 Pcs. Set Item No. T8, T9, T10, T15, 45592 T20, T25, T27, T30 45589 Item No. 45589 11 Pcs. lbs. 1.07 Set T6, T7, T8, T9, T10x80, T15, T20, T25, T27, T30, T40 lbs. 2.2 www.wihatools.com 9 Wiha 3K Series Drivers and Sets 3K Series Hole for hanging Blade high alloy CVM steel, hardened Precision black tip Molded on soft grip ergonomic handle, impact resistant 455 Screwdriver, With Wiha-3K Series Handle Blade high alloy CVM steel, hardened, precision black tip. Molded on ergonomic Wiha-3K Series handle, impact resistant. Item No. 45504 45508 45509 45525 45527 45530 45540 45550 Size T6 T8 T9 T25 T27 T30 T40 T50 mm Inch 60 2.4 60 2.4 60 2.4 100 3.9 115 4.5 115 4.5 130 5.1 130 5.1 mm Inch 3.2 9/64 3.5 9/64 4.0 5/32 6.0 1/4 7.0 9/32 6.0 1/4 7.0 9/32 9.0 3/8 mm Inch 145 5.7 139 5.5 149 5.8 215 8.4 240 9.4 233 9.1 248 9.7 249 9.8 lbs. .06 .06 .08 .20 .28 .21 .25 .33 pkg. 10 10 10 10 10 10 10 10 Wiha Bit Holders 1/4” Bit holding Screwdriver, 48401 With Wiha-Ergo 3K Handle Magnetic, holds bit & screw. Retainer out of stainless steel. CVM tool steel, nickel plated. Item No. Size mm Inch mm Inch lbs. pkg. 1/4” 125 5.0 211 8.3 .24 1 48401 48400 1/4” Bit holding Screwdriver, With Wiha-Proturn Handle Magnetic, holds bit & screw. Retainer out of stainless steel. Shaft CVM tool steel, nickel plated. Item No. Size mm Inch mm Inch lbs. pkg. 1/4” 125 5.0 243 9.6 .24 10 48400 45593 Set 5 Pcs. Blade CVM steel, hardened, precision black tip. Wiha-3k Ergo handle, cushion grip. Item No. T8, T10, T15, T20, T25 45593 lbs. .86 Toll Free: (800) 494-6104 10 Wiha Drive-Loc VI Handles, Blades & Sets Drive-Loc VI For Adjustable Length Locking Blades 28488 Drive-Loc VI Cushion Grip Handle Wiha-SoftFinish® impact resistant, with roll off protection. Ergonomic cushion grip, Drive-Loc mechanism guarantees a secure hold & rapid blade exchange. Item No. mm mm Inch mm Inch lbs. 6.0 115 4.5 36.0 1.41 .20 28488 D 28486 ESD Safe Drive-Loc VI Cushion Grip Handle Wiha-SoftFinish® impact resistant, with roll off protection. Ergonomic cushion grip, Drive-Loc mechanism guarantees a secure hold and rapid blade exchange. Static Dissipative Item No. mm mm Inch mm Inch lbs. 28486 6.0 115 4.5 36.0 1.41 .20 Drive-Loc VI MicroFinish Non28487 Slip Grip Handle Wiha-MicroFinish handle, won’t peel, crack or deteriorate when exposed to petroleum solvents. Ideal for Hex, TORX® & Nut Drivers. Ergonomic handle shape for maximum comfort, mechanism guarantees a secure hold & rapid blade exchange. Item No. mm mm Inch mm Inch lbs. 28487 6.0 115 4.5 36.0 1.41 .20 10810 Drive-Loc VI Standard Narrow Profile Tech Handle Dynamic non-locking, impact resistant, friction hold. Fits all Drive-Loc blades. Does not have locking feature. Item No. mm mm Inch mm Inch lbs. 6.0 135 5.3 15.2 .60 .16 10810 Locking mechanism allows blade length to be adjusted from 40mm-120mm. (1.7 to 4.7” In 1/8” increments) Blades high quality CVM steel, hard chrome finish. Ergonomic handles in ESD Safe, cushioned & non-slip grip. 281 Drive-Loc VI Interchangeable Blade High alloy CVM steel, through hardened, hard chrome finish. Over all blade length 150mm/5.9”. Blades fit all Drive-Loc VI handles. Item No. Size + Size lbs. pkg. T6 T8 .09 1 28126 T7 T9 .09 1 28127 T10 T15 .10 1 28128 T20 T25 .10 1 28129 T30 T40 .10 1 28130 281 Security Drive-Loc VI Over all blade length 150mm/5.9”. Blades fit all Drive-Loc VI handles. Item No. Size + Size lbs. pkg. T6s T8s .09 1 28132 T7s T9s .09 1 28133 T10s T15s .10 1 28134 T20s T25s .10 1 28135 T30s T40s .10 1 28136 28197 Drive-Loc VI Interchangeable Blade Set, 6 Pcs. In Durable Pouch Set includes Drive-Loc VI handle & 5 interchangeable blades. Item No. Security T6s+T8s, T7s+T9s, T10s+T15s, 28197 T20s+T25s, T30s+T40s lbs. SoftFinish® Cushion Grip Blade .83 Lock Handle 28189 15Pc. Drive-Loc VI Interchangeable Blade Set, In Durable Pouch Set includes Drive-Loc VI handle & 14 interchangeable blades. Item No. 28189 lbs. 1.28 Slotted: 3.5+4.5, 5.5+6.5 Phillips: 1+2 Security : T6s+T8s, T7s+T9s, T10s+T15s, T20s+T25s, T30s+T40s Hex Inch: 3/32+7/64, 1/8+9/64, 5/32+3/16 Hex Metric: 2.0+2.5, 3.0+4.0, 5.0+6.0mm Wiha SoftFinish® Cushion Grip Blade Lock Handle 28485 5 Pack Drive-Loc VI Interchangeable Blade Set Over all blade length 150mm/5.9” Item No. T6+T8, T7+T9, T10+T15, 28485 T20+T25, T30+T40 lbs. .35 5 Pack Drive-Loc VI 28477 Interchangeable Blade Set Item No. T6s+T8s, T7s+T9s, T10s+T15s, 28477 T20s+T25s, T30s+T40s lbs. .35 www.wihatools.com 11 Wiha SlimLine Security SoftFinish® Screwdrivers Wiha Insulated SlimLine Tools Insulation according to EN/IE, ASTM, VDE, DIN, NFPA70E & CSA specification 1.4” 1000Volt 325 Insulated Security SlimLine Drivers Insulation According to ASTM, New VDE Specification 0682/part 201 and EN/ IEC 60900, NFPA70E & CSA, up to 1000 Volt. Individually Tested to 10,000Volts. Item lbs. Pkg. No. Size mm mm .08 1 T10s 100 204 32512 .12 1 T15s 100 211 32513 .12 1 T20s 100 211 32514 .18 1 T25s 125 243 32515 .21 1 T27s 125 243 32517 .21 1 T30s 125 243 32518 T40s 150 268 .26 1 32519 1000Volt 32596 6 Pc. Insulated SlimLine Security Screwdrivers. Insulation According to ASTM F-1505, New VDE Specification 0682/part 201 and EN/IEC 60900, NFPA70E & CSA, up to 1000 Volt. Individually Tested to 10,000Volts. High quality CV steel, through hardened. SlimLine blades have up to 33% narrower insulation diameter then standard insulated tools. Item Security : T10s, T15s, No. T20s, T25s, T27s, T30s lbs. 1.18 32596 Wiha PocketStar Fold Outs 28301 SlimLine Blade Holder, With Wiha-SoftFinish® Handle Insulation Chrome-vanadium steel, through-hardened. Insulation molded directly onto blade. Friction hold blade holder. Wiha-SoftFinish® handle, multi-component, cushion grip. Item No. Size mm Inch mm Inch lbs. pkg. 28301 1/4” 50 2.0 160 6.3 .15 1 Wiha SlimTECHNOLOGY Achieves blade diameters up to 33% narrower utilizing integrated insulation Insulated SlimLine Blades 283 High quality CV steel, through hardened. Item Slim Max Inch/ No. Size Dia. Nm lbs. lbs. Pkg. 1 28339 T8 4.0 1.3 11.5 .02 1 28344 T9 4.0 1.3 11.5 .02 1 28340 T10 4.0 3.8 33.6 .02 1 28341 T15 6.0 5.5 48.7 .02 1 28342 T20 6.0 5.5 48.7 .02 1 28343 T25 6.0 5.5 48.7 .02 Wiha Offset Screwdrivers Push button key release Blade length range 1.68 - 1.94” PocketStar Fold Outs, 36396 7 Pc. Set High alloy CVM steel, hardened, molded ergonomic handle. OAL 3.8” Item No. 36396 lbs. .22 T7, T8, T9, T10, T15, T20, T25 Push button key release Blade length range 1.95 - 2.39” 36398 PocketStar Fold Outs, 8 Pc. Set High alloy CVM steel, hardened, molded ergonomic handle. OAL 4.74” Item No. 36398 T9, T10, T15, T20, lbs. .24 T25, T27, T30, T40 Push button key release Blade length range 1.68 - 1.94” Security PocketStar 36395 Fold Outs, 7 Pc. Set High alloy CVM steel, hardened, molded ergonomic handle. OAL 3.8” Item No. TR lbs. 36395 T7s, T8s, T9s, .22 T10s, T15s, T20s, T25s Push button key release 207 Offset Screwdriver With Molded Handle For working in confined spaces. Blade CVM special steel, hardened, black finish. Item No. 20756 20757 20758 20759 20760 Size T6 + T8 T7 + T9 T10 + T15 T20 + T25 T27 + T30 lbs. pkg. .02 1 .02 1 .02 1 .07 1 .10 1 Blade length range 1.95 - 2.39” 36397 Security PocketStar Fold Outs, 8 Pc. Set High alloy CVM steel, hardened, molded ergonomic handle. OAL 4.74” Item No. TR lbs. .24 36397 T9s, T10s, T15s, T20s, T25s, T27s, T30s, T40s Offset Screwdriver Set, 20799 5 Pcs. With Molded Handle Blade CVM special steel, hardened, black finish. Item Set Includes: T6+T8, No. T7+T9, T10+T15, lbs. pkg. 20799 T20+T25, T27+T30 .24 1 Toll Free: (800) 494-6104 12 Short Arm L-keys Long Arm L-keys Wiha Security L-keys Security Torx® L-Keys 363 L-key, Short Arm High alloy CVM steel, hardened, black finish. Item No. Size mm Inch mm Inch lbs. T5 37 1.5 16 .6 .01 36305 T6 39 1.5 16 .6 .01 36306 T7 42 1.7 16 .6 .01 36307 T8 45 1.8 16 .6 .01 36308 T9 48 1.9 16 .6 .01 36309 T10 51 2.0 17 .7 .01 36310 T15 54 2.1 19 .7 .01 36315 T20 58 2.3 19 .7 .01 36320 T25 63 2.5 21 .8 .02 36325 T27 67 2.6 22 .9 .03 36327 T30 73 2.9 24 .9 .05 36330 T40 79 3.1 26 1.0 .06 36340 T45 82 3.2 28 1.1 .09 36345 T50 95 3.7 32 1.3 .13 36350 T55 108 4.3 35 1.4 .27 36355 T60 120 4.7 38 1.5 .40 36360 L-key, Long Arm 366 High alloy CVM steel, hardened, black finish. Item No. Size mm Inch mm Inch lbs. T5 71 2.8 12 .5 .06 36645 T6 78 3.1 13 .5 .07 36646 T7 87 3.4 16 .6 .10 36647 T8 99 3.9 18 .7 .13 36648 T9 106 4.2 18 .7 .17 36649 T10 118 4.6 21 .8 .23 36650 T15 131 5.2 23 .9 .33 36651 T20 144 5.7 25 1.0 .44 36652 T25 158 6.2 28 1.1 .65 36653 T27 169 6.7 30 1.2 .98 36654 T30 184 7.2 32 1.3 1.27 36655 T40 201 7.9 35 1.4 2.09 36659 T45 222 8.7 40 1.6 2.70 36660 T50 213 8.4 40 1.6 3.14 36661 363 High alloy Item No. 36323 36326 36328 36329 36332 36335 36337 36339 36342 36346 36352 36357 Security L-key, Short Arm CVM steel, hardened, black finish. Size mm Inch mm Inch lbs. T8s 45 1.8 16 .6 .01 T9s 48 1.9 16 .6 .01 T10s 51 2.0 17 .7 .01 T15s 54 2.1 19 .7 .01 T20s 58 2.3 19 .7 .02 T25s 63 2.5 21 .8 .02 T27s 67 2.6 22 .9 .03 T30s 73 2.9 24 .9 .04 T40s 79 3.1 26 1.0 .06 T45s 82 3.2 28 1.1 .09 T50s 95 3.7 35 1.3 .13 T55s 108 4.3 38 1.4 .27 Security Torx® L-Key Sets #36392 #36394 #36399 36392 Set, 7 Pc. In Plastic Holder Equipped with T6, T7, T8, T9, T10, T15, T20 Item No. lbs. pkg. 36392 .10 1 36394 Set, 9 Pc. In Plastic Holder T8, T9, T10, T15, T20, T25, T27, T30, T40 Item No. lbs. pkg. 36394 .30 1 36399 Set, 16 Pc. Equipped with T5, T6, T7, T8, T9, T10, T15, T20, T25, T27, T30, T40, T45, T50, T55, T60 Item No. lbs. pkg. 1 .14 1 36399 36699 Long Arm Set, 13 Pc. in Molded Holder Equipped with T5, T6, T7, T8, T9, T10, T15, T20, T25, T27, T30, T40, T50 Item No. lbs. pkg. 1.13 1 36699 36698 Long Arm Set, 10 Pc. In Molded Holder Equipped with T6, T7, T8, T9, T10, T15, T20, T25, T27, T30 Item No. lbs. pkg. 36698 1.04 1 36391 Security Set, 6 Pcs. T10s, T15s, T20s, T25s, T27s, T30s Item No. lbs. pkg. 36391 .16 1 26 Piece Combo Pack Long Arm And Hex Inch L-key Sets, In Pouch Set includes: 36699-13pc set T5-T50 and 36991-13pc set .050 - 3/8” Item No. lbs. pkg. 36694 2.13 1 36694 36390 Set, 9 Pc. In Metal Stand Equipped with T10, T15, T20, T25, T30, T40, T50, T55, T60 Item No. lbs. pkg. 1.86 1 36390 36393 Security Set, 9 Pcs. In Plastic Holder Equipped with T8s, T9s, T10s, T15s, T20s, T25s, T27s, T30s, T40s Item No. lbs. pkg. .30 1 36393 www.wihatools.com 13 Wiha “Rust Free” Finish L-keys 96 hour salt bath tested for best corrosion protection Pacified Zinc Chromate Finish CVM tool steel through hardened and tempered for maximum tool life 36693 Long Arm Set, 13 Pc. In ErgoStar Molded Holder Equipped with T5, T6, T7, T8, T9, T10, T15, T20, T25, T27, T30, T40, T45 Item No. lbs. pkg. 36693 1.10 1 Wiha Soft Grip T-handles & Set Wiha T-handle Blade high alloy CVM steel, hardened, hard chrome finish. Wiha T-handle high quality plastic, impact resistant 364 Item No. 36409 36410 36415 36417 36420 36422 36425 36427 36430 36432 36435 36437 36440 36442 36445 36450 36452 with Wiha T-handles Size mm Inch mm Inch mm Inch lbs pkg. T9 100 3.9 4.0 5/32 80 3.1 .07 10 T10 100 3.9 4.0 5/32 80 3.1 .07 10 T15 100 3.9 4.0 5/32 80 3.1 .07 10 T15 200 7.9 5.5 7/32 80 3.1 .13 10 T20 100 3.9 4.0 5/32 100 3.9 .10 10 T20 200 7.9 5.5 7/32 100 3.9 .17 10 T25 100 3.9 4.0 5/32 100 3.9 .11 10 T25 200 7.9 5.5 7/32 100 3.9 .17 10 T27 100 3.9 5.5 7/32 100 3.9 .14 10 T27 200 7.9 5.5 7/32 100 3.9 .17 10 T30 100 3.9 7.9 6.0 100 3.9 .14 10 T30 200 7.9 6.0 1/4 100 3.9 .19 10 T40 100 3.9 7.0 9/32 100 3.9 .16 10 T40 200 7.9 7.0 9/32 100 3.9 .23 10 T45 150 5.9 8.0 5/16 120 4.7 .29 10 T50 150 5.9 9.0 3/8 120 4.7 .30 10 T50 250 9.8 9.0 3/8 120 4.7 .45 10 Two Tools In One! Through the handle side driver Short and Long Arm In One Powerful Tool Two component soft grip handle Torx - Blades of CVM tool steel, through hardened durability, hard chrome finish Maximum Comfort & Maximum Power 36492 T-handle Set, 7 Pc. Includes T9, T10, T15, T20, T25, T27, T30 Item No. lbs. pkg. 36492 1.24 1 T-handle Set, 7 Pc. 36490 In Metal Stand Equiped with T10, T15, T20, T25, T30, T40, T50 Item No. lbs. pkg. 36490 2.65 1 Soft grips are molded on & include through the handle side torque drive 364 Item No. 36480 36481 36482 36483 36484 36486 36487 Soft Grip T-handle Size mm lbs. pkg. T10 100 .08 10 T15 100 .08 10 T20 100 .13 10 T25 150 .16 10 T27 150 .19 10 T30 150 .20 10 T40 150 .24 10 36497 7 Piece Set Soft Grip T-handles Item No. T10, T15, T20, T25, lbs. 36497 T27, T30, T40 1.53 36494 T-handle Set, 8 Pc. In Metal Stand Equipped with T9, T10, T15, T20, T25, T27, T30, T40 Item No. lbs. pkg. 3.10 1 36494 Toll Free: (800) 494-6104 14 Wiha Tools Wing Handle 10 Packs & 2 Packs Ideal for use with indexable carbide tooling and also for working in confined spaces 365 Screwdriver, With Wing Handle - 10 Pack Blade high alloy CVM steel, hardened, black finish. Wing handle high quality plastic, impact resistant. Item No. Size mm Inch mm Inch mm Inch lbs. pkg. 36511 T6 35 1.4 70 2.7 40 1.6 .02 10 36513 T7 35 1.4 70 2.7 40 1.6 .02 10 36514 T8 40 1.6 75 2.9 40 1.6 .02 10 36534 T9 40 1.6 75 2.9 40 1.6 .02 10 36536 T10 40 1.6 75 2.9 40 1.6 .02 10 36537 T15 45 1.8 80 3.1 40 1.6 .02 10 36538 T20 45 1.8 80 3.1 40 1.6 .02 10 365 Item No. 36516 36517 36518 36519 36521 36522 36523 36591 Wing Handle Set, 7 Pc. Set includes: T6, T7, T8, T9, T10, T15, T20 wt. .16 Screwdriver, With Wing Handle - 2 Pack Size mm Inch mm Inch mm Inch lbs. pkg. T6 35 1.4 70 2.7 40 1.6 .02 2 T7 35 1.4 70 2.7 40 1.6 .02 2 T8 40 1.6 75 2.9 40 1.6 .02 2 T9 40 1.6 75 2.9 40 1.6 .02 2 T10 40 1.6 75 2.9 40 1.6 .02 2 T15 45 1.8 80 3.1 40 1.6 .02 2 T20 45 1.8 80 3.1 40 1.6 .02 2 Wiha 36590 Wing Handle Set, 7 Pc. In Metal Stand Set includes: T6, T7, T8, T9, T10, T15, T20 wt. .32 Tools Flag Handle 10 Packs & 2 Packs Ideal for use with indexable carbide tooling and also for working in confined spaces 370 Screwdriver, With Flag Handle - 10 Pack Blade high alloy CVM steel, hardened, black finish. Flag handle high quality plastic, impact resistant. Item No. Size mm Inch mm Inch mm Inch lbs. pkg. 37055 T5 35 1.4 63 2.6 15.0 .75 .01 10 37056 T6 35 1.4 63 2.6 15.0 .75 .01 10 37057 T7 35 1.4 67 2.6 19.0 .75 .01 10 37058 T8 40 1.6 72 2.8 19.0 .75 .01 10 37059 T9 40 1.6 74 2.9 23.5 .93 .01 10 37060 T10 40 1.6 74 2.9 23.5 .93 .01 10 37061 T15 45 1.8 80 3.1 28.0 1.10 .02 10 37062 T20 45 1.8 80 3.1 28.0 1.10 .02 10 370 Item No. 37005 37006 37007 37008 37009 37010 37011 37012 37091 Flag Handle Set, 7 Pc. Set includes: T6, T7, T8, T9, T10, T15, T20 wt. .14 Screwdriver, With Flag Handle - 2 Pack Size mm Inch mm Inch mm Inch lbs. pkg. T5 35 1.4 63 2.6 15.0 .75 .01 2 T6 35 1.4 63 2.6 15.0 .75 .01 2 T7 35 1.4 67 2.6 19.0 .75 .01 2 T8 40 1.6 72 2.8 19.0 .75 .01 2 T9 40 1.6 74 2.9 23.5 .93 .01 2 T10 40 1.6 74 2.9 23.5 .93 .01 2 T15 45 1.8 80 3.1 28.0 1.10 .02 2 T20 45 1.8 80 3.1 28.0 1.10 .02 2 37090 Flag Handle Set, 7 Pc. In Metal Stand Set includes: T6, T7, T8, T9, T10, T15, T20 wt. .31 www.wihatools.com 15 Wiha Ball End Screwdrivers • Ball End For 25 Angle Driving • Precision Machined Exact Fit Tips • Through Hardened For Maximum Durability • WIHA High Performance CRM-72 Tool Steel • Guaranteed Quality Made By Wiha O 25O 25O 362 Ball End Screwdriver, With Wiha-SoftFinish® Handle Blade high alloy chrome-vanadium-molybdenum steel, hardened, hard chromed. Wiha-Chromtop finish on tips. Wiha-SoftFinish® handle, multi-component, cushion grips. Item No. Size mm Inch mm Inch mm Inch lbs. pkg. 36216 T9 60 2.4 4.0 .157 164 6.5 .10 10 36217 T10 60 2.4 4.0 .157 184 7.2 .11 10 36221 T15 80 3.1 4.0 .157 191 7.5 .11 10 36222 T20 80 3.1 4.0 .157 211 8.3 .11 10 36226 T25 100 3.9 4.5 .177 218 8.6 .12 10 36227 T27 115 4.5 5.5 .216 233 9.2 .19 10 36236 T30 115 4.5 6.0 .236 233 9.2 .20 10 Wiha Ball End 25O 366 Ball End L-key, Long Arm High alloy CVM steel, hardened, black finish. Item No. Size mm Inch mm Inch lbs. pkg. 36631 T9 111 4.4 21 .83 .17 10 36632 T10 121 4.8 23 .91 .23 10 36633 T15 136 5.4 27 1.1 .33 10 36634 T20 148 5.8 29 1.1 .44 10 36635 T25 163 6.4 33 1.3 .65 10 36636 T27 176 6.9 36 1.4 .98 10 36637 T30 191 7.5 38 1.5 1.27 10 36638 T40 210 8.3 43 1.7 2.09 10 36639 T45 232 9.1 50 2.0 2.34 10 L-keys 25O 36692 Ball End L-key Set, 8 Pc. in Plastic Holder Equipped with T9, T10, T15, T20, T25, T27, T30, T40 Item No. lbs. pkg. 6.16 1 36692 36237 Set 7 Pcs. Blade high alloy CVM steel, hardened, hard chromed. Wiha-Chromtop finish on tips. SoftFinish® handle, multi-component, cushion grips. Item No. Size mm Size mm lbs. T9 60 T25 100 1.24 36237 T10 60 T27 115 T15 80 T30 115 T20 80 Ball End 745 Ball End Power Bits 1/4” Hex Drive, Length 2.0”/50mm Item No. Size mm pkg. lbs. T9 50 10 .18 74524 T10 50 10 .18 74526 T15 50 10 .18 74528 T20 50 10 .18 74532 T25 50 10 .18 74534 T27 50 10 .18 74537 T30 50 10 .18 74539 T40 50 10 .18 74541 2 bit pack 25O Wiha ErgoStar Ball End Long L-keys 25 O 36689 ErgoStar Long Arm Set, 13 Pc. In Molded Holder Equipped with T5, T6, T7, T8, T9, T10, T15, T20, T25, T27, T30, T40, T45 Item No. lbs. pkg. 1.08 1 36689 Power Bits 745 Item No. 74505 74520 74522 74543 74545 74547 74549 74550 Ball End Power Bit Packs, 1” Size mm lbs. T9 50 .05 T10 50 .05 T15 50 .05 T20 50 .05 T25 50 .06 T27 50 .06 T30 50 .08 T40 50 .08 Toll Free: (800) 494-6104 16 The Advantage Wiha PocketStar Fold Out The TorxPlus® Drive System offers 100% improvement in driver bit fatigue & 25% average improvement in driver bit torsional strength. In addition its unique design provides optimum torque transfer & eliminates the need for excessive end load pressure while driving the fastener. The TorxPlus® configuration also virtually eliminates tool “camout” & slippage that can damage the head of the fastener and cause reduced tool life. 60o 0o Push button key release Not for use in standard Torx fasteners • Broad Surface For Driving • Features 0O Drive Angle Between The Fastener & Driver • Greater Engagement Depth Wiha Tools 2 Packs & 10 Packs 36697 PocketStar Fold Outs, 8 Pc. Set High alloy CVM steel, hardened, molded ergonomic handle. Item No. PocketStar lbs. .31 : IP6, IP7, IP8, IP9, 36697 IP10, IP15, IP20, IP25 Not for use in standard Torx fasteners 370 Screwdriver, With Flag Handle - 2 & 10 Packs Ideal for use with indexable carbide tooling and also for working in confined spaces. Blade high alloy CVM steel, hardened, black finish. Flag handle high quality plastic, impact resistant. Item Item No. Size mm Inch mm Inch mm Inch lbs. pkg. No. Size pkg. IP5 35 1.4 63 2.6 15.0 .75 .01 10 37063 IP5 2 37014 IP6 35 1.4 63 2.6 15.0 .75 .01 10 37064 IP6 2 37015 IP7 35 1.4 67 2.6 19.0 .75 .01 10 37065 IP7 2 37017 IP8 40 1.6 72 2.8 19.0 .75 .01 10 37066 IP8 2 37018 IP9 40 1.6 74 2.9 23.5 .93 .01 10 37067 IP9 2 37021 IP10 40 1.6 74 2.9 23.5 .93 .01 10 37068 IP10 2 37023 IP15 45 1.8 80 3.1 28.0 1.10 .02 10 37069 IP15 2 37024 IP20 45 1.8 80 3.1 28.0 1.10 .02 10 37070 IP20 2 37027 37092 Flag Handle Set, 7 Pc. in Metal Stand Set includes: lbs. .31 IP6, IP7, IP8, IP9, IP10, IP15, IP20 Not for use in standard Torx fasteners 7 Pc. Wing Handle 36592 Set In Metal Stand. Equipped with IP6, IP7, IP8, IP9, IP10, IP15, IP20 Item No. lbs. pkg. .38 1 36592 365 Screwdriver, With Wing Handle - 2 & 10 Packs Blade high alloy CVM steel, hardened, black finish. Wing handle high quality plastic, impact resistant. Item Item No. Size mm Inch mm Inch mm Inch lbs. pkg. No. Size pkg. 36539 36524 IP5 35 1.4 70 2.7 40 1.6 .02 10 IP5 2 36541 36526 IP6 35 1.4 70 2.7 40 1.6 .02 10 IP6 2 36543 36527 IP7 35 1.4 70 2.7 40 1.6 .02 10 IP7 2 36545 36528 IP8 40 1.6 75 3.0 40 1.6 .02 10 IP8 2 36547 36529 IP9 40 1.6 75 3.0 40 1.6 .02 10 IP9 2 36549 36531 IP10 40 1.6 75 3.0 40 1.6 .02 10 IP10 2 36551 36532 IP15 45 1.8 80 3.1 40 1.6 .02 10 IP15 2 36553 36533 IP20 45 1.8 80 3.1 40 1.6 .02 10 IP20 2 www.wihatools.com 17 Wiha Cushion Grip Drivers Not for use in standard Torx fasteners 362 Round blade Item No. 36211 36223 36228 36229 36233 36238 36239 36243 36248 36253 36255 362 Round blade Item No. 36214 36231 36232 36241 36242 36246 36247 36252 36262 36263 36265 Screwdriver With Wiha SoftFinish Handle high alloy CVM tool steel, hardened, hard chromed. Wiha-Chromtop finish on tips. Size IP6 IP7 IP8 IP9 IP10 IP15 IP20 IP25 IP27 IP30 IP40 mm Inch 60 2.4 60 2.4 60 2.4 60 2.4 80 3.1 80 3.1 100 3.9 100 3.9 115 4.5 115 4.5 130 5.1 mm Inch 3.5 .139 3.5 .139 4.0 .157 4.0 .157 4.0 .157 4.0 .157 4.5 .177 5.5 .216 6.0 .236 7.0 .275 7.0 .275 mm Inch lbs. pkg. 164 6.5 .06 10 164 6.5 .06 10 171 6.7 .10 10 171 6.7 .11 10 191 7.5 .11 10 191 7.5 .11 10 211 8.3 .11 10 211 8.3 .19 10 233 9.2 .20 10 233 9.2 .28 10 254 10.0 .28 10 Screwdriver With Wiha SoftFinish Handle In Clamshell high alloy CVM tool steel, hardened, hard chromed. Wiha-Chromtop finish on tips. Size IP6 IP7 IP8 IP9 IP10 IP15 IP20 IP25 IP27 IP30 IP40 mm Inch 60 2.4 60 2.4 60 2.4 60 2.4 80 3.1 80 3.1 100 3.9 100 3.9 115 4.5 115 4.5 130 5.1 mm Inch 3.5 .139 3.5 .139 4.0 .157 4.0 .157 4.0 .157 4.0 .157 4.5 .177 5.5 .216 6.0 .236 7.0 .275 7.0 .275 mm Inch lbs. pkg. 164 6.5 .06 1 164 6.5 .06 1 171 6.7 .10 1 171 6.7 .11 1 191 7.5 .11 1 191 7.5 .11 1 211 8.3 .11 1 211 8.3 .19 1 233 9.2 .20 1 233 9.2 .28 1 254 10.0 .28 1 36296 Set 6 Pcs. Blade high alloy CVM steel, hardened, hard chromed. Wiha-SoftFinish handle, multi-component. Item No. IP6, IP7, IP8, IP9 .72 36296 IP10, IP15 Set 7 Pcs. Blade high 36299 alloy CVM steel, hardened, hard chromed. Wiha-SoftFinish handle, multi-component. Item No. IP8, IP10, IP15, IP20, lbs. 36299 IP25, IP30, IP40 1.23 36297 Set 8 Pcs. Blade high alloy CVM steel, hardened, hard chromed. Wiha-SoftFinish handle, multi-component. Item No. IP6, IP7, IP8, IP9 lbs. 36297 IP10, IP15, IP20, IP25 1.35 Wiha T-handle Not for use in standard Torx fasteners 364 Screwdriver, With Wiha T-handle Blade high alloy chrome-vanadium-molybdenum steel, hardened, hard chromed. Wiha T-handle high quality plastic, impact resistant. Item No. Size mm Inch mm Inch mm Inch lbs pkg. 36461 IP9 100 3.9 4.0 .157 80 3.1 .07 10 36463 IP10 100 3.9 4.0 .157 80 3.1 .07 10 36466 IP15 100 3.9 4.0 .157 80 3.1 .07 10 36469 IP20 100 3.9 4.0 .157 80 3.1 .10 10 36472 IP25 150 5.9 8.0 .315 120 4.7 .13 10 36474 IP27 150 5.9 8.0 .315 120 4.7 .14 10 36476 IP30 150 5.9 8.0 .315 120 4.7 .16 10 36478 IP40 150 5.9 8.0 .315 120 4.7 .20 10 36496 Set 6 Pc. T-handles Blade CVM steel, hardened, hard chromed. Chromtop blade tips. Wiha T-handle high quality plastic, impact resistant. Item No. Size mm Size mm lbs. IP10 100 IP25 150 1.01 36496 IP15 100 IP27 150 IP20 100 IP30 150 Toll Free: (800) 494-6104 18 MagicSpring Tools For Improved Torque and Longer Tool Life Not for use in standard Torx fasteners 361 L-key, Short Arm High alloy CVM steel, hardened, black finish. Item No. Size mm Inch mm Inch lbs. 36106 IP6 39 1.5 16 .6 .01 36107 IP7 42 1.7 16 .6 .01 36108 IP8 45 1.8 16 .6 .01 36109 IP9 48 1.9 16 .6 .01 36110 IP10 51 2.0 17 .7 .01 36115 IP15 55 2.2 19 .7 .01 36120 IP20 58 2.3 19 .7 .01 36125 IP25 63 2.5 21 .8 .01 36127 IP27 68 2.7 22 .9 .02 36130 IP30 73 2.9 24 .9 .03 36140 IP40 81 3.2 26 1.0 .05 36197 L-key, Short Arm, 7 Pc. Set In Holder High alloy CVM steel, hardened, black finish. Item No. 36197 lbs. Set includes the following L-keys: .10 IP6, IP7, IP8, IP9, IP10, IP15, IP20 L-key, Short Arm, 36199 9 Pc. Set In Holder Item Set includes the following L-keys: No. lbs. IP8, IP9, IP10, IP15, IP20, 36199 .30 IP25, IP27, IP30, IP40 Not for use in standard Torx fasteners 366 L-key, Long Arm High alloy CVM steel, hardened, black finish. Item No. Size mm Inch mm Inch lbs. IP6 64 2.5 14 .6 .01 36606 IP7 68 2.7 14 .6 .01 36607 IP8 74 2.9 15 .6 .01 36608 IP9 78 3.1 16 .6 .01 36609 IP10 83 3.3 18 .7 .01 36610 IP15 88 3.5 18 .7 .02 36615 IP20 94 3.7 18 .7 .02 36620 IP25 98 3.9 19 .7 .03 36625 IP27 107 4.2 23 .9 .05 36627 IP30 114 4.5 24 .9 .06 36630 IP40 118 4.6 27 1.0 .09 36640 36690 L-key, Long Arm, 7 Pc. Set In Holder High alloy CVM steel, hardened, black finish. Item No. lbs. Set includes the following L-keys: .22 IP6, IP7, IP8, IP9, IP10, IP15, IP20 36690 36691 L-key, Long Arm, 9 Pc. Set In Holder Item Set includes the following L-keys: No. lbs. IP8, IP9, IP10, IP15, IP20, 36691 .35 IP25, IP27, IP30, IP40 371 MagicSpring Screw Holding L-key, Long Arm High alloy CVM steel, hardened, black finish. Item No. Size mm Inch mm Inch lbs. T6 14 .55 80 3.1 .001 37106 T7 16 .63 88 3.5 .002 37107 T8 18 .71 101 4.0 .003 37108 T9 19 .75 111 4.4 .005 37109 T10 21 .83 121 4.8 .007 37110 T15 22 .87 136 5.4 .009 37115 T20 25 .98 148 5.8 .01 37120 T25 28 1.1 163 6.4 .02 37125 T27 30 1.2 176 6.9 .03 37127 T30 34 1.3 191 7.5 .04 37130 T40 36 1.4 210 8.3 .07 37140 MagicSpring Long Arm Screw 37190 Holding Set, 7 Pc. in Plastic Holder Equipped with T6, T7, T8, T9, T10, T15, T20 Item No. lbs. pkg. .20 1 37190 MagicSpring Long Arm Screw 37192 Holding Set, 10 Pc. in Plastic Holder T6, T7, T8, T9, T10, T15, T20, T25, T27, T30 Item No. lbs. pkg. .35 1 37192 Laser Welded MagicSpring Assembly www.wihatools.com 19 Wiha MagicSpring • • • • • • • Laser welded assembly Holds screws securely Won’t damage screws Doesn’t weaken tool Exact fit tips Hardened tool steel blades Holds standard Torx screws* Tools Screw Holding TORX® Stainless Rotary Spring Wiha-Chromtop finish on tips Wiha-SoftFinish® handle, multicomponent, cushion grips 362 MagicSpring Screw Holding Driver, With Wiha-SoftFinish® Handle Round blade high alloy CVMm steel, hardened, hard chromed. Item No. Size mm Inch mm Inch mm Inch lbs. pkg. T6 60 2.4 3.5 .139 164 6.5 .07 10 36202 T7 60 2.4 3.5 .139 164 6.5 .07 10 36203 T8 60 2.4 3.5 .139 164 6.5 .07 10 36207 T9 60 2.4 4.0 .157 171 6.7 .11 10 36234 T10 80 3.1 4.0 .157 191 7.5 .11 10 36244 T15 80 3.1 4.0 .157 191 7.5 .11 10 36249 T20 100 3.9 4.0 .157 211 8.3 .16 10 36254 T25 100 3.9 4.5 .177 211 8.3 .17 10 36256 T27 115 4.5 5.5 .216 233 9.2 .20 10 36257 T30 115 4.5 6.0 .236 233 9.2 .21 10 36258 Stainless Rotary Spring 365 MagicSpring Screw Holding driver, With Wing Handle Ideal for use with indexable carbide tooling and also for working in confined spaces. Blade high alloy CVM steel, hardened, black finish. Wing handle high quality plastic, impact resistant. Molded on. Item No. Size mm Inch mm Inch mm Inch lbs. pkg. T6 35 1.4 70 2.7 40 1.6 .01 10 36556 T7 35 1.4 70 2.7 40 1.6 .02 10 36557 T8 40 1.6 75 3.0 40 1.6 .02 10 36558 T9 40 1.6 75 3.0 40 1.6 .02 10 36559 T10 40 1.6 75 3.0 40 1.6 .02 10 36560 T15 45 1.8 80 3.1 40 1.6 .02 10 36561 T20 45 1.8 80 3.1 40 1.6 .02 10 36562 Screw Holding Tools 36598 MagicSpring Screw Holding Wing Handle Set, Pc. in Metal Stand Equipped with T6, T7, T8, T9, T10, T15, T20 .36 lbs. 36290 Set 6 Pcs. MagicSpring Screw Holding SoftFinish Screwdrivers Round blade high alloy CVM steel, hardened, hard chromed. Wiha-Chromtop finish on tips. Wiha-SoftFinish® handle, multi-component, cushion grips. Molded on. Item No. Size mm Size mm lbs. T8 60 T20 100 .98 36290 T10 80 T25 100 T15 80 T30 115 *MagicSpring tools will hold Torx® screws made to CamCar Textron Torx® specifications 267 MagicSpring Screw Holding Driver, With Wiha-Precision PicoFinish Handle Blade high alloy CVM steel, hardened, hard chromed. Molded on ergo Wiha-Pico Finish precision handle, molded on, soft grips. Item No. 26721 26723 26725 26727 26729 26731 Size mm Inch mm Inch lbs. pkg. T6 40 1.6 140 5.5 .03 10 T7 40 1.6 140 5.5 .03 10 T8 40 1.6 140 5.5 .03 10 T9 50 2.0 150 5.9 .04 10 T10 50 2.0 150 5.9 .04 10 T15 60 2.4 160 6.3 .04 10 26798 Set 6 Pcs. MagicSpring Screw Holding Screwdriver, With WihaPrecision PicoFinish Handle Blade high alloy CVM steel, hardened, hard chromed. Molded on ergonomic Wiha-Pico Finish precision handle, molded on, soft grips. Item No. Size mm Size mm lbs. 26798 T6 40 T9 50 .45 T7 40 T10 50 T8 40 T15 60 Toll Free: (800) 494-6104 20 Wiha TorqueControl Screwdrivers Molded cushion grip two component handles allow for maximum achievable torque to be reached with comfort Precise repeatability! All TorqueVario tools are tested and comply with: TorqueVario models include torque setting adjustment tool • EN ISO 6789 • BS EN 26789 • ASME B107.14M Each tool has unique serial number and certificate of calibration See 4mm Micro Bits on Page 25 and Micro Bit holder Blades For TorqueFix 285 & TorqueVario tip blades on narrow 5/32 Hex shafts. High alloy CVM steel, hardened, satin hard chrome finish. Item Max. No. Size mm mm lbs. Nm pkg. IP5 175 4.0 .07 0.5 1 28571 IP6 175 4.0 .07 0.8 1 28572 IP7 175 4.0 .07 1.3 1 28573 IP8 175 4.0 .07 2.0 1 28574 IP9 175 4.0 .07 3.0 1 28575 IP10 175 4.0 .07 4.5 1 28576 IP15 175 4.0 .07 6.6 1 28577 IP20 175 4.0 .07 8.0 1 28578 IP25 175 4.0 .07 8.0 1 28579 Direct Reading Scale Screw g Holdin +/-6% accuracy tolerance Certificate of calibration 285 Adjustable TorqueVario With Direct Reading Scale EN ISO 6789, BS EN 26789, ASME B107.14M. Ergonomic molded multi-component handle, light and compact. Handle sizes proportioned to optimize torque range. Audible and perceptible click when the torque setting has been attained, automatically resets for next torque cycle. Pkg. 1 Item Range No. Inch lbs. Increments mm 28501 15 - 80(in/oz) 2.5 In.oz. 127 28502 5 - 10 .5 In.lbs. 127 28506 10 - 50 2 In.lbs. 138 · 28501 +/- 10% (This unit only)* Item No. 28404 28408 Range Inch lbs. Increments mm 5 - 18 .5 in/lbs. 131 18 - 62 2 In.lbs. 142 +/-6% accuracy tolerance Certificate of calibration 285 Adjustable TorqueVario-S Handle In Newton Meter Scale EN ISO 6789, BS EN 26789, ASME B107.14M. Ergo molded multi-component handle, light & compact. Handle sizes proportioned to optimize torque range. Audible & perceptible click when the torque setting has been attained, automatically resets for next torque cycle. Pkg. 1 Item Newton No. Meter Scale Increments mm 28550 0.1 - 0.6Nm .02 Nm 127 28551 0.4 - 1.0Nm .05 Nm 127 28552 0.5 - 2.0Nm .10 Nm 131 28553 0.8 - 5.0Nm .20 Nm 138 28655 2.0 - 7.0Nm .25 Nm 142 MagicSpring Blades 285 For TorqueFix & TorqueVario blades on narrow 5/32 Hex shafts. High alloy CVM steel, hardened, satin hard chrome finish. Item Max. No. Size mm mm lbs. Nm pkg. T6 175 4.0 .07 0.6 1 28512 T7 175 4.0 .07 0.9 1 28527 28528 T8 175 4.0 .07 1.3 1 28529 T9 175 4.0 .07 2.5 1 28530 T10 175 4.0 .07 3.8 1 28531 T15 175 4.0 .07 5.5 1 28532 T20 175 4.0 .07 8.0 1 28533 T25 175 4.0 .07 8.0 1 * +/- 10% (This unit only) Screw g Holdin 285 Interchangeable Blades For TorqueFix & TorqueVario tip blades on narrow 5/32 Hex shafts. High alloy CVM steel, hardened, satin hard chrome finish. Item Max. No. Size mm mm lbs. Nm pkg. T5 175 4.0 .07 0.4 1 28561 T6 175 4.0 .07 0.6 1 28562 T7 175 4.0 .07 0.9 1 28563 T8 175 4.0 .07 1.3 1 28564 T9 175 4.0 .07 2.5 1 28565 T10 175 4.0 .07 3.8 1 28566 T15 175 4.0 .07 5.5 1 28567 T20 175 4.0 .07 8.0 1 28568 T25 175 4.0 .07 8.0 1 28569 286 MagicSpring Interchangeable Blades For TorqueFix & TorqueVario blades on narrow 5/32 Hex shafts. High alloy CVM steel, hardened, satin hard chrome finish. Item Max. No. Size mm mm lbs. Nm pkg. 28611 IP6 175 4.0 .07 0.8 1 28612 IP7 175 4.0 .07 1.3 1 28613 IP8 175 4.0 .07 2.0 1 28614 IP9 175 4.0 .07 3.0 1 28616 IP10 175 4.0 .07 4.5 1 28617 IP15 175 4.0 .07 6.6 1 28618 IP20 175 4.0 .07 8.0 1 28619 IP25 175 4.0 .07 8.0 1 *None of the blades featured on this page will function in a TorqueVario Insulated Handle www.wihatools.com 21 Wiha Easy Torque Handles Wiha Insulated TorqueControl Tools * Includes Certificate 292 easyTorque Screwdriver Handle With Blades easyTorque value pre-set. Release accuracy +/- 10%. Internal mechanism clicks when torque value has been attained. Cushion grip comfortable handle for good power transfer. easyTorque Screwdriver Handle 292 With Blades easyTorque value pre-set. Release accuracy +/- 10%. Internal mechanism clicks when torque value has been attained. Cushion grip comfortable handle for good power transfer. Item Pre-Sets No. Size Inch/lbs. Nm lbs. pkg. 29232 T5 4.4 0.5 .24 1 29233 T6 5.3 0.6 .24 1 29234 T7 8.0 0.9 .24 1 29236 T8 10.6 1.2 .25 1 29237 T9 12.4 1.4 .25 1 29239 T10 17.7 2.0 .26 1 29242 T15 26.6 3.0 .26 1 29243 T20 35.4 4.0 .26 1 29244 T25 44.2 5.0 .28 1 Item Pre-Sets No. Size Inch/lbs. Nm lbs. pkg. 29246 IP5 4.4 0.5 .24 1 29247 IP6 5.3 0.6 .24 1 29248 IP7 8.0 0.9 .24 1 29249 IP8 10.6 1.2 .25 1 29252 IP9 12.4 1.4 .25 1 29253 IP10 17.7 2.0 .26 1 29254 IP15 26.6 3.0 .26 1 29255 IP20 35.4 4.0 .26 1 29256 IP25 44.2 5.0 .28 1 * No Calibration Certificates * No Calibration Certificates TorqueFix Key Wing Handles & Blades EN ISO 6789, BS EN 26789, ASME B107.14M 283 TorqueFix Wing Handles Audible & perceptible click when torque setting has been attained. Item No. Nm mm Inch pkg. lbs. 0.5 68 2.7 1 .28 28349 0.6 68 2.7 1 .28 28351 0.9 68 2.7 1 .28 28352 1.1 68 2.7 1 .28 28353 1.2 68 2.7 1 .28 28354 1.4 68 2.7 1 .28 28355 2.0 68 2.7 1 .28 28356 2.5 68 2.7 1 .28 28357 3.0 68 2.7 1 .28 28358 3.8 68 2.7 1 .28 28359 4.0 68 2.7 1 .28 28360 Compact design specially used for hard to reach screws and confined spaces CVM steel, through-hardened, titanium silver blades * Requires SlimLine Blades 1000Volt 287 Insulated TorqueVario-S, With Window Scale Insulation up to 1000Volt EN ISO, BS EN, ASME, VDE, ASTM & NFPA70E standards, +/- 6% Accuracy. Handle sizes proportioned to optimize torque range. Audible and perceptible click when torque setting has been attained. Includes SlimLine blade holder. Item Range No. Inch lbs. Increments mm lbs. pkg. 28750 5 - 18 .5 In.lbs. 131 .43 1 28751 10 - 50 2 In.lbs. 138 .40 1 28752 18 - 62 2 In.lbs. 142 .69 1 Each TorqueVario handle has unique serial number and certificate of calibration +/- 6% Accuracy Includes Calibration Certificate * Includes SlimLine blade holder #28350 283 Blades For TorqueFix Wing Handles Item Max No. Size Nm Inch pkg. 28374 T6 0.6 3.0 1 28375 T7 0.9 3.0 1 28376 T8 1.3 3.0 1 28377 T9 2.5 3.0 1 28378 T10 3.8 3.0 1 28379 T15 5.5 3.0 1 28380 T20 8.0 3.0 1 28381 T25 8.0 3.0 1 Blades For 283 TorqueFix Wing Handles Item Max No. Size Nm Inch pkg. IP6 0.8 3.0 1 28382 IP7 1.3 3.0 1 28383 IP8 2.0 3.0 1 28384 IP9 3.0 3.0 1 28385 IP10 4.5 3.0 1 28386 IP15 6.6 3.0 1 28387 IP20 8.0 3.0 1 28388 IP25 8.0 3.0 1 28389 287 Insulated TorqueVario-S Handle In Newton Meter Scale Includes SlimLine blade holder Item Range No. Nm mm lbs. pkg. 0.5 - 2.0 131 .45 1 28740 1.0 - 5.0 138 .45 1 28741 2.0 - 7.0 142 .72 1 28742 283 Insulated SlimLine Blades High quality CV steel, through hardened. SlimLine blades have up to 33% narrower insulation diameter then standard insulated tools. Item Slim Max Inch/ No. Size Dia. Nm lbs. lbs. pkg. 1 T8 4.0 1.3 11.5 .02 28339 1 T9 4.0 1.3 11.5 .02 28344 1 T10 4.0 3.8 33.6 .02 28340 1 T15 6.0 5.5 48.7 .02 28341 1 T20 6.0 5.5 48.7 .02 28342 1 T25 6.0 5.5 48.7 .02 28343 Toll Free: (800) 494-6104 22 Wiha TorqueControl Tool Sets T-handle TorqueControl Tools Each TorqueFix T-handle has unique serial number and certificate of calibration Accuracy Ergonomic multi-component handle, light & compact Includes Calibration Certificate 28597 8 Pc. TorqueControl Set With Blades Certified to EN ISO 6789, BS EN 26789, ASME B107.14M 28597 lbs. 1.01 : T7, T8, T9, T10, T15, T20 28506 - Handle Range 10 - 50 In/lbs. With Certificate of Calibration 28598 8 Piece TorqueControl Set With Blades Certified to EN ISO 6789, BS EN 26789, ASME B107.14M lbs. 1.00 28598 IP7, IP8, IP9, IP10, IP15, IP20 28506 - Handle Range 10 - 50 In/lbs. With Certificate of Calibration TorqueFix T-handle EN ISO 289 BS EN 26789, ASME B107.14M, +/- 6% Item Torque Torque No. In-lbs. Nm mm x mm lbs. 28931 53.1 6 56 x 120 .81 28933 70.8 8 56 x 120 .82 28935 88.5 10 56 x 120 .79 28937 106.2 12 56 x 120 .79 28938 110.6 12.5 56 x 120 .80 28939 123.9 14 56 x 120 .80 Includes Calibration Certificate 6789, pkg. 1 1 1 1 1 1 Adjustable TorqueVario STplus 28940 T-handle EN ISO 6789, BS EN 26789, ASME B107.14M, +/- 6% Item No. 28940 Torque Torque Nm In-lbs. mm x mm lbs. pkg. 5-14 44.3-123.9 56 x 120 .81 1 * (1 Nm 8.8507) (Scale is shown in Nm only) 289 Interchangeable Blades For TorqueFix T-Handle tip blades on 6mm Hex shafts. High alloy CVM steel, hardened, hard chromed. Interchangeable Blades 289 For TorqueFix T-Handle tip blades on 6mm Hex shafts. High alloy CVM steel, hardened, hard chromed. Item No. 28903 28904 28905 28906 28907 28908 Item No. 28910 28911 28912 28913 28914 28915 Size mm Inch mm lbs. pkg. T15 130 5.1 6.0 .10 1 T20 130 5.1 6.0 .10 1 T25 130 5.1 6.0 .11 1 T27 130 5.1 6.0 .11 1 T30 130 5.1 6.0 .11 1 T40 130 5.1 6.0 .11 1 Size mm IP15 130 IP20 130 IP25 130 IP27 130 IP30 130 IP40 130 Inch mm lbs. 5.1 6.0 .10 5.1 6.0 .10 5.1 6.0 .11 5.1 6.0 .11 5.1 6.0 .11 5.1 6.0 .11 pkg. 1 1 1 1 1 1 ESD Safe Adjustable TorqueControl Tools Each TorqueVario handle has unique serial number and certificate of calibration 28599 14 Piece TorqueControl Set With & Blades Certified to EN ISO 6789, BS EN 26789, ASME B107.14M. Set includes Ergonomic multi-component adjustable TorqueVario-S handle, 12 blades & Torque adjustment tool. Packed in a durable canvas pouch. : lbs. 1.25 IP7, IP8, IP9, IP10, IP15, IP20 : T7, T8, T9, T10, T15, T20 28506 - Handle Range 10 - 50 In/lbs. With Certificate of Calibration D Includes Certificate 285 ESD Safe TorqueVario-S, With Window Scale EN ISO 6789, BS EN 26789, ASME B107.14M, +/- 6% Accuracy. Ergonomic multi-component handle, light and compact. Handle sizes proportioned to optimize torque range. Audible & perceptible click when torque setting has been attained. With Certificate of accuracy. Pkg. 1 Item Range No. Inch lbs. Increments mm 28522* 15-80(in/oz) 2.5 In.oz. 122-127 28524 5-10 .2 In.lbs. 122-127 28526 7.5-20 .5 In.lbs. 126-131 Item Range No. Nm mm Inch lbs. 28500* .04 - .46 124 4.875” .35 * +/- 10% (This unit only) lbs. .33 .34 .42 pkg. 1 D ESD Safe Interchangeable 288 Blades For TorqueVario-S tip blades on narrow 5/32 Hex shafts. High alloy CVM steel, hardened, hard chromed. Item Max. Torque No. Size mm mm Nm lbs. pkg. 1 28825 T5 175 4.0 0.4 .07 1 T7 175 4.0 0.9 .07 28827 1 T9 175 4.0 2.5 .07 28829 D 288 ESD Pentalobe Interchangeable Blades For TorqueVario-S Newton Meter Handle tip blades on narrow 5/32 Hex shafts. Item No. Size mm mm lbs. pkg. 28818 PL1 175 4.0 .07 1 www.wihatools.com 23 Wiha Precision Series 267 Screwdriver, With Precision Handle Blade high alloy chromevanadium-molybdenum steel. Item No. Size mm Inch mm Inch lbs. pkg. T1 40 1.6 120 4.7 .01 10 26701 T2 40 1.6 120 4.7 .02 10 26702 T3 40 1.6 120 4.7 .02 10 26703 T4 40 1.6 120 4.7 .02 10 26704 T5 40 1.6 120 4.7 .02 10 26705 T6 40 1.6 120 4.7 .02 10 26706 T7 40 1.6 120 4.7 .02 10 26707 T8 40 1.6 120 4.7 .03 10 26708 T9 50 2.0 145 5.7 .03 10 26709 T10 50 2.0 145 5.7 .03 10 26710 T15 60 2.4 170 6.7 .05 10 26715 T20 60 2.4 170 6.7 .05 10 26720 *Metric dimensions actual - Inch dimensions approximate 26791 Item No. 26791 8 Pcs. Screwdriver Set T1, T2, T3, T4, T5, T6, T7, T8 26799 8 Pc. Screwdriver Set Blade high alloy chrome-vanadiummolybdenum steel. Hard chrome finished. In canvas storage pouch Item : T3, T4, T5, No. T6, T7, T8 x 40mm lbs. 26799 T9 x T10 x 50mm .50 6 Pc. Screwdriver Set 26790 Blade high alloy chrome-vanadiummolybdenum steel. Item No. : lbs. 26790 T6, T7, T8 x 40mm .30 T9, T10 x 50mm T15 x 60mm Wiha Pico Soft Grip 267 Driver, With Precision Soft PicoFinish Handle Blade high alloy CVM tool steel, hardened, hard chrome finish. Item No. Size mm Inch mm Inch Pkg. 26732 10 T1 40 1.6 134 5.3 26733 10 T2 40 1.6 134 5.3 26735 10 T3 40 1.6 134 5.3 26736 10 T4 40 1.6 134 5.3 26737 10 T5 40 1.6 134 5.3 26739 10 T6 40 1.6 140 5.5 26741 10 T7 40 1.6 140 5.5 26743 10 T8 40 1.6 140 5.5 26745 10 T9 50 2.0 150 5.9 26747 10 T10 50 2.0 150 5.9 26749 10 T15 60 2.4 160 6.3 26751 10 T20 60 2.4 160 6.3 *Metric dimensions actual - Inch dimensions approximate In storage pouch 8 Pc. Precision Driver 26793 Set, With Soft PicoFinish Handle Blade high alloy CVM steel, hardened, hard chromed. ChromTop finish on tip for a perfect fit. Item : No. T1, T2, T3, T4, lbs. 26793 T5, T6, T7, T8 .50 In storage pouch 7 Pc. Screwdriver Set 26792 Blade high alloy chrome-vanadiummolybdenum steel. Item No. : lbs. 26792 T5, T6, T7, T8 x 40mm .33 T9, T10 x 50mm T15 x 60mm 91118 Rugged Polyester Canvas Storage Pouch Holds 8 Precision Tools up to 170mm in length. Folding pouch. Has security flaps and velcro closer. Item No. Size lbs. pkg. 14-1/2” W x 7-3/4” L .13 1 91118 26796 8 Pc. Precision Driver Set, Soft PicoFinish Handle Blade high alloy CVM steel, hardened, hard chromed. ChromTop finish on tip for a perfect fit. Item : No. T5, T6, T7, T8 x 40mm lbs. .57 26796 T9, T10 x 50mm, T15, T20 x 60mm Toll Free: (800) 494-6104 24 ESD Safe Dissipative Precision Screwdrivers Surface resistance of handles is 106 - 109 Ohms 278 Screwdriver, With Precision ESD Safe Dissipative Handle Blade high alloy CVM steel. Hard chrome finished. Handle impact resistant, dissipative material. ESD standard IEC 61340-5-1. Item No. Size mm Inch mm Inch lbs. pkg. T1 40 1.6 120 4.7 .03 10 27801 T2 40 1.6 120 4.7 .03 10 27802 T3 40 1.6 120 4.7 .03 10 27803 T4 40 1.6 120 4.7 .03 10 27804 T5 40 1.6 120 4.7 .03 10 27805 T6 40 1.6 120 4.7 .03 10 27811 T7 40 1.6 120 4.7 .03 10 27817 T8 40 1.6 120 4.7 .03 10 27823 T9 50 2.0 145 5.7 .04 10 27829 T10 50 2.0 145 5.7 .04 10 27835 T15 60 2.4 170 6.7 .07 10 27841 T20 60 2.4 170 6.7 .07 10 27847 *Metric dimensions actual - Inch dimensions approximate D 278 Screwdriver, With Precision ESD Safe Dissipative Handle Blade high alloy CVM steel, hardened, hard chromed. ESD standard IEC 61340-5-1. Item No. Size mm Inch mm Inch lbs. pkg. 27850 IP4 40 1.6 120 4.7 .03 10 27851 IP5 40 1.6 120 4.7 .03 10 27852 IP6 40 1.6 120 4.7 .03 10 27853 IP7 40 1.6 120 4.7 .03 10 27854 IP8 40 1.6 120 4.7 .03 10 27855 IP9 50 2.0 145 5.7 .04 10 27856 IP10 50 2.0 145 5.7 .04 10 27857 IP15 60 2.4 170 6.7 .07 10 *Metric dimensions actual - Inch dimensions approximate D ESD standard IEC 61340-5-1 27894 Set 7 Pcs. ESD Safe Dissipative Handle Item : No. IP5, IP6, IP7, IP8 27894 IP9, IP10, IP15 ESD standard IEC 61340-5-1 Precision lbs. .27 27890 ESD standard IEC 61340-5-1 Set 8 Pcs. Precision 27899 ESD Safe Dissipative Handle Set In Pouch Blade high alloy CVM steel, hardened, hard chromed. Handle impact resistant, dissipative material. In storage pouch. Item : No. T1, T2, T3, T4, lbs. 27899 T5, T6, T7 .47 Chip Lifter ESD Safe Dissipative Precision 28000 Handle with rotating control cap. Surface resistant 106-109 Ohms. 4 mm hex retainer for all SYSTEM 4 interchangeable blades. Tapered handle, high quality plastic, impact resistant. Ball retainer hold. 110mm/4.3” OAL Item No. mm Inch mm Inch lbs. 28000 4.0 .1574 14.0 .55 .04 28001 ESD Safe Dissipative Precision Adjustable Handle with rotating control cap. • Use in ESD sensitive applications. Surface resistant 106-109 Ohms. • Collet lock allows for quick & easy adjustment. • Holds blade securely in place. Accepts all SYSTEM 4 blades. 110mm/4.3” OAL Item No. mm Inch mm Inch lbs. 28001 4.0 .1574 14.0 .55 .04 ESD Safe SYS 4 Drive-Loc Handle & Blades D Set 7 Pcs. Precision ESD Safe Dissipative Handle Blade high alloy CVM steel, hardened, hard chromed. Handle manufactured from impact resistant, dissipative material. Item : No. T4, T5, T6, T7, lbs. 27890 T8, T9, T10 .31 ESD Safe Precision Handles & Blades D ESD Safe Dissipative Precision 26961 Drive-Loc Handle Surface resistant 106-109 Ohms. 4 mm hex retainer for all SYSTEM 4 interchangeable blades. Ball retainer hold. 105mm/4.13” OAL Item No. mm Inch mm Inch lbs. 26961 4.0 .1574 23 .91 .08 SYSTEM 4 Drive-Loc 269 Reversible Locking Blades On 4mm Hex Item No. Size Size lbs. 26977 T1 + T2 .02 26978 T3 + T4 .02 26979 T5 + T6 .02 26980 T6 + T8 .02 26981 T7 + T9 .02 26982 T10 + T15 .02 26983 T15 + T20 .02 269 SYS 4 Reversible Blade High alloy chrome-vanadium-molybdenum steel, hardened, vapor chrome protected, Wiha vapor Chrome-Top finish on tips. 120mm/4.7” OAL Item No. Size Size lbs. 26951 T6 + T8 .03 26952 T7 + T9 .03 26953 T10 + T15 .03 26954 T15 + T20 .03 269 SYS 4 Interchangeable Blade 120mm/4.7” OAL Item No. Size lbs. T3 .03 26955 T4 .03 26956 T5 .03 26957 www.wihatools.com 25 SYSTEM 4 Handles & Micro Bits 757 Bits CVM steel, hardened Rotating Cap Tips Exact fit, precision machined Tapered Handle High alloy CVM steel, hardened, on 4 mm stock for precise turning & control allows rapid rotation, requires less clearance. Static Dissipative 106 - 109 ohms Use bits directly in handle or with 4” bit extension D 75801 SYS 4 ESD Safe Dissipative Precision Bit Handle 110mm/4.3” OAL Advantages: • For working in ESD sensitive applications Surface resistant 106-109 Ohms • Ball retainer holds bits securely in place • Accepts all SYSTEM 4 Series bits Item No. mm Inch mm Inch lbs. 75801 4.0 .1574 14.0 .55 .06 Item No. 75701 75702 75703 75704 75705 75706 75707 75708 75709 75710 75715 75720 SYSTEM 4 10 Bit Pack Micro Bits Size mm Inch lbs. T1 28 1.1 .01 T2 28 1.1 .01 T3 28 1.1 .01 T4 28 1.1 .01 T5 28 1.1 .01 T6 28 1.1 .01 T7 28 1.1 .01 T8 28 1.1 .01 T9 28 1.1 .01 T10 28 1.1 .01 T15 28 1.1 .01 T20 28 1.1 .01 756 Item No. 75660 75661 75662 75663 75664 75665 75666 75667 75668 75669 75670 75671 SYSTEM 4 Micro Bits Size mm Inch lbs. T1 28 1.1 .06 T2 28 1.1 .06 T3 28 1.1 .06 T4 28 1.1 .06 T5 28 1.1 .06 T6 28 1.1 .06 T7 28 1.1 .06 T8 28 1.1 .07 T9 28 1.1 .07 T10 28 1.1 .07 T15 28 1.1 .08 T20 28 1.1 .08 10 Bit Pack 757 Item No. 75735 75742 SYS 4 Security Micro Bits Size mm Inch lbs. T10s 28 1.1 .01 T20s 28 1.1 .01 756 Item No. 75681 75683 SYS 4 Security Micro Bits Size mm Inch lbs. T10s 28 1.1 .07 T20s 28 1.1 .08 Notes: 75988 SYSTEM 4 Micro Bit Replacement Pack, 10 Pcs. CVM steel, hardened, on 4 mm hex stock. Item No. SYSTEM 4 Micro Bit Set 75988 : T1, T2, T3, T4, T5, T6, T7, T8, T9, T10 lbs. .06 75093 SYS 4 Slotted, Phillips, Compact ESD Precision Interchangeable Bit Set, 16 Pcs. Wiha precision handle, bit extension & 14 interchangeable bits. Item No. Combination Bit Set Set with ESD Safe Precision Handle 75093 Slotted: 1.5, 2.0, 2.5, 3.0mm Phillips: 00, 0, 1 lbs. : T6, T7, T8, T9, T10, T15, T20 .17 100mm Bit Extension 75985 Micro Bit Handle Storage Bit Set, 7 Pcs. Wiha precision storage handle & 6 interchangeable bits. Item No. Set with Precision Storage Handle 75985 : T3, T4, T5, T6, T7, T8 lbs. .12 Toll Free: (800) 494-6104 26 CushionGrip Stubby Bit Holders Wiha Cushion Grip Pop-Up Bit Holder Set Bit holder stainless steel, magnetic 38045 SoftFinish® CushionGrip Stubby Bit Holder with Wiha cushion grip handle and CVM tool steel shaft. Includes The Following 1/4” Bits: lbs. : T8, T10, T15, .20 T20, T25, T30 Wiha Pop-Up Bit Screwdriver Sets Bit holder stainless steel, magnetic 75mm Bits 38042 Security Pop-Up Bit Screwdriver Set Wiha Cushion Grip handle, multi-component. Compact storage for 6 bits in the handle. lbs. .44 Includes The Following 75mm 1/4” Bits: Security : T10s, T15s, T20s, T25s, T27s, T30s 38044 Pop-Up Bit Screwdriver Set with Wiha Cushion Grip handle, multicomponent. Compact storage holds12 bits. Set includes the following 1/4” bits: lbs. : T5, T6, T7, T8, T9, T10, .42 T15, T20, T25, T27, T30, T40 Bit holder stainless steel, magnetic 38047 Security SoftFinish® CushionGrip Stubby Bit Holder with Wiha cushion grip handle and CVM tool steel shaft. Includes The Following 1/4” Bits: lbs. .20 Security : T8s, T10s, T15s, T20s, T25s, T30s 38046 Security Pop-Up Bit Screwdriver Set Wiha Cushion Grip handle, multi-component. Compact storage for 12 bits in the handle. lbs. .42 Includes The Following 1/4” Bits: : T5, T6 Security : T7s, T8s, T9s, T10s, T15s, T20s, T25s, T27s, T30s, T40s For working in confined spaces 28103 Magnetic 1/4” Bit Holder With Wiha SoftFinish® Stubby Handle Stainless steel with strong magnet. Wiha-SoftFinish® handle multi-component, cushion grips. Item No. Inch mm Inch lbs. pkg. 1/4” 57 2.2 .11 1 28103 Wiha Insert Bit & Socket Set Wiha Insert Bit Blister Pack 72590 11 Piece Insert Bit Pack & Socket Set CVM S2 modified tool steel. 1/4” to 3/8” Drive Socket 1/4” Bits: T10, T15, T20, T25, T27, T30 5/16” to 3/8” Drive Socket 5/16” Bits: T40, T45, T50 10 Pack Insert Bit Pack 72595 CVM S2 modified tool steel. 72595 lbs. : T7, T8, T9, T10, .16 T15, T20, T25, T27, T30, T40 x 1” www.wihatools.com 27 Wiha Insert Bit Selectors Wiha Power Bit Belt Packs Wiha XSelector Bit Sets Easy bit access with hinged cover 79242 Bit-Selector With Bits Includes Universal Magnetic 1/4” Bit Holder & The Following 10 Insert Bits: lbs. : T5, T6, T7, T8, T9, .32 T10, T15, T20, T25, T30 79245 Bit-Selector With Bits Includes Auto Lock Magnetic 1/4” Bit Holder & The Following 10 Insert Bits: lbs. : T7, T8, T9, T10, .34 T15, T20, T25, T27, T30, T40 Includes Clicfix quick release holder 74985 Power Bit Belt Pack W/ Bits Includes the following 10 bits: lbs. .28 : T6, T7, T8, T9, T10, T15, T20, T25, T27, T30 79445 XSelector Bit Set With Set Includes Quick Release Holder & the following 10 bits: lbs. : T7, T8, T9, T10, T15, .29 T20, T25, T27, T30, T40 Bits XSelector Pocket Sized 3 1/8” x 2 1/8” x 1/2” 79447 74981 Bit-Selector With Security 79247 Bits, Includes Magnetic 1/4” Bit Holder & The Following 10 Bits: lbs. .32 Security : T7s, T8s, T9s, T10s, T15s, T20s, T25s, T27s, T30s, T40s Power Bit Belt Pack With Align Bits Set includes the following 10 bits: Align: T6, T7, T8, T9, T10, T15, T20, T25, T27, T30 lbs. .28 70190 Bit-Selector With Security Bits, Includes The Following 7 Insert Bits: Security : T7s, T8s, T9s, lbs. T10s, T15s, T20s, T25s .21 XSelector Bit Set With Security Bits, Includes Quick Release Holder & The Following 10 Bits: lbs. .27 Security : T7s, T8s, T9s, T10s, T15s, T20s, T25s, T27s, T30s, T40s Wiha Insert PokitPaks 74987 lbs. .29 Power Bit Belt Pack With Security Bits, Includes the following 10 bits: Security : T7s, T8s, T9s, T10s, T15s, T20s, T25s, T27s, T30s, T40s 71690 Bit-Selector With Bits Set Includes Magnetic 1/4” Bit Holder & The Following 10 Bits: : IP7, IP8, IP9, lbs. IP10, IP15, IP20, IP25 .31 IP27, IP30, IP40 71692 Bit-Selector With Bits Set Includes Magnetic 1/4” Bit Holder & The Following 10 Bits: : IP3, IP4, lbs. IP5, IP6, IP7, IP8, IP9, .31 IP10, IP15, IP20 74982 Power Bit Belt Pack W/ Bits Includes The Following 10 Bits: : IP6, IP7, lbs. IP8, IP9, IP10, IP15, .28 IP20, IP25, IP27, IP30 71195 PokitPak Insert Bits In Molded Case - Includes 6 - 1/4” Insert Bits & Magnetic Bit Holder lbs. .16 : T8, T10, T15, T20, T25, T30 79283 PokitPak Align Insert Bits In Molded Case Set Includes 6 - 1/4” Insert Bits lbs. Align: T10, T15, .12 T20, T25, T30, T40 Toll Free: (800) 494-6104 28 Wiha 1/4” Bit Holders Magnetic Pull Sleeve Forward 1 Retainer out of stainless steel 1/4” Magnetic Bit Holding Drivers, 384 With Wiha SoftFinish® Handle Ergonomic cushion grip, magnetic, holds bit and screw. Shaft CVM steel, nickel-plated. Item No. Size mm Inch mm Inch lbs. 1/4” 125 5.0 240 9.46 .23 38450 1/4” 300 11.8 400 15.69 .37 38460 Notes: Remove Bit 2 Pull Sleeve Back To Lock Insert New Bit 4 3 • Narrow Profile • One handed bit changes • Internal bit lock mechanism Adjustable Blade Length Magnetic Bit Holder Drive-Loc VI Bit Holder 28489 High alloy CVM steel, through hardened, hard chrome finish. Wiha-SoftFinish® handle multi-component, cushion grips. Item No. Inch Extends lbs. pkg. 28489 1/4” 1-3/4” to 4-7/8” .36 1 71491 ClicFix Bit Holder, Magnetic For Insert Bits Quick release Item No. Size Size mm Inch lbs. pkg. 71491 1/4” 1/4” 75 2.9 .07 1 High Precision Tool Holder Quick release tool holder for Drills, Countersinks & Power bits 48401 1/4” Bit holding Screwdriver, With Wiha-Ergo 3K Handle Magnetic, holds bit & screw. Retainer out of stainless steel. Item No. Size mm Inch mm Inch lbs. pkg. 48401 1/4” 125 5.0 211 8.3 .24 1 48400 1/4” Bit holding Screwdriver, With Wiha-Proturn Handle Magnetic, holds bit & screw. Retainer out of stainless steel. Item No. Size mm Inch mm Inch lbs. pkg. 1/4” 125 5.0 243 9.6 .24 10 48400 71480 Item No. 71480 CentroFix Bit Holder Size Size mm Inch lbs. pkg. 1/4” 1/4” 60 2.4 .09 1 71494 Stainless Steel Bit Holder, 1/4” For Insert Bits Internal C-ring for bit holding & magnet. Item No. Size Size mm Inch lbs. 1/4” 1/4” 54 2.1” .05 71494 www.wihatools.com 29 Wiha Terminator Up To 30X Performance Over Standard Screwdriver Bits Impact Bits - Insert & Power Impact rated bits for long life in impact applications Provide up to 30 times impact performance over standard bits 1/4” Drive Insert & Power Bits Standard 1/4” drive - No special adaptor required Wiha enhanced bi-material torsion zone Precision machined exact fit tips Dual material impact absorbing torsion zone Wiha exclusive CVM tool steel Guaranteed to out perform impact imposters 10 pc. bit pack! 10 pc. bit pack! 765 Terminator Impact Bits, 1/4” Insert - 10 Bit Pack Item No. Size mm pkg. 76510 T10 29 10 76511 T15 29 10 76512 T20 29 10 76513 T25 29 10 76514 T27 29 10 76516 T30 29 10 76517 T40 29 10 76877 10 Pc. Bit Buddy Set With Terminator Impact Insert Bits - 29mm Set includes the following bits: 76877 Torx®: T10, T15, T20 (2), T25 (2), T27, T30 (2), T40 2 pack! Terminator Impact Bits, 768 1/4” Insert - 2 Bit Pack Item No. Size mm pkg. T10 29 2 76810 T15 29 2 76811 T20 29 2 76812 T25 29 2 76813 T27 29 2 76814 T30 29 2 76816 T40 29 2 76817 Identification on bits allows quick bit selection 76895 8 Pc. Bit Buddy Set With Terminator Impact Insert Bits - 29mm Set includes the following bits: 76895 Torx®: T10, T15, T20, T25, T27, T30, T40 Includes magnetic bit holder 765 Terminator Impact Bits, 1/4” Power - 10 Bit Pack Item No. Size mm pkg. T10 49 10 76553 T15 49 10 76554 T20 49 10 76555 T25 49 10 76556 T27 49 10 76557 T30 49 10 76558 T40 49 10 76559 768 Terminator Impact Bits, 1/4” Power - 2 Bit Pack Item No. Size mm pkg. 76853 T10 49 2 76854 T15 49 2 76855 T20 49 2 76856 T25 49 2 76857 T27 49 2 76858 T30 49 2 76859 T40 49 2 76896 7 Pc. Bit Buddy Set With Terminator Impact Power Bits - 49mm Set includes the following bits: 76896 Torx®: T10, T15, T20, T25, T27, T30, T40 Toll Free: (800) 494-6104 30 Bits The ideal multi-purpose bits for all around quality & performance Made in Germany Production Quality Highly resistant to wear & tear for a long tool life Torx® Profiles Security Torx® Torx® 30 Piece Contractor Grade Bit Boxes With a purchase of 10 bit boxes Security TorxPlus® TorxPlus® Ball End 10 Piece Contractor Grade Bits Impact resistant modified CVM, tool steel, hardened Suitable for all applications for both manual & machine Hardness HRC 59-61 2 bit pack 715 1/4” Insert Bits Insert Bit Packs, 1” CVM S2 modified tool steel. Item No. Size mm lbs. pkg. T3 25 .03 2 71548 T4 25 .03 2 71549 T5 25 .03 2 71550 T6 25 .03 2 71551 T7 25 .03 2 71552 T8 25 .03 2 71553 T9 25 .03 2 71554 T10 25 .03 2 71555 T15 25 .03 2 71556 T20 25 .03 2 71557 T25 25 .03 2 71558 T27 25 .04 2 71559 T30 25 .04 2 71560 T40 25 .04 2 71561 2 bit pack 777 Double End 1/4” Insert Bit Packs CVM S2 modified tool steel. 2 bit pack Item No. Size mm pkg. T6+T7 30 2 77701 T8+T9 30 2 77702 T10+T15 30 2 77703 T20+T25 30 2 77704 T27+T30 30 2 77705 715 Bits, 1/4”. In Clamshell Item No. Size mm pkg. lbs. 71523 T3 25 10 .12 71524 T4 25 10 .12 71505 T5 25 10 .12 71506 T6 25 10 .12 71507 T7 25 10 .12 71508 T8 25 10 .12 71509 T9 25 10 .12 71510 T10 25 10 .12 71515 T15 25 10 .12 71520 T20 25 10 .12 71525 T25 25 10 .12 71527 T27 25 10 .13 71530 T30 25 10 .14 71540 T40 25 10 .15 Bits, 1/4” Bit Box Packs 725 Item No. Size mm pkg. lbs. 72572 T7 25 30 .36 72573 T8 25 30 .36 72574 T9 25 30 .36 72575 T10 25 30 .36 72576 T15 25 30 .36 72577 T20 25 30 .36 72578 T25 25 30 .36 72579 T27 25 30 .36 72580 T30 25 30 .36 72581 T40 25 30 .36 100 Piece Contractor Grade Bits Bits, 1/4” Bulk Packs 722 Item No. Size mm pkg. lbs. 72238 T15 25 100 1.5 72239 T20 25 100 1.5 72240 T25 25 100 1.5 72241 T27 25 100 1.5 72142 T30 25 100 1.5 250 Piece Contractor Grade Bits Bits, 1/4” Bulk Packs 723 Item No. Size mm pkg. lbs. 72338 T15 25 250 7.5 72339 T20 25 250 7.5 72340 T25 25 250 7.5 72341 T27 25 250 7.5 72342 T30 25 250 7.5 Wiha Bit Packs Insert Bit Packs, 1” CVM 71571 S2 modified tool steel. Extra hard with natural finish. Exact fit machined tips. 6 pc. bit pack. 71571 Set includes the following bits: Sizes: T15, T20, T25, T27, wt. .08 T30, T40 x 1” (25mm) Insert Bit Packs, 1” CVM 71570 S2 modified tool steel. Extra hard with natural finish. Exact fit machined tips. 6 pc bit pack. Set includes the following bits: 71570 Sizes: T5, T6, T7, T8, T9, wt. .07 T10 x 1” (25mm) www.wihatools.com 31 1/4” Power Bits 2 bit pack 745 Item No. 74525 74527 74530 74540 74559 74501 74502 74503 74504 74506 74508 74510 74514 74515 74516 74518 CVM S2 modified tool steel Power Bit Packs, 2” Size mm lbs. T1 50 .05 T2 50 .05 T3 50 .05 T4 50 .05 T5 50 .05 T6 50 .05 T7 50 .05 T8 50 .05 T9 50 .05 T10 50 .05 T15 50 .05 T20 50 .05 T25 50 .06 T27 50 .06 T30 50 .06 T40 50 .06 10 Piece Contractor Grade Bits Power Bits 745 1/4” Hex Drive, Length 2.0”/50mm. In clamshell Item No. Size mm pkg. lbs. 74511 T6 50 10 .18 74512 T7 50 10 .18 74513 T8 50 10 .18 74517 T9 50 10 .18 74519 T10 50 10 .18 74521 T15 50 10 .18 74523 T20 50 10 .18 74529 T25 50 10 .18 74531 T27 50 10 .18 74533 T30 50 10 .18 74535 T40 50 10 .18 100 Piece Contractor Grade Bits Bits, 1/4” Power Bits 722 Item No. Size mm pkg. lbs. 72279 T15 50 100 1.5 72280 T20 50 100 1.5 72281 T25 50 100 1.5 72282 T27 50 100 1.5 72283 T30 50 100 1.5 250 Piece Contractor Grade Bits Bits, 1/4” Power Bits 723 Item No. Size mm pkg. lbs. 72379 T15 50 250 7.5 72381 T20 50 250 7.5 72382 T25 50 250 7.5 72383 T27 50 250 7.5 72384 T30 50 250 7.5 745 Power Bits 1/4” Hex Drive, Length 2.75”/70mm Item No. Size mm pkg. lbs. T6 70 1 .02 74536 T7 70 1 .02 74538 T8 70 1 .02 74542 T9 70 1 .02 74544 T10 70 1 .02 74546 T15 70 1 .02 74548 T20 70 1 .03 74551 T25 70 1 .03 74553 T27 70 1 .04 74556 T30 70 1 .04 74558 T40 70 1 .04 74561 15 Piece Contractor With a Grade Bit Boxes purchase of 10 Bit boxes Bits, 1/4” Bit Box Packs 745 Item No. Size mm pkg. lbs. 74592 T15 50 15 .36 74593 T20 50 15 .36 74594 T25 50 15 .36 74596 T27 50 15 .36 74597 T30 50 15 .36 745 Power Bits 1/4” Hex Drive, Length 3.5”/90mm Item No. Size mm pkg. lbs. T6 90 1 .03 74563 T7 90 1 .03 74565 T8 90 1 .03 74567 T9 90 1 .03 74569 T10 90 1 .03 74571 T15 90 1 .03 74573 T20 90 1 .04 74575 T25 90 1 .04 74577 T27 90 1 .04 74579 T30 90 1 .04 74581 T40 90 1 .04 74583 745 Power Bits 1/4” Hex Drive, Length 6.0”/150mm Item No. Size mm pkg. lbs. 74580 T6 150 10 .04 74582 T7 150 10 .04 74584 T8 150 10 .04 74585 T9 150 10 .04 74586 T10 150 10 .04 74587 T15 150 10 .04 74588 T20 150 10 .04 74589 T25 150 10 .04 74590 T27 150 10 .04 74591 T30 150 10 .04 Wiha Double End Bits 744 Double End Bits 1/4” Hex Drive, Length 2.56”/65mm Item No. Size Size mm pkg. lbs. T7 T7 65 10 .32 74413 T8 T8 65 10 .32 74415 74417 T9 T9 65 10 .32 T10 T10 65 10 .32 74419 T27 T27 65 10 .34 74431 T30 T30 65 10 .35 74433 T40 T40 65 10 .38 74435 2 bit pack Double End Bits 744 1/4” Hex Drive, Length 2.56”/65mm Item No. Size Size mm lbs. 74461 T7 T7 65 .05 74462 T8 T8 65 .05 74463 T9 T9 65 .05 74464 T10 T10 65 .05 74465 T15 T15 65 .05 74468 T27 T27 65 .05 74469 T30 T30 65 .05 74470 T40 T40 65 .05 Toll Free: (800) 494-6104 32 Wiha Wiha 5/16” Insert Bits Align Insert Bits and Power Bits 10 bit pack 5/16” 725 Bits, 5/16” Item No. Size mm pkg. lbs. T25 35 10 .27 72525 T27 35 10 .27 72527 T30 35 10 .27 72530 T40 35 10 .28 72540 T45 35 10 .31 72545 T50 35 10 .32 72550 T55 35 10 .52 72555 T60 35 10 .52 72570 2 bit pack 725 Item No. 72528 72529 72531 72541 72546 72551 72556 72569 Insert Bit Packs, 5/16” Size mm lbs. T25 35 .28 T27 35 .28 T30 35 .28 T40 35 .28 T45 35 .31 T50 35 .32 T55 35 .52 T60 35 .52 Stainless Steel Bits Torx® Align Impact resistant modified chrome-vanadiummolybdenum, tool steel, hardened Tapered For Snug Fit In Screw Made in Germany Production Quality Highly resistant to wear and tear for a long tool life 715 Align Bits, 1/4” Item No. Size mm pkg. lbs. 71536 T6 25 10 .12 71537 T7 25 10 .12 71538 T8 25 10 .12 71541 T10 25 10 .12 71542 T15 25 10 .12 71543 T20 25 10 .12 71544 T25 25 10 .13 71545 T27 25 10 .13 71546 T30 25 10 .14 71547 T40 25 10 .15 *Also Known As Torx Wedge Fit Suitable for all applications for both manual and machine Hardness HRC 59-61 Align Bits, 1/4” Hex Drive, 747 Length 2.0”/50mm Item No. Size mm pkg. lbs. 74711 T6 50 10 .18 74714 T7 50 10 .18 74717 T8 50 10 .18 74721 T9 50 10 .18 74724 T10 50 10 .18 74728 T15 50 10 .20 74732 T20 50 10 .22 74736 T25 50 10 .22 74739 T27 50 10 .22 74742 T30 50 10 .22 *Also Known As Torx Wedge Fit Stainless Steel High-quality, non-rusting stainless steel, completely vacuum-hardened. Stainless Steel Bits, 1/4” 715 Item No. Size mm pkg. T8 25 10 71500 T10 25 10 71502 T40 25 10 71513 704 Stainless Steel Power Bits 1/4” Hex Drive, Length 2.0”/50mm Item No. Size mm pkg. T15 50 10 70411 T25 50 10 70414 T30 50 10 70416 T40 50 10 70417 2 bit pack 733 2 bit pack Align Insert Bit Packs, 1” CVM S2 modified tool steel Item No. Size mm lbs. T6 25 .03 73310 T7 25 .03 73311 T8 25 .03 73312 T9 25 .03 73313 T10 25 .03 73314 T15 25 .03 73315 T20 25 .03 73316 T25 25 .03 73317 T27 25 .03 73318 T30 25 .03 73319 T40 25 .04 73320 747 Item No. 74760 74761 74762 74763 74764 74765 74766 74767 74768 74769 Align Power Bit Packs, 2” Size mm lbs. T6 50 .05 T7 50 .05 T8 50 .05 T9 50 .05 T10 50 .05 T15 50 .05 T20 50 .06 T25 50 .06 T27 50 .06 T30 50 .06 www.wihatools.com 33 Wiha Security Security Torx® Made in Germany Production Quality Impact resistant modified CVM tool steel, hardened Highly resistant to wear and tear for a long tool life Insert Bits and Power Bits 705 Security Power Bits, 1/4” Hex Drive, Length 2.0”/50mm Item No. Size mm pkg. lbs. T7s 50 10 .18 70507 T8s 50 10 .18 70508 T9s 50 10 .18 70509 T10s 50 10 .19 70510 T15s 50 10 .19 70515 T20s 50 10 .21 70520 T25s 50 10 .23 70525 T27s 50 10 .23 70527 T30s 50 10 .23 70530 T40s 50 10 .23 70540 T45s 50 10 .33 70545 T50s 50 10 .37 70550 Suitable for all applications for both manual & machine Hardness HRC 59-61 701 Security Bits, 1/4” Item No. Size mm pkg. lbs. T7s 25 10 .12 70127 T8s 25 10 .12 70128 T9s 25 10 .12 70129 T10s 25 10 .12 70135 T15s 25 10 .12 70139 T20s 25 10 .12 70142 T25s 25 10 .12 70148 T27s 25 10 .13 70160 T30s 25 10 .13 70163 T40s 25 10 .14 70168 2 bit pack 705 Item No. 70556 70557 70558 70559 70560 70561 70562 70563 70564 70565 70566 70567 70568 Security Size T7s T8s T9s T10s T15s T20s T25s T27s T30s T40s T45s T50s T55s Power Bit Packs, 2” mm lbs. 50 .07 50 .07 50 .07 50 .07 50 .07 50 .07 50 .07 50 .07 50 .07 50 .07 50 .07 50 .07 50 .07 5/16” Made in Taiwan 745 Proturn Security Power Bits 1/4” Hex Drive, Length 3.0”/75mm Item No. Size mm pkg. lbs. 74566 T10s 75 5 .01 74568 T15s 75 5 .01 74570 T20s 75 5 .01 74572 T25s 75 5 .02 74574 T27s 75 5 .02 74576 T30s 75 5 .03 725 Security Bits, 5/16” Item No. Size mm pkg. lbs. T25s 35 10 .26 72514 T27s 35 10 .27 72515 T30s 35 10 .28 72516 T40s 35 10 .28 72542 T45s 35 10 .32 72547 T50s 35 10 .34 72552 T55s 35 10 .52 72557 T60s 35 10 .65 72558 2 bit pack 701 Security 2 bit pack Insert Bit Packs, 1” CVM S2 modified tool steel. Item No. Size mm lbs. 70150 T7s 25 .03 70151 T8s 25 .03 70152 T9s 25 .03 70153 T10s 25 .03 70154 T15s 25 .03 70155 T20s 25 .03 70156 T25s 25 .03 70157 T27s 25 .03 70158 T30s 25 .03 70159 T40s 25 .03 705 Security Power Bits, 1/4” Hex Drive, Length 3.5”/90mm Item No. Size mm pkg. lbs. 70533 T10s 90 5 .20 70534 T15s 90 5 .20 70535 T20s 90 5 .20 70536 T25s 90 5 .21 70537 T27s 90 5 .21 70538 T30s 90 5 .23 70539 T40s 90 5 .25 Bits, 5/16” 2 Bit Pack 725 Security Item No. Size mm lbs. 72559 T25s 35 .26 72560 T27s 35 .27 72561 T30s 35 .28 72562 T40s 35 .28 72563 T45s 35 .29 72564 T50s 35 .30 72567 T55s 35 .32 72568 T60s 35 .35 Toll Free: (800) 494-6104 34 Wiha Wiha Security Pentalobe 5 Point Insert Bit Insert Bits and Power Bits 2 bit pack Made in Germany Production Quality Highly resistant to wear and tear for a long tool life Impact resistant modified CVM, tool steel, hardened Suitable for all applications for both manual & machine Hardness HRC 59-61 716 Insert Bits, 1/4” Hex, 1” Item No. Size mm pkg. lbs. 71603 IP3 25 10 .12 71604 IP4 25 10 .12 71605 IP5 25 10 .12 71606 IP6 25 10 .12 71607 IP7 25 10 .12 71608 IP8 25 10 .12 71609 IP9 25 10 .12 71610 IP10 25 10 .12 71615 IP15 25 10 .12 71620 IP20 25 10 .12 71625 IP25 25 10 .12 71627 IP27 25 10 .13 71630 IP30 25 10 .13 71640 IP40 25 10 .15 746 Power Bits, 1/4” Hex, 2” Item No. Size mm pkg. lbs. 74601 IP5 50 10 .18 74602 IP6 50 10 .18 74603 IP7 50 10 .18 74604 IP8 50 10 .18 74608 IP9 50 10 .18 74612 IP10 50 10 .20 74616 IP15 50 10 .20 74620 IP20 50 10 .20 74624 IP25 50 10 .20 74628 IP27 50 10 .25 74632 IP30 50 10 .25 74636 IP40 50 10 .25 716 Insert Bit Packs, 1” CVM S2 modified tool steel Item No. Size mm lbs. IP3 25 .03 71631 IP4 25 .03 71632 IP5 25 .03 71633 IP6 25 .03 71634 IP7 25 .03 71635 IP8 25 .03 71636 IP9 25 .03 71637 IP10 25 .03 71638 IP15 25 .03 71639 IP20 25 .03 71641 IP25 25 .03 71642 IP27 25 .03 71643 IP30 25 .03 71644 IP40 25 .04 71645 2 bit pack 746 Item No. 74611 74613 74614 74617 74659 74660 74661 74662 74663 74664 74665 74666 74667 74668 74669 74670 Power Bit Packs, 2” Size mm lbs. IP1 50 .05 IP2 50 .05 IP3 50 .05 IP4 50 .05 IP5 50 .05 IP6 50 .05 IP7 50 .05 IP8 50 .05 IP9 50 .05 IP10 50 .05 IP15 50 .05 IP20 50 .05 IP25 50 .05 IP27 50 .05 IP30 50 .05 IP40 50 .05 Wiha Ball End Bits See additional Ball End TORX Tools on Page 15 716 Security Pentalobe 5 Point Insert Bits, 1/4” Hex, 1” OAL Item No. Size mm pkg. lbs. PLS8 25 1 .11 71648 PLS10 25 1 .11 71650 PLS15 25 1 .11 71652 PLS20 25 1 .12 71654 PLS25 25 1 .13 71656 PLS27 25 1 .13 71657 PLS30 25 1 .14 71658 PLS40 35 1 .14 71660 XSelector Pocket Sized 3 1/8” x 2 1/8” x 1/2” XSelector Bit Set With Security 79450 Pentalobe 5 Point Bits Set Includes Quick Release Holder lbs. and the following 7 bits: .18 Security Pentalobe 5 Point Sizes: PLS8, PLS10, PLS15, PLS20, PLS25, PLS27, PLS30 Wiha MagicSpring Screw Holding Power Bits Screw Holding TORX Bits Stainless rotary spring 2 bit pack MagicSpring Screw Holding 745 Power Bits, 1/4” Hex Drive, 2.0”/50mm OAL Item No. Size mm pkg. lbs. 74552 T10 50 2 .05 74554 T15 50 2 .05 74555 T20 50 2 .05 74557 T25 50 2 .05 74562 T30 50 2 .05 74564 T40 50 2 .05 www.wihatools.com 35 Set Screw Replaceable Bit Wiha Sockets Set Screw Replaceable Bit 761 Sockets 1/4” Square Drive Item No. Size mm lbs. T6 38 .04 76106 T7 38 .04 76107 T8 38 .04 76109 T9 38 .04 76111 T10 38 .04 76113 T15 38 .04 76117 T20 38 .04 76119 T25 38 .04 76121 T27 38 .04 76123 T30 38 .05 76129 T40 38 .05 76131 763 Sockets 3/8” Square Drive, Set Screw Replaceable Bit. 1/4” bits Item No. Size mm lbs. 76312 T9 42 .09 76314 T10 42 .09 76316 T15 42 .09 76318 T20 42 .09 76322 T25 42 .09 76324 T27 42 .09 76326 T30 42 .09 76328 T40 42 .09 763 Sockets 3/8” Square Drive, Set Screw Replaceable Bit. 5/16” Bit. 2” OAL Item No. Size mm lbs. T40 51 .11 76346 T45 51 .11 76348 T50 51 .11 76352 T55 51 .13 76354 716 Sockets 1/4” Square Drive, Set Screw Replaceable Bit. 1/4” bits Item No. Size mm lbs. 71661 IP6 38 .04 71662 IP7 38 .04 71663 IP8 38 .04 71664 IP9 38 .04 71665 IP10 38 .04 71666 IP15 38 .04 71667 IP20 38 .04 71668 IP25 38 .04 71669 IP27 38 .04 71670 IP30 38 .04 71671 IP40 38 .04 763 Security Sockets 1/4” Square drive, 1/4” bits Item No. Size mm T7s 38 76329 T8s 38 76330 T9s 38 76331 T10s 38 76332 T15s 38 76333 T20s 38 76334 T25s 38 76335 T27s 38 76335 T30s 38 76337 T40s 38 76338 Set Screw Replaceable Bit 716 Sockets 3/8” Square Drive, Set Screw Replaceable Bit. 1/4” bits Item No. Size mm lbs. IP9 42 .09 71673 IP10 42 .09 71674 IP15 42 .09 71675 IP20 42 .09 71676 IP25 42 .09 71677 IP27 42 .09 71678 IP30 42 .09 71680 IP40 42 .09 71681 701 Security Sockets 3/8” Square drive, 1/4” bits. 2” OAL Item No. Size mm lbs. 70107 T7s 42 .09 70108 T8s 42 .09 70109 T9s 42 .09 70110 T10s 42 .09 70113 T15s 42 .09 70115 T20s 42 .09 70117 T25s 42 .09 70119 T27s 42 .09 70121 T30s 42 .09 70123 T40s 42 .09 Set Screw Replaceable Bit 763 Security Sockets 3/8” Square drive, 5/16” bits Item No. Size mm T40s 51 76339 T45s 51 76340 T50s 51 76341 T55s 51 76342 1/2” Square Drive Sockets Set Screw Replaceable Bit 764 Sockets 1/2” Square Drive Item No. Size mm lbs. pkg. T30 59 .10 1 76403 T40 59 .10 1 76404 T45 59 .10 1 76405 T50 59 .10 1 76406 T55 59 .11 1 76407 T60 59 .18 1 76408 Set Screw Replaceable Bit 764 Security Sockets 1/2” Square Drive Item No. Size mm lbs. pkg. T40s 59 .11 1 76411 T45s 59 .11 1 76412 T50s 59 .11 1 76413 T55s 59 .12 1 76414 Toll Free: (800) 494-6104 36 Wiha Long Blade Sockets 771 Sockets 1/4” Drive 6” Long Bit Socket Item No. Size Inch lbs. T8 6 .12 77151 T9 6 .12 77153 T10 6 .12 77152 T15 6 .12 77154 T20 6 .12 77156 T25 6 .12 77158 T27 6 .12 77160 T30 6 .12 77162 T40 6 .12 77164 77193 7 Pc. Socket Blade Set : T10, T15, T20, T25, T27, T30, T40 wt. .69 771 3/8” Drive Item No. 77101 77103 77105 77107 77109 77111 77113 77115 77117 Sockets 6” Long Bit Socket Size Inch lbs. T8 6 .12 T9 6 .12 T10 6 .12 T15 6 .12 T20 6 .12 T25 6 .12 T27 6 .12 T30 6 .12 T40 6 .12 77195 9 Pc. Socket Blade Set : T8, T9, T10, T15, T20, T25, T27, T30, T40 wt. 1.08 Wiha External Sockets 773 External Sockets 1/4” Square drive socket. Item No. Size mm lbs. E4 25 .03 77304 E5 25 .03 77305 E6 25 .03 77306 E8 25 .04 77308 773 External Sockets 3/8” Square drive socket. Item No. Size mm lbs. 77331 E8 28 .07 77333 E10 28 .07 77335 E12 28 .07 77337 E14 28 .08 Wiha Socket Sets On Molded Rails 10 pc. Socket Set 76191 1/4” Square Drive Replaceable Bit Sockets. Bits CVM tool steel. OAL 1.5” Item No. Set Includes: lbs. T7, T8, T9, T10, T15, 76191 .49 T20, T25, T27, T30, T40 6 pc. Socket Set 76194 1/4” Square Drive Replaceable Bit Sockets. Bits CVM tool steel. Item No. Set Includes: 76194 lbs. T10, T15, T20, .20 T25, T27, T30 8 pc. Socket Set 76395 3/8” Square Drive Replaceable Bit Sockets. Bits CVM tool steel. OAL 1.5” Item No. Set Includes: lbs. T9, T10, T15, T20, 76395 .75 T25, T27, T30, T40 77390 22 pc. Set 1/4” Drive Socket Ratchet 5.5”, extension 2” & 4”, swivel & hand driver in steel box. Hard chromed and polished. Item No. 77390 lbs. Set includes the following: 2.14 E4, E5, E6, E7, E8, E10, T6, T7, T8, T9, T10, T15, T20, T25, T27, T30, T40 Socket Set 76396 8 pc. 3/8” Square Drive Replaceable Bit Sockets. 1/4” & 5/16” Bits CVM tool steel. OAL 1.65” Item No. 76396 lbs. Set Includes: .87 1/4”: T20, T25, T27, T30, T40 5/16”: T45, T50, T55 773 External Sockets 1/2” Square drive socket. Item No. Size mm lbs. E12 37 .12 77341 E14 37 .12 77343 E16 37 .14 77345 E18 37 .14 77347 E20 37 .15 77349 E24 40 .24 77353 6 pc. Socket Set 76490 1/2” Square Drive Replaceable Bit Sockets. Bits CVM tool steel. Item No. Set Includes: 76490 lbs. T30, T40, T45 1.06 T50, T55, T60 www.wihatools.com 37 Wiha Socket Sets On Molded Rails Security Torx® 70195 10 pc. Security Socket Set 1/4” Square drive replaceable bit sockets. 1/4” Bits CVM tool steel. Item No. Set Includes: lbs. T7s, T8s, T9s, 70195 .48 T10s, T15s, T20s, T25s, T27s, T30s, T40s 9 pc. Security Socket Set 76397 1/4” & 3/8” Square Drive Replaceable Bit Sockets. 1/4” & 5/16” Bits CVM tool steel. Item No. Set Includes: 76397 lbs. 1/4”: T10s, T15s, T20s, .85 T25s, T27s, T30s 3/8”: T40s (1/4” bit) 3/8”: T45s, T50s (5/16” bit) 12 pc. Security Socket 76399 Set 1/4” & 3/8” Square Drive Replaceable Bit Sockets. 1/4” & 5/16” Bits CVM tool steel. Item No. Set Includes: 1/4”: T7s, T8s, T10s, T15s, lbs. 76399 .80 T20s, T25s, T27s, T30s, T40s 5/16”: T45s, T50s, T55s 8 pc. Socket Set On 71698 Rail, In Vinyl Pouch 1/4” & 3/8” Square Drive Replaceable Bit Sockets. Bits CVM tool steel. Item No. 71698 lbs. Set Includes: .60 1/4”: IP9, IP10, IP15, IP20 3/8”: IP25, IP27, IP30, IP40 Item No. Page Item No. Page Item No. Page Item No. Page 10810 10 10893 6 20756 11 20757 11 20758 11 20759 11 20760 11 20799 11 26701 23 26702 23 26703 23 26704 23 26705 23 26706 23 26707 23 26708 23 26709 23 26710 23 26715 23 26720 23 26721 19 26723 19 26725 19 26727 19 26729 19 26731 19 26732 23 26733 23 26735 23 26736 23 26737 23 26739 23 26741 23 26743 23 26745 23 26747 23 26749 23 26751 23 26790 23 26791 23 26792 23 26793 23 26796 23 26798 19 26799 23 26951 24 26952 24 26953 24 26954 24 26955 24 26956 24 26957 24 26961 24 26977 24 26978 24 26979 24 26980 24 26981 24 26982 24 26983 24 27801 24 27802 24 27803 24 27804 24 27805 24 27811 24 27817 24 27823 24 27829 24 27835 24 27841 24 27847 24 27850 24 27851 24 27852 24 27853 24 27854 24 27855 24 27856 24 27857 24 27890 24 27894 24 27899 24 28000 24 28001 24 28103 26 28126 10 28127 10 28128 10 28129 10 28130 10 28132 10 28133 10 28134 10 28135 10 28136 10 28189 10 28197 10 28301 11 28339 11,21 28340 11,21 28341 11,21 28342 11,21 28343 11,21 28344 11,21 28349 21 28351 21 28352 21 28353 21 28354 21 28355 21 28356 21 28357 21 28358 21 28359 21 28360 21 28374 21 28375 21 28376 21 28377 21 28378 21 28379 21 28380 21 28381 21 28382 21 28383 21 28384 21 28385 21 28386 21 28387 21 28388 21 28389 21 28404 20 28408 20 28477 10 28485 10 28486 10 28487 10 28488 10 28489 28 28500 22 28501 20 28502 20 28506 20 28512 20 28522 22 28524 22 28526 22 28527 20 28528 20 28529 20 28530 20 28531 20 28532 20 28533 20 28550 20 28551 20 28552 20 28553 20 28554 20 28561 20 28562 20 28563 20 28564 20 28565 20 28566 20 28567 20 28568 20 28569 20 28571 20 28572 20 28573 20 28574 20 28575 20 28576 20 28577 20 28578 20 28579 20 28597 22 28598 22 28599 22 28611 20 28612 20 28613 20 28614 20 28616 20 28617 20 28618 20 28619 20 28740 21 28741 21 28742 21 28750 21 28751 21 28752 21 28818 22 28825 22 28827 22 28829 22 28903 22 28904 22 28905 22 28906 22 28907 22 28908 22 28910 22 28911 22 28912 22 28913 22 28914 22 28915 22 28931 22 28933 22 28935 22 28937 22 28938 22 28939 22 28940 22 29232 21 29233 21 29234 21 29236 21 29237 21 29239 21 29242 21 29243 21 29244 21 29246 21 29247 21 29248 21 29249 21 29252 21 29253 21 29254 21 29255 21 29256 21 32505 7 32511 7 32512 11 32513 11 32514 11 32515 11 32516 7 32517 11 32518 11 32519 11 32521 7 32526 7 32531 7 32536 7 32541 7 32546 7 32551 7 32556 7 32561 7 32566 7 32590 7 32592 7 32596 11 36106 18 36107 18 36108 18 36109 18 36110 18 36115 18 36120 18 36125 18 36127 18 36130 18 36140 18 36197 18 36199 18 36200 6 36201 5 36202 19 36203 19 36204 6 36205 8 36206 6 36207 19 36208 6 36209 6 36210 8 36211 17 36212 8 36214 17 36215 8 36216 15 36217 15 36218 6 36219 6 36220 8 36221 15 36222 15 36223 17 36224 6 36225 8 36226 15 36227 15 36228 17 36229 17 36230 8 36231 17 36232 17 36233 17 36234 19 36235 8 36236 15 36237 15 36238 17 36239 17 36240 8 Toll Free: (800) 494-6104 38 Item No. Page Item No. Page Item No. Page Item No. Page Item No. Page Item No. Page 36241 17 36242 17 36243 17 36244 19 36245 8 36246 17 36247 17 36248 17 36249 19 36250 8 36252 17 36253 17 36254 19 36255 17 36256 19 36257 19 36258 19 36259 6 36260 6 36262 17 36263 17 36264 5 36265 17 36266 5 36267 5 36268 5 36269 6 36270 5 36271 6 36272 5 36273 6 36274 5 36275 6 36276 5 36277 6 36278 5 36279 6 36280 5 36281 6 36282 5 36283 6 36284 5 36285 6 36286 5 36287 6 36288 5 36289 6 36290 19 36291 5 36292 8 36293 8 36294 5 36296 17 36298 6 36297 17 36299 17 36305 12 36306 12 36307 12 36308 12 36309 12 36310 12 36315 12 36320 12 36323 12 36325 12 36326 12 36327 12 36328 12 36329 12 36330 12 36332 12 36335 12 36337 12 36339 12 36340 12 36342 12 36345 12 36346 12 36350 12 36352 12 36355 12 36357 12 36360 12 36390 12 36391 12 36392 12 36393 12 36394 12 36395 11 36396 11 36397 11 36398 11 36399 12 36409 13 36410 13 36415 13 36417 13 36420 13 36422 13 36425 13 36427 13 36430 13 36432 13 36435 13 36437 13 36440 13 36442 13 36445 13 36450 13 36452 13 36461 17 36463 17 36466 17 36469 17 36472 17 36474 17 36476 17 36478 17 36480 13 36481 13 36482 13 36483 13 36484 13 36486 13 36487 13 36490 13 36492 13 36494 13 36496 17 36497 13 36511 14 36513 14 36514 14 36516 14 36517 14 36518 14 36519 14 36521 14 36522 14 36523 14 36524 16 36526 16 36527 16 36528 16 36529 16 36531 16 36532 16 36533 16 36534 14 36536 14 36537 14 36538 14 36539 16 36541 16 36543 16 36545 16 36547 16 36549 16 36551 16 36553 16 36556 19 36557 19 36558 19 36559 19 36560 19 36561 19 36562 19 36590 14 36591 14 36592 16 36598 19 36606 18 36607 18 36608 18 36609 18 36610 18 36615 18 36620 18 36625 18 36627 18 36630 18 36631 15 36632 15 36633 15 36634 15 36635 15 36636 15 36637 15 36638 15 36639 15 36640 18 36645 12 36646 12 36647 12 36648 12 36649 12 36650 12 36651 12 36652 12 36653 12 36654 12 36655 12 36659 12 36660 12 36661 12 36689 15 36690 18 36691 18 36692 15 36693 13 36694 12 36697 16 36698 12 36699 12 37005 14 37006 14 37007 14 37008 14 37009 14 37010 14 37011 14 37012 14 37013 14 37014 16 37015 16 37016 14 37017 16 37018 16 37019 14 37021 16 37022 14 37023 16 37024 16 37026 14 37027 16 37029 14 37032 14 37036 14 37055 14 37056 14 37057 14 37058 14 37059 14 37060 14 37061 14 37062 14 37063 16 37064 16 37065 16 37066 16 37067 16 37068 16 37069 16 37070 16 37090 14 37091 14 37092 16 37106 18 37107 18 37108 18 37109 18 37110 18 37115 18 37120 18 37125 18 37127 18 37130 18 37140 18 37190 18 37192 18 38042 26 38044 26 38045 26 38046 26 38047 26 38450 28 38460 28 45504 9 45505 8 45506 8 45508 9 45509 9 45511 8 45516 8 45521 8 45525 9 45526 8 45527 9 45530 9 45531 8 45536 8 45540 9 45541 8 45546 8 45550 9 45551 8 45556 8 45561 8 45589 8 45591 8 45592 8 45593 9 48400 9,28 48401 9,28 52711 7 52713 7 52716 7 52719 7 52722 7 52726 7 52729 7 52732 7 52790 7 52791 7 70107 35 70108 35 70109 35 70110 35 70113 35 70115 35 70117 35 70119 35 70121 35 70123 35 70127 33 70128 33 70129 33 70135 33 70139 33 70142 33 70148 33 70150 33 70151 33 70152 33 70153 33 70154 33 70155 33 70156 33 70157 33 70158 33 70159 33 70160 33 70163 33 70168 33 70190 27 70195 37 70411 32 70414 32 70416 32 70417 32 70507 33 70508 33 70509 33 70510 33 70515 33 70520 33 70525 33 70527 33 70530 33 70533 33 70534 33 70535 33 70536 33 70537 33 70538 33 70539 33 70540 33 70545 33 70550 33 70556 33 70557 33 70558 33 70559 33 70560 33 70561 33 70562 33 70563 33 70564 33 70565 33 70566 33 70567 33 70568 33 71195 27 71480 28 71491 28 71494 28 71500 32 71502 32 71505 30 71506 30 71507 30 71508 30 71509 30 71510 30 71512 32 71513 32 71515 30 71516 30 71517 30 71518 30 71520 30 71521 30 71522 30 71523 30 71524 30 71525 30 71527 30 71530 30 71536 32 71537 32 71538 32 71540 30 71541 32 71542 32 71543 32 71544 32 71545 32 71546 32 71547 32 71548 31 71549 31 71550 31 71551 31 71552 31 71553 31 71554 31 71555 31 71556 31 71557 31 71558 31 71559 31 71560 31 71561 31 71563 30 71564 30 71565 30 71566 30 71567 30 71568 30 71569 30 71570 31 71571 31 71576 30 71578 30 71582 30 71585 30 71587 30 71588 30 71603 34 71604 34 71605 34 71606 34 71607 34 71608 34 71609 34 71610 34 71615 34 71620 34 71625 34 71627 34 71630 34 71631 34 71632 34 71633 34 71634 34 71635 34 71636 34 www.wihatools.com 39 Item No. Page 71637 34 71638 34 71639 34 71640 34 71641 34 71642 34 71643 34 71644 34 71645 34 71648 34 71650 34 71652 34 71654 34 71656 34 71657 34 71658 34 71660 34 71661 35 71662 35 71663 35 71664 35 71665 35 71666 35 71667 35 71668 35 71669 35 71670 35 71671 35 71673 35 71674 35 71675 35 71676 35 71677 35 71678 35 71680 35 71681 35 71690 27 71692 27 71698 37 72238 30 72239 30 72240 30 72241 30 72242 30 72279 31 72280 31 72281 31 72282 31 72283 31 72338 30 72339 30 72340 30 72341 30 72342 30 72379 31 72381 31 72382 31 72383 31 72384 31 72514 33 72515 33 72516 33 72525 33 72527 33 72528 32 72529 32 72530 33 72531 32 72540 33 72541 32 72542 33 72545 32 72546 32 72547 33 72550 32 72551 32 72552 33 72555 32 Item No. Page 72556 32 72557 33 72558 32 72559 33 72560 33 72561 33 72562 33 72563 33 72564 33 72567 33 72568 33 72569 32 72570 32 72572 30 72573 30 72574 30 72575 30 72576 30 72577 30 72578 30 72579 30 72580 30 72581 30 72590 26 72595 26 73310 32 73311 32 73312 32 73313 32 73314 32 73315 32 73316 32 73317 32 73318 32 73319 32 73320 32 74413 31 74415 31 74417 31 74419 31 74431 31 74433 31 74435 31 74461 31 74462 31 74463 31 74464 31 74465 31 74468 31 74469 31 74470 31 74501 31 74502 31 74503 31 74504 31 74505 15 74506 31 74508 31 74510 31 74511 31 74512 31 74513 31 74514 31 74515 31 74516 31 74517 31 74518 31 74519 31 74520 15 74521 31 74522 15 74523 31 74524 15 74525 31 74526 15 74527 31 74528 15 74529 31 Item No. Page 74530 31 74531 31 74532 15 74533 31 74534 15 74535 31 74536 31 74537 15 74538 31 74539 15 74540 31 74541 15 74542 31 74543 15 74544 31 74545 15 74546 31 74547 15 74548 31 74549 15 74550 15 74551 31 74552 34 74553 31 74554 34 74555 34 74556 31 74557 34 74558 31 74559 31 74561 31 74562 34 74563 31 74564 34 74565 31 74566 33 74567 31 74568 33 74569 31 74570 33 74571 31 74572 33 74573 31 74574 33 74575 31 74576 33 74577 31 74579 31 74580 31 74581 31 74582 31 74583 31 74584 31 74585 31 74586 31 74587 31 74588 31 74589 31 74590 31 74591 31 74592 31 74593 31 74594 31 74596 31 74597 31 74601 34 74602 34 74603 34 74604 34 74608 34 74611 34 74612 34 74613 34 74614 34 74616 34 74617 34 74620 34 74624 34 Item No. Page 74628 34 74632 34 74636 34 74659 34 74660 34 74661 34 74662 34 74663 34 74664 34 74665 34 74666 34 74667 34 74668 34 74669 34 74670 34 74711 32 74714 32 74717 32 74721 32 74724 32 74728 32 74732 32 74736 32 74739 32 74742 32 74760 32 74761 32 74762 32 74763 32 74764 32 74765 32 74766 32 74767 32 74768 32 74769 32 74981 27 74982 27 74985 27 74987 27 75093 25 75660 25 75661 25 75662 25 75663 25 75664 25 75665 25 75666 25 75667 25 75668 25 75669 25 75670 25 75671 25 75679 25 75681 25 75683 25 75701 25 75702 25 75703 25 75704 25 75705 25 75706 25 75707 25 75708 25 75709 25 75710 25 75715 25 75720 25 75728 25 75735 25 75742 25 75801 25 75985 25 75988 25 76106 35 76107 35 76109 35 76111 35 76113 35 Item No. Page Item No. Page 76117 35 76119 35 76121 35 76123 35 76129 35 76131 35 76191 36 76194 36 76312 35 76314 35 76316 35 76318 35 76322 35 76324 35 76326 35 76328 35 76329 35 76330 35 76331 35 76332 35 76333 35 76334 35 76335 35 76336 35 76337 35 76338 35 76339 35 76340 35 76341 35 76342 35 76346 35 76348 35 76352 35 76354 35 76395 36 76396 36 76397 37 76399 37 76403 35 76404 35 76405 35 76406 35 76407 35 76408 35 76411 35 76412 35 76413 35 76414 35 76490 36 76510 29 76511 29 76512 29 76513 29 76514 29 76516 29 76517 29 76553 29 76554 29 76555 29 76556 29 76558 29 76557 29 76559 29 76810 29 76811 29 76812 29 76813 29 76814 29 76816 29 76817 29 76853 29 76854 29 76855 29 76856 29 76857 29 76858 29 76859 29 76877 29 76895 29 76896 29 77101 36 77103 36 77105 36 77107 36 77109 36 77111 36 77113 36 77115 36 77117 36 77151 36 77152 36 77153 36 77154 36 77156 36 77158 36 77160 36 77162 36 77164 36 77193 36 77195 36 77304 36 77305 36 77306 36 77308 36 77331 36 77333 36 77335 36 77337 36 77341 36 77343 36 77345 36 77347 36 77349 36 77353 36 77390 36 77701 30 77702 30 77703 30 77704 30 77705 30 79242 27 79245 27 79247 27 79283 27 79445 27 79447 27 79450 34 91118 23 Prop65 WARNING: This product could expose you to chemicals including Vinyl Chloride, Ethylene Glycol, Ni or CrVl, which are known to the state od California to cause cancer or reproductive harm. For more information go to www.P65warnings.ca.gov/ PROFESSIONAL TOOLS Wiha Quality Tools (800) 494-6104 fax: (800) 494-7456 cservice@wihatools.com www.wihatools.com 1348 Dundas Circle Monticello, MN 55362 tel: 763.295.6591 fax: 763.295.6598 Wiha Tools Canada Ltd. www.wihatools.ca Brampton, ONT L6T 4X4 tel: 866.494.0096 or 763.295.6591 fax: 763.295.6598 To: Catalog Item No. 99914 .wo version - 3/1/19 Subject to change without notice ©2019 Willi Hahn Corporation ®Torx is a registered trademark of Acument Intellectual Properties LLC. 99977.wo - Pliers/Crimpers Catalog 2019 99934.wo - Hex Tools Catalog 2019 99001.wo - TorqueControl Catalog 99951.wo - Bits Catalog 2019 99919.wo - Insulated Catalog 2019 Professional Quality Tools MERCHANDISE PROGRAM 99002.wo - Screwdrivers Catalog 99004.wo - Shop Tools Catalog 99006.wo - Tech Tools Catalog 99945.wo - ESD Catalog 99007.wo - Merchandise Catalog
74580 价格&库存
很抱歉,暂时无法提供与“74580”相匹配的价格&库存,您可以联系我们找货
