IF-FC1-RP2
IF-FC1-RP2
    INDUSTRIALFIBER
    BLADE STAND EDGE IF-FC1 100PC
IF-FC1-RP2 数据手册
POF Cutter Block Operating Instructions Model Number: IF FC1 Industrial Fiber Optics Introduction Congratulations on your purchase of Industrial Fiber Optics’ POF Cutter Block. This instruction sheet contains all the information you need to operate this device safely and knowledgeably, even if you are new to fiber optics and fiber termination procedures. Please read carefully before operating. As soon as you receive this fiber cutter, inspect it and its shipping container. Besides this instruction sheet, the cutter product consists of: • Fiber cutter body with installed razor blade • 2-56 x ½ inch screw for blade retention • #2 wave washer • 4 Extra KEEN single-edge razor blades If parts are missing please contact us immediately for replacement. If the cutter has been damaged during shipping, immediately notify the shipping carrier. Industrial Fiber Optics makes every effort to incorporate state-of-the-art technology, highest quality, and dependability in its products. We constantly explore new ideas and products to best serve the rapidly expanding needs of industry and education. We encourage comments that you may have about our products, and we welcome the opportunity to discuss new ideas that may better serve your needs. Thank you for selecting this Industrial Fiber Optics product. We hope it meets your expectations and provides many hours of productive activity. General Information The POF Cutter Block has been designed exclusively for cutting plastic optical fiber. Do not attempt to cut glass fiber. Razor blade Body Screw Upon inspection of the fiber cutter you will find 1 2 3 4a4b 5 6 seven holes or apertures as shown in Figure 1. The apertures are precisely drilled holes for Figure 1. Front view of the fiber cutter optimal cutting of the most commonly used with the fiber apertures numbered. plastic optical fibers. See Table 1 to determine the proper aperture for the fiber you wish to cut. If you do not find the fiber listed, please refer to the aperture sizes in Table 2. Choose the closest aperture size that exceeds the overall diameter of the fiber. 1021.eps To eliminate a step when working with jacketed duplex fiber, the cutter splits the jacket at the midpoint when it is pushed into the cutter. To split a 1000 μm core jacketed fiber, insert the fiber into apertures 4a and 4b when following the instructions in the next section. Splitting and cutting the fiber this way ensures that both fiber ends are the same length for a professional and easy-to-use termination. –2– Table 1. Recommended apertures for various fibers. Fiber Type Aperture 750 μm core, 2.2 mm jacketed simplex 4a or 4b 1000 μm core, 2.2 mm jacketed simplex 4a or 4b 750 μm core, jacketed duplex 4a and 4b 1000 μm core, jacketed duplex 4a and 4b 750 μm core bare fiber 1 1.5 mm core, jacketed simplex 3 1000 μm core bare fiber 5 1.5 mm core bare fiber 5 2.0 mm bare fiber 2 3.0 mm bare fiber 3 16-fiber 265 μm core, light bundle 4a or 4b 24-fiber 265 μm core, light bundle 3 32-fiber 265 μm core, light bundle 3 64-fiber 265 μm core light bundle 6 Fiber Cutting Procedure To cut fiber with this cutter please complete the following steps: • Select the correct aperture for the fiber being cut. • Pull up the razor blade. • Push fiber into the selected aperture until it extends 2 mm beyond the razor blade. • Press down on the top of the razor blade until the fiber is cut through. • Pull up the razor blade and remove fiber. Replacement Blades The replacement blades for this cutter are the same physical size as single-edge razor blades available at most hardware stores. We recommend “Extra KEEN” single-edge blades because they produce superior terminations when cutting most fiber except the 3.0 mm core bare type. Our part number for the Extra KEEN blade in packages of 100 is IF-FC1-RP1. For the 3.0 mm bare fiber, we recommend standard-edge blades. The replacement package of 100 standard blades is our part number IF-FC1-RP2. Table 2. Hole diametersfor individual apertures. Size (in) Size (mm) 1 .035 .88 2 .086 2.184 3 .125 3.175 4a .0935 2.375 4b .0935 2.375 5 .0635 1.613 6 .136 3.459 Standard edge blades last longer when cutting all fiber diameter, but do not produce as smooth and defect-free fiber cuts. –3– Blade Replacement Procedure 12 0250 To replace the fiber cutter blade complete the following steps: • Using a size 1 Phillips screwdriver remove the 2-56 screw. • Adjacent to the razor blade is a #2 wave washer. Remove the washer and dull razor blade from the cutter body. • Dispose of the razor blade carefully. • Place a new single-edge razor blade and wave washer into the slot. • Align blade, wave washer and screw holes and then re-insert the 2-56 screw. • Tighten the 2-56 screw so a slight amount of friction is placed on the razor blade. For longer blade life, rotate a worn blade 180 degrees and re-install. This places a new portion of the blade into use in relationship to a particular aperture. Warranty Industrial Fiber Optics products are warranted against defects in materials and workmanship for 90 days. The warranty will be voided if internal or external components have been damaged, mishandled, or altered by the buyer. Warranty liability is limited to repair or replacement of any defective unit at the company’s facilities, and does not include attendant or consequential damages. Repair or replacement can be made only after failure analysis at the factory. Authorized warranty repairs are made at no charge, and are guaranteed for the balance of the original warranty. Industrial Fiber Optics will pay the return freight and insurance charges for warranty repair within the continental United States, by United Parcel Service or Parcel Post. Any other delivery means must be paid for by the customer. The costs of return shipments for a fiber cutter no longer under warranty must be paid by the customer. If an item is not under warranty, repairs will not be undertaken until the cost of such repairs has been prepaid by the customer. When returning items for analysis and possible repair, please do the following: • In a letter, describe the problem, name of the person whom we should contact, phone number and return address. • Pack the fiber cutter, instruction sheet and your letter carefully in a strong box with adequate packing material to prevent damage in shipment. • Ship the package to: Industrial Fiber Optics 1725 West 1st Street Tempe, AZ 85281-7622 USA Rev E © 2012 Industrial Fiber Optics, Inc
IF-FC1-RP2
物料型号:IF FC1
器件简介:这是Industrial Fiber Optics生产的塑料光纤切割器,专为切割塑料光纤设计,不适用于玻璃光纤。
引脚分配:文档中没有提及引脚分配,因为它是物理设备而非电子元件。
参数特性: - 设计有七个精确钻孔的孔或孔口,用于切割常用塑料光纤。 - 提供了不同光纤类型和推荐的孔口大小的对应表。
功能详解: - 切割过程包括选择正确的孔口、拉起刀片、将光纤推入孔口直至超出刀片2毫米、按下刀片顶部直至光纤被切断、拉起刀片并移除光纤。
应用信息:该切割器专为塑料光纤切割设计,不适用于带皮双层光纤。
封装信息:附带物品包括切割器本体、安装的剃须刀片、用于刀片固定的2-56 x ½英寸螺丝、#2波形垫圈以及4片额外的单刃剃须刀片。
IF-FC1-RP2 价格&库存
很抱歉,暂时无法提供与“IF-FC1-RP2”相匹配的价格&库存,您可以联系我们找货
