90HBW10PT
90HBW10PT
    GRAYHILLINC.
    插件
    开关 滑动 插件 单刀单掷 25mA 24V
90HBW10PT 数据手册
Surface Mount DIP Switches SERIES 90HB SPST, Low Profile DIP Switches FEATURES • Compatible with SMT Assembly, Including Infrared Reflow and Vapor-Phase • Top Seal Withstands High Pressure Aqueous Cleaning • Reliable Spring and Ball Contact DIMENSIONS In inches (and millimeters) Top View–Gull Wing SWITCH IS PACKAGED AS SHOWN HERE WITH ALL O N POSITIONS ON Gull Wing 1 2 .020 ± .002 (0,51 ± 0,05) TYP. .052 ± .002 (1,32 ± 0,13) TYP. .085 ± .005 (2,16 ± 0,13) TYP. 3 4 5 6 7 8 .290 (7,37) MAX. CL C L .100 ± .005 (2,54 ± 0,13) TYP. Recommended PC Pad Dimensions–Gull Wing CL CL .395 ± .010 (10,03 ± 0,25) .012 ± .002 (0,30 ± 0,05) .165 ± .005 (4,19 ± 0,13) LENGTH ± .010 (0,25) SEE CHART .004 (0,10) .190 (4,83) MAX. .100 (2,54) TYP. .070 (1,78) TYP. J-Bend .500 (12,7) TYP. .250 (6,35) TYP. .125 (3,18) TYP. .320 (8,13) MAX. .290 (7,37) MAX. .165 ± .005 (4,19 ± 0,13) LENGTH ± .010 (0,25) SEE CHART Recommended PC Pad Dimensions–J-Bend CL CL .100 (2,54) TYP. .070 (1,78) TYP. .350 (8,90) TYP. .012 ± .001 (0,30 ± 0,03) TYP. .250 ± .010 (6,35 ± 0,25) .150 (3,81) TYP. .220 (5,59) MAX. .085 ± .005 (2,16 ± 0,13) TYP. .020 ± .002 (0,51 ± 0,05) TYP. .100 ± .010 (2,54 ± 0,25) TYP. .004 (0,10) CL CL .100 (2,54) TYP. CIRCUITRY As viewed from the top of the switch in the positions shown in the drawing. B-5 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Surface Mount DIP Switches SPECIFICATIONS Electrical Ratings DIP Switches Make-and-break Current Rating: 2,000 operations per switch position at these resistive loads:10 mA, 30 Vdc; or 10 mA, 50 mVdc; 10 mA, 50 mVdc; or 25 mA, 24 Vdc; or 100 mA,6 Vdc. Contact Resistance: (measured at 10 mA, 50 mVdc). Initial: 20 mohms maximum, After Life: 100 mohms maximum Insulation Resistance: Minimum, at 100 Vdc between adjacent closed contacts and also acrosr776425 losed co.d also100): 5c[(,)-.473( )-..96( )-3569(imum, Afte TwM(100): 1c[( 2,00um)Tj/F7 1 TfT2-0.0011 Tc-0.093Die Tw(El Stak gthstance:)Tj/F4.463 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
90HBW10PT 价格&库存
很抱歉,暂时无法提供与“90HBW10PT”相匹配的价格&库存,您可以联系我们找货
90HBW10PT
  • 1+87.406521+11.28246
  • 16+69.7174616+8.99915
  • 32+65.8130832+8.49517
  • 112+59.51381112+7.68206
  • 256+55.92204256+7.21843
  • 512+53.25757512+6.87450
  • 1008+50.947411008+6.57631
库存:224
90HBW10PT
    • 25+44.43355
    • 1000+28.59446
    • 2500+21.47002
    • 5000+12.78406
