97C08ST
97C08ST
    GRAYHILLINC.
    SMD,P=1.27mm
    开关 滑动 插件 单刀单掷 25mA 24V
97C08ST 数据手册
Half Pitch DIP Switches SERIES 97 Half-Pitch Fig. 1 Series 97C DIMENSIONS Top View DIP Switches APPLICATIONS Used in any DIP application where space is at a premium such as notebook computers, hand-held radios, industrial control products, CDROM drives, cellular base stations and coin changers. FEATURES • Half the Size of Standard DIP Switches • Available in 2, 4, 6, 8, and 10 Positions • Low Profile • Less Mass for Easy Vacuum Pick & Place In inches (and millimeters) Front View Recommended PC Pad Dimensions Side View LENGTH SEE ORDERING INFORMATION .050 (1,27) Pitch .177 (4,50) TAPE THICKNESS .003 (0,08) .059 (1,50) .030 (0,76) .024 (0,61) .264 (6,71) Fig. 2 Series 97R DIMENSIONS Top View A .050 .004 (1,27) (0,10) Pitch Unless otherwise specified, tolerances are ±0.008 (0,20) .016 (0,41) In inches (and millimeters) Front View .047 (1,20) Side View .177±.002 (4,50±0,05) 4 5 6 7 .024 (0,6) 8 .319 (8,1) .024 (0,6) Electrical Ratings Contact Rating: 25 mA at 24 Vdc switching; 100 mA at 50 Vdc non-switching Contact Resistance: 100mΩ max, initial Insulation Resistance: 100 MΩ min at 100 Vdc Dielectric Strength: 300 Vac 60 sec Switch Capacitance: 5pF maximum Contact Arrangement: SPST Mechanical Ratings Life: 1,000 cycles minimum Operation Force: 500 gF Mechanical Shock: MIL-STD-202F, Method, 213B, Test Condition A. Gravity: 50G's (peak value), 11 m/sec. Direction and times: 6 sides and 3 times in each direction. Vibration: MIL-STD-202F, Method 201A. Passed 6 hours (2 hours in each) of three ORDERING INFORMATION .050 (1,27) PITCH .030 (0,76) .016 (0,40) Unless otherwise specified, tolerances are ±0.008 (0,20) SPECIFICATIONS Recommended PC Pad Dimensions .057 (1,44) TAPE .002 (0,05) ON 1 2 3 .291 (7,39) .242 (6,15) .193 (4,90) .050 (1,27) PITCH .004±.004 (0,10±0,10) perpendicular planes at a cycle of 10-55-10Hz/ 1 minute. Operating Temperature Range: -40 to 85°C Storage Temperature Range: -40 to 85°C .360 .260 (6,60) (9,10) .310 (7,85) CIRCUITRY Materials Base and Cover: UL94V-0 Nylon, black Actuators: UL94V-0 Nylon thermoplastic, white Base Contacts: Alloy copper with goldplating over nickel Terminals: Brass with gold-plating Tape Seal: Kapton Soldering Information Vapor phase and IR-reflow soldering can be applied. With stands 240°C peak temperature. All DIP switches are shipped in the "ON" position. Series: 97C see fig. 1, 97R see fig. 2 Positions: 02 = .148 (3,76), 04 = .248 (6,30), 06 = .348 (8,84), 08 = .448 (11,38), 10 = .548 (13,92) 97C06SR Packaging: Blank = Tube, R = Tape and Reel (see pkg note) Seal: Blank = Unsealed, S = Top Tape Seal Cleaning: Tape sealed versions are capable of withstanding spray wash processes using alcoholic solvents only, water or other solvents are not recommended. Care should be taken to avoid flux from the circuit board adhering to the switch body. The switch should be allowed to cool for at least 3 minutes between the end of the solder process and the beginning of the wash process. The solvent stage of the cleaning process is not to exceed 1 minute and the whole wash process is not to exceed 3 minutes. Ultrasonic cleaning is not recommended. Packaging Information Tube: 130 pcs/tube (2 positions), 75 pcs/ tube (4 positions), 54 pcs/tube (6 positions), 40 pcs/tube (8 positions), 33 pcs/tube (10 positions). Tape and Reel: 97C: 4,000 pcs/reel (all positions). 97R: 2500 pcs/reel (all positions). Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com B-4
97C08ST 价格&库存
很抱歉,暂时无法提供与“97C08ST”相匹配的价格&库存,您可以联系我们找货
