PANEL
PCB SWITCHES
T
-P
SW
11
21
65
PT65 series
Rotary code switches
DISTINCTIVE FEATURES
4 actuator types
Sub-miniature size
Solder and flux sealed, washable
ENVIRONMENTAL SPECIFICATIONS
• Operating temperature: -20 °C to +70 °C (-4 °F to +167 °F)
ELECTRICAL SPECIFICATIONS
• Operating voltage : ≤ 42 V
• Contact load, static : ≤ 0.2 A
• Contact load, dynamic : ≤ 0.15 A
• Initial contact resistance : 80 mΩ max.
• Insulation resistance : 100 MΩ min.
MECHANICAL SPECIFICATIONS
• Torque (typically) : 1.7 Ncm min
• Expected life : 30,000 steps
MATERIALS
• Base : UL94-V0, high temperature thermoplastic
• Cover : UL94-V0, high temperature thermoplastic
• Actuator : PA 4.6 nylon
• Contacts : gold over nickel plated phosphor bronze
• Terminals : tin plated
The company reserves the right to change specifications without notice.
1
PCB MOUNTING
SOLDERING
PACKAGING
• Switches for screwdriver slot or accessory actuation (PT651
and PT657) : tubes of 50 pieces
PCB RIGHT ANGLE 2.54
2.54
(.100)
Ø1.00
(.039 DIA)
• Accessories : bag of 50 pieces
2.54
(.100)
7.62
(.300)
• Wave soldering : 280 °C (536 °F) max. for 5 seconds max.
PCB STRAIGHT
2.54
(.100)
• Manual soldering : 340 °C (644 °F) max. for 2 seconds max.
Ø1.00
(.039 DIA)
• DIN CEI 68-2-20
2.54
(.100)
2
5.08
(.200)
PCB RIGHT ANGLE 5.08
Ø1.00
(.039 DIA)
PCB SWITCHES
PT65 series
BUILD YOUR PART NUMBER
PT65
ACTUATORS
SERIES
CODES
TERMINALS
1
Screwdriver
01
BCD
3
Spindle
02
BCD complement
5
Segment wheel
03
Hexadecimal
7
Cross accessories
06
Hexadecimal
complement
SCREWDRIVER
(blank)
SPINDLE
Straight
L254
Right angle,
spacing 2.54 (.100)
L508
Right angle,
spacing 5.08 (.200)
SEGMENT WHEEL
ACCESSORIES
Upper actuation
Side actuation
Upper actuation
Upper actuation
Side actuation
Upper actuation
BCD
PT65101
PT65101L254
PT65101L508
PT65301
PT65501
PT65701
BCD
COMPLEMENT
PT65102
PT65502
HEXADECIMAL
PT65103
PT65103L254
PT65103L508
PT65303
PT65503
PT65303L254
HEXADECIMAL
COMPLEMENT
PT65106
DIMENSIONS
3
PANEL
PCB SWITCHES
PT65 series
PCB SWITCHES
PT65 series
ACTUATORS
PT65
1
3
8
7
Screwdriver
Spindle (grey)
Segment wheel (grey)
Cross - accessories (see next page)
1
3
7
5
CODES
PT65
01
02
03
06
BCD
BCD complement
Hexadecimal
Hexadecimal complement
POSITION
C
POSITION
C
MARKING
1
2
8
C
MARKING
1
2
4
8
1
2
4
POSITION
8
C
MARKING
1
2
4
8
1
1
1
2
2
2
2
3
3
3
3
4
4
4
4
5
5
5
5
6
6
6
1
1
1
1
7
7
7
7
2
2
2
2
8
8
8
8
3
3
3
3
9
9
9
9
4
4
4
4
10
A
10
A
5
5
5
5
11
B
11
B
6
6
6
6
12
C
12
C
7
7
7
7
13
D
13
D
8
8
8
8
14
E
14
E
9
9
9
9
15
F
15
F
01
4
4
POSITION
MARKING
02
03
06
TERMINALS
PT65
(blank) Straight
L254 Right angle, spacing 2.54 (.100)
L508 Right angle, spacing 5.08 (.200)
(none)
L254
L508
ACCESSORIES
To order separately.
ACCESSORIES ADAPTED TO YOUR APPLICATIONS
Basic model PT657 has been designed to accept different actuators with snap-in connection.
According to your application, you can choose between spindles or plastic knobs in two different lengths and a Ø 17
mm (.669) knurled wheel for lateral marking.
Standard colours are shown below. Special colours are also available on request.
SPINDLES
PLASTIC KNOBS
P/N
COLORS
U4822
black
U4824
grey
Length 13.3 mm
U4832
black
Length 5.3 mm
(standard)
U4906
red
Length 15.7 mm
U4916
red
Length 11.6 mm
(standard)
Length 4.4 mm
KNURLED WHEEL
(unmarked - marking on request)
U4941
blue
U4943
green
U4944
grey
U4945
yellow
U4946
red
U4847/1
white/black
DIMENSIONS
5
PANEL
PCB SWITCHES
PT65 series
很抱歉,暂时无法提供与“PT65501L254”相匹配的价格&库存,您可以联系我们找货
