76HPSB10GWRT
76HPSB10GWRT
    GRAYHILLINC.
    插件
    开关 DIP 琴键式 STYLE 10位 30伏
76HPSB10GWRT 数据手册
Surface Mount DIP Switches Series 76HP FEATURES • Compatible with SMT Assembly Including Infrared Reflow and Vapor-Phase • Easily Accessed when PC Boards are Racked • Reliable Spring and Ball Contact Side Actuated PIANO-DIP® DIP Switches DIMENSIONS In inches (and millimeters) LeNGtH ± .010 (0,25 See OrDer INFO .023 .055 ± .010 (5,84) (1,40 ± 0,25) reF. .305 ± .010 (7,75 ± 0,25) Recommended PC Pad Dimensions .380 ± .010 (9,65 ± 0,25) .025 (0,64) r. CL CL .100 ± .005 (2,54 ± 0,13) tyP. Circuitry Specifications Electrical Ratings Make-and-break Current Rating: 2,000 operations per switch position at 1 mA, 5 Vdc; 50 mA, 30 Vdc; or 150 mA, 30 Vdc Contact Resistance: Initial: 30 mohms maximum; After Life: 100 mohms maximum (10 mA at 50 Vdc, open circuit) Insulation Resistance: Minimum, at 100 Vdc between adjacent closed contacts and also across open switch contacts. Initial: 2,000 Mohms Dielectric Strength: Minimum voltage (AC RMS) measured between adjacent closed contacts and also across open switch contacts. Initial: 750 volts; After Life: 500 volts Carry Rating: 5 amps, maximum rise of 20°C Switch Capacitance: 2 pF at 1 megahertz Mechanical Ratings Mechanical Life: 2,000 operations per switch position .280 (7,11) tyP. .303 ± .015 (7,70 ± 0,38) .012 ± .001 (0,30 ± 0,03) tyP. .424 ± .015 (10,77 ± 0,38) tyP. Vibration Resistance: Per Method 204, Test Condition B. 1 mS opening (10 mS allowed) Mechanical Shock: Per Method 213, Test Condition A. 1 mS opening (10 mS allowed) Thermal Shock Resistance: Per specification; no failures; passes contact resistance Terminal Strength: Per specification Thermal Aging: 1,000 hours at 85°C; no failures As viewed from the top of the switch in the positions shown in the drawing. .530 (13,46) tyP. Environmental Ratings Meets all requirements of MIL- S-83504**. Where Grayhill performance is superior, the MIL spec is listed in parentheses. Operating Temperature Range: -40°C to + 85°C Storage Temperature Range: -55°C to + 85°C Moisture Resistance: Per MIL-STD-202, Method 106 .070 (1,78) tyP. .100 (2,54) tyP. CL CL Materials and Finishes Shorting Member: Brass, gold-plated over nickel barrier. Base Contacts: Copper alloy, gold-plated, over nickel barrier. Terminals: Copper alloy, matte tin plated over nickel barrier. Non-Conductive Parts: Cover is natural color thermoplastic, actuators are white thermoplastic (UL94V-O) Tape Seal: Not available with Tape Seal. Tape and Reel Packaging Meets requirements of EIA 481-2 or EIA 481-3 13 INCH DIAMeter reeL Soldering Information Solderability: Per MIL-STD-202, Method 208 Tested to EIA Standard RS-448-2. Resistance to Soldering Heat:Per MIL-S-83504, six second test Recommended Processing Temperature: 220°C–230°C (1 pass—260°C maximum) Processing Position: Switch is to be processed with all actuators in the closed (on) position as shipped. CONDUCtIVe PLAStIC eMBOSSeD tAPe DIreCtION OF FeeD 16 & 24mm tAPe 16mm 76HPSB 08GW XXXX OPeN 76HPSB 08GW XXXX OPeN 76HPSB 08GW XXXX OPeN Ordering Information: Tape and Reel Packaging (500 switches per reel) 7,1 mm 12,2 mm 17,3 mm 22,4 mm 27,4 mm 24 mm 24 mm 32 mm 44 mm 44 mm 76HPSB02GWRT 76HPSB04GWRT 76HPSB06GWRT 76HPSB08GWRT 76HPSB10GWRT * For other lengths, contact Grayhill, Inc. ** Note: 100% matte tin terminal plating does not meet MIL-S-83504 for lead content. Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. XXXX 0.280" 0.480" 0.680" 0.880" 1.080" 76HPSB08GW 2 4 6 8 10 XXXX OPeN Part Number 76HPSB08GW Carrier Width Dim. A XXXX Length (metric) OPeN Length (inches) OPeN No. of Positions* 76HPSB08GW 16mm PIN ONe LOCAtION 32, 44 & 56mm tAPe COVer tAPe DIM. A (See OrDer INFO.) Each reel has a 15.750 inch (390 mm) minimum leader and a 6.30 inch (160 mm) minimum trailer. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com DIP 8
76HPSB10GWRT 价格&库存
很抱歉,暂时无法提供与“76HPSB10GWRT”相匹配的价格&库存,您可以联系我们找货
76HPSB10GWRT
  • 1+82.542671+10.71254
  • 10+68.5055110+8.89077
  • 25+63.4562325+8.23546
  • 100+56.70635100+7.35945
  • 250+52.89299250+6.86455
库存:2915
76HPSB10GWRT
  • 500+50.35492500+6.53515
  • 1000+48.104641000+6.24311
  • 1500+46.915201500+6.08874
库存:2915
