78J02T
78J02T
    GRAYHILLINC.
    插件,P=2.54mm
    开关 滑动式 DIP 单刀双掷 150毫安 30伏
78J02T 数据手册
Thru-Hole DIP Switches SERIES 76 and 78 SPDT DIMENSIONS: Series 76 DIP Switches FEATURES • Raised and Recessed Rocker, and Toggle Actuated Styles • SPDT with a Common Pole, or SPDT with 2 Isolated Circuits • Spring and Ball Contact • Top Tape Seal Option for Most Styles • RoHS Compliant CIRCUITRY: Series 76 in inches (and millimeters) Series 76 Raised Rocker 1 C1 2 .447 ± .015 (11,35 ± 0,38) TYP. A = .247 ± .010 (6,27 ± 0,25) .380 ± .010 (9,65 ± 0,25) C2 .020 + .005 –.000 (0,51 + 0,13) A .180 ± .010 (4,57 ± 0,25) .090 ± .005 (2,29 ± 0,13) TYP. .100 ± .005 (2,54 ± 0,13) TYP. C L DIMENSIONS: Series 78 C L Recessed Rocker 1 2 3 4 .100 ± .002 (2,54 ± 0,05) 5 A .020 ± .002 (0,51 ± 0,05) .020 ± .002 (0,51 ± 0,05) TYP. .090 ± .005 (2,29 ± 0,13) TYP. .100 ± .005 (2,54 ± 0,13) TYP. .295 + .000 –.020 (7,49 + 0 - 0,51) .156 + .015 –.010 (3,96 + 0,38 –0,25) TYP. C2 1 C1 1 1 C L C L .180 ± .010 (4,57 ± 0,25) .012 ± .001 (0,30 ± 0,03) .300 + .030 –.000 (7,62 + 0,76 - 0) To create common poles, tie together 2 adjoining terminals on 1 (either) side of Circuitry Positions Length Length No./ Raised Recessed Toggle Inches Metric Tube Type* Rockers* DIP* SPDT   2 Circuits C2 1 C1 A = .245 + .000 –.020 (6,22 + 0 - 0,51) ORDERING INFORMATION SPDT Form C 2 SPDT, 2 Circuits (No Commons) Dot on cover indicates active terminal when slide is on that side of switch. Contact is made with terminal on opposite .070 (1,78) REF. .050 ± .005 (1,27 ± 0,13) TYP. C C L L 1 C1 CIRCUITRY: Series 78 in inches (and millimeters) DIM. A SEE CHART 2 .247 ± .010 (6,27 ± 0,25) .012 ± .001 (0,30 ± 0,03) .300 + .030 –.000 (7,62 + 0,76) Series 78 Slide 0.380 ± .005 (9,65 ± 0,13) 1 C1 .295 + .000 –.020 (7,49 –0,51) .156 + .015 –.010 (3,96 + 0,38 –0,25) .050 ± .005 (1,27 ± 0,13) .020 ± .002 (0,51 ± 0,05) TYP. SPDT with Common True Form C Switching Toggle-DIP .380 ± .010 (9,65 ± 0,25) 2 4 1 2 3 4 5 0.380" 0.780" 9,7mm 19,8mm 0.280" 7,1mm 0.480" 12,2mm 0.680" 17,3mm 0.880" 22,4mm 1.080" 27,4mm 27 13 35 21 15 12 9 76SC02T 76SC04T 78J01T 78J02T 78J03T 78J04T 78J05T 76RSC02T 76STC02T 76RSC04T 76STC04T — — — — — — — — — — ADDITIONAL INFORMATION See Options and Accessories brochure For the most current sodering and cleaning processing guidelines reference Grayhill DIP Switch Processing Information, Bulletin 1234 Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. *To order top seal versions, add "S" before the "T" in the Grayhill part number. Not available on Toggle-DIP. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
78J02T 价格&库存
很抱歉,暂时无法提供与“78J02T”相匹配的价格&库存,您可以联系我们找货
