76SB12T
76SB12T
    GRAYHILLINC.
    插件,P=2.54mm
    开关 DIP EXT 翘板式 12位 通孔安装 30伏
76SB12T 数据手册
Thru-Hole DIP Switch SERIES 76 FEATURES • Raised and Recessed, Rocker and PIANO-DIP® Styles • Sealed Base Standard • Spring and Ball Contact • Top Tape Seal Option SPST Rocker DIP Switches 76 Th DIMENSIONS In inches (and millimeters) PIANO-DIP® Rocker and Recessed Rocker Side Actuated PIANODIP® End Views B = .156 ± .010 (3,96 ± 0,25) TYPICAL .020 + .005 –.000 (0,51 + 0,13) LENGTH ± .010 (±0,25) SEE ORDER INFO. LENGTH ± .010 (±0,25) SEE ORDER INFO. 1 2 3 4 5 6 .281 ± .010 (7,14 ± 0,25) TYP. B 7 .380 ± .010 (9,65 ± 0,25) .380 ± .010 (9,65 ± 0,25) OPEN OPEN C L C L .012 ± .001 (0,30 ± 0,03) .300 + .030 –.000 (7,62 + 0,76) Rocker A = .272 ± .010 (6,91 ± 0,25) 1 2 3 4 5 6 7 8 .020 + .005 –.000 (0,51 + 0,13) A .090 ± .005 (2,29 ± 0,13) .020 ± .002 (0,51 ± 0,05) .100 ± .005 (2,5 ± 0,13) .090 ± .005 (2,29 ± 0,13) .020 ± .002 (0,51 ± 0,05) .100 ± .005 (2,5 ± 0,13) .156 ± .010 (3,96 ± 0,25) TYP. C L C L .012 ± .001 (0,30 ± 0,03) .300 + .030 –.000 (7,62 + 0,76) For recessed rockers, delete .295 dimension. See also end view. See also end view. .295 + .000 –.020 (7,49 –0,51) CIRCUITRY Styles 76SB and 76RSB Style 76PSB Styles 76PRB UP IS OPEN (OFF) Typical circuit diagram with actuator as shown in the dimension drawing. UP IS CLOSED (ON) Actuator shown in the up position. Actuator shown in the up position. ORDERING INFORMATION Series Switch Style: SB = Raised Rocker RSB = Recessed Rocker PSB = Piano-DIP (Up is Off) PRB = Piano DIP (Up is On) T 76RSB04ST T = Lead-Free Sealed *: S = Tape Seal Number of Positions: 02 through 10, 12 *A top tape seal is required for switches that are machine soldered or heavily cleaned after hand soldering. To order top seal versions, add "S" to the Grayhill part number. Grayhill, Inc. • 561 Hillgrove Avenue No. of Pos. Length (Inches) Length (Metric) No./Tube 2 3 4 5 6 7 8 9 10 12 0.280" 0.380" 0.480" 0.580" 0.680" 0.780" 0.880" 0.980" 1.080" 1.280" 7,1 9,7 12,2 14,7 17,3 19,8 22,4 24,9 27,4 32,5 35 27 21 18 15 13 12 10 9 8 mm mm mm mm mm mm mm mm mm mm Available from your local Grayhill Distributor. For Specifications, see page B-14. For Options and Accessories, see page B-20. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. • LaGrange, Illinois 60525-5997 • USA •Phone: 708-354-1040 • Fax: 705-354-2820 • www.grayhill.com B-10
76SB12T 价格&库存
很抱歉,暂时无法提供与“76SB12T”相匹配的价格&库存,您可以联系我们找货
76SB12T
    • 1+23.10120
    • 200+9.22320
    • 496+8.91000
    • 1000+8.75880
    76SB12T
    • 1+64.634791+8.38631
    • 16+51.7069116+6.70893
    • 32+48.7984532+6.33156
    • 104+44.32219104+5.75077
    • 256+41.33793256+5.36357
    • 504+39.34902504+5.10551
    • 1000+37.555041000+4.87274
    • 2504+35.476832504+4.60309
    库存:29
    76SB12T
    • 31+31.12224
    • 1000+21.15926
    • 2500+16.85486
    • 5000+13.40893
    库存:3
