78HJ04GWT
78HJ04GWT
    GRAYHILLINC.
    插件
    开关 滑动式 DIP 单刀双掷 150毫安 30伏
78HJ04GWT 数据手册
Surface Mount DIP Switches Series 78H FEATURES • Compatible with SMT Assembly Including Infrared Reflow and Vapor-Phase • Reliable Spring and Ball Contact SPDT and DPST DIMENSIONS In inches (and millimeters) SPDT, DPST, Top Actuated, Slide Operated .023 .055 ± .010 (5,84) (1,40 ± 0,25) REF. Recommended PC Pad Dimensions LENGTH ± .010 (0,25) See OrDer iNFO .380 ± .010 (9,65 ± 0,25) .012 ± .001 (0,30 ± 0,03) TyP. .530 (13,46) TyP. .268 ± .010 (6,81 ± 0,25) .025 (0,64) R. .303 ± .015 (7,70 ± 0,38) .424 ± .015 (10,77 ± 0,38) TyP. CL CL .100 ± .005 (2,54 ± 0,13) TyP. .295 + .000 – .020 (7,49 – 0,51) with all actuators in the closed (on) position as shipped. DPST 1 ON 1 DIP Switches Dot indicates active circuit. OFF Specifications Electrical Ratings Meets requirements of EIA 481-2 or EIA 481-3 Environmental Ratings Meets all requirements of MIL- S-83504**. Where Grayhill performance is superior, the MIL spec is listed in parentheses. Operating Temperature Range: -40°C to + 85°C Storage Temperature Range: -55°C to + 85°C Moisture Resistance: Per MIL-STD-202, Method 106 4 3 2 1 4 3 2 1 3 24 mm 24 mm 32 mm 44 mm 44 mm 78HJ01GWT 78HJ02GWT 78HJ03GWT 78HJ04GWT 78HJ05GWT 78HF01GWT 78HF02GWT 78HF03GWT 78HF04GWT 78HF05GWT * Insert "R" before the "T" in the Grayhill part number for tape and reel packaging (500 switches/ reel). ** Note: 100% matte tin terminal plating does not meet MIL-S-83504 for lead content. 1 7,1 mm 12,2 mm 17,3 mm 22,4 mm 27,4 mm 16mm 2 0.280" 0.480" 0.680" 0.880" 1.080" Part Number* SPDT DPST 1 Carrier Width Dim. A 3 Length (metric) 4 Solderability: Per MIL-STD-202, Method 208 Soldering Heat Resistance: Per MIL-S-83504, six second test Recommended Processing Temperature: 220°C–230°C (1 pass—260°C maximum) Processing Position: Switch is to be processed Length (inches) 16 & 24mm TAPe 2 1 2 3 4 5 DIRECTION OF FeeD 1 1 1 4 CONDUCTIVE PLASTIC EMBOSSED TAPe 2 No. of Positions 13 INCH DIAMETER REEL Soldering Information Ordering Information: Tube Packaging Tape and Reel Packaging 3 Mechanical Life: 2,000 operations per switch position Vibration Resistance: Per method 204, Test Condition B. 1 mS opening (10 mS allowed) Mechanical Shock: Per Method 213, Test Condition A. 1 mS opening (10 mS allowed) Terminal Strength: Per specification Thermal Aging: 1,000 hours at 85°C; no failures Thermal Shock: Per specification; no failures; passes contact resistance Shor ting Member : Brass, gold-plated over nickel barrier. Base Contacts: Copper alloy, gold-plated over nickel barrier. Terminals: Copper alloy, matte tin-plated over nickel barrier. Non-Conductive Parts: Cover is natural color thermoplastic, actuators are white thermoplastic (UL94V-O) 4 Mechanical Ratings ON Materials and Finishes 4 Make-and-break Current Rating: 2,000 operations per switch position at 1 mA, 5 Vdc; 50 mA, 30 Vdc; or 150 mA, 30 Vdc Contact Resistance: Initial: 30 mohms max. After Life: 100 mohms max. (10 mA at 50 Vdc, open circuit) Insulation Resistance: Minimum, at 100 Vdc between adjacent closed contacts and also across open switch contacts. Initial: 2,000 Mohms; After Life: 1,000 Mohms Dielectric Strength: Minimum voltage (AC, RMS) measured between adjacent closed contacts and also across open switch contacts. Initial: 750 volts; After Life: 500 volts Current Carry Rating: 4 amps, maximum rise of 20°C Switch Capacitance: 2 pF at 1megahertz .070 (1,78) TyP. .100 (2,54) TyP. CL CL Circuitry SPDT 2 Circuits (no common) 1 1 ON .280 (7,11) TyP. 1 1 1 2 2 2 3 3 3 4 4 4 16mm PIN ONE LOCATION 32 & 44mm TAPe COVER TAPE DIM. A (SEE ORDER INFO.) Each reel has a 15.750 inch (390 mm) minimum leader and a 6.30 inch (160 mm) minimum trailer. Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. DIP 7 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
78HJ04GWT 价格&库存
很抱歉,暂时无法提供与“78HJ04GWT”相匹配的价格&库存,您可以联系我们找货
78HJ04GWT
    • 1+94.38120
    • 204+37.65960
    • 504+36.40680
    • 996+35.78040
    78HJ04GWT
      78HJ04GWT
      • 1+120.190751+15.41688
      78HJ04GWT
