PT65101L254
PT65101L254
    APEM(埃斐)
    DIP
    PT65101L254
PT65101L254 数据手册
PANEL PCB SWITCHES T -P SW 11 21 65 PT65 series Rotary code switches DISTINCTIVE FEATURES 4 actuator types Sub-miniature size Solder and flux sealed, washable ENVIRONMENTAL SPECIFICATIONS • Operating temperature: -20 °C to +70 °C (-4 °F to +167 °F) ELECTRICAL SPECIFICATIONS • Operating voltage : ≤ 42 V • Contact load, static : ≤ 0.2 A • Contact load, dynamic : ≤ 0.15 A • Initial contact resistance : 80 mΩ max. • Insulation resistance : 100 MΩ min. MECHANICAL SPECIFICATIONS • Torque (typically) : 1.7 Ncm min • Expected life : 30,000 steps MATERIALS • Base : UL94-V0, high temperature thermoplastic • Cover : UL94-V0, high temperature thermoplastic • Actuator : PA 4.6 nylon • Contacts : gold over nickel plated phosphor bronze • Terminals : tin plated The company reserves the right to change specifications without notice. 1 Rotary code switches PCB MOUNTING SOLDERING PACKAGING • Switches for screwdriver slot or accessory actuation (PT651 and PT657) : tubes of 50 pieces PCB RIGHT ANGLE 2.54 2.54 (.100) Ø1.00 (.039 DIA) • Accessories : bag of 50 pieces 2.54 (.100) 7.62 (.300) • Wave soldering : 280 °C (536 °F) max. for 5 seconds max. PCB STRAIGHT 2.54 (.100) • Manual soldering : 340 °C (644 °F) max. for 2 seconds max. Ø1.00 (.039 DIA) • DIN CEI 68-2-20 2.54 (.100) 2 5.08 (.200) PCB RIGHT ANGLE 5.08 Ø1.00 (.039 DIA) PCB SWITCHES PT65 series Rotary code switches BUILD YOUR PART NUMBER PT65 ACTUATORS SERIES CODES TERMINALS 1 Screwdriver 01 BCD 3 Spindle 02 BCD complement 5 Segment wheel 03 Hexadecimal 7 Cross accessories 06 Hexadecimal complement SCREWDRIVER (blank) SPINDLE Straight L254 Right angle, spacing 2.54 (.100) L508 Right angle, spacing 5.08 (.200) SEGMENT WHEEL ACCESSORIES Upper actuation Side actuation Upper actuation Upper actuation Side actuation Upper actuation BCD PT65101 PT65101L254 PT65101L508 PT65301 PT65501 - PT65701 BCD COMPLEMENT PT65102 - - PT65502 - - HEXADECIMAL PT65103 PT65103L254 PT65103L508 PT65303 PT65503 PT65303L254 - HEXADECIMAL COMPLEMENT PT65106 - - - - - DIMENSIONS 3 PANEL PCB SWITCHES PT65 series PCB SWITCHES PT65 series Rotary code switches ACTUATORS PT65 1 3 8 7 Screwdriver Spindle (grey) Segment wheel (grey) Cross - accessories (see next page) 1 3 7 5 CODES PT65 01 02 03 06 BCD BCD complement Hexadecimal Hexadecimal complement POSITION C POSITION C MARKING 1 2 8 C MARKING 1 2 4 8 1 2 4 POSITION 8 C MARKING 1 2 4 8 0 0 0 0 1 1 1 1 2 2 2 2 3 3 3 3 4 4 4 4 5 5 5 5 0 0 0 0 6 6 6 6 1 1 1 1 7 7 7 7 2 2 2 2 8 8 8 8 3 3 3 3 9 9 9 9 4 4 4 4 10 A 10 A 5 5 5 5 11 B 11 B 6 6 6 6 12 C 12 C 7 7 7 7 13 D 13 D 8 8 8 8 14 E 14 E 9 9 9 9 15 F 15 F 01 4 4 POSITION MARKING 02 03 06 Rotary code switches TERMINALS PT65 (blank) Straight L254 Right angle, spacing 2.54 (.100) L508 Right angle, spacing 5.08 (.200) (none) L254 L508 ACCESSORIES To order separately. ACCESSORIES ADAPTED TO YOUR APPLICATIONS Basic model PT657 has been designed to accept different actuators with snap-in connection. According to your application, you can choose between spindles or plastic knobs in two different lengths and a Ø 17 mm (.669) knurled wheel for lateral marking. Standard colours are shown below. Special colours are also available on request. SPINDLES PLASTIC KNOBS P/N COLORS U4822 black U4824 grey Length 13.3 mm U4832 black Length 5.3 mm (standard) U4906 red Length 15.7 mm U4916 red Length 11.6 mm (standard) Length 4.4 mm KNURLED WHEEL (unmarked - marking on request) U4941 blue U4943 green U4944 grey U4945 yellow U4946 red U4847/1 white/black DIMENSIONS 5 PANEL PCB SWITCHES PT65 series
PT65101L254 价格&库存
很抱歉,暂时无法提供与“PT65101L254”相匹配的价格&库存,您可以联系我们找货
