DPL02T
DPL02T
    APEM(埃斐)
    插件
    DPL02T
DPL02T 数据手册
DIP & ROTARY DIP SWITCHES SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. DIP & ROTARY DIP SWITCH SELECTION GUIDE: This catalog contains an extensive variety of DIP & rotary DIP switches with many options. To facilitate easy selection of the desired switch for your application, this guide lists the various Series with a brief description. G SERIES DESCRIPTION PAGE(S) IK DIP switches, low profile, surface and through-hole mounting G2-G3 DS, DA & DP DIP switches, vertical, right angle and piano styles, through-hole mounting G4-G6 DI & DM DIP switches, low profile, surface and through-hole mounting G7-G8 PI & PM DIP switches, sealed piano style, low profile, surface and through-hole mounting G9-G10 DHS DIP switches, ultra-compact 1/2 pitch, surface mounting G11 MPG DIP switches, transfer style in 1, 2, 3 & 4 pole models, through-hole mounting G12-G13 TDS DIP switches, 3 state (+, 0, -), through-hole mounting G14 P36 & P36S Rotary DIP switches, low profile, surface and through-hole mounting G15-G16 PT65 Rotary DIP switches, through-hole mounting with extensive options G17-G20 P60A & P60AS Rotary DIP switches, low profile, surface and through-hole mounting, 4+1 terminal layout G21-G22 PT65 Rotary DIP switches, pulse generator, through-hole mounting G23-G24 APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com G1 IK SERIES HIGH REL SPST SURFACE MOUNT DIP SWITCHES FEATURES Ultra-compact size with very low-profile. Self-cleaning wiping contacts. Tin plated terminals. IR & vapor phase reflow solderable. Washable. Heavy gold plate. GENERAL SPECIFICATIONS Electrical life Contact rating, non-switching Contact rating, switching Initial contact resistance Insulation resistance Dielectric strength 2000 cycles minimum 100 mA at 48 VDC 100 mA at 24 VDC 30 mΩ maximum after 2000 cycles: 100 mΩ max. 1000 MΩ min. at 500 VDC 500 VAC minimum MECHANICALS, THERMALS Travel Operating temperature range Storage temperature range .026" (0.67mm) -40°C to +100°C -40°C to +125°C SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. ELECTRICALS SOLDERING & CLEANING RECOMMENDATIONS Hand soldering 330°C max. for 3 seconds max.(30 watt iron max.) Reflow soldering Set oven at 215°C max. for 90 seconds max. Cleaning 1-1-1 Trichloroethane, Freon TE, Isopropyl alcohol or aqueous (with standard tape seal) cleaner for 2 minutes max. at 20°C IC TUBES TAPE & REEL MATERIALS G Case Actuators Stationary contact Moving contact Terminals Tape seal UL94-VO, thermoplastic, white UL94-VO, thermoplastic, black Gold over nickel over bronze Gold over beryllium copper Tin plated over nickel barrier Polyimide ANTISTATIC PACKAGING Standard packaging: Reels of 1,000 units - Tape meeting IEC Standard - Publication 286-3 (EIA481A). Start leader: 15.7" (400mm) min. End leader: 6.3" (160mm) - see illustration. IC tubes - see illustration Tape & reel Model No. IC tubes Model No. No of pos. IKN0204000 IKN0203000 2 .236 (6mm) IKN0404000 IKN0403000 4 .437 (11.1mm) IKN0604000 IKN0603000 6 .637 (16.2mm) IKN0804000 IKN0803000 8 .838 (21.3mm) Pos. 2 4 6 8 Tape dim. 'L' .629 (16mm) .944 (24mm) .944 (24mm) 1.259 (32mm) Pos. 2 4 6 8 Qty per tube 88 48 33 25 Dimension 'A' Tape All switches are supplied in 'ON' position. Dimensions shown in millimeters and inches (in parenthesis). G2 APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com IK SERIES HIGH REL SPST THROUGH-HOLE DIP SWITCHES FEATURES Ultra-compact size with low-profile. Self-cleaning wiping contacts. Tin plated terminals. Wave solderable. Washable. Heavy gold plate. GENERAL SPECIFICATIONS SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. ELECTRICALS Electrical life Contact rating, non-switching Contact rating, switching Initial contact resistance Insulation resistance Dielectric strength 2000 cycles minimum 100 mA at 48 VDC 100 mA at 24 VDC 30 mΩ maximum after 2000 cycles: 100 mΩ max. 1000 MΩ min. at 500 VDC 500 VAC minimum MECHANICALS, THERMALS Travel Operating temperature range Storage temperature range .026" (0.67mm) -40°C to +100°C -40°C to +125°C SOLDERING & CLEANING RECOMMENDATIONS Hand soldering 330°C max. for 3 seconds max.(30 watt iron max.) Reflow soldering Set oven at 215°C max. for 90 seconds max. Cleaning 1-1-1 Trichloroethane, Freon TE, Isopropyl alcohol or aqueous (with standard tape seal) cleaner for 2 minutes max. at 20°C IC TUBES MATERIALS Case Actuators Stationary contact Moving contact Terminals Tape seal UL94-VO, thermoplastic, white UL94-VO, thermoplastic, black Gold over nickel over bronze Gold over beryllium copper Tin plated over nickel barrier Polyimide Pos. 2 4 6 8 ANTISTATIC PACKAGING Standard packaging: IC tubes - see illustration Model Number G Qty per tube 88 48 33 25 No of Dimension 'A' pos. Model No. IKN0200000 2 .236 (6mm) IKN0400000 4 .437 (11.1mm) IKN0600000 6 .637 (16.2mm) IKN0800000 8 .838 (21.3mm) Tape All switches are supplied in 'ON' position. General dimensional tolerances are ± .012 (0.3mm) Dimensions shown in millimeters and inches (in parenthesis). APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com G3 DS, DA & DP SERIES SPST STANDARD DIP SWITCHES FEATURES High reliability. Self-cleaning contacts. Multi- positions. Process compatible with tape seal. Dual in-line .100" x .300" term. spacing. GENERAL SPECIFICATIONS Electrical life Contact rating, non-switching Contact rating, switching Contact resistance at current 100 mA Insulation resistance at 500 VDC Dielectric strength Capacitance 2000 cycles min. per switch @ 24 VDC, 25 mA 100 mA at 50 VDC 25 mA at 24 VDC 50 mΩ max. initial - 100 mΩ max. after life test 100 MΩ minimum 500 VAC for 1 minute 5 pf. max. between adjacent terminals MECHANICALS, THERMALS Mechanical life Operating force Vibration Shock Operating temperature range 2000 cycles min. per switch 1000 grams max. (DP Series only - 400 grams max.) 10-55 Hz.per MIL-STD-202F METHOD 201A 50 G (peak value) for 11 msec. per MIL-STD-202F, METHOD 213B -40°C to 85°C SOLDERING & CLEANING RECOMMENDATIONS* Hand soldering 320°C max. for 2 seconds max.(30 watt iron max.) Wave soldering 260°C max. for 5 seconds max. Cleaning (with tape seal) Spray wash from top side only. * Note: keep switches in “OFF” position during soldering and cleaning for best results G MATERIALS Base Cover Actuators Contacts & Terms. Sealing Tape seal UL94V-O, glass fiber filled PBT, black UL94V-O, glass fiber filled PBT, red UL94V-O, glass fiber filled PBT, white Gold over nickel plated phosphor bronze Epoxy Polyester film PACKAGING DIP switches are shipped in standard IC tubes with all actuators in the "OFF" position. SWITCH CROSS SECTIONS SCHEMATIC (TYPICAL) Normally open contact system DS & DA G4 DP See tabulations on following pages for number of positions available (10 shown) APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. ELECTRICALS DS Series Slides Actuator Style & Terminal Mat'l. Raised Actuator SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. Gold Terms. Recessed Actuator Gold Terms. MODEL NO. with no tape seal MODEL NO. with tape seal 'A' Dimension No. of +.008/-.000" Pos. (+0.2/-0.0mm) DS02 DS03 DS04 DS05 DS06 DS07 DS08 DS09 DS10 DS12 DS02T DS03T DS04T DS05T DS06T DS07T DS08T DS09T DS10T DS12T 2 3 4 5 6 7 8 9 10 12 .254 .354 .454 .554 .654 .754 .854 .954 1.054 1.254 (6,45) (8,98) (11,52) (14,08) (16,60) (19,14) (21,68) (24,22) (26,77) (31,85) n/a n/a n/a n/a n/a n/a n/a n/a n/a n/a DSR02T DSR03T DSR04T DSR05T DSR06T DSR07T DSR08T DSR09T DSR10T DSR12T 2 3 4 5 6 7 8 9 10 12 .254 .354 .454 .554 .654 .754 .854 .954 1.054 1.254 (6,45) (8,98) (11,52) (14,08) (16,60) (19,14) (21,68) (24,22) (26,77) (31,85) n/a = not available. G DA Series Right angle Actuator Style Raised Actuator MODEL NO. with no tape seal MODEL NO. with tape seal No. of Pos. DA04 DA05 DA06 DA07 DA08 DA09 DA10 DA12 DA04T DA05T DA06T DA07T DA08T DA09T DA10T DA12T 4 5 6 7 8 9 10 12 'A' Dimension +.008/-.000" (+0.2/-0.0mm) .454 .554 .654 .754 .854 .954 1.054 1.254 (11,52) (14,08) (16,60) (19,14) (21,68) (24,22) (26,77) (31,85) APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com G5 Actuator Style G MODEL NO. with no tape seal MODEL NO. with tape seal No. of Pos. 'A' Dimension +.008/-.000" (+0.2/-0.0mm) Recessed Actuator DP02 DP03 DP04 DP05 DP06 DP07 DP08 DP09 DP10 DP12 DP02T DP03T DP04T DP05T DP06T DP07T DP08T DP09T DP10T DP12T 2 3 4 5 6 7 8 9 10 12 .261 .361 .461 .561 .661 .761 .861 .961 1.061 1.261 (6,64) (9,18) (11,72) (14,25) (16,80) (19,34) (21,88) (24,42) (26,96) (32,04) Extended Actuator DPL02 DPL03 DPL04 DPL05 DPL06 DPL07 DPL08 DPL09 DPL10 DPL12 DPL02T DPL03T DPL04T DPL05T DPL06T DPL07T DPL08T DPL09T DPL10T DPL12T 2 3 4 5 6 7 8 9 10 12 .261 .361 .461 .561 .661 .761 .8601 .961 1.061 1.261 (6,64) (9,18) (11,72) (14,25) (16,80) (19,34) (21,88) (24,42) (26,96) (32,04) Note: Push up for ON position is also available on special order - consult factory. SPLASHPROOF COVER Clear polyethylene snap-fit cover for models DS08 and DSR08. Order part no. C8 G6 APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. DP Series Piano DI & DM SERIES SPST STANDARD DIP SWITCHES FEATURES High reliability. Self-cleaning contacts. Multi- positions. Process compatible with tape seal. Dual in-line .100" x .300" term. spacing. GENERAL SPECIFICATIONS SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. ELECTRICALS Electrical life Contact rating, non-switching Contact rating, switching Contact resistance at current 100 mA Insulation resistance at 100 VDC Dielectric strength Capacitance 2000 cycles min. per switch @ 24 VDC, 25 mA 100 mA at 50 VDC 25 mA at 24 VDC 50 mΩ max. initial - 100 mΩ max. after life test 100 MΩ minimum 500 VAC for 1 minute 5 pf. max. between adjacent terminals MECHANICALS, THERMALS Mechanical life Operating force Vibration Shock Operating temperature range 2000 cycles min. per switch 1000 grams max. 10-55 Hz.per MIL-STD-202F METHOD 201A 50 G (peak value) for 11 msec. per MIL-STD-202F, METHOD 213B -40°C to 85°C SOLDERING & CLEANING RECOMMENDATIONS* Hand soldering 320°C max. for 2 seconds max.(30 watt iron max.) Wave soldering 260°C max. for 5 seconds max. Cleaning (with tape seal) Spray wash from top side only. * Note: keep switches in “OFF” position during soldering and cleaning for best results MATERIALS Base & Cover Actuators Contacts Terminals Term. Sealing Tape seal G DI: UL94V-O, glass fiber filled PBT, black DM: UL94V-O, glass fiber filled PPS, black UL94V-O, Nylon, white Gold over nickel plated copper alloy DI: Tin/lead plated brass. DM: Gold over nickel plated copper alloy. Molded-in Kapton PACKAGING DIP switches are shipped in standard IC tubes with all actuators in the "OFF" position. Tape & reel packaging per EIA available for DMR models (see next page). SWITCH CROSS SECTIONS SCHEMATIC (TYPICAL) Double contact system DI & DM See tabulations on following pages for number of positions available (10 shown) APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com G7 Tin/lead plated brass terminals Gold plated terminals available on request Recessed MODEL NO. with no tape seal DI01H DI02H DI04H DI06H DI08H DI10H DIR01H DIR02H DIR04H DIR06H DIR08H DIR10H Spread terminals MODEL NO. with tape seal n/a n/a n/a n/a n/a n/a n/a DIR02HT DIR04HT DIR06HT DIR08HT DIR10HT MODEL NO. with no tape seal DI01S DI02S DI04S DI06S DI08S DI10S DIR01S DIR02S DIR04S DIR06S DIR08S DIR10S MODEL NO. with tape seal n/a n/a n/a n/a n/a n/a DIR01ST DIR02ST DIR04ST DIR06ST DIR08ST DIR10ST No. 'A' Dim. of +.008/-.000" Pos. (+0.2/-0.0mm) 1 2 4 6 8 10 1 2 4 6 8 10 .137 .237 .437 .637 .837 1.037 .137 .237 .437 .637 .837 1.037 (3,48) (6,02) (11.10) (16,18) (21,26) (26,34) (3,48) (6,02) (11,10) (16,18) (21,26) (26,34) ★ Auto-insertable using equipment from Amistar, Dynapert, Panasert, Northeastern Tool, Universal and others. n/a = not available. G DM Series Surface Mount ★ Actuator Style Raised Actuator Recessed Actuator MODEL NO. with no tape seal MODEL NO. with tape seal DM01 DM02 DM03 DM04 DM05 DM06 DM07 DM08 DM09 DM10 DM12 DMR01 DMR02 DMR03 DMR04 DMR05 DMR06 DMR07 DMR08 DMR09 DMR10 DMR12 n/a n/a n/a n/a n/a n/a n/a n/a n/a n/a n/a n/a DMR02T DMR03T DMR04T DMR05T DMR06T DMR07T DMR08T DMR09T DMR10T DMR12T 'A' Dimension No. of +.008/-.000" Pos. (+0.2/-0.0mm) 1 2 3 4 5 6 7 8 9 10 12 1 2 3 4 5 6 7 8 9 10 12 .137 .237 .337 .437 .537 .637 .737 .837 .937 1.037 1.237 .137 .237 .337 .437 .537 .637 .737 .837 .937 1.037 1.237 (3,48) (6,02) (8,56) (11,10) (13,64) (16,18) (18,72) (21,26) (23,80) (26,34) (31.42) (3,48) (6,02) (8,56) (11,10) (13,64) (16,18) (18,72) (21,26) (23,80) (26,34) (31.42) For tape & reel packaging on DMR models only, add 'TR' to model number - example: DMR08TTR. Note- tape & reel packaging is available only with tape seal models. 900 switches per reel. G8 APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. Actuator Squared terminals Raised DI Series Machine Insertable ★ PI & PM SERIES SPST SEALED PIANO DIP SWITCHES FEATURES Built-in seal for process compatibility. High reliability. Splayed thru-hole or SMT terminals. 2, 4, 6, 8 & 10 positions. Piano style actuators. Dual in-line .100" x .300" term. spacing. GENERAL SPECIFICATIONS SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. ELECTRICALS Electrical life Contact rating, non-switching Contact rating, switching Contact resistance at current 100 mA Insulation resistance at 500 VDC Dielectric strength Capacitance 200 cycles min. per switch @ 24 VDC, 25 mA 100 mA at 50 VDC 25 mA at 24 VDC 50 mΩ max. initial - 100 mΩ max. after life test 100 MΩ minimum 300 VAC for 1 minute 5 pf. max. between adjacent terminals MECHANICALS, THERMALS Mechanical life Operating force Vibration Shock Operating temperature range 500 cycles min. per switch 800 grams max. 10-55 Hz.per MIL-STD-202F METHOD 201A 50 G (peak value) for 11 msec. per MIL-STD-202F, METHOD 213B -40°C to 85°C SOLDERING & CLEANING RECOMMENDATIONS* Hand soldering 320°C max. for 2 seconds max.(30 watt iron max.) Wave soldering 260°C max. for 5 seconds max. Note PM Series is vapor phase or IR reflow solderable. Force rinse, high agitation or Sealed construction permits washing with freons, alcohol, water triple bath cleaning method and steam. When vapor methods are used, do not subject switch to solvents above 51°C. * Note: keep switches in “ON” position during soldering and cleaning for best results MATERIALS Base & Cover Actuators Contacts Terminals Term. Sealing Tape seal UL94V-O, high temperature thermoplastic, color black UL94V-O, high temperature thermoplastic, color `.01*white Gold over nickel plated copper alloy or brass Tin/lead (90/10 solder) plated copper alloy or brass Molded-in High temperature modulus Teflon internal seal G d PM e PI an ls featur e mod uely iq a un ned g desi al seal! n inter PACKAGING DIP switches are shipped in standard IC tubes with all actuators in the "ON" position. Tape & reel packaging per EIA available for PM models - consult factory. SWITCH CROSS SECTION SCHEMATIC (TYPICAL) Double contact system PI & PM See tabulations on following page for number of positions available (10 shown) APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com G9 Actuator Style MODEL N0. (internally sealed) 'A' Dimension ±.012 (0,30mm) Flush PI02090 PI04090 PI06090 PI08090 PI10090 2 4 6 8 10 .290 .490 .690 .890 1.090 (7,37) (12,45) (17,53) (22,61) (27,69) Extended PI02190 PI04190 PI06190 PI08190 PI10190 2 4 6 8 10 .290 .490 .690 .890 1.090 (7,37) (12,45) (17,53) (22,61) (27,69) Auto-insertable using equipment from Amistar, Dynapert, Panasert, Northeastern Tool, Universal and others. ★ G PM Series Piano ★ PI and PM models listed feature a uniquely designed internal seal! Non-sealed versions are also available. To order the non-sealed model, replace the '0' at the end of the model number with '1'. MODEL N0. (internally sealed) No. of Pos. Flush PM02090 PM04090 PM06090 PM08090 PM10090 2 4 6 8 10 .290 .490 .690 .890 1.090 (7,37) (12,45) (17,53) (22,61) (27,69) Extended PM02190 PM04190 PM06190 PM08190 PM10190 2 4 6 8 10 .290 .490 .690 .890 1.090 (7,37) (12,45) (17,53) (22,61) (27,69) Actuator Style G10 No. of Pos. 'A' Dimension ±.012 (0,30mm) APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. PI Series Piano ★ DHS SERIES 1/2 PITCH SPST SURFACE MOUNT DIP SWITCHES FEATURES Ultra-compact low-profile size. .050" (1.27mm) terminal spacing. Self-cleaning twin point contacts. Auto-insertable and reflow solderable. Process compatible with std'd. tape seal. GENERAL SPECIFICATIONS SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. ELECTRICALS Electrical life 1000 cycles minimum Contact rating, non-switching 100 mA at 50 VDC Contact rating, switching 100 mA at 6 VDC Contact resistance 100 mΩ maximum Insulation resistance 100 MΩ minimum Dielectric strength 250 VDC for 1 min. between adjacent or opposite terminals Capacitance 5 pf. max. between adjacent or opposite terminals MECHANICALS, THERMALS Operating force 400 grams maximum Vibration 10-55 Hz. per MIL-STD-202F, METHOD 201A Shock 50 g (peak value) for 11 msec. per MIL-STD-202F, METHOD 213B Operating temperature range -40°C to +80°C SOLDERING & CLEANING RECOMMENDATIONS Hand soldering 330°C max. for 3 seconds max.(30 watt iron max.) Reflow soldering Set oven at 215°C max. for 90 seconds max. Cleaning (with standard tape seal in place) MATERIALS Base Cover Actuators Contacts Terminals Terminal seal Tape seal 1-1-1 Trichloroethane, Freon TE, Isopropyl alcohol or aqueous cleaner for 2 minutes max. at 20°C UL94V-O, glass fiber filled PPS, black UL94V-O, glass fiber filled PPS, black UL94V-O, Polyamide, yellow Gold plated beryllium copper Gold plated copper alloy Epoxy Polyimide MECHANICAL OUTLINE G PACKAGING Supplied in tape & reel packaging. Reel & tape meets the requirements of EIA-481-A. S Style SR/TC Style MODEL NO. 0F A DIMENSION NUMBER POS. IN(± .012) MM(± 0.30) DHS4S 4 .268 6.81 DHS6S 6 .368 9.35 DHS8S 8 .468 11.89 DHS10S 10 .568 14.43 Note: S at end of model no. indicates S style packaging. Substitute SR/TC for S for SR/TC packaging. PRINTED CIRCUIT BOARD OUTLINE (8 positions shown) SCHEMATIC (8 positions shown) APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com G11 MDG & MPG SERIES TRANSFER DIP SWITCHES SPDT & DPDT MODELS FEATURES Gold plated contacts. Self-cleaning contacts. UL94V-O materials used throughout. Process compatible with tape seal. Dual in-line .100" x .300" term. spacing. GENERAL SPECIFICATIONS Electrical life Contact rating, non-switching Contact rating, switching Contact resistance Insulation resistance at 100 VDC Dielectric strength Capacitance 2000 cycles minimum 100 mA at 50 VDC 25 mA at 24 VDC 50 mΩ max. initial - 100 mΩ max. after life test 1000 MΩ minimum 500 VDC for 1 minute 5 pf. max. between adjacent terminals MECHANICALS, THERMALS Mechanical life Operating force Vibration Humidity Temperature range 3000 cycles minimum MDG; 800 grmas max. per pole MPG; 400 grams max. per pole. Per MIL-STD-202, METHOD 204B 95% relative humidity, 40°C for 96 hours Operating: -25°C to 70°C Storage: -40°C to 85°C SOLDERING & CLEANING RECOMMENDATIONS G Hand soldering Wave soldering 320°C max. for 2 seconds max.(30 watt iron max.) 230°C max. for 3 seconds max. Cleaning (with tape seal) Spray wash from top side only MATERIALS Cover Actuators Contacts & Terminals Sealing Tape seal UL94V-O, Polyamide UL94V-O, Polyamide Gold over nickel plate over brass Epoxy Polyester film PACKAGING DIP switches are shipped in standard IC tubes with all actuators in the “OFF” position SWITCH CROSS SECTION MDG G12 MPG APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. ELECTRICALS MDG Series Slides DPDT MDG602S SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. Actuator Style & Contact Material MODEL N0. with no tape seal Std'd Act. MDG601S Gold Cont. MDG602S MODEL NO. with tape seal MDG601ST MDG602ST No. ‘A' Dimension of ±.012 (0,30mm) Pos. 1 2 .461 .854 (11,7) (21,7) G MPG Series Piano SPDT MPG302B Actuator Style & Contact Material Piano Gold Contacts MODEL N0. with no tape seal MODEL NO. with tape seal MPG301B MPG302B MPG303B MPG304B MPG305B MPG306B MPG301BT MPG302BT MPG303BT MPG304BT MPG305BT MPG306BT No. 'A' Dimension of ±.012 (0,30mm) Pos. 1 2 3 4 5 6 .264 .461 .657 .854 1.050 1.250 (6,7) (11,7) (16,7) (21,7) (26,7) (31,8) APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com G13 TDS SERIES SP 3 POSITION 3 STATE (+,0,-) DIP SWITCHES FEATURES 3 code functions per position (n). Self-cleaning twin point contacts. UL94V-O materials used throughout. Process compatible. Crimped terminals for positive p.c. board retention during installation. GENERAL SPECIFICATIONS Electrical life 2000 operations minimum per switch Contact rating, non-switching 100 mA at 50 VDC Contact rating, switching 25 mA at 24 VDC Contact resistance Initial:50 mΩ max. After 2000 operations: 100 mΩ max. Insulation resistance 100 MΩ minimum between adjacent terms.at 500 VDC Dielectric strength 500 VDC for 1 minute Capacitance 5 pf. maximum MECHANICALS, THERMALS Mechanical life Operating force Vibration Shock Temperature range 2000 operations minimum per switch 1000 grams maximum 10-55-10 Hz./1 min. (3 planes) per MIL-STD-202F, METHOD 201A 50 G (peak value) for 11 msec. per MIL-STD-202F, METHOD 213B Operating and storage: -40°C to +85°C SOLDERING RECOMMENDATIONS* Hand soldering 320°C max. for 2 seconds max.(30 watt iron max.) Wave soldering 260°C max. for 5 seconds *For best results, keep actuator in 'O' position during soldering. G MATERIALS Base Cover Actuators Contacts Terminals UL94V-O, glass fiber filled PBT, black UL94V-O, glass fiber filled PBT, black UL94V-O, glass fiber filled Nylon, white Gold over nickel over brass 90/10 Solder plate over brass PACKAGING Normally supplied in standard IC tubes with all actuators in the 'O' position MODEL NO. 0F NUMBER POS. (n) G14 A DIM. (MAX) B DIMENSION INCHES MM INCHES MM TDS04 4 .557 14.14 .300 7.62 TDS08 8 .957 24.3 .700 17.78 TDS09 9 1.057 26.84 .800 20.32 TDS10 10 1.157 29.39 .900 22.86 APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. ELECTRICALS SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. P36 & P36S SERIES ROTARY DIP SWITCHES FEATURES ● 3 + 3 terminal layout. ● Completely sealed for process compatibility. ● Ultra-compact size with 10 or 16 positions. ● Precision designed detent action. ● Thru-hole (P36 Series) & SMT (P36S Series) models. ● High reliability & long life. ● Clockwise or counterclockwise settable. ● Solder coated terminals. GENERAL SPECIFICATIONS ELECTRICALS Operating voltage Contact rating, static Contact rating, dynamic Test voltage Initial contact resistance Insulation resistance 24 VDC max. 400 mA max. 100 mA max. 250V 50Hz/1 min. < 100 milliohms > 100 megohms MATERIALS Base MECHANICALS, THERMALS Torque Expected life Contact force Operating temperature range 0.98 inch-oz. min. (0.7 Ncm min.) 10,000 switching operations 15 grams min. -30°C to 90°C Cover Actuator 340°C max. for 2 seconds max. (40 watt iron max.) 260°C max. for 10 seconds max. 215°C max. for 40 seconds max. Freons or alcohol. (Do not use chlorinated solvents) Deionized water preferred Terminals Terminal sealing Actuator seal Contacts SOLDERING RECOMMENDATIONS Hand soldering Wave soldering Reflow soldering (SMT) Solvent washing Aqueous cleaning UL94V-O, high temperature thermoplastic Stainless steel UL94V-O, high temperature thermoplastic Gold over nickel plated stainless steel Solder coated brass Molded-in 'O'-ring G Thru-hole and SMT Printed Circuit Models Model No. Model No. Mounting Mounting Code (see truth tables pg. G16) Positions (see fig. 1) (see fig. 2) Binary Coded Decimal 10 P36101 P36S101 Complement of BCD 10 P36102 P36S102 Binary Coded Hexadecimal 16 P36103 P36S103 Complement of BCH 16 P36106 P36S106 Figure 1 Thru-hole Surface Figure 2 Mechanical outline P.C. hole pattern Mechanical outline P.C. pad layout APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com G15 STANDARD OPTIONS BY SERIES: Codes 01 BCD 02 BCD complement 03 Hexadecimal 06 Hexadecimal Comp. Terminals None Straight V Crimped L254 Rt. angle 2.54 (.100") None SMT P36 P36S X X X X X X X X X X X X X X P36 & P36S SERIES ACTUATORS 1 Arrow shaped slot 3 Spindle 8 Slotted spindle* X X X X ORDER GUIDE: Make selections from the above table in sequence to specify a complete model number. Note that 'None' indicates that no option suffix is required. Example; P36101V Series Actuator * Slotted spindle actuator is color coded to truth table code selec tion as follows: BCD - red, BCD complement - Orange, Hexadecimal - gray, Hexadecimal complement - white. Terminals Code Tape and reel packaging available for SMT models - consult factory. CODES NOTE: For each dial position in tables, Common terminals (C) are connected to terminal number(s) indicated - i.e. - none or combinations of 1, 2, 4 or 8. Each model in this series has 2 Common terminals. MECHANICAL OUTLINES Terminal option suffix*: Mtg. hole pattern: G BINARY CODED DECIMAL (01) 10 Positions Dial No. 1 2 0 1 ● 2 ● 3 ● ● 4 5 ● 6 ● 7 ● ● 8 9 ● 4 ● ● ● ● BINARY CODED HEXADECIMAL (03) 16 Positions Dial No. 1 2 4 0 1 ● 2 ● 3 ● ● 4 ● 5 ● ● 6 ● ● 7 ● ● ● 8 9 ● A ● B ● ● C ● D ● ● E ● ● F ● ● ● G16 8 ● ● 8 ● ● ● ● ● ● ● ● COMP. OF BINARY CODED DECIMAL (02) 10 Positions Dial No. 1 2 4 8 0 ● ● ● ● 1 ● ● ● 2 ● ● ● 3 ● ● 4 ● ● ● 5 ● ● 6 ● ● 7 ● 8 ● ● ● 9 ● ● COMP. OF BINARY CODED HEXADEC. (06) 16 Positions Dial No. 1 2 4 8 0 ● ● ● ● 1 ● ● ● 2 ● ● ● 3 ● ● 4 ● ● ● 5 ● ● 6 ● ● 7 ● 8 ● ● ● 9 ● ● A ● ● B ● C ● ● D ● E ● F * 'None' indicates no option suffix is required. APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. Series Actuators 1 Arrow shaped slot 3 Spindle 8 Slotted spindle SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. PT65 SERIES ROTARY DIP SWITCHES FEATURES ● 3 + 3 terminal layout. ● Completely sealed for process compatibility. ● 4, 6, 8, 10 or 16 positions w/extensive codings. ● Precision designed detent action. ● Compact size. ● High reliability & long life. ● Clockwise or counterclockwise settable. ● Solder coated terminals. MATERIALS Base Cover Actuator Contacts Terminals Terminal sealing Actuator seal GENERAL SPECIFICATIONS ELECTRICALS Operating voltage Contact rating, static Contact rating, dynamic Switching capacity Initial contact resistance Insulation resistance 24 VDC max. 400 mA max. 150 mA max. 1.5 VA max. < 80 milliohms > 100 megohms UL94V-O, high temperature thermoplastic UL94V-O, high temperature thermoplastic POM Gold over nickel plated bronze Gold over nickel plated bronze Molded-in 'O'-ring MECHANICALS, THERMALS Torque Expected life Contact force Operating temperature range 7.0 inch-oz. min. (0.7 Ncm min.) 10,000 switching operations 15 grams min. -20°C to 70°C SOLDERING RECOMMENDATIONS Hand soldering Wave soldering Solvent washing Aqueous cleaning 340°C max. for 2 seconds max. (40 watt iron max.) 260°C max. for 10 seconds max. Freons or alcohol. (Do not use chlorinated solvents) Deionized water preferred CODES NOTE: For each dial position in tables, Common terminal(s) (C) are connected to terminal number(s) indicated - i.e. none or combinations of 1, 2, 3, 4 or 8. Each model in this series has 2 Common terminals except codes 11 and 24 which have one. CODE 26 OCTAL 8 Positions Dial No. 1 0 1 ● 2 3 ● 4 5 ● 6 7 ● 2 ● ● ● ● 4 ● ● ● ● CODE 11 ON/0FF 4 Positions Dial No. 1 0 1 ● 0 1 ● CODE 27 OCTAL COMPLEMENT 8 Positions Dial No. 1 2 4 8 0 ● ● ● ● 1 ● ● ● 2 ● ● ● 3 ● ● 4 ● ● ● 5 ● ● 6 ● ● 7 ● CODE 12 BCD 4 Positions Dial No. 1 0 1 ● 2 3 ● BINARY CODED DECIMAL (01) 10 Positions Dial No. 1 2 0 1 ● 2 ● 3 ● ● 4 5 ● 6 ● 7 ● ● 8 9 ● 4 ● ● ● ● 2 ● ● 8 ● ● CODE 21 DECIMAL 4 Positions Dial No. 1 1 ● 2 3 0 2 ● 3 ● COMP. OF BINARY CODED DECIMAL (02) 10 Positions Dial No. 1 2 4 8 0 ● ● ● ● 1 ● ● ● 2 ● ● ● 3 ● ● 4 ● ● ● 5 ● ● 6 ● ● 7 ● 8 ● ● ● 9 ● ● 4 ● CODES 24 & 25 BCD 6 Positions Dial No. 1 2 4 0 1 ● 2 ● 3 ● ● 4 ● 5 ● ● BINARY CODED HEXADECIMAL (03) 16 Positions Dial No. 1 2 4 0 1 ● 2 ● 3 ● ● 4 ● 5 ● ● 6 ● ● 7 ● ● ● 8 9 ● A ● B ● ● C ● D ● ● E ● ● F ● ● ● 8 ● ● ● ● ● ● ● ● CODE 05 GRAY CODE 16 Positions Dial No. 1 0 1 ● 2 ● 3 4 5 ● 6 ● 7 8 9 ● A ● B C D ● E ● F 2 ● ● ● ● ● ● ● ● 4 ● ● ● ● ● ● ● ● 8 G ● ● ● ● ● ● ● ● COMP. OF BINARY CODED HEXADEC. (06) 16 Positions Dial No. 1 2 4 8 0 ● ● ● ● 1 ● ● ● 2 ● ● ● 3 ● ● 4 ● ● ● 5 ● ● 6 ● ● 7 ● 8 ● ● ● 9 ● ● A ● ● B ● C ● ● D ● E ● F APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com G17 Arrow shaped slot Actuator Models Complete Model No. by Terminal Style Right Angle Straight Code (see truth tables) Pitch Positions Binary Coded Decimal .100" (2,54) PT65101 PT65101L254 PT65101L508 Comp. of Binary Coded Dec. 10 PT65102 PT65102L254 PT65102L508 Binary Coded Hexadecimal 16 PT65103 PT65103L254 PT65103L508 Code 05, Gray Code 16 PT65105 PT65105L254 PT65105L508 Comp. of Binary Coded Hex. 16 PT65106 PT65106L254 PT65106L508 Code 11, ON/OFF 4 PT65111 PT65111L254 PT65111L508 Code 12, Binary Coded Dec. 4 PT65112 PT65112L254 PT65112L508 Code 21, Decimal 4 PT65121 PT65121L254 PT65121L508 Code 24, Binary Coded Dec. 6 PT65124 PT65124L254 PT65124L508 Code 25, Binary Coded Dec. 6 PT65125 PT65125L254 PT65125L508 Code 26, Octal 8 PT65126 PT65126L254 PT65126L508 Code 27, Octal complement 8 PT65127 PT65127L254 PT65127L508 Spindle Actuator Models Complete Model No. by Terminal Style Right Angle Straight Code (see truth tables) G Pitch Positions .100" (2,54) .200"(5,08) Binary Coded Decimal 10 PT65301 PT65301L254 PT65301L508 Comp. of Binary Coded Dec. 10 PT65302 PT65302L254 PT65302L508 Binary Coded Hexadecimal 16 PT65303 PT65303L254 PT65303L508 Code 05, Gray Code 16 PT65305 PT65305L254 PT65305L508 Comp. of Binary Coded Hex. 16 PT65306 PT65306L254 PT65306L508 Code 11, ON/OFF 4 PT65311 PT65311L254 PT65311L508 Code 12, Binary Coded Dec. 4 PT65312 PT65312L254 PT65312L508 Code 21, Decimal 4 PT65321 PT65321L254 PT65321L508 Code 24, Binary Coded Dec. 6 PT65324 PT65324L254 PT65324L508 Code 25, Binary Coded Dec. 6 PT65325 PT65325L254 PT65325L508 Code 26, Octal 8 PT65326 PT65326L254 PT65326L508 Code 27, Octal complement 8 PT65327 PT65327L254 PT65327L508 Segment Wheel Actuator Models Complete Model No. by Terminal Style Right Angle Straight Code (see truth tables) Binary Coded Decimal All models listed on this page have 2 Common terminals except Code 11 and Code 24 which have one. Other codes are available - consult factory. G18 .200"(5,08) 10 SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. PT65 SERIES Positions Pitch .100" (2,54) .200"(5,08) 10 PT65501 PT65501L254 PT65501L508 Comp. of Binary Coded Dec. 10 PT65502 PT65502L254 PT65502L508 Binary Coded Hexadecimal 16 PT65503 PT65503L254 PT65503L508 Code 05, Gray Code 16 PT65505 PT65505L254 PT65505L508 Comp. of Binary Coded Hex. 16 PT65506 PT65506L254 PT65506L508 Code 11, ON/OFF 4 PT65511 PT65511L254 PT65511L508 Code 12, Binary Coded Dec. 4 PT65512 PT65512L254 PT65512L508 Code 21, Decimal 4 PT65521 PT65521L254 PT65521L508 Code 24, Binary Coded Dec. 6 PT65524 PT65524L254 PT65524L508 Code 25, Binary Coded Dec. 6 PT65525 PT65525L254 PT65525L508 Code 26, Octal 8 PT65526 PT65526L254 PT65526L508 Code 27, Octal complement 8 PT65527 PT65527L254 PT65527L508 APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com PT65 SERIES Cross shaped slot Actuator Models Complete Model No. by Terminal Style Right Angle Straight Code (see truth tables) SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. Binary Coded Decimal Positions Pitch .100" (2,54) .200"(5,08) 10 PT65701 PT65701L254 PT65701L508 Comp. of Binary Coded Dec. 10 PT65702 PT65702L254 PT65702L508 Binary Coded Hexadecimal 16 PT65703 PT65703L254 PT65703L508 Code 05, Gray Code 16 PT65705 PT65705L254 PT65705L508 Comp. of Binary Coded Hex. 16 PT65706 PT65706L254 PT65706L508 Code 11, ON/OFF 4 PT65711 PT65711L254 PT65711L508 Code 12, Hexadecimal 4 PT65712 PT65712L254 PT65712L508 Code 21, Decimal 4 PT65721 PT65721L254 PT65721L508 Code 24, Binary Coded Dec. 6 PT65724 PT65724L254 PT65724L508 Code 25, Binary Coded Dec. 6 PT65725 PT65725L254 PT65725L508 Code 26, Octal 8 PT65726 PT65726L254 PT65726L508 Code 27, Octal complement 8 PT65727 PT65727L254 PT65727L508 Operating Elements snap-fit securely into PT65 (& P60A) Series switch models with cross shaped slot actuators. Order separately by Model number shown below and indicate color. Spindle colors: red, gray or black Model No. Dim. A SAPT65473 .287 SAPT654116 .457 SAPT654133 .524 G Short spindle above applies to model SAPT65473 only Segment wheel colors: yellow, red, green, blue, gray or black Model No. SRPT659544 Knob color: red Model No. Dim. A DKPT6510553 .209 DKPT65105157 .618 DKPT65105291 1.146 DKPT65105344 1.354 Short knob above applies to model DKPT6510553 only Wheel color: white Model No. Dim. A DRPT651772 .283 consult factory for printing (fits PT65 models only) APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com G19 MECHANICAL OUTLINES Terminal option suffix*: Mtg. hole pattern: Codes 01 BCD 02 BCD complement 03 Hexadecimal 06 Hexadecimal Comp. See other available codes on page G17 NONE Straight terminals Terminals None Straight V Crimped L254 Rt. angle 2.54 (.100") L508 Rt. angle 5.08 (,200") ORDER GUIDE: V Crimped terminals Make selections from the above table in sequence to specify a complete model number. Note that 'None' indicates that no option suffix is required. L254 Right angle terminals Example; PT65101V Series Actuator Terminals Code L508 Right angle terminals G * 'None' indicates no option suffix is required. TERMINAL IDENTIFICATION FOR ALL MODELS (viewed from top of switch inserted into printed circuit board). Refer to TRUTH TABLES on page G17. 1 C C Code 11 G20 2 1 2 C C C 4 3 1 Code 12 Code 21 1 C 2 4 Code 24 1 1 8 C C C C 4 2 4 2 Codes 25 & 26 Code 27 and 10& 16 pos. models APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. PT65 SERIES STANDARD OPTIONS : Actuators 1 Arrow shaped slot 3 Spindle 5 Segment wheel 7 Cross shaped slot PT65 SERIES SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. P60A & P60AS SERIES ROTARY DIP SWITCHES New ! FEATURES ● New 4 + 1 terminal layout. ● Completely sealed for process compatibility. ● Ultra-compact size with 10 or 16 positions. ● Precision designed detent action. ● Thru-hole (P60A Series) & SMT (P60AS Series) models. ● High reliability & long life. ● Clockwise or counterclockwise settable. ● Solder coated terminals. GENERAL SPECIFICATIONS ELECTRICALS Operating voltage Contact rating, static Contact rating, dynamic Test voltage Initial contact resistance Insulation resistance 24 VDC max. 400 mA max. 150 mA max. 250V 50Hz/1 min. < 100 milliohms > 100 megohms MATERIALS Base MECHANICALS, THERMALS Torque Expected life Contact force Operating temperature range 0.98 inch-oz. min. (0.7 Ncm min.) 10,000 switching operations 15 grams min. -20°C to 85°C Cover 340°C max. for 2 seconds max. (40 watt iron max.) 260°C max. for 10 seconds max. 215°C max. for 40 seconds max. Freons or alcohol. (Do not use chlorinated solvents) Deionized water preferred Terminals Terminal sealing Actuator seal Actuator Contacts SOLDERING RECOMMENDATIONS Hand soldering Wave soldering Reflow soldering (SMT) Solvent washing Aqueous cleaning UL94V-O, high temperature thermoplastic UL94V-O, high temperature thermoplastic Nylon Gold over nickel plated stainless steel Solder coated copper Molded-in 'O'-ring G Thru-hole and SMT Printed Circuit Models Model No. Model No. Mounting Mounting Code (see truth tables pg. G22) Positions (see fig. 1) (see fig. 2) Binary Coded Decimal 10 P60A701 P60AS701 Complement of BCD 10 P60A702 P60AS702 Binary Coded Hexadecimal 16 P60A703 P60AS703 Complement of BCH 16 P60A706 P60AS706 Figure 1 Thru-hole Surface Figure 2 Mechanical outline P.C. hole pattern Mechanical outline P.C. pad layout APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com G21 Series Actuators 3 Spindle 5 Segment wheel 7 Cross shaped slot P60A P60AS X X X X* X* X X X X X X X X X New ! P60A & P60AS SERIES ACTUATORS 3 Spindle Codes 01 BCD 02 BCD complement 03 Hexadecimal 06 Hexadecimal Comp. Terminals None Straight V Crimped L508 Rt. angle 5.08 (.200") None SMT 5 Segment wheel 7 Cross shaped slot X X X X * - Assemble after soldering process. ORDER GUIDE: Make selections from the above table in sequence to specify a complete model number. Note that 'None' indicates that no option suffix is required. See page G19 for optional Operating Elements. P60A301V Series Actuator Example; Terminals Code CODES G NOTE: For each dial position in tables, Common terminals (C) are connected to terminal number(s) indicated - i.e. - none or combinations of 1, 2, 4 or 8. Each model in this series has 2 Common terminals. BINARY CODED DECIMAL (01) 10 Positions Dial No. 1 2 0 1 ● 2 ● 3 ● ● 4 5 ● 6 ● 7 ● ● 8 9 ● 4 ● ● ● ● BINARY CODED HEXADECIMAL (03) 16 Positions Dial No. 1 2 4 0 1 ● 2 ● 3 ● ● 4 ● 5 ● ● 6 ● ● 7 ● ● ● 8 9 ● A ● B ● ● C ● D ● ● E ● ● F ● ● ● G22 8 ● ● 8 ● ● ● ● ● ● ● ● MECHANICAL OUTLINES Terminal option suffix*: COMP. OF BINARY CODED DECIMAL (02) 10 Positions Dial No. 1 2 4 8 0 ● ● ● ● 1 ● ● ● 2 ● ● ● 3 ● ● 4 ● ● ● 5 ● ● 6 ● ● 7 ● 8 ● ● ● 9 ● ● NONE Straight terminals COMP. OF BINARY CODED HEXADEC. (06) 16 Positions Dial No. 1 2 4 8 0 ● ● ● ● 1 ● ● ● 2 ● ● ● 3 ● ● 4 ● ● ● 5 ● ● 6 ● ● 7 ● 8 ● ● ● 9 ● ● A ● ● B ● C ● ● D ● E ● F L508 Right angle terminals Mtg. hole pattern: V Crimped terminals NONE SMT terminals * 'None' indicates no option suffix is required. APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. STANDARD OPTIONS BY SERIES: PT65 SERIES PULSE GENERATORS SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. FEATURES ● 3 + 3 terminal layout. ● 10 positions. ● Completely sealed for process compatibility. ● Precision designed detent action. ● Compact size. ● High reliability & long life. ● Clockwise or counterclockwise settable. ● Solder coated terminals. The pulse generator is a mechanical rotary switch connecting input C to outputs 1 and 2 in a time delayed sequence. Typical applications include dimmer and volume control, where adding or subtracting instructions are read into digital electronics. Code 31: The connections between input C and terminals 1 and 2 occur only for the duration of the pulses, after which they are disconnected (set back to 0). MATERIALS Base Cover Actuator Contacts Terminals Terminal sealing Actuator seal Contact bounce pulse duration (at 15 rpm): C+Pin 1 > 50 ms C+Pin 1+Pin 2 > 100 ms C+Pin 2 > 50 ms UL94V-O, high temperature thermoplastic UL94V-O, high temperature thermoplastic POM Gold over nickel plated bronze Gold over nickel plated bronze Molded-in 'O'-ring G GENERAL SPECIFICATIONS ELECTRICALS Operating voltage Contact rating, static Contact rating, dynamic Test voltage Initial contact resistance Contact bounce Pulse durations 12 VDC max. 400 mA max. 150 mA max. 250 V for 1 minute < 80 milliohms < 10 milliseconds See graphs below Refer to Actuator drawings shown Actuator MECHANICALS, THERMALS Code 31 Torque Code 31 Expected life Contact force Positions per rotation Rotation speed Vibration resistance Operating temperature range Right Angle Straight Code 0.98 inch-oz. min. (0.7 Ncm min.) 10,000 switching operations 15 grams min. 10 50 rpm (Max.) 10g -20°C to 70°C Complete Model No. by Terminal Style Pitch .100" (2,54) .200"(5,08) Arrow shpd. slot PT65131 PT65131L254 PT65131L508 Spindle PT65331L254 PT65331L508 PT65331 SOLDERING RECOMMENDATIONS Hand soldering Wave soldering Solvent washing Aqueous cleaning 340°C max. for 2 seconds max. (40 watt iron max.) 260°C max. for 10 seconds max. Freons or alcohol. (Do not use chlorinated solvents) Deionized water preferred APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com G23 PT65 SERIES PULSE GENERATORS Mtg. hole pattern: NONE Straight terminals Terminals None Straight V Crimped L254 Rt. angle 2.54 (.100") L508 Rt. angle 5.08 (,200") ORDER GUIDE: Make selections from the above table in sequence to specify a complete model number. Note that 'None' indicates that no option suffix is required. Example; PT65131V Series Actuator Terminals Code V Crimped terminals L254 Right angle terminals G L508 Right angle terminals * 'None' indicates no option suffix is required. ACTUATORS Arrow shaped slot G24 Spindle Segment wheel Cross shaped slot APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. Codes 31 10 position pulse generator MECHANICAL OUTLINES Terminal option suffix*: PT65 SERIES STANDARD OPTIONS : Actuators 1 Arrow shaped slot 3 Spindle 5 Segment wheel 7 Cross shaped slot
DPL02T 价格&库存
很抱歉,暂时无法提供与“DPL02T”相匹配的价格&库存,您可以联系我们找货
