76PRB03ST
76PRB03ST
    GRAYHILLINC.
    插件,P=2.54mm
    开关 DIP 琴键式 密封型 3位
76PRB03ST 数据手册
Thru-Hole DIP Switches SERIES 76 SPST Rocker DIMENSIONS DIP Switches FEATURES • Raised and Recessed, Rocker and PIANO-DIP® Styles • Sealed Base Standard • Spring and Ball Contact • Top Tape Seal Option in inches (and millimeters) Rocker and Recessed Rocker PIANO-DIP® B = .156 ± .010 (3,96 ± 0,25) TYPICAL End Views 1 2 3 4 5 .020 + .005 –.000 (0,51 + 0,13) LENGTH ± .010 (±0,25) SEE ORDER INFO. LENGTH ± .010 (±0,25) SEE ORDER INFO. 6 .281 ± .010 (7,14 ± 0,25) TYP. B 7 .380 ± .010 (9,65 ± 0,25) .380 ± .010 (9,65 ± 0,25) OPEN CL  Rocker OPEN 1 .090 ± .005 (2,29 ± 0,13) .020 ± .002 (0,51 ± 0,05) .100 ± .005 (2,5 ± 0,13) 2 3 4 5 6 7 A = .272 ± .010 (6,91 ± 0,25) 8 .020 + .005 –.000 (0,51 + 0,13) A .090 ± .005 (2,29 ± 0,13) .020 ± .002 (0,51 ± 0,05) See also end view. CL .012 ± .001 (0,30 ± 0,03) .300 + .030 –.000 (7,62 + 0,76) .100 ± .005 (2,5 ± 0,13) .295 + .000 –.020 (7,49 –0,51) .156 ± .010 (3,96 ± 0,25) TYP. CL CL .012 ± .001 (0,30 ± 0,03) .300 + .030 –.000 (7,62 + 0,76) For recessed rockers, delete .295 dimension. See also end view. CIRCUITRY Styles 76SB and 76RSB Typical circuit diagram with actuator in the closed position. Style 76PSB Styles 76PRB UP IS OPEN (OFF) UP IS CLOSED (ON) Actuator shown in the down position. Actuator shown in the down position. ORDERING INFORMATION Series Switch Style: SB = Raised Rocker RSB = Recessed Rocker PSB = Piano-DIP (Up is Off ) PRB = Piano-DIP (Up is On) 76RSB04ST T = RoHS compliant Sealed*: S = Tape Seal Number of Positions: 02 through 10, 12 *A top tape seal is required for switches that are machine soldered or heavily cleaned after hand soldering. To order top seal versions, add "S" to the Grayhill part number. No. of Pos. 2 3 4 5 6 7 8 10 12 Length (Inches) 0.280" 0.380" 0.480" 0.580" 0.680" 0.780" 0.880" 1.080" 1.280" Length (Metric) No./Tube 7,1 mm 9,7 mm 12,2 mm 14,7 mm 17,3 mm 19,8 mm 22,4 mm 27,4 mm 32,5 mm 35 27 21 18 15 13 12 9 8 Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
76PRB03ST 价格&库存
很抱歉,暂时无法提供与“76PRB03ST”相匹配的价格&库存,您可以联系我们找货
