97R08S
97R08S
    GRAYHILLINC.
    插件
    开关 DIP 8位 半间距 表面贴装
97R08S 数据手册
Surface Mount DIP Switches Series 97 Half-Pitch Fig. 1 Series 97C DIMENSIONS Top View DIP Switches Applications Used in any DIP application where space is at a premium such as notebook computers, hand-held radios, industrial control products, CD-ROM drives, cellular base stations and coin changers. Features • Half the Size of Standard DIP Switches • Available in 2, 4, 6, 8, and 10 Positions • Low Profile • Less Mass for Easy Vacuum Pick & Place In inches (and millimeters) Front View Side View LENGTH SEE ORDERING INFORMATION Recommended PC Pad Dimensions .050 (1,27) Pitch TAPE THICKNESS .003 (0,08) .177 (4,50) .059 (1,50) .030 (0,76) .024 (0,61) .050 (1,27) Pitch .016 (0,41) .264 (6,71) .291 (7,39) .242 (6,15) .193 (4,90) .004 (0,10) Unless otherwise specified, tolerances are ±0.008 (0,20) Fig. 2 Series 97R DIMENSIONS Top View A In inches (and millimeters) Front View .047 (1,20) Side View .177±.002 (4,50±0,05) TaPe .002 (0,05) ON 1 2 3 4 5 6 7 8 .319 (8,1) .024 (0,6) .024 (0,6) Recommended PC Pad Dimensions .057 (1,44) .030 (0,76) .016 (0,40) Unless otherwise specified, tolerances are ±0.008 (0,20) .050 (1,27) PiTCH .004±.004 (0,10±0,10) Operating Temperature Range: -40 to 85°C Storage Temperature Range: -40 to 85°C SPECIFICATIONS Electrical Ratings Contact Rating: 25 mA at 24 Vdc switching; 100 mA at 50 Vdc non-switching Contact Resistance: 100 mΩ max, initially Insulation Resistance: 100 MΩ minimum at 100 Vdc Dielectric Strength: 300 Vac for one minute Switch Capacitance: 5pF maximum Contact Arrangement: SPST Mechanical Ratings Life: 1,000 cycles minimum Operation Force: 500 gF Mechanical Shock: MIL-STD-202F, Method, 213B, Test Condition A. Gravity: 50G's (peak value), 11 m/sec. Direction and times: 6 sides and 3 times in each direction. Vibration: MIL-STD-202F, Method 201A. Passed 6 hours (2 hours in each) of three perpendicular planes at a cycle of 10-5510Hz/1 minute. .050 (1,27) PiTCH .360 .260 (6,60) (9,10) .310 (7,85) Circuitry Materials Base and Cover: UL94V-0 Nylon, black Actuators: UL94V-0 Nylon thermoplastic, white Base Contacts: Alloy copper with gold-plating over nickel Terminals: Brass with gold-plating Tape Seal: Kapton Soldering Information Vapor phase and IR-reflow soldering can be applied. With stands 255°C peak temperature. Cleaning: Tape sealed versions are capable of withstanding washing processes using alcohol-based solvents only. Water or other water-based solvent washing processes are not recommended. Care should be taken to avoid flux adhering to the switch body from the circuit board soldering process. The switch should be allowed to cool for at least 3 minutes between the end of the solder process and the beginning of the wash process. The solvent stage of the cleaning process is not to exceed 1 minute and the whole wash process is not to exceed 3 minutes. Ultrasonic or pressure wash cleaning is not recommended. Packaging Information Tube: 130 pcs/tube (2 positions), 75 pcs/tube (4 positions), 54 pcs/tube (6 positions), 40 pcs/tube (8 positions), 33 pcs/tube (10 positions). Tape and Reel: 97C: 4,000 pcs/reel (all positions). 97R: 2500 pcs/reel (all positions). Actuation Instructions: Switch slides should be actuated from a low angle in the intended Series: 97C see fig. 1, 97R see fig. 2 direction of travel. The application of excess Positions: 02 = .148 (3,76), 04 = .248 (6,30), 06 = .348 (8,84), force from a high angle can cause permanent 08 = .448 (11,38), 10 = .548 (13,92) damage to the contact system of the switch. Tape seals must be removed to properly actuate T= RoHS compliant the switches as described above. Click here for Packaging: Blank = Tube, R = Tape and Reel (see pkg note) visual sample. Seal: Blank = Unsealed, S = Top Tape Seal All DIP switches are shipped in the "ON" position. ORDERING INFORMATION 97C06SRT Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com DIP 4 Surface Mount DIP Switches Series 90HB SPST, Low Profile FEATURES • Compatible with SMT Assembly, Including Infrared Reflow and Vapor-Phase • Reliable Spring and Ball Contact DIMENSIONS In inches (and millimeters) Top View–Gull Wing SWITCH IS PACKAGED AS SHOWN HERE WITH ALL O N POSITIONS ON DIP Switches 1 2 .020 ± .002 (0,51 ± 0,05) TYP. .052 ± .002 (1,32 ± 0,13) TYP. .085 ± .005 (2,16 ± 0,13) TYP. Gull Wing 3 4 5 6 7 8 .290 (7,37) MAX. CL C L .100 ± .005 (2,54 ± 0,13) TYP. Recommended PC Pad Dimensions–Gull Wing CL CL .395 ± .010 (10,03 ± 0,25) .012 ± .002 (0,30 ± 0,05) .160 ± .005 (4,19 ± 0,13) LENGTH ± .010 (0,25) SEE CHART .004 (0,10) .190 (4,83) MAX. .100 (2,54) TYP. .070 (1,78) TYP. J-Bend .500 (12,7) TYP. .250 (6,35) TYP. .125 (3,18) TYP. .320 (8,13) MAX. .290 (7,37) MAX. Recommended PC Pad Dimensions–J-Bend CL CL .100 (2,54) TYP. .070 (1,78) TYP. .350 (8,90) TYP. .150 (3,81) TYP. .012 ± .001 (0,30 ± 0,03) TYP. .250 ± .010 (6,35 ± 0,25) .160 ± .005 (4,19 ± 0,13) LENGTH ± .010 (0,25) SEE CHART .220 (5,59) MAX. .085 ± .005 (2,16 ± 0,13) TYP. .020 ± .002 (0,51 ± 0,05) TYP. .100 ± .010 (2,54 ± 0,25) TYP. .004 (0,10) CL CL .100 (2,54) TYP. circuitry As viewed from the top of the switch in the positions shown in the drawing. DIP 5 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Surface Mount DIP Switches Specifications Electrical Ratings Mechanical Ratings Where Grayhill performance is superior, the MIL spec is listed in parentheses. Mechanical Life: 2,000 operations per switch position Vibration Resistance: Per Method 204, Test Condition B , 1mS opening (10 mS allowed) Mechanical Shock: Per Method 213, Test Condition A. 1mS opening (10 mS allowed) Thermal Shock Resistance: Per specification; no failures; passes contact resistance. Terminal Strength: Per specification Thermal Aging: 1,000 hours at 85°C; no failures. Materials and Finishes Meets all requirements of MIL- S-83504**. Operating Temperature Range: -40°C to + 85°C Storage Temperature Range: -40°C to + 85°C Moisture Resistance: Per MIL-STD-202, Method 106. Shorting Member (Ball): Brass, gold-plate over nickel barrier. Base Contacts: Copper alloy, gold-plate over nickel barrier. Terminals: Copper alloy, matte tin plated over nickel barrier. Non-Conductive Parts: Thermoplastic (UL94V-O) Soldering Information Tape and Reel Packaging Solderability: Per MIL-STD-202, Method 208 Soldering Heat Resistance: Per MIL-S-83504, six second test. Recommended Processing Temperature: 220°C–230°C (1 pass—260°C maximum) Processing Position: Switch is to be processed with all actuators in the closed (on) position as shipped. Fluxing: Per EIA RS-448-2 with flux touching switch body. Cleaning: Passes immersion test using water/ detergent. Acceptable solutions include 1-1-1 trichlorethane, freon, (TF, TE, or TMS), isopropyl alcohol, detergent (140°F maximum). Terpene acceptable for Series 90 only. Solutions which are not recommended include acetone, methylene chloride, freon TMC. High pressure aqueous Tape Seal Integrity: Passes gross leak test using 125°C flourinert for 20 seconds minimum. Reference MIL-STD-202, Method 112 Tape Seal: Polyimide film Environmental Ratings Tape and Reel Packaging Meets requirements of EIA 481-2 or EIA 481-3 13 INCH DIAMETER REEL CONDUCTIVE PLASTIC EMBOSSED TAPE DIRECTION OF FEED Ordering Information cleaning is not recommended. 16mm 24mm TAPE 16mm 32 & 44mm TAPE Series Terminal Style: W = Gull Wing, J = J-Bend RoHS compliant 90HBW02PRT Packaging: R = Tape and reel packaging (750 switches/reel) Blank = Tube packaging (each tube is 19.5" long) Seal: P = Polyimide Seal Blank = No Seal Number of Positions: 02 through 10 No. of Positions Length Inches Length Metric Number Per Tube 2 3 4 5 6 7 8 9 10 .270" .370" .470" .570" .670" .770" .870" .970" 1.070" 6,9 mm 9,4 mm 11,9 mm 14,5 mm 17,0 mm 19,6 mm 22,1 mm 24,6 mm 27,2 mm 60 47 37 31 26 23 20 18 16 PIN ONE LOCATION Each reel has a 15.750 inch (390 mm) minimum leader and a 6.30 inch (160 mm) minimum trailer. Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. ** Note: 100% matte tin terminal plating does not meet MIL-S-83504 for lead content. DIP 6 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com DIP Switches Make-and-break Current Rating: 2,000 operations per switch position at these resistive loads:10 mA, 30 Vdc; or 10 mA, 50 mVdc; 10 mA, 50 mVdc; or 25 mA, 24 Vdc; or 100 mA,6 Vdc. Contact Resistance: (measured at 10 mA, 50 mVdc). Initial: 20 mohms maximum, After Life: 100 mohms maximum Insulation Resistance: Minimum, at 100 Vdc between adjacent closed contacts and also across open switch contacts. Initial (Mohms): 5,000, After Life (Mohms): 1,000 Dielectric Strength: Minimum voltage (AC RMS) measured between adjacent closed contacts and also across open switch contacts. lnitial: 500 volts, After Life: 500 volts Current Carry Rating: 3A maximum rise of 20°C Switch Capacitance: 2 pF at 1 megahertz Surface Mount DIP Switches Series 78H FEATURES • Compatible with SMT Assembly Including Infrared Reflow and Vapor-Phase • Reliable Spring and Ball Contact SPDT and DPST DIMENSIONS In inches (and millimeters) SPDT, DPST, Top Actuated, Slide Operated .023 .055 ± .010 (5,84) (1,40 ± 0,25) REF. Recommended PC Pad Dimensions LENGTH ± .010 (0,25) See OrDer iNFO .380 ± .010 (9,65 ± 0,25) .012 ± .001 (0,30 ± 0,03) TyP. .530 (13,46) TyP. .268 ± .010 (6,81 ± 0,25) .025 (0,64) R. .303 ± .015 (7,70 ± 0,38) .424 ± .015 (10,77 ± 0,38) TyP. CL CL .100 ± .005 (2,54 ± 0,13) TyP. .295 + .000 – .020 (7,49 – 0,51) with all actuators in the closed (on) position as shipped. DPST 1 ON 1 DIP Switches Dot indicates active circuit. OFF Specifications Electrical Ratings Tape and Reel Packaging Meets requirements of EIA 481-2 or EIA 481-3 Environmental Ratings Meets all requirements of MIL- S-83504**. Where Grayhill performance is superior, the MIL spec is listed in parentheses. Operating Temperature Range: -40°C to + 85°C Storage Temperature Range: -55°C to + 85°C Moisture Resistance: Per MIL-STD-202, Method 106 13 INCH DIAMETER REEL CONDUCTIVE PLASTIC EMBOSSED TAPe 4 3 2 1 4 3 2 DIRECTION OF FeeD 1 3 Soldering Information 2 16 & 24mm TAPe 1 4 3 16mm 2 1 1 1 1 2 4 Solderability: Per MIL-STD-202, Method 208 Soldering Heat Resistance: Per MIL-S-83504, six second test Recommended Processing Temperature: 220°C–230°C (1 pass—260°C maximum) Processing Position: Switch is to be processed 3 Mechanical Life: 2,000 operations per switch position Vibration Resistance: Per method 204, Test Condition B. 1 mS opening (10 mS allowed) Mechanical Shock: Per Method 213, Test Condition A. 1 mS opening (10 mS allowed) Terminal Strength: Per specification Thermal Aging: 1,000 hours at 85°C; no failures Thermal Shock: Per specification; no failures; passes contact resistance Shor ting Member : Brass, gold-plated over nickel barrier. Base Contacts: Copper alloy, gold-plated over nickel barrier. Terminals: Copper alloy, matte tin-plated over nickel barrier. Non-Conductive Parts: Cover is natural color thermoplastic, actuators are white thermoplastic (UL94V-O) 4 Mechanical Ratings ON Materials and Finishes 4 Make-and-break Current Rating: 2,000 operations per switch position at 1 mA, 5 Vdc; 50 mA, 30 Vdc; or 150 mA, 30 Vdc Contact Resistance: Initial: 30 mohms max. After Life: 100 mohms max. (10 mA at 50 Vdc, open circuit) Insulation Resistance: Minimum, at 100 Vdc between adjacent closed contacts and also across open switch contacts. Initial: 2,000 Mohms; After Life: 1,000 Mohms Dielectric Strength: Minimum voltage (AC, RMS) measured between adjacent closed contacts and also across open switch contacts. Initial: 750 volts; After Life: 500 volts Current Carry Rating: 4 amps, maximum rise of 20°C Switch Capacitance: 2 pF at 1megahertz .070 (1,78) TyP. .100 (2,54) TyP. CL CL Circuitry SPDT 2 Circuits (no common) 1 1 ON .280 (7,11) TyP. 1 1 1 2 2 2 3 3 3 4 4 4 Ordering Information: Tube Packaging No. of Positions 1 2 3 4 5 Length (inches) Length (metric) Carrier Width Dim. A 0.280" 0.480" 0.680" 0.880" 1.080" 7,1 mm 12,2 mm 17,3 mm 22,4 mm 27,4 mm 24 mm 24 mm 32 mm 44 mm 44 mm Part Number* SPDT DPST 78HJ01GWT 78HJ02GWT 78HJ03GWT 78HJ04GWT 78HJ05GWT 78HF01GWT 78HF02GWT 78HF03GWT 78HF04GWT 78HF05GWT * Insert "R" before the "T" in the Grayhill part number for tape and reel packaging (500 switches/ reel). ** Note: 100% matte tin terminal plating does not meet MIL-S-83504 for lead content. 16mm PIN ONE LOCATION 32 & 44mm TAPe COVER TAPE DIM. A (SEE ORDER INFO.) Each reel has a 15.750 inch (390 mm) minimum leader and a 6.30 inch (160 mm) minimum trailer. Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. DIP 7 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Surface Mount DIP Switches Series 76HP FEATURES • Compatible with SMT Assembly Including Infrared Reflow and Vapor-Phase • Easily Accessed when PC Boards are Racked • Reliable Spring and Ball Contact Side Actuated PIANO-DIP® DIP Switches DIMENSIONS In inches (and millimeters) LeNGtH ± .010 (0,25 See OrDer INFO .023 .055 ± .010 (5,84) (1,40 ± 0,25) reF. .305 ± .010 (7,75 ± 0,25) Recommended PC Pad Dimensions .380 ± .010 (9,65 ± 0,25) .025 (0,64) r. CL CL .100 ± .005 (2,54 ± 0,13) tyP. Circuitry Specifications Electrical Ratings Make-and-break Current Rating: 2,000 operations per switch position at 1 mA, 5 Vdc; 50 mA, 30 Vdc; or 150 mA, 30 Vdc Contact Resistance: Initial: 30 mohms maximum; After Life: 100 mohms maximum (10 mA at 50 Vdc, open circuit) Insulation Resistance: Minimum, at 100 Vdc between adjacent closed contacts and also across open switch contacts. Initial: 2,000 Mohms Dielectric Strength: Minimum voltage (AC RMS) measured between adjacent closed contacts and also across open switch contacts. Initial: 750 volts; After Life: 500 volts Carry Rating: 5 amps, maximum rise of 20°C Switch Capacitance: 2 pF at 1 megahertz Mechanical Ratings Mechanical Life: 2,000 operations per switch position .280 (7,11) tyP. .303 ± .015 (7,70 ± 0,38) .012 ± .001 (0,30 ± 0,03) tyP. .424 ± .015 (10,77 ± 0,38) tyP. Vibration Resistance: Per Method 204, Test Condition B. 1 mS opening (10 mS allowed) Mechanical Shock: Per Method 213, Test Condition A. 1 mS opening (10 mS allowed) Thermal Shock Resistance: Per specification; no failures; passes contact resistance Terminal Strength: Per specification Thermal Aging: 1,000 hours at 85°C; no failures As viewed from the top of the switch in the positions shown in the drawing. .530 (13,46) tyP. Environmental Ratings Meets all requirements of MIL- S-83504**. Where Grayhill performance is superior, the MIL spec is listed in parentheses. Operating Temperature Range: -40°C to + 85°C Storage Temperature Range: -55°C to + 85°C Moisture Resistance: Per MIL-STD-202, Method 106 .070 (1,78) tyP. .100 (2,54) tyP. CL CL Materials and Finishes Shorting Member: Brass, gold-plated over nickel barrier. Base Contacts: Copper alloy, gold-plated, over nickel barrier. Terminals: Copper alloy, matte tin plated over nickel barrier. Non-Conductive Parts: Cover is natural color thermoplastic, actuators are white thermoplastic (UL94V-O) Tape Seal: Not available with Tape Seal. Tape and Reel Packaging Meets requirements of EIA 481-2 or EIA 481-3 13 INCH DIAMeter reeL Soldering Information Solderability: Per MIL-STD-202, Method 208 Tested to EIA Standard RS-448-2. Resistance to Soldering Heat:Per MIL-S-83504, six second test Recommended Processing Temperature: 220°C–230°C (1 pass—260°C maximum) Processing Position: Switch is to be processed with all actuators in the closed (on) position as shipped. CONDUCtIVe PLAStIC eMBOSSeD tAPe DIreCtION OF FeeD 16 & 24mm tAPe 16mm 76HPSB 08GW XXXX OPeN 76HPSB 08GW XXXX OPeN 76HPSB 08GW XXXX OPeN Ordering Information: Tape and Reel Packaging (500 switches per reel) 7,1 mm 12,2 mm 17,3 mm 22,4 mm 27,4 mm 24 mm 24 mm 32 mm 44 mm 44 mm 76HPSB02GWRT 76HPSB04GWRT 76HPSB06GWRT 76HPSB08GWRT 76HPSB10GWRT * For other lengths, contact Grayhill, Inc. ** Note: 100% matte tin terminal plating does not meet MIL-S-83504 for lead content. Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. XXXX 0.280" 0.480" 0.680" 0.880" 1.080" 76HPSB08GW 2 4 6 8 10 XXXX OPeN Part Number 76HPSB08GW Carrier Width Dim. A XXXX Length (metric) OPeN Length (inches) OPeN No. of Positions* 76HPSB08GW 16mm PIN ONe LOCAtION 32, 44 & 56mm tAPe COVer tAPe DIM. A (See OrDer INFO.) Each reel has a 15.750 inch (390 mm) minimum leader and a 6.30 inch (160 mm) minimum trailer. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com DIP 8
97R08S 价格&库存
很抱歉,暂时无法提供与“97R08S”相匹配的价格&库存,您可以联系我们找货
