A02505
A02505
    APEM(埃斐)
    SWITCH BLOCK 1 NO 1 NC
A02505 数据手册
A02 series Illuminated or non-illuminated pushbutton switches Panel cut-out Ø 22 (.866) or 29,5 x 21,5 (1.160x.846) A pushbutton assembly requires : screen + lamp (if illuminated) + operator + one or two switch blocks. To order these elements, select desired model numbers from tables below. Example : IP65 illuminated rectangular maintained pushbutton, switch block with 2 N.O. contacts, red screen and 12V red LED assembly = A0261B, A0242J1, A0201X and A02503UL. N.O. N.C. N.O./N.C. 10.00 (.394) 10.00 (.394) 10.00 (.394) 24.00 (.945) 29.00 (1.142) 36.00 (1.417) Ø29.00 (1.142 DIA) 21.00 (.827) 21.00 (.827) 27.00 (1.062) 33.50 (1.319) 64.00 (2.520) 64.00 (2.520) 55.50 (2.185) 29.00x29.00 (1.142 SQ) 33.50 (1.319) ❷ ❶ Screen Bezel G ❸ ❹ Lamp Operator Colour Part No Lamp Voltage black red amber yellow green blue clear white black red amber yellow green blue clear white black red amber yellow green blue clear white A0261A A0261B A0261C A0261D A0261E A0261F A0261G A0261J A0262A A0262B A0262C A0262D A0262E A0262F A0262G A0262J A0263A A0263B A0263C A0263D A0263E A0263F A0263G A0263J Filament Filament Filament Filament Filament Filament Neon Neon LED 6.3V A0141A 14V A0141B 28V A0141C 36V A0141D 48V A0141E 60V A0141F 110V A0143G 220V A0143H model numbers: see A01 pages G6-G7. 6V A0242H* 12V A0242J* 24V A0242K* 6V A0243H* 12V A0243J* 24V A0243K* 6V A0244H* 12V A0244J* 24V A0244K* LED assy LED assy LED assy LED assy LED assy LED assy LED assy LED assy LED assy Part No Replace * with colour code for LED assemblies: 1: red 2: green 3: amber Bezel Switch block Description Lamp type Part No Contacts Part No Illum, momentary Illum, maintained Illum, momentary Illum, maintained Non-illum, maintained Non-illum, momentary Illum, momentary Illum, maintained Illum, momentary Illum, maintained Non-illum, momentary Non-illum, maintained Illum, momentary Illum, maintained Illum, momentary Illum, maintained Non-illum, momentary Non-Illum, maintained Lamp/LED Lamp/LED LED assy LED assy A0201Y A0201X A0202Y A0202X A0203X A0203Y A0204Y A0204X A0205Y A0205X A0206Y A0206X A0207Y A0207X A0208Y A0208X A0209Y A0209X 1 N.O. 1 N.C. 2 N.O. 2 N.C. 1 N.O./1 N.C. A02501UL A02502UL A02503UL A02504UL A02505UL Lamp/LED Lamp/LED LED assy LED assy Lamp/LED Lamp/LED LED assy LED assy White or blue LED assembly : contact APEM. UNSEALED SWITCHES (IP40) : add “01” to end of operator model number. Second switch block Contacts Part No 1 N.O. 1 N.C. 2 N.O. 2 N.C. 1 N.O./1 N.C. A02506UL A02507UL A02508UL A02509UL A02510UL To achieve 3 or 4 pole switching, add second switch block, from above table. SCREEN ENGRAVING / INSERTABLE LEGENDS : contact APEM. Bezel: G-16 rectangular, square, round, ‘Illum’ - illuminated, ‘Non-illum’ - non illuminated www.apem.com APEM A02 series Metal bezel pushbutton switches and indicators Panel cut-out Ø 22 (.866) A pushbutton assembly requires : screen + lamp (if illuminated) + operator + one or two switch blocks. An indicator assembly requires : screen + lamp + operator To order these elements, select desired model numbers from tables below. Example : IP65 illuminated metal bezel maintained pushbutton, switch block with 2 N.O. contacts, red screen and 12V red LED assembly = A0263B, A0244J1, A0211X and A02503UL. N.C. N.O. N.O./N.C. 75.00 (2.952) 45.50 (1.791) 11.50 (.452) Ø29.00 (1.142DIA) Ø29.00 (1.142DIA) 34.00 (1.338) ❷ ❶ Screen Bezel ❸ Lamp ❹ Operator Colour Part No Lamp Voltage black red amber yellow green blue clear white A0263A A0263B A0263C A0263D A0263E A0263F A0263G A0263J Filament Filament Filament Filament Filament Filament Neon Neon LED 6.3V A0141A 14V A0141B 28V A0141C 36V A0141D 48V A0141E 60V A0141F 110V A0143G 220V A0143H model numbers: see A01 pages G6-G7. 6V A0244H* 12V A0244J* 24V A0244K* LED assy LED assy LED assy 21.00 (.826) Part No Replace * with colour code for LED assemblies: 1: red 2: green 3: amber Bezel Switch block Description Lamp type Part No Contacts Part No Illum, momentary Illum, maintained Illum, momentary Illum, maintained Non-illum, momentary Non-illum, maintained Illum, indicator Illum, indicator Lamp/LED Lamp/LED LED assy LED assy A0210Y A0210X A0211Y A0211X A0212Y A0212X A0277 A0278 1 N.O. 1 N.C. 2 N.O. 2 N.C. 1 N.O./1 N.C. A02501UL A02502UL A02503UL A02504UL A02505UL Lamp/LED LED assy Std bezel material : nickel plated brass. For optional black finish, add “G” to the end of operator model number. UNSEALED SWITCHES (IP40) : add “01” to end of operator model number. Second switch block Contacts Part No 1 N.O. 1 N.C. 2 N.O. 2 N.C. 1 N.O./1 N.C. A02506UL A02507UL A02508UL A02509UL A02510UL To achieve 3 or 4 pole switching, add second switch block, from above table. White or blue LED assembly : contact APEM. SCREEN ENGRAVING / INSERTABLE LEGENDS : contact APEM. Bezel: APEM rectangular, square, round, ‘Illum’ - illuminated, ‘Non-illum’ - non illuminated www.apem.com G-17 G A02 series Flush mounting pushbutton switches and indicators Panel cut-out Ø 30 (1.181) A pushbutton assembly requires : screen + lamp (if illuminated) + operator + one or two switch blocks. An indicator assembly requires : screen + lamp + operator To order these elements, select desired model numbers from tables below. Example : IP65 illum. flush mounting maintained pushbutton, switch block with 2 N.O. contacts, red screen and 12V red LED assembly = A0263B, A0244J1, A0213X and A02503UL. N.O. Ø35.00 (1.378DIA) N.C. N.O./N.C. 73.00 (2.874) 46.00 (1.811) 2.00 (.078) Ø35.00 (1.378DIA) PANEL DU CUT-OUT DECOUPE PANNEAU 34.00 (1.338) ❷ ❶ Screen Bezel G ❸ Operator Part No Lamp Voltage black red amber yellow green blue clear white A0263A A0263B A0263C A0263D A0263E A0263F A0263G A0263J Filament Filament Filament Filament Filament Filament Neon Neon LED 6.3V A0141A 14V A0141B 28V A0141C 36V A0141D 48V A0141E 60V A0141F 110V A0143G 220V A0143H model numbers: see A01 pages G6-G7. 6V A0244H* 12V A0244J* 24V A0244K* Part No Replace * with colour code for LED assemblies: 1: red 2: green 3: amber Bezel 30.00 (1.181) ❹ Lamp Colour LED assy LED assy LED assy 21.00 (.826) Switch block Description Lamp type Part No Contacts Part No Illum, momentary Illum, maintained Illum, momentary Illum, maintained Non-illum, momentary Non-illum, maintained Illum, indicator Illum, indicator Lamp/LED Lamp/LED LED assy LED assy A0214Y A0214X A0213Y A0213X A0215Y A0215X A02791 A02792 1 N.O. 1 N.C. 2 N.O. 2 N.C. 1 N.O./1 N.C. A02501UL A02502UL A02503UL A02504UL A02505UL Lamp/LED LED assy Std bezel material : silver anodised aluminium. For optional black anodised aluminium, add “G” to end of operator model number. UNSEALED SWITCHES (IP40) : add “01” to end of operator model number. White or blue LED assembly : contact APEM. Second switch block Contacts Part No 1 N.O. 1 N.C. 2 N.O. 2 N.C. 1 N.O./1 N.C. A02506UL A02507UL A02508UL A02509UL A02510UL To achieve 3 or 4 pole switching, add second switch block, from above table. SCREEN ENGRAVING / INSERTABLE LEGENDS : contact APEM. Bezel: G-18 rectangular, square, round, ‘Illum’ - illuminated, ‘Non-illum’ - non illuminated www.apem.com APEM A02 series Indicators Panel cut-out Ø 22 (.866) or 29,5 x 21,5 (1.160x.846) 10.00 (.394) An indicator assembly requires : Screen + lamp, LED or LED assembly + operator. To order these elements, select desired model numbers from tables below. Example : IP65 rectangular indicator with red screen and 12V red LED assembly = A0261B, A0242J1 and A0272. 24.00 (.945) 29.00 (1.142) 36.00 (1.417) 33.50 (1.319) 21.00 (.827) 10.00 (.394) 29.00 (1.142) 29.00x29.00 (1.142 SQ) 37.50 (1.476) Ø29.00 (1.142 DIA) 33.50 (1.319) ❷ ❶ Screen Bezel ❸ Lamp Operator Colour Part No Lamp Voltage black red amber yellow green blue clear white black red amber yellow green blue clear white black red amber yellow green blue clear white A0261A A0261B A0261C A0261D A0261E A0261F A0261G A0261J A0262A A0262B A0262C A0262D A0262E A0262F A0262G A0262J A0263A A0263B A0263C A0263D A0263E A0263F A0263G A0263J Filament Filament Filament Filament Filament Filament Neon Neon LED 6.3V A0141A 14V A0141B 28V A0141C 36V A0141D 48V A0141E 60V A0141F 110V A0143G 220V A0143H model numbers: see A01 pages G6-G7. 6V A0242H* 12V A0242J* 24V A0242K* 6V A0243H* 12V A0243J* 24V A0243K* 6V A0244H* 12V A0244J* 24V A0244K* LED assy LED assy LED assy LED assy LED assy LED assy LED assy LED assy LED assy 21.00 (.827) Replace * with colour code for LED assemblies: Part No 1: red 2: green 3: amber Bezel Description Lamp type Part No Indicator Indicator Indicator Indicator Indicator Indicator Lamp/LED LED assy Lamp/LED LED assy Lamp/LED LED assy A0271 A0272 A0273 A0274 A0275 A0276 G UNSEALED INDICATORS (IP40) : add “01” to end of operator model number. White or blue LED assembly : contact APEM. SCREEN ENGRAVING / INSERTABLE LEGENDS : contact APEM. Bezel: APEM rectangular, square, round, www.apem.com G-19 A02 series Rotary switches Panel cut-out Ø 22 (.866) A rotary lever assembly requires : operator + one or two switch blocks. To order these elements, select desired model numbers from tables below. Example : IP65 square 2 position maintained rotary switch with long lever, clockwise rotation, switch block with 2 N.O. contacts = A029107 and A02503UL. N.O./N.C. N.C. N.O. 29.00 (1.142) 20.00 (.787) 22.00 (.866) 29.00x29.00 (1.142 SQ) 22.00 (.866) 64.00 (2.520) 64.00 (2.520) Ø29.00 (1.142 DIA) 27.00 (1.062) 21.00 (.827) 33.50 (1.319) ❷ ❶ Lever positions B Operator Bezel G Switch block Description Short lever Long lever Contacts Part No 2 pos. maintained 2 pos. momentary 3 pos. maintained 3 pos. momentary 3 pos. mainL, momR 3 pos. momL, mainR 2 pos. maintained 2 pos. momentary 3 pos. maintained 3 pos. momentary 3 pos. mainL, momR 3 pos. momL, mainR A029207 A029208 A029203 A029204 A029205 A029206 A029407 A029408 A029403 A029404 A029405 A029406 A029107• A029108• A029103 A029104 A029105 A029106 A029307• A029308• A029303 A029304 A029305 A029306 1 N.O. 1 N.C. 2 N.O. 2 N.C. 1 N.O./1 N.C. A02501UL A02502UL A02503UL A02504UL A02505UL OPTION To specify flush mounting (30 mm Ø) option, add “FM” to the end of the part number (for round operators only). Example : A029407FM. Bezel: G-20 square, Second switch block Contacts Part No 1 N.O. 1 N.C. 2 N.O. 2 N.C. 1 N.O./1 N.C. A02506UL A02507UL A02508UL A02509UL A02510UL To achieve 3 or 4 pole switching, add second switch block, from above table. C A • Lever Rotation - 2 position switches The model numbers shown are for switches with clockwise lever rotation. For anticlockwise rotation, replace : 07 with 01 08 with 02 at the end of the model number. Optional engraving on lever end To order, add “WL” to the end of the part No. Example : A029407WL. round, www.apem.com APEM A02 series Keylock switches Panel cut-out Ø 22 or 29,5 x 21,5 A keyswitch assembly requires : operator + one or two switch blocks. To order these elements, select desired model numbers from tables below. Example : IP65 square 2 position keyswitch, clockwise rotation, switch block with 2 N.O. contacts = A028220 and A02503UL. N.O./N.C. N.C. N.O. 29.00 (1.142) 34.50 (1.358) 29.00x29.00 (1.142 SQ) 64.00 (2.520) 55.50 (2.185) 38.00 (1.496) 24.00 (.945) 36.00 (1.417) Ø29.00 (1.142 DIA) 21.00 (.827) 21.00 (.827) 27.00 (1.062) 33.50 (1.319) 33.50 (1.319) ❷ Key positions C B Operator Bezel Description 2 pos. maintained 2 pos. momentary 3 pos. maintained 3 pos. momentary 3 pos. mainL, momR 3 pos. momL, mainR 2 pos. maintained 2 pos. momentary 3 pos. maintained 3 pos. momentary 3 pos. mainL, momR 3 pos. momL, mainR 2 pos. maintained 2 pos. momentary 3 pos. maintained 3 pos. momentary 3 pos. mainL, momR 3 pos. momL, mainR Switch block Part No Key removable in positions A028120• A-B A028119• A A028105 A-B-C A028106 A A028107 A-B A028108 A-C A028220• A-B A028219• A A028205 A-B-C A028206 A A028207 A-B A028208 A-C A028320• A-B A028319• A A028305 A-B-C A028306 A A028307 A-B A028308 A-C OPTION To specify flush mounting (30 mm Ø) option, add “FM” to the end of the part number (for round operators only). Example : A028320FM. Bezel: APEM rectangular, square, A Contacts Part No • Key Rotation - 2 position switches 1 N.O. 1 N.C. 2 N.O. 2 N.C. 1 N.O./1 N.C. A02501UL A02502UL A02503UL A02504UL A02505UL The model numbers shown are for switches with clockwise key rotation. For anticlockwise rotation, replace: Second switch block Contacts Part No 1 N.O. 1 N.C. 2 N.O. 2 N.C. 1 N.O./1 N.C. A02506UL A02507UL A02508UL A02509UL A02510UL 20 19 with with G 01 02 at the end of the model number • 2 standard keys are supplied. • 20 key barrel types available from stock. Non-removable key positions : contact APEM. To achieve 3 or 4 pole switching, add second switch block, from above table round, www.apem.com G-21 A02 series Emergency stop switches Panel cut-out Ø 22 (.866) • Prominent 40 mm (1.575) dia. red mushroom actuator • Highly reliable positive break switch • Push to shut off switch, twist to reset to ON • Approved to UL 1054 / EN 60947-5-5 N.C. An emergency stop switch assembly requires : operator + switch block. To order, specify with single pole or double pole positive break switch block. General specifications • Mechanical life : 6.050 cycles (6 cycles per minute) • Operating force : 20 N • Operating temperature : -20°C to +85°C • Degree of environ. protection (IEC529) : IP65 front of panel, IP40 back of panel • Switch terminals : M3 screws - wire 2x0.75mm2 max. Electrical specifications • Current/voltage rating : 2,5A 380VAC AC-15 • Contact gap : > 3 mm (.118) • Dielectric strength : 2.500V • Electrical life : 6.050 cycles 29.00 (1.142) 64.00 (2.520) 21.00 (.827) Ø40.00 (1.575 DIA) 21.00 (.827) ❷ ❶ Accessory G Operator Bezel 90 mm Ø Self Adhesive Label Description Part No Yellow label with text Yellow label A02YL1 A02YL2 Switch block Description Part No No of poles Part No Emergency stop A02ES Double pole Single pole A02511 A02512 EMERGENCY STOP SWITCH ENCLOSURE To order the Emergency Stop Switch in the Plastic Enclosure (94 x 94 x 81 mm) with a 2 pole Positive Break Switch Block and Emergency Stop label, use Part number : A02PE2L. G-22 www.apem.com APEM A02 series Mushroom head pushbutton switches Panel cut-out Ø 22 (.866) • Prominent 40 mm (1.575) dia. mushroom actuator or optional 26 mm (1.024) actuator • Momentary and maintained functions Momentary function versions are unmarked Maintained function versions are twist to release (arrows indicate direction of twist) • Various coloured mushroom actuators are available N.O. N.C. N.O./N.C. 29.00 (1.142) 64.00 (2.520) 21.00 (.827) Ø40.00 (1.575 DIA) 21.00 (.827) ❷ ❶ Operator Bezel Switch block Description Part No Contacts Part No Black momentary Red momentary Yellow momentary Green momentary Blue momentary Black maintained Red maintained Yellow maintained Green maintained Blue maintained A02MMA A02MMB A02MMD A02MME A02MMF A02MXA A02MXB A02MXD A02MXE A02MXF 1 N.O. 1 N.C. 2 N.O. 2 N.C. 1 N.O./1 N.C. A02501UL A02502UL A02503UL A02504UL A02505UL OPTION For optional reduced (Ø 26 mm) mushroom head operators : contact APEM. G Second switch block Contacts Part No 1 N.O. 1 N.C. 2 N.O. 2 N.C. 1 N.O./1 N.C. A02506UL A02507UL A02508UL A02509UL A02510UL To achieve 3 or 4 pole switching, add second switch block, from above table Bezel: APEM round www.apem.com G-23 A02 series Industrial controls Installation Modular construction / panel mounting PUSHBUTTONS & INDICATORS PANEL CUT-OUT SCREEN Round & square operators LEGEND EMERGENCY STOP ROTARY LEVERS SWITCHES KEYLOCK SWITCHES REFLECTOR LOCATING SLOT Ø22.00 (.866 DIA 0.00/+0.50 .000/+.019) 3.00 (.118) BULB FIXING NUT 6.00 Maxi (.236 MAX) POLARISING DOT PANEL SEAL 13.00 (.511) Rectangular operators 0.00/+0.50 .000/+.019) OPERATOR 21.50 (.846 ADAPTOR BLOCK SWITCH BLOCK 29.50 (1.161 0.00/+0.50 .000/+.019 ) END CAP PANEL CLAMP FIXING SCREW Max. panel thickness : 8 mm (.315) PANEL MOUNTING ASSEMBLY TO REMOVE BULB • Drill/punch hole in panel as shaped above. Remove reflector/screen assembly. Use the bulb extractor 30-0002 to remove the bulb. • Assemble front operator through hole and : a/ Round & square types : tighten nut to a maximum torque of 0,8Nm using tool No 30-0001. Snap on adaptor block b/ Rectangular types : tighten two panel fixing screws in front to a maximum torque of 6cNm. • Wire chosen switch block as required and snap onto front operator. TO REMOVE SWITCH BLOCK Lever out latches using small screwdriver taking care not to overbend, and pull off the block from the front operator. A02 Accessories • Snap end cap onto switch block. • Fit bulb if required using tool No 30-0002. G • Snap screen onto reflector assembly with legend in between if required ans snap into front operator TAKING CARE TO LINE UP THE LOCATING SLOT WITH THE POLARISING DOT, and not to damage the seal. Part No : 14-0005 End cap terminal guard offering unique terminal protection. 6.35 mm push on tab terminals. Specify “SP” to the end of the switchblock and operator P/N. Example : A02503SP. G-24 www.apem.com APEM A03 series Illuminated or non-illuminated pushbutton switches and indicators Panel cut-out Ø 22 (.866) or 30 (1.181) - Plastic or metal flush mounting bezel A pushbutton assembly requires : screen + lamp (if illuminated) + operator + switch block. To order these elements, select desired model numbers from tables below. Example : IP65 flush mounting round pushbutton, maintained function, red screen, 12V red LED and single pole switch block = A0314X, A0263B, A0142M1 and A0151BUL. 3 1 2 Ø29.00 (1.143 DIA) 1.0 to 6.0 Panel Thickness 59.50 (2.344) 59.00 (2.325) 49.00 (1.931) 26.00 (1.024) 10.00 (.394) 2.00 (.079) Ø35.00 (1.379 DIA) 0.50 6.00 (.236) 18.00 (.709) 6.00 (.236) 18.00 (.709) ❷ ❶ ❸ Screen Bezel Bezel: APEM ❹ Lamp Operator Colour Part No Lamp Voltage Part No black red amber yellow green blue clear white A0263A A0263B A0263C A0263D A0263E A0263F A0263G A0263J Filament Filament Filament Filament Filament Filament Neon Neon LED LED LED LED LED LED LED LED LED LED LED LED LED LED LED LED 6.3V 14V 28V 36V 48V 60V 110V 220V 6V red 6V green 6V amber 12V red 12V green 12V amber 12V blue 12V white 24V red 24V green 24V amber 24V blue 24V white 48V red 48V green 48V amber A0141A A0141B A0141C A0141D A0141E A0141F A0143G A0143H A0142L1 A0142L2 A0142L3 A0142M1 A0142M2 A0142M3 A0142M4 A0142M5 A0142N1 A0142N2 A0142N3 A0142N4 A0142N5 A0142P1 A0142P2 A0142P3 round. ‘Illum’ - illuminated, 7.65 (.301) Bezel Description Plastic illum, momentary Plastic illum, maintained Plastic non-illum, momentary Plastic non-illum, maintained Metal illum, momentary Metal illum, maintained Metal non-illum, momentary Metal non-illum, maintained F/mount illum, momentary F/mount illum, maintained F/mount non-illum, momentary F/mount non-illum, maintained Plastic indicator Metal indicator F/mount indicator Switch block Lamp type Part No No of poles Part No Lamp/LED bulb Lamp/LED bulb A0307Y A0307X A0309Y A0309X A0310Y A0310X A0312Y A0312X A0314Y A0314X A0315Y A0315X A0375 A0377 A03791 Single pole Double pole Three pole Four pole A0151BUL A0152BUL A0155BUL A0153BUL Lamp/LED bulb Lamp/LED bulb Lamp/LED bulb Lamp/LED bulb UNSEALED SWITCHES (IP40) : add “01” to end of operator model number. SCREEN ENGRAVING / INSERTABLE LEGENDS : contact APEM. ‘Non-illum’ - non illuminated www.apem.com G-25 G
A02505 价格&库存
很抱歉,暂时无法提供与“A02505”相匹配的价格&库存,您可以联系我们找货
