A0150BD
A0150BD
    APEM(埃斐)
    SWITCHBLOCKFOREMERGENCYSTOP
A0150BD 数据手册
PANEL SWITCHES - SW D ES 1 A0 1 80 -1 A01ES-D series Emergency stop switches • panel cut-out Ø 16 mm DISTINCTIVE FEATURES Approved to EN 60947-5-5 5 prominent red actuator styles Locked/unlocked status indicator option AC15 1.5 A 250 VAC, 6 A 250 VAC Panel sealed to IP65 ENVIRONMENTAL SPECIFICATIONS • Sealing options : front panel IP65, rear panel IP40 according to EN60947-5-5 • Operating temperature : -20 °C to +55 °C (-4 °F to +131 °F) ELECTRICAL SPECIFICATIONS • Electrical function : push to shut off, twist to release • Current/voltage rating : AC-15 1.5 A 250 VAC, 6 A 250 VAC • Electrical life : 6,050 cycles • Contact gap : > 3 mm • Insulation resistance : 50 MΩ min • Dielectric test voltage : 2,900 V GENERAL SPECIFICATIONS • Panel thickness : 6 mm (.236) max. • Mechanical life : 6,050 cycles • Operating force : 18 to 20 N • Torque : 0.8 Nm • Soldering : 350 °C (662 °F) , 5 seconds (IEC 68-2-2-20Tb, method 2) • Switch terminals : solder/ quick-connect 2.8 mm (.110) (IEC 68-2-20) The company reserves the right to change specifications without notice. 1 Emergency stop switches • panel cut-out Ø 16 mm PANEL CUT-OUT MATERIALS • Operator case : polyetherimide 9.25 (.364) APEM products may be recycled at end-of-life for the re-claiming of valuable metal components. 7.25 0.75 (.030) (.285) Switch block approved to UL 1054 / VDE (EN 61058-1) and DEMKO (60947-5-5) Ø16.00 (.630 DIA) 9.25 (.364) CA01ESDPE 0.75 (.030) (.630 DIA) A01ES-D - A01ES-DF1- A01ES-DF2 1.50 (.059) AGENCY APPROVAL Ø16.00 echelle 0.65 CA01ESDPE ELECTRICAL FUNCTIONS echelle 0.65 Single pole Normally Closed Double pole Normally Closed CA01ESDFCT CA01ESDFCT echelle 1echelle 1 2 0.75 (.030) • Panel seal : neoprene Ø16.00 (.630 DIA) 0.75 (.030) 7.25 (.285) 1.50 (.059) Ø16.00 (.630 DIA) • Switch block : PBT 1.50 (.059) A01ES-DM - A01ES-DSP3 • Actuator : polycarbonate 1.50 (.059) PANEL SWITCHES A01ES-D series Emergency stop switches • panel cut-out Ø 16 mm BUILD YOUR PART NUMBER An emergency stop switch assembly requires : 1 operator + 1 switch block. Example : Ø 16 mm red twist to reset, knurled head actuator with double pole positive break switch block = A01ES-D + A0154B-D OPERATOR A01 OPERATOR TYPE SERIES ES Emergency stop ACTUATOR DM D Mushroom head (standard) Knurled head DF1 Finger grip DF2 Smooth DSP3 Ø 40 mm head SWITCH BLOCK A01 SERIES OPTIONS SWITCH BLOCK 50B-D Single pole Blank 54B-D Double pole Customization on request. None ABOUT THIS SERIES Mounting accessories : standard hardware supplied : 1 nut and 1 flat seal 3 PANEL SWITCHES A01ES-D series Emergency stop switches • panel cut-out Ø 16 mm MUSHROOM HEAD ACTUATOR - STANDARD 21.12 (.831) 4.40 (.173) 14.50 (.571) 14.50 (.571) 54.60 (2.150) A01ES-DM 54.60 (2.150) 21.12 (.831) Ø24.00 Ø24.00 (.945 DIA) (.945 DIA) 4.40 (.173) 14.40 (.567) Ø18.00 Ø18.00 (.709 DIA) (.709 DIA) 14.40 (.567) KNURLED HEAD ACTUATOR 23.65 (.931) 54.65 (2.152) CA01ESDMCA0 14.50 (.571) echelle 0.65ech 14.50 (.571) A01ES-D 54.65 (2.152) 23.65 (.931) Ø24.10Ø24.10 (.949 DIA) (.949 DIA) 4.40 4.40 (.173) (.173) 14.40 14.40 (.567) (.567) Ø21.00Ø21.00 (.827 DIA) (.827 DIA) FINGER GRIP ACTUATOR 23.25 (.915) CA01ESD CA0 54.25 (2.136 14.50 (.571) echelleech 0.6 14.50 (.571) A01ES-DF1 54.25 (2.136 23.25 (.915) Ø27.44Ø27.44 (1.080(1.080 DIA) DIA) 4.40 4.40 (.173) (.173) 14.40 14.40 (.567) (.567) Ø21.00Ø21.00 (.827 DIA) (.827 DIA) SMOOTH ACTUATOR 24.20 (.953) CA01 C eche ec 55.20 (2.173) 24.20 (.953) Ø27.42Ø27.42 (1.080 DIA) (1.080 DIA) 55.20 (2.173) 4.40 4.40 (.173) (.173) Ø21.00Ø21.00 (.827 DIA) (.827 DIA) 4 14.50 (.571) A01ES-DF2 14.50 (.571) PANEL SWITCHES A01ES-D series 14.40 14.40 (.567) (.567) Emergency stop switches • panel cut-out Ø 16 mm Ø 40 MM HEAD ACTUATOR PANEL SWITCHES A01ES-D series 63.30 (2.492) 29.80 (1.173) Ø40.00 (1.575 DIA) 14.50 (.571) A01ES-DSP3 4.40 (.173) 14.40 (.567) Ø18.00 (.709 DIA) SINGLE POLE SWITCH BLOCK: A0150B-D DOUBLE POLE SWITCH BLOCK: A0154B-D 7.25 (.285) 18.00 (.709) 0.50 (.020) 2.80 (.110) 9.00 (.354) CA01ESDSP3 15.30 (.603) echelle 0.65 8.40 (.330) 15.30 (.603) 8.40 (.330) 0.50 (.020) 14.50 (.571) 14.50 (.571) 18.00 (.709) 2.80 (.110) 12.00 (.472) CA0154BD ACCESSORIES echelle 0.65 CA0150BD échelle 0.65 Order separately. Ø 60 MM SELF-ADHESIVE LABEL A01YL1 A01YL2 A01YL3 A01YL4 English text Without text French text Italian text NUT TOOL 30-0001 Nut tool Other languages on request. 5
A0150BD 价格&库存
很抱歉,暂时无法提供与“A0150BD”相匹配的价格&库存,您可以联系我们找货
A0150BD
    • 13+67.39525
    • 45+64.21532
    • 200+61.28929
    • 450+58.62927
    库存:500
    A0150BD
    • 5+339.126105+43.87502
    库存:90
