A0101X
A0101X
    APEM(埃斐)
    SWITCH OPERATOR RECT 1 OR 2 POLE
A0101X 数据手册
A1-A01-A02-A03 series Industrial controls Distinctive features The A01 and A02 series offer ranges of : - pushbutton switches, illuminated or not - indicators - 2 or 3 position keylock switches - 2 or 3 position rotary lever switches - emergency stop switches with rectangular, square or round operators. • Custom engraved aluminium pushbutton switches, A1 series ! New • Switch enclosures • Pushbutton switches and indicators, A03 series ❑ Environmental protection : IP65 ❑ Modular construction ❑ Electrical life : 50.000 cycles min. ❑ Screen engraving or insertable legends on request ❑ Approvals UL 1054 EN 61058-1 pending BS RIA 20 Shock & Vibration Each sub-assembly has to be ordered separately. EN 61058-1 A01 - A1 - A03 series A02 series • Panel cut-out : Ø 16 mm (.630), except : - flush mount round : Ø 22 mm (.866) - flush mount rectangular : 20.60 x 26.70 mm - flush mount square : 20.60 x 20.60 mm - A1 series : Ø 22 mm (.866) - A03 series : round or square Ø 22 (.866) flush mount : Ø 30 mm (1.378) • Panel cut-out : - round or square : Ø 22 mm (.866) - rectangular : 29,5 x 21,5 mm (1.160x.846) - flush mount : Ø 30 mm (1.378) • 1, 2, 3 and 4 poles • Current/voltage rating : 12A 380VAC 16A 250VAC max. - 25mA 5VAC min. • Solder lug/quick-connect terminals • Contacts : silver, gold plated • Current/voltage rating : 6A 250VAC max. - 10mA 5VAC min. • Lamp : filament, neon or LED G • 1 and 2 poles • Screw terminals (optional : quick-connect term.) • Contacts : silver • Lamp : filament, neon, LED or special multi-LED array Option : end cap terminal guard. Order separately (see end of A02 series). Packaging unit : A1 : 25 pieces - A01 : 20 pieces (except pushbuttons: 25 pieces) - A02 : 25 pieces - A03 : 10 pieces. Dimensions : first dimensions are in mm while inches are shown as bracketted numbers. APEM www.apem.com G-3 A1-A01-A02-A03 series Industrial controls Specifications for pushbutton, keylock and rotary switches ELECTRICAL SPECIFICATIONS A01 - A1 - A03 A02 Momentary or maintained action Momentary or maintained action 10mA 5VAC min. 6A 250VAC max. - 6A 12VDC max. 25mA 5VAC min. 12A 380VAC - 16A 250VAC max. 12A 12VDC max. > 1 mm (.039) Double break 2 x 1,5 mm (.059) 10mΩ max. at 1A 4VDC 10mΩ max. at 1A 4VDC 50 MΩ min. 50 MΩ min. 750V between open contacts 5KV live to accessible 2KV between open contacts 4KV live to accessible 50.000 cycles 50.000 cycles • Insulation : Class 2 Class 2 • Lamp life : LED : 60.000 h min. to 75% relative luminosity - Filament : approx. 5.000 h Neon : approx. 10.000 h LED : 60.000 h min. to 75 % relative luminosity - Filament : approx. 5.000 h Neon : approx. 10.000 h • Function : • Current/voltage rating : • Contact gap • Initial contact resistance : • Insulation resistance : • Dielectric strength : • Electrical life (resistive load) : • Lamp circuit diagrams A B A B GENERAL SPECIFICATIONS A01 - A1 - A03 • Min. mechanical life : Pushb. momentary : 1 million cycles Pushb. maintained : 100.000 cycles Keylock and rotary : 100.000 cycles Pushb. momentary: 1 million cycles Pushb. maintained : 100.000 cycles Keylock and rotary : 100.000 cycles 8 mm (.315) max. 8 mm (.315) max. • Operating temperature : -20°C to +55°C -20°C to +85°C • Solder heat resistance : (IEC 68-2-20Tb, method 2) 350°C, 5 sec. 350°C, 5 sec. • Degree of environmental protection (IEC 529 ) IP 65 front of panel IP 40 back of panel IP 65 front of panel IP 40 back of panel Midget Grooved T13/4, filament, LED or neon Midget Grooved T13/4, filament, LED or neon Special multi-LED array • Switch terminals : Solder/quick-connect 2,8 mm (.110) M3 screws - wire 2 x 0,75 mm2 max. • Lamp terminals : Solder/quick-connect 2,8 mm (.110) M3 screws Flexible wire 2 x 2,5 mm2 max. Rigid wire 4 mm2 max. • Panel thickness G A02 • Lamps : Specifications for emergency stop switches : see pages 10 and 22. For screen engraving or film legends, contact APEM. G-4 www.apem.com APEM A1 series Engraved aluminium flush mounting pushbuttons and indicators Panel cut-out Ø 22 (.866) A pushbutton assembly requires : engraved screen + lamp (if illuminated) + operator + switch block + flush mount bezel. To order these elements, select desired model numbers from the table below. Example : pushbutton, round, illuminated, sealed to IP65, latching, single pole with “start” engraving, 24V blue LED and flush mounting bezel = A1PCA1X103K403. 3 1 2 14.5 (.571) 42.05 (1.655) 12.00 (.472) Ø25.00 (9.85 DIA) 8.5 (.335) 7.65 (.301) 15.3 (.602) 18.00 (.709) 18.00 (.709) 2.8 (.110) 0.5 (.020) A1 Accessories 03 - flushmount Switch Type Bezel Illumination Sealing Function Switch block P - pushbutton I - indicator C - round A - illuminated B - non-illum. 0 - unsealed 1 - sealed IP65 0 - indicator X - latching Y - momentary 0 - indicator 1 - single pole 2 - double pole 5 - three pole 3 - four pole Engraved Screen Options OTHER SCREEN ENGRAVING OPTIONS : contact APEM. APEM 01 - Front Fog Lights 11 - ‘Lock’ 02 - Rear Fog Lights 12 - ‘Unlock’ 03 - ‘Start’ 13 - Rear Window Heating 04 - Interior Light 14 - Cooling 05 - Boot Release 15 - Wipers 06 - Hazard Warning 16 - Washers 07 - Lights 17 - Fan 08 - Heating & Ventilation 18 - Horn 09 - Map Lights 19 - Air recirculation 10 - Side Lights 20 - Blank www.apem.com Bulb A1 - filament 6.3V B1 - filament 14V C1 - filament 28V D1 - filament 36V E1 - filament 48V F1 - filament 60V G1 - Neon 110V H1 - Neon 220V I1 - Led 6V red I2 - Led 6V green I3 - Led 6V amber J1 - Led 12V red J2 - Led 12V green J3 - Led 12V amber J4 - Led 12V blue J5 - Led 12V white K1 - Led 24V red K2 - Led 24V green K3 - Led 24V amber K4 - Led 24V blue K5 - Led 24V white L1 - Led 48V red L2 - Led 48V green L3 - Led 48V amber G-5 G A01 series Illuminated or non-illuminated pushbutton switches Panel cut-out Ø 16 (.630) A pushbutton assembly requires : screen + lamp (if illuminated) + operator + switch block. To order these elements, select desired model numbers from tables below. Example : IP65 rectangular pushbutton, single pole, maintained, red screen and 12V red LED = A0161B, A0142M1, A0101X and A0151BUL. 3 3 3 2 2 1 1 E F 8.50 (.335) 3 2 3 1 2 7.65 (.301) 2 3 1 2 6.00 (.236) 1 7.65 7.65 (.301) (.301) 18.00 (.709) 1 9.00 (.354) 6.00 (.236) 12.00 (.472) 9.00 (.354) 18.00 (.709) 2 24.00 (.945) 16.25 (.640) 3 1 24.00 (.945) 0.50 (.020) ❷ Screen Bezel G ❹ Lamp Operator Part No Lamp Voltage Part No Pole black red amber yellow green blue clear white black red amber yellow green blue clear white black red amber yellow green blue clear white A0161A A0161B A0161C A0161D A0161E A0161F A0161G A0161J A0162A A0162B A0162C A0162D A0162E A0162F A0162G A0162J A0163A A0163B A0163C A0163D A0163E A0163F A0163G A0163J Filament Filament Filament Filament Filament Filament Neon Neon LED LED LED LED LED LED LED LED LED LED LED LED ED LED LED LED 6.3V 14V 28V 36V 48V 60V 110V 220V 6V red 6V green 6V amber 12V red 12V green 12V amber 12V blue 12V white 24V red 24V green 24V amber 24V blue 24V white 48V red 48V green 48V amber A0141A A0141B A0141C A0141D A0141E A0141F A0143G A0143H A0142L1 A0142L2 A0142L3 A0142M1 A0142M2 A0142M3 A0142M4 A0142M5 A0142N1 A0142N2 A0142N3 A0142N4 A0142N5 A0142P1 A0142P2 A0142P3 1 or 2 1 or 2 1 or 2 1 or 2 3 or 4 3 or 4 3 or 4 3 or 4 1 or 2 1 or 2 1 or 2 1 or 2 3 or 4 3 or 4 3 or 4 3 or 4 1 or 2 1 or 2 1 or 2 1 or 2 3 or 4 3 or 4 3 or 4 3 or 4 D 30.70 (1.209) 18.00 (.709) ❸ Colour C 2.80 (.110) 18.00 (.709) ❶ D Ø18.00 (.709 DIA) C 28.50 (1.122) 8.40 (.330) 42.00 (1.654) 18.00x18.00 (.709 SQ) 10.00 (.394) 6.00 (.236) Bezel Switch block Description Part No No of poles Part No Illum, momentary Illum, maintained Non-illum, momentary Non-illum, maintained Illum, momentary Illum, maintained Non-illum, momentary Non-illum, maintained Illum, momentary Illum, maintained Non-illum, momentary Non-illum, maintained Illum, momentary Illum, maintained Non-illum, momentary Non-illum, maintained Illum, momentary Illum, maintained Non-illum, momentary Non-illum, maintained Illum, momentary Illum, maintained Non-illum, momentary Non-illum, maintained A0101Y A0101X A0102Y A0102X A0103Y A0103X A0104Y A0104X A0105Y A0105X A0106Y A0106X A0107Y A0107X A0108Y A0108X A0109Y A0109X A0110Y A0110X A0111Y A0111X A0112Y A0112X Single pole Double pole Three pole Four pole A0151BUL A0152BUL A0155BUL A0153BUL UNSEALED SWITCHES (IP40) : add “01” to end of operator model number. BI-COLOUR LED’s optional. SCREEN ENGRAVING/INSERTABLE LEGENDS : contact APEM Bezel: G-6 rectangular, square, round, ‘Illum’ - illuminated, ‘Non-illum’ - non illuminated www.apem.com APEM A01 series Indicators Panel cut-out Ø 16 (.630) An indicator assembly requires : screen + lamp + operator. To order these elements, select desired model numbers from tables below. Example : IP65 rectangular indicator with red screen and 12V red LED = A0161B, A0142M1 and A0171. 24.00 (.945) Ø18.00 (.709 DIA) 8.40 (.330) 42.00 (1.654) 10.00 (.394) 18.00 (.709) 18.00 (.709) 0.50 (.020) 2.80 (.110) 8.50 (.335) ❷ ❶ Screen Bezel ❸ Operator Lamp Colour Part No Lamp Voltage Part No black red amber yellow green blue clear white black red amber yellow green blue clear white black red amber yellow green blue clear white A0161A A0161B A0161C A0161D A0161E A0161F A0161G A0161J A0162A A0162B A0162C A0162D A0162E A0162F A0162G A0162J A0163A A0163B A0163C A0163D A0163E A0163F A0163G A0163J Filament Filament Filament Filament Filament Filament Neon Neon LED LED LED LED LED LED LED LED LED LED LED LED LED LED LED LED 6.3V 14V 28V 36V 48V 60V 110V 220V 6V red 6V green 6V amber 12V red 12V green 12V amber 12V blue 12V white 24V red 24V green 24V amber 24V blue 24V white 48V red 48V green 48V amber A0141A A0141B A0141C A0141D A0141E A0141F A0143G A0143H A0142L1 A0142L2 A0142L3 A0142M1 A0142M2 A0142M3 A0142M4 A0142M5 A0142N1 A0142N2 A0142N3 A0142N4 A0142N5 A0142P1 A0142P2 A0142P3 Bezel Description Part No Indicator Indicator Indicator A0171 A0172 A0173 G UNSEALED INDICATORS (IP40) : add “01” to end of operator model number. SCREEN ENGRAVING / INSERTABLE LEGENDS : contact APEM Bezel: APEM rectangular, square, round www.apem.com G-7 A01 series Rotary lever switches Panel cut-out Ø 16 (.630) A rotary lever switch assembly requires : operator + switch block. To order these elements, select desired model numbers from tables below. Example : IP65 rectangular rotary switch with long lever, clockwise rotation, single pole, 2 positions, maintained = A019109 and A0151BUL. 3 1 2 12.00 (.472) 24.00 (.945) 6.00 (.236) 3 1 2 18.00 (.709) 3 2 1 3 1 3 2 2 1 2 7.65 (.301) 1 3 8.40 (.330) C D 28.50 (1.122) 10.00 (.394) 42.00 (1.654) 0.50 (.020) 18.00 (.709) 18.00x18.00 (.709 SQ) Ø18.00 (.709 DIA) C D E F 2.80 (.110) 18.00 (.709) ❷ ❶ 1 3 2 24.00 (.945) 30.70 (1.209) Lever Positions B C A Operator Pole G 1 or 2 1 or 2 3 or 4 3 or 4 1 or 2 1 or 2 1 or 2 1 or 2 1 or 2 1 or 2 3 or 4 3 or 4 1 or 2 1 or 2 1 or 2 1 or 2 1 or 2 1 or 2 3 or 4 3 or 4 1 or 2 1 or 2 1 or 2 1 or 2 Bezel: G-8 Bezel Description 2 pos. maintained 2 pos. momentary 2 pos. maintained 2 pos. momentary 3 pos. maintained 3 pos. momentary 3 pos. mainL, momR 3 pos. momL, mainR 2 pos. maintained 2 pos. momentary 2 pos. maintained 2 pos. momentary 3 pos. maintained 3 pos. momentary 3 pos. mainL, momR 3 pos. momL, mainR 2 pos. maintained 2 pos. momentary 2 pos. maintained 2 pos. momentary 3 pos. maintained 3 pos. momentary 3 pos. mainL, momR 3 pos. momL, mainR rectangular, Switch block Short lever Long lever No of poles Part No A019209 A019210 A019211 A019212 A019205 A019206 A019207 A019208 A019409 A019410 A019411 A019412 A019405 A019406 A019407 A019408 A019609 A019610 A019611 A019612 A019605 A019606 A019607 A019608 Single pole Double pole Three pole Four pole A0151BUL A0152BUL A0155BUL A0153BUL square, A019109• A019110• A019111• A019112• A019105 A019106 A019107 A019108 A019309• A019310• A019311• A019312• A019305 A019306 A019307 A019308 A019509• A019510• A019511• A019512• A019505 A019506 A019507 A019508 round, • Lever Rotation - 2 position switches The model numbers shown are for switches with clockwise lever rotation. For anticlockwise rotation, replace : 09 with 01 10 with 02 11 with 03 12 with 04 at the end of the model number. Optional Engraving on Lever end See above photo left. To order, add “WL” to the end of the operator part No. Example : A019609WL.. ‘pos’ - position, ‘mainL’ - maintained left, www.apem.com ‘momR’ - momentary right, etc APEM A01 series Keylock switches Panel cut-out Ø 16 (.630) A keylock switch assembly requires : operator + switch block. To order these elements, select desired model numbers from tables below. Example : IP65 rectangular keyswitch, clockwise rotation, single pole, 2 positions, maintained = A018125 and A0151BUL. 3 1 2 12.00 (.472) 24.00 (.945) 3 1 1 3 7.65 (.301) 2 18.00 (.709) 2 3 3 2 3 2 2 1 2 1 1 38.00 (1.496) 1 3 6.00 (.236) 18.00x18.00 (.709 SQ) 24.00 (.945) C D 2.80 (.110) 0.50 (.020) 18.00 (.709) 18.00 (.709) ❷ ❶ 28.50 (1.122) 8.40 (.330) 42.00 (1.654) Ø18.00 (.709 DIA) C D E F 30.70 (1.209) Key Positions B Operator Pole Bezel Description 1 or 2 1 or 2 1 or 2 3 or 4 3 or 4 1 or 2 1 or 2 1 or 2 1 or 2 1 or 2 1 or 2 1 or 2 3 or 4 3 or 4 1 or 2 1 or 2 1 or 2 1 or 2 1 or 2 1 or 2 1 or 2 3 or 4 3 or 4 1 or 2 1 or 2 1 or 2 1 or 2 Bezel: APEM 2 pos. maintained 2 pos. maintained 2 pos. momentary 2 pos. maintained 2 pos. momentary 3 pos. maintained 3 pos. momentary 3 pos. mainL, momR 3 pos. momL, mainR 2 pos. maintained 2 pos. maintained 2 pos. momentary 2 pos. maintained 2 pos. momentary 3 pos. maintained 3 pos. momentary 3 pos. mainL, momR 3 pos. momL, mainR 2 pos. maintained 2 pos. maintained 2 pos. momentary 2 pos. maintained 2 pos. momentary 3 pos. maintained 3 pos. momentary 3 pos. mainL, momR 3 pos. momL, mainR rectangular, A018123 A018125• A018124• A018127• A018128• A018105 A018106 A018107 A018108 A018223 A018225• A018224• A018227• A018228• A018205 A018206 A018207 A018208 A018323 A018325• A018324• A018327• A018328• A018305 A018306 A018307 A018308 square, A Switch block Part No Key removable A A-B A A-B A A-B-C A A-B A-C A A-B A A-B A A-B-C A A-B A-C A A-B A A-B A A-B-C A A-B A-C round, No of poles Part No Single pole Double pole Three pole Four pole A0151BUL A0152BUL A0155BUL A0153BUL C • Key Rotation - 2 position switches The model numbers shown are for switches with clockwise key rotation. For anticlockwise rotation, replace : 25 24 27 28 with with with with G 01 02 03 04 at the end of the model number. 2 standard keys are supplied. 20 key barrel types available from stock. NON-REMOVABLE KEY POSITIONS / ON-ON-ON FUNCTION : contact APEM. ‘pos’ - position, ‘mainL’ - maintained left, www.apem.com ‘momR’ - momentary right, etc G-9 A01 series Emergency stop switches Panel cut-out Ø 16 (.630) • Prominent 24 mm (.944) dia. or optional 40 mm (1.575) dia. red mushroom actuator • Highly reliable positive break switch • Push to shut off switch, twist to reset to ON • Approved to UL 1054 / EN 60947-5-1 N.C. An emergency stop switch assembly requires : operator + switch block. To order, specify with single pole or double pole positive break switch block. General specifications • Min. mechanical life : 6.050 cycles (6 cycles per minute) • Operating force / torque : 16 N / 0,1 Nm • Operating temperature : -20°C to +55°C • Solder heat resistance : 350°C, 5 secs (IEC 68-2-2-20Tb, method 2) • Degree of environmental protection (IEC 529) : IP65 front of panel, IP40 back of panel • Switch terminals : solder/quick-connect 2,8 mm (.110) (IEC 68-2-20) Electrical specifications • Current/voltage rating : 1,5A 250VAC AC-15 • Contact gap : > 3 mm (.118) • Dielectric strength : 2.900V • Electrical life : 6.050 cycles 19.00 (1.047) Ø24.00 (.945 DIA) 15.30 (.602) 12.00 (.472) 0.50 (.020) 18.00 (.709) ❷ ❶ C D Ø40.00 8.40 (.330) 42.00 (1.654) Option : SP3 version 2.80 (.110) 18.00 (.709) Accessory 60 mm Ø Self Adhesive Label G Operator Description 24 mm Ø Emergency stop 40 mm Ø Emergency stop G-10 Description Part No Yellow label with text Yellow label A01YL1 A01YL2 Switch block Part No No of poles Part No A01ES A01ES SP3 Single pole Double pole A0150BUL A0154BUL www.apem.com APEM A01 series Emergency stop switches/mushroom head pushbutton switches Fitted in enclosures • Prominent 40 mm (1.575) dia. mushroom actuator, twist to release • Highly reliable positive break switching on E-Stop • Sealed to IP65 • 6A current rating • Robust polycarbonate enclosures • Knockouts for popular conduit sizes • Double pole changeover switch blocks available for momentary/maintained mushroom head pushbuttons. N.C. Emergency stop 3 1 Technical specifications • Contact rating : Pushbutton switch : 6A 250VAC - E-Stop : 1,5A 250VAC • Dimensions : 65 x 65 x 57 mm • Electrical life : Pushbutton switch : 50 000 cycles - E-Stop : 6 050 cycles • Operating temperature : -20°C to +55°C 2 Momentary & maintained 55.0 (2.167) 17.5 (.689) Ø40.0 (1.575 DIA) 65.0 SQUARE (2.561) Description Part No Emergency stop Black momentary Red momentary Yellow momentary Green momentary Blue momentary Black maintained Red maintained Yellow maintained Green maintained Blue maintained A01ESSP354B + PEA01 A01MMASP352B + PEA01 A01MMBSP352B + PEA01 A01MMDSP352B + PEA01 A01MMESP352B + PEA01 A01MMFSP352B + PEA01 A01MXASP352B + PEA01 A01MXBSP352B + PEA01 A01MXDSP352B + PEA01 A01MXESP352B + PEA01 A01MXFSP352B + PEA01 G OPTIONS 12A 250V versions or custom printing on mushroom head actuators : contact APEM. APEM www.apem.com G-11 A01 series Mushroom head pushbutton switches Panel cut-out Ø 16 (.630) • Prominent 24 mm (.944) dia. or optional 40 mm (1.575) dia. mushroom actuators • Momentary and maintained functions Momentary function versions are unmarked. Maintained function versions are twist release (arrows indicate direction of twist) • Various coloured mushroom actuators are available. 3 1 Ø24.00 (.945DIA) 19.00 (1.047) 2 0.50 (.020) 18.00 (.709) Operator 2.80 (.110) 18.00 (.709) Switch block Actuator Description Part No No of poles Part No 24mmØ 24mmØ 24mmØ 24mmØ 24mmØ 24mmØ 24mmØ 24mmØ 24mmØ 24mmØ 40mmØ 40mmØ 40mmØ 40mmØ 40mmØ 40mmØ 40mmØ 40mmØ 40mmØ 40mmØ Black momentary Red momentary Yellow momentary Green momentary Blue momentary Black maintained Red maintained Yellow maintained Green maintained Blue maintained Black momentary Red momentary Yellow momentary Green momentary Blue momentary Black maintained Red maintained Yellow maintained Green maintained Blue maintained A01MMA A01MMB A01MMD A01MME A01MMF A01MXA A01MXB A01MXD A01MXE A01MXF A01MMA SP3 A01MMB SP3 A01MMD SP3 A01MME SP3 A01MMF SP3 A01MXA SP3 A01MXB SP3 A01MXD SP3 A01MXE SP3 A01MXF SP3 Single pole Double pole Three pole Four pole A0151BUL A0152BUL A0155BUL A0153BUL G-12 D ❷ ❶ G C Ø40.00 (1.575 DIA) 8.40 (.330) 42.00 (1.654) OPTION : SP3 VERSION Option : SP3 version www.apem.com APEM A1-A01 series Industrial controls Accessories 29.80 (1.173) 23.80 (.937) 12.00 (.472) Ø25.00 (.984 DIA) Ø16.00 (.630DIA) Ø22.00 (.866 DIA) 18.15 (.715) 11.00 (.433) +0.20 20.60 0.00 +.008 (.811 .000) 12.00 (.472) Ø16.00 (.630DIA) 23.80 (.937) 20.40 (.803) 18.10 (.712) 23.80 (.937) 20.40 (.803) Ø16.00 (.630DIA) Dark grey plastic material - supplied with sealing washer 18.10 (.712) FLUSH MOUNTING BEZELS +0.20 20.60 0.00 (.811 +.008 .000 ) Rectangular A01FM1 Square A01FM (.874 Round A01FM2 Ø25.00 (.984 DIA) Ø16.00 (.630DIA) Ø22.00 (.866 DIA) Metal versions 18.15 (.715) FLUSH MOUNTING BEZELS +0.20 22.20 0.00 +.008 .000 ) +0.20 26.70 0.00 (1.051 +.008 .000 ) 11.00 (.433) +0.20 22.20 0.00 +.008 .000 ) (.874 Round, anodised aluminium A01FMM Round, matt black A01FMMG PCB SOCKET 18.00 (.708) 7.65 (.301) 7.65 (.301) 0.80 (.031) 6.00 (.236) 10.25 (.403) 6.00 (.236) 18.00 (.708) 5.00 (.196) Single pole, non illuminated Double pole, non illuminated Single pole, illuminated Double pole, illuminated Indicator Single pole, E-stop Double pole, E-stop 4.25 (.167) 1.10 (.043) A01PC1 A01PC2 A01PC3 A01PC4 A01PC5 A01PC6 A01PC7 G 4.25 (.167) 24.00 (.945) 13.65 (.537) Rectangular A01FG1 APEM 18.00 (.708) 24.00 (.945) 12.00 (.472) 24.00 (.945) 9.00 (.354) 13.50 (.531) 13.50 (.531) FLAPGUARDS 13.65 (.537) Square/round A01FG2 www.apem.com G-13 A1-A01 series Industrial controls Accessories METAL GUARDS ➞ Slot as alternative to Ø 2 mm hole - Material : 1 mm thick aluminium. 12.00 (.472) 18.00 (.708) 12.00 (.472) Ø19.60 (.771 DIA) 18.20 (.717) 24.00 (.944) 10.15 (.399) Ø2.00 (.078DIA) Ø16.00 (.630DIA) Ø16.00 (.630DIA) Rectangular A01MG1 ANTI ROTATION RING 18.20 (.717) 18.00 (.708) 18.20 (.717) Ø18.10 (.712 DIA) Ø16.05 (.631DIA) Round, natural A01MG2 Matt black A01MG2G Square A01MG Recommended to prevent product rotation 14.75 (.580) A01LW 18.00 (.708) ALUMINIUM SCREENS 2.00 (.078) For illuminated pushbuttons Ø15.00 5.00 (.197) (.591 DIA) Ø3.00 For non-illuminated pushbuttons A0163AL Ø15.00 5.00 (.197) (.591 DIA) 18.00 (.708) Ø16.00 (.629DIA) A0163AL1 SWITCHBLOCK TERMINAL GUARDS 10.50 10.00 (.413) (.393) 20.75 (.816) 20.75 (.816) 6.00 (.236) 7.35 (.289) 7.45 (.293) 14.85 (.584) 2 way A01RTC2 20.75 (.816) 8 way A01RTC8 BLANKING PLUGS 24.0 (.946) 18.0 (.709) Round A0133 RESISTOR ASSEMBLY Square A0132 18.0 (.709) Ø18.0 (.709 DIA) 18.0 (.709) G 8.50 (.334) 10.50 10.00 (.413) (.393) Rectangular A0131 Resistor assembly - 2 stage illumination A0152B + RISSP (DIM) normally closed G-14 www.apem.com (BRIGHT) normally open APEM A1-A01 series Industrial controls Installation - tools Modular construction / panel mounting PANEL CUT-OUT PUSHBUTTONS & INDICATORS Round & square operators only SCREEN EMERGENCY STOP ROTARY LEVER SWITCHES Ø16.00 0.00/+0.30 (.629 DIA .000/+.011 ) LEGEND KEYLOCK SWITCHES REFLECTOR POLARISING DOT FIXING NUT 4.00 Maxi (.157 MAX) PANEL SEAL OPERATOR 7.25 (.285) LOCATING SLOT BULB 1.50 (.059) Rectangular operators only Ø16.00 0.00/+0.30 (.629 DIA .000/+.011 ) Ø2.00 (.078 DIA) LATCH SWITCH BLOCK 10.50 (.413) Max. panel thickness : 8 mm (.315) PANEL MOUNTING ASSEMBLY TO REMOVE BULB • Drill/punch hole shaped as above. Remove reflector/screen assembly. Use the bulb extractor 30-0002 to remove the bulb. • Assemble front operator through hole, fit fixing nut and tighten to a maximum torque of 0,8Nm using tool No 30-0001. • Wire chosen switch block as required and slide onto operator until latch engages. • Fit bulb if required using tool No 30-0002. • Snap screen onto reflector assembly with legend in between if required and snap onto front operator TAKING CARE TO LINE UP THE LOCATING SLOT WITH THE POLARISING DOT, and not to damage the seal. APEM SWITCH BLOCK To assemble switch block to front operator, TAKE CARE TO LINE UP SWITCH BLOCK WITH FRONT OPERATOR. Once in position, slide on to front operator. NB. : Ensure latch is fully engaged correctly onto the switch block. To remove switch block, depress the latch and slide the switch block off the operator. G FIXING NUT KEY BULB REMOVER 30-0001 30-0002 www.apem.com G-15
A0101X 价格&库存
很抱歉,暂时无法提供与“A0101X”相匹配的价格&库存,您可以联系我们找货
A0101X
库存:9
A0101X
  • 1+115.16663
  • 10+111.13647
  • 50+107.68949
  • 100+103.84679
  • 250+101.59740
库存:9
