TS-1D1S00A-1294
TS-1D1S00A-1294
    APEM(埃斐)
    TS-1D1S00A-1294
TS-1D1S00A-1294 数据手册
JOYSTICKS T- JS 12 23 TS TS series Proportional miniature thumb controls • non-contacting Hall effect technology DISTINCTIVE FEATURES One or two axis Analog, PWM or USB outputs IP67 Above panel sealing mounting Rear or drop-in mounting Pushbutton option ENVIRONMENTAL SPECIFICATIONS • Operating Temperature: -40 °C to +85 °C (-40 °F to +185 °F) • Storage Temperature: -40 °C to +85 °C (-40 °F to +185 °F) • Above Panel Sealing: IP67, IP69K1 (subject to mounting style & final specifications) • EMC Immunity Level: EN61000-4-3 • EMC Emissions Level: EN61000-6-3:2001 • ESD: EN61000-4-3 Level 2 (± 4 kv contact, ± 6 kv air) SENSOR SPECIFICATIONS • Technology: Hall effect sensors, single or dual • Supply Voltage Range: 5.00 V ± 0.01 VDC • Supply Current: 11 mA max • Ratiometric Output Options: See options • Reverse Polarity max: -10 V • Transient overvoltage max: 16 V • Start-up time: 15 ms max • Output Impedance: 2Ω • Return to Center Voltage Tolerance: ± 200 mV initial U.S. Patent #D816,169 S U.S. Patent #D732,047 S U.S. Patent #D816,169 S U.S. Patent #D734,138 S The company reserves the right to change specifications without notice. 1 JOYSTICKS TS series Proportional miniature thumb controls • non-contacting Hall effect technology MECHANICAL SPECIFICATIONS • Operating Force: 3.1 N ± 0.5 N (0.70 lbf ± 0.11 lbf)2 • Maximum Vertical Load: 200 N (45 lbf)2 • Maximum Horizontal Load: 150 N (33.7 lbf)2 • Mechanical Angle of Movement: 50° X & Y axis (subject to limiter plate) • Expected Life: 1 million cycles • Mass/Weight: 18.25 g ± 5.0 g (0.64 oz ± 0.18 oz) • Lever Action (centering): Spring  ll options are IP68 and IP69K rated, however drop-in mounting does not prevent A panel ingress. 2 Force applied to the top of the castle cap. 1 • Metal threaded Housing: Black oxide plated brass • Boot: Silicone • Terminal: Brass with silver plating • Contact Resistance: 100 mΩ max • Insulation Resistance: 100 MΩ min. 500 VDC • Dielectric Strength: 250 VAC /1 minute • Contact Arrangement: 1 pole 1 throw • Stop Strength: Max 3 kgf vertical static load for 15 seconds • Vibration Resistance: MIL-STD-202F METHOD 201A • Shock Resistance: MIL-STD-202F METHOD 213B • Handles: 1, 2, 3, E, F, G - Glass filled nylon 4, 5, 6, 7, 8 - Silicone B, C, D - Thermoplastic elastomer H - Polycarbonate LED SPECIFICATIONS (OPTION H HANDLE) APEM products may be recycled at end-of-life for the re-claiming of valuable metal components. CONNECTIONS WIRING SPECIFICATION (Termination options 1 & 2) 2 • Rating: 50 mA, 12 VDC. • Storage Temperature: -30 °C to +85 °C (-22 °F to +158 °F) • Body: Glass filled nylon 2 • Electrical Life: 100,000 cycles • Operating Temperature: -25 °C to +70 °C (-4 °F to +158 °F) MATERIALS 1 PUSHBUTTON SWITCH SPECIFICATIONS (OPTION 6 HANDLE) Black Ground & button common, or LED common Red Power (5 V)1 Blue X axis output (alpha) Yellow Y axis output (alpha) Orange Pushbutton switch (option 6 handle) or LED supply (option H handle) 2 2 Blue/White Stripe X axis output (beta) Yellow/Black Stripe Y axis output (beta) Red/White Stripe Power (5 V) (beta) Black/White Stripe Ground (beta)  all sensor and LED supply (LED control option 1) H User controllable (LED control option 2) LED CONTROL OPERATING VOLTAGE OPERATING CURRENT 1 – ON, driven by joystick supply voltage - 25-30 mA 2 – User controlled 5V 25-30 mA Proportional miniature thumb controls • non-contacting Hall effect technology JOYSTICKS TS series NEW OPTIONS AVAILABLE PLASTIC THREADED HOUSING LED ILLUMINATION OPTION H HANDLE MOUNTING PLASTIC HOUSING - REAR MOUNT OPTION CUTOUT PLASTIC HOUSING - REAR MOUNT OPTION CUTOUT PLASTIC HOUSING - DROP-IN PLASTIC CUTOUT HOUSING - DROP-IN OPTION CUTOUT DIMENSIONS Ø25.65 (1.01) Ø2.87 (0.113) 4 x PUSH IN CONNECTORS 4 x 1/2 FH SS PHIL SCREW Ø25.65 (1.01) Ø2.87 (0.113) CHAMFERED FOR #4 FLAT HEAD SCREW (4 PLACES) 24.64 (0.97) 24.64 (0.97) DROP-IN BEZEL 1.00 (0.04) x 45º CHAMFER O-RING REAR MOUNT BEZEL 24.64 (0.97) 24.64 (0.97) • The under panel depth for the Drop-in configuration is 16.02 mm (0.631 in). • The maximum panel thickness for the Rear Mount configuration is 2.032 mm (0.08 in). • Mounting screws can be driven to a recommended torque of 4 lbf. METAL THREADED HOUSING - DROP-IN OPTION CUTOUT DIMENSIONS METAL THREADED HOUSING - DROP-IN CUTOUT R17.17 x 2 (0.063) 2X R1.6 .063 11.94 .470 PLASTIC THREADED HOUSING - DROP-IN CUTOUT FIG. 5 R17.17 2X (0.063) 11.94 .470 11.94 (0.47) 25.02 .985 Ø25.02 (0.985) 2X R1.6 .063 11.94 (0.470) 25.02 .985 ( NUT 25.02 0.985) • The under panel depth for the Metal Threaded Housing configuration is 14.55 mm (0.573 in). • The under panel depth for the Plastic Threaded Housing configuration is 14.55 mm (0.573 in). • Mounting nut can be tightened to a recommended torque of 10 in-lb. • Mounting nut can be tightened to a recommended torque of 10 in-lb. 3 JOYSTICKS TS series Proportional miniature thumb controls • non-contacting Hall effect technology BUILD YOUR PART NUMBER TS MOUNTING OPTIONS SERIES TERMINATION2 N None D Drop-in R Rear mount A Drop-in and Rear Mount T Threaded housing, Metal P Threaded housing, Plastic HANDLE1 0 None 6 Pushbutton D Conical, elastomer 1 Castle 7 Mushroom1 E Quadcave 2 Winged Hat 8 Low Profile1 F Puck 3 Conical A Handles 1, 2, 3 G Roller 4 Finger Tip B Castle, elastomer H 5 Round Jog C Winged Hat, elastomer Castle, LED illumination1-2 1 22 AWG PTFE, 25 cm ± 1.27 cm 2-1 2 28 AWG PTFE, 25 cm ± 1.27 cm 2-2 3 72” Overmold Cable with USB Male Type Connector 4 2.54 mm (0.100”) Pitch TE Connector 5 2.54 mm (0.100”) Pitch TE Connector with 10” Mating Harness 0 V to 5 V 01 0.25 V to 4.75 V 02 0.5 V to 4.5 V 03 1 V to 4 V 04 0 V to 5 V - Sensor 1 0 V to 5 V - Sensor 2 05 0.25 V to 4.75 V - Sensor 1 0.25 V to 4.75 V - Sensor 2 06 0.5 V to 4.5 V - Sensor 1 0.5 V to 4.5 V - Sensor 2 07 1 V to 4 V - Sensor 1 1 V to 4 V - Sensor 2 08 0 V to 5 V - Sensor 1 5 V to 0 V - Sensor 2 09 0.5 V to 4.5 V - Sensor 1 4.5 V to 0.5 V - Sensor 2 10 0.25 V to 4.75 V - Sensor 1 4.75 V to 0.25 V - Sensor 2 11 1 V to 4 V - Sensor 1 4 V to 1 V - Sensor 2 12 Customer specified 13 PWM 14 USB (Game Controller) 15 Joyball (Cursor emulation) U Single axis S Square G Guided feel P Plus LED CONTROL OUTPUT OPTIONS 4 00 LIMITER BLANK 1 ON, driven by joystick supply voltage 6 2 User controlled 7 POWER SUPPLY OPTIONS A Single B Independent No illumination LED COLOR BLANK 5 BB Blue RR Red Mushroom and Low Profile handles not available with P (threaded housing, plastic) or T (threaded housing, metal) housing options. Contact factory if USB output is needed with illuminated castle actuator. 2-1 Wires are thick, robust, and best suited for stand alone applications. 2-2 Wires are thin and best suited for tightly constrained wire routing. 3 Contact factory for PWM configuration. 4 Output voltage is ratiometric to supply voltage. 5 Only available on dual output. Not available with Handle 6 (Pushbutton). Not available with termination options 4 or 5. 6 LED control is driven by joystick supply voltage. Illumination is constantly on 7 LED requires independent 5V supply. Illumination is user controlled. 1 1-2 4 No illumination JOYSTICKS TS series Proportional miniature thumb controls • non-contacting Hall effect technology PLASTIC HOUSING 17.17 (0.676) PIN INDICATES +Y DIRECTION TOP VIEW 19.20 (0.75) 23.00 (0.91) 33.27 (1.31) 10.00 - 13.00 (0.40 - 0.50) 25.40 (1.00) 29.70 (1.17) 8 7 6 5 Top view D LOCATING FEATURE, Y+ METAL THREADED HOUSING C 17.17 (0.676) 11.81 .47 Ø24.89 (0.98) 17.17 (0.676) 33.12 (1.304) 10.00 - 13.00 (0.40 - 0.50) 33.12 (1.304) 24.89 .98 Bottom view B 11.81 (0.465) Ø24.89 (0.98) LOCATING FEATURE, Y+ Ø32.77 (1.29) 11.81 UNLESS (0.465) 10.00 - 13.00 (0.40 - 0.50) DIMENS TOLERA .X .03 .XX .0 .XXX . .XXXX A 8 Ø32.77 (1.29) 7 LOCATING FEATURE, Y+ 6 5 Top view 4 :C MATERIA FINISH FORM 6 7 8 D 5 LOCATING FLAT, Y+ PLASTIC THREADED HOUSING 35.56 1.40 17.16 C .68 Bottom view 34.84 1.37 B MINIMUM PANEL THICKNESS: .125" 10.1 .40 UNLESS OTHERWISE SPECIFIED: 32.77 A 1.29 LOCATING FLAT, Y+ DIMENSIONS ARE IN INCHES TOLERANCES: .X .030 .XX .010 .XXX .005 ANGLES 1 .XXXX .0005 FRACTIONS 1/32 Top view 35.56 1.40 MATERIAL FINISH FORM NO.: EF-301 6 7 8 3RD ANGLE PROJECTION : CRITICAL DIMENSIONS 17.16 .68 4 5 34.84 1.37 MINIMUM PANEL T 10.1 .40 32.77 1.29 35.56 1.40 LOCATING FLAT, Y+ 5 JOYSTICKS TS series Proportional miniature thumb controls • non-contacting Hall effect technology HANDLE OPTIONS HANDLE OPTIONS 1. CASTLE B. CASTLE (ELASTOMER) 2. WINGED HAT C. WINGED HAT (ELASTOMER) Ø17.17 .676 (0.676) 4. FINGER TIP 3. CONICAL D. CONICAL (ELASTOMER) Ø17.42 .686 (0.686) Ø17.30 .681 (0.681) Ø18.36 .723 (0.723) 29.69 1.169 (1.169) 19.20 .735 (0.75) 19.84 .781 (0.781) 1 Castle B Castle (elastomer) 20.35 .801 (0.801) 2 Winged hat C Winged hat (elastomer) 5. ROUND JOG 3 Conical D Conical (elastomer) 6. PUSHBUTTON Ø17.22 .678 (0.678) REV. Ø17.65 Ø.695 (0.695) A REV. DESCRIPTION A RELEASE INITIAL 24.08 .948 (0.948) 4 Fingertip 8. LOW PROFILE 7. MUSHROOM 7 8 ECN DESCRIPTION DATE ECN INITIAL RELEASE 11/10/16 4645 Ø20.32 GT 11/10/16 .800 (0.800) INITIALS DATE INITIALS 4645 6 5 4 3 REV GT REV. Ø15.24 .600 (0.600) D 19.99 .787 (0.787) DESCRIPTI A 20.27 .798 (0.798) INITIAL RELEA 14.88 .586 (0.586) PIN INDICATES +Y DIRECTION 5 Round jog 6 Pushbutton 7 Mushroom 8 Low profile C 20.55 (0.809) 20.55 (0.809) 17.16 (0.676) 17.16 (0.676) 19 .75 19.5 .77 18.60 (0.732) 18.60 (0.732) 18.89 (0.744) 18.89 (0.744) 17.4 .69 21.8 .86 B QUADCAVE PUCK PUCK QUADCAVE E Quadcave F Puck G Roller H Castle, LED illumination NAME UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES TOLERANCES: .X .030 .XX .010 .XXX .005 ANGLES 1 .XXXX .0005 FRACTIONS 1/32 A USB OPTIONS UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES TOLERANCES: .X .030 .XX .010 .XXX .005 ANGLES 1 .XXXX .0005 FRACTIONS 1/32 USB : GAME CONTROLLER : CRITICAL DIMENSIONS MATERIAL X.Xxxxx XX/XX/2017 CHECKED X.Xxxxx XX/XX/2017 ENG. APR. X.Xxxxx XX/XX/2017 3RD ANGLE PROJECTION : CRITICAL DIMENSIONS MATERIAL UNLESS OTHERWISE SPECIFIED: DATE NAME NAME DATE THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION OF APEM, INC. AND IS TENTED SUBJECT TO THE CONDITIONS THAT THE INFORMATION (A) BE RETAINED IN DIMENSIONS ARE IN INCHES CONFIDENCE (B) NOT BE REPRODUCED OR COPIED IN DRAWN TOLERANCES: DRAWN 11/10/16 11/10/16 WHOLE OR PART (C) NOT BE LEASED TO THIRD PARTY AND .X .030 MAN-MACHINE INTERFACE PRODUCTS (D) NOT BE8USEDOF OR INCORPORATED IN ANY PRODUCT MANUFACTURERS OF MAN-MACHINE INTERFACE PRODUCTSMANUFACTURERS .XX .010 970 PARK CENTER DR. VISTA, CA 92081 970 PARK CENTER DR. VISTA, CA 92081 EXCEPT UNDER EXPRESSED WRITTEN AGREEMENT WITH TEL:APEM, (760)INC. 598-2518 FAX: (760) 598-2524 .XXX .005 ANGLES 1 TEL: (760) 598-2518 FAX: (760) 598-2524 CHECKED .XXXX .0005 FRACTIONS 1/32 11/10/16 CHECKED 11/10/16 - - - - : CRITICAL DIMENSIONS ENG APPR. MATERIAL - TITLE: ENG APPR. 11/10/16 - SIZE THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION OF APEM, INC. AND IS TENTED SUBJECT TO THE CONDITIONS THAT THE INFORMATION (A) BE RETAINED IN CONFIDENCE (B) NOT BE REPRODUCED OR COPIED IN WHOLE OR PART (C) NOT BE LEASED TO THIRD PARTY AND (D) NOT 7BE USED OR INCORPORATED IN ANY PRODUCT EXCEPT UNDER EXPRESSED WRITTEN AGREEMENT WITH APEM, INC. 5 4 3 USB: JOYBALL (CURSOR EMULATION) TITLE: ACTUATOR, TS, ACTUATOR, QUADCAVETS, QUADCAVE 11/10/16 FINISH AS MOLDED - FINISH COMMENTS: AS MOLDED COMMENTS: PROJECT/ACCT. NO. PLOTFILE: 7/5/2017 DWG. NO.SIZE PROJECT/ACCT. NO. FILE NO. MANUFACTURED • Features: - USB 2.0 HID compliant “game controller” device - Easy to install and operate - Functions determined by controlled application • Supplied wiring: USB Male Type A Connector with 72” overmolded cable 6 PLOTFILE: 7/5/2017 DWG. NO. REV REV FILE NO. MANUFACTURED Cursor Emulation option is widely used in shipboard and military applications. • Features: - HID compliant “pointing device” - Plug-and-play with USB option • Supplied wiring: USB Male Type A Connector with overmolded cable TITLE: SIZE PROJECT/A PLOTFILE: 4 FILE NO. SCALE: 1.5 FORM NO.: EF-301 6 MANUFACTURERS OF M 970 PARK CENTER DR. V TEL: (760) 598-2518 FA B COMMENTS: FINISH A A5210 Featuring USB 2.0 HID compliant interface. A APEM’s USB The cursorA emulation option converts a multi-axis A5210 A SCALE: 1:1 DO NOT SCALE SHEET 1 OF 1 FORM NO.: EF-300 SCALE: 1:1 DO NOT SCALE DRAWING SHEET 1 OF 1 DRAWING FORM NO.: EF-300 joysticks are recognized as standard HID “game controller” joystick into a mouse or cursor control device 2 4 3 1 2 4 3 1 devices. Adhering to the HID specification, APEM’s USB joysticks • Applications: The cursor emulation option is are plug-and-play with most versions of Windows. Joystick ideal for vehicle applications subjected to dirt button and axis assignments are dependent upon the controlled and high vibration which makes operating a application. traditional cursor control device difficult. The - 5 DATE DRAWN Proportional miniature thumb controls • non-contacting Hall effect technology 5.0 5.0 4.5 4.5 4.5 4.0 4.0 4.0 4.0 3.5 3.0 2.5 2.0 1.5 1.0 3.5 3.0 2.5 2.0 1.5 1.0 2.5 2.0 1.5 1.0 0.5 0 0 0 TRAVEL (º) MAX MIN TRAVEL (º) MAX 3.5 3.0 2.5 2.0 1.5 1.0 0.5 MIN TRAVEL (º) 0 MAX MIN Option 02 Option 01 5.0 4.5 4.5 4.0 4.0 4.0 4.0 3.0 2.5 2.0 1.5 1.0 3.5 3.0 2.5 2.0 1.5 1.0 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0.5 0.5 0 0 0 MIN TRAVEL (º) MAX MIN Option 04 TRAVEL (º) MAX OUTPUT VOLTAGE (V) 5.0 4.5 OUTPUT VOLTAGE (V) 5.0 4.5 3.5 3.5 3.0 2.5 2.0 1.5 1.0 MIN TRAVEL (º) 0 MAX MIN Option 06 4.5 4.0 4.0 4.0 4.0 2.5 2.0 1.5 1.0 3.0 2.5 2.0 1.5 1.0 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0.5 0.5 0 0 0 MIN TRAVEL (º) MAX MIN Option 08 TRAVEL (º) MAX OUTPUT VOLTAGE (V) 5.0 4.5 OUTPUT VOLTAGE (V) 5.0 4.5 OUTPUT VOLTAGE (V) 5.0 4.5 3.0 TRAVEL (º) MAX Option 07 5.0 3.5 MAX 0.5 Option 05 3.5 TRAVEL (º) Option 03 5.0 OUTPUT VOLTAGE (V) OUTPUT VOLTAGE (V) 3.0 0.5 Option 00 OUTPUT VOLTAGE (V) 3.5 0.5 MIN OUTPUT VOLTAGE (V) 5.0 4.5 OUTPUT VOLTAGE (V) 5.0 OUTPUT VOLTAGE (V) OUTPUT VOLTAGE (V) VOLTAGE OUTPUT OPTIONS 1 3.5 3.0 2.5 2.0 1.5 1.0 0.5 MIN Option 09 TRAVEL (º) Option 10 MAX 0 MIN TRAVEL (º) MAX Option 11 Sensor 1 Sensor 2 CONNECTOR TERMINATION OPTION PINOUT SPECIFICATION 1 TE 3-647166-5 TE 3-647166-7 PIN 1 Y (alpha) Pushbutton / LED PIN 2 5 VDC 1 GND / Pushbutton common / LED common PIN 3 X (alpha) X (alpha) PIN 4 GND/ Pushbutton common / LED common Y (beta) PIN 5 Pushbutton / LED Y (alpha) PIN 6 - 5 VDC PIN 7 - X (beta) Voltage outputs are ratiometric to supply voltage • Single output configurations feature a five position TE 3-647166-5 connector. • Dual output configurations feature a seven position TE 3-647166-7 connector. • A mating harness is not included, but may be specified for single output configurations at the time of order for an additional charge. • The five function harness is part number 505-499. • The seven function harness is part number 505-500. 7 JOYSTICKS TS series
TS-1D1S00A-1294 价格&库存
很抱歉,暂时无法提供与“TS-1D1S00A-1294”相匹配的价格&库存,您可以联系我们找货
