3000 series
30
Y-
JO
JOYSTICKS
08
23
00
Robust proportional fingertip controllers •
non-contacting Hall effect technology
DISTINCTIVE FEATURES
One, two or three axis
Analog - PWM
CAN J1939 & CANopen
Low profile less than 20 mm below panel depth*
5 V or 3.3 V operation
Metal mechanism
ENVIRONMENTAL SPECIFICATIONS
• Operating Temperature: -25 °C to +70 °C
• Storage Temperature: -40 °C to +70 °C
• Sealing: IP66 (above panel subject to handle and final specification)
• EMC Immunity Level: EN61000-4-3 (extended)
• EMC Emissions Level: EN61000-6-3:2001, CISPR 22:2005,
Class B 30 MHz-11GHz
• ESD: EN61000-4-2 (extended)
ELECTRICAL SPECIFICATIONS
• Output Voltage Range: ±10% x V to ±50% x V
• Output at Center: V/2 ±(5% x gain)
• Power Supply: 5 V ±0.5 V transient free; 3.3 V ±0.1 V (configuration 2)
• Output impedance: 10 Ω
• Overvoltage max: +20 V
MECHANICAL SPECIFICATIONS
• Operating Force: 1.3 N (2.86 lbf) (Dependant on configuration)
• Maximum Load: 400 N (89.921 lbf) (subject to handle)
• Mechanical Angle of Movement: 36° X & Y axis (subject to limiter);
50° Z axis (subject to handle)
• Expected Mechanical Life: 10 million lifecycles
• Mass/weight: 100 g (3.53 oz) nominal
• Lever Action (centering): Spring
The company reserves the right to change specifications without notice.
*Non CAN options only
1
JOYSTICKS
3000 series
MATERIALS
TERMINATION (CAN OUTPUTS
ONLY)
• Shaft: Stainless steel
• Boot: Neoprene
• 3000 series joysticks configured with CAN
outputs are supplied with on-board 6 way
connector
• Handles:
BL, E, Q, AL - Nylon
AR - Aluminum
K - ABS
T - Stainless steel
• Header specifications: JST S6B-PH-K-S(LF)(SN)
- 6 position, 2mm pitch, single row header (Fig 1)
Fig. 1
CONNECTIONS
Pin 1 7 to 35Vdc Power Supply
The analog and PWM joystick is fitted, as standard,
with 150mm long BS6360 rated cables and an industry
standard 2.5mm pitch connector(s). Further nonstandard connectors and cable options are available
upon request.
Pin 2 0V Ground
Pin 3 ID Select MSB / Node ID Select MSB
Pin 4 ID Select LSB / Node ID Select LSB
Pin 5 CAN HI
Pin 6 CAN LO
Pin 6
CONFIGURATIONS 1 & 2
Joysticks are supplied with a seven way connector as
standard. If the joystick is specified with a pushbutton
handle, the connector will be nine way.
Pin 1
Pin 2 0V Ground
Select MSB
JSTIDS6B-PH-K-S(LF)
(SN) header
Pin 5 CAN HI
Pin 6 CAN LO
HEADER PINOUT AND MATING WIRE HARNESS COLOR
PIN
FUNCTION
COLOR
1
0V
Black
2
Center Tap Reference
Green
HEADER PINOUT
Z Axis Output - Where Specified
Purple
4
Y Axis Output
Yellow
JST B6B-PH-S(LF)
(SN)
HEADER PIN #
5
X Axis Output- Where Specified
Blue
1
3
6
+V
Red
7
Center Detect
Orange
8
Pushbutton
Orange
9
Pushbutton
Orange
CONFIGURATIONS 3 & 4
Joysticks are supplied with two completely independent
cable assemblies for a truly dual system.
PIN
FUNCTION
COLOR
1
0V
Black
2
Green
3
No connection
4
Y Axis Output
Yellow
5
Blue
6
+V
Red
7
No connection
For details on configuration 5 pinout, please contact
Customer Support.
2
DEFINITION
CAN BUS
FUNCTION
CANOPEN
FUNCTION
Supply power
(7 to 35 VDC)
Supply power
(7 to 35 VDC)
2
Ground
Ground
3
ID select MSB
Node ID select MSB
4
ID select LSB
Node ID select LSB
5
CAN Hi
CAN Hi
6
CAN Lo
CAN Lo
MOUNTING)
When mounting the joystick, care should be taken to site it in a position that does not make it vulnerable to damage
when in use. If the joystick is intended for use in a handheld enclosure then care must be taken to protect the joystick
from damage caused by dropping. Basic precautions such as mounting it at the lightest end of the enclosure so it
doesn’t hit the ground first or by protecting it with a guard should always be implemented for long term reliability.
The body of the joystick, on the underside of the panel, must not be subject to water spray, excessive humidity or dust.
Some handles may be larger than some panel cut-outs. This may restrict the choice of mounting and bezel options.
Please refer to APEM for assistance.
DROP-IN MOUNT CUT-OUT AND INSTALLATION
• The joystick is dropped into the panel cut-out.
• For panel thickness of
很抱歉,暂时无法提供与“3140SAL6475”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+5250.219951+679.25610
- 5+4578.500715+592.35128
- 10+4315.6937110+558.35018
