FG2168
FG2168
    APEM(埃斐)
    FG2168
FG2168 数据手册
FG series FIXED GRIP™ hand controllers Distinctive features and specifications ENVIRONMENTAL  USB outputs available  Rugged hand operation  Above panel sealing up to IP65  Custom configured STANDARD SWITCH CHARACTERISTICS/RATINGS • Electrical Resistive Load: 5A • Operating Temperature: -40⁰C to 85⁰C (-40⁰F to 185⁰F) • Storage Temperature: -40⁰C to 85⁰C (-40⁰F to 185⁰F) • Sealing: up to IP65 • EMC Immunity Level (V/M): IEC 61000-4-8:2009 • EMC Emissions Level: IEC 61000-4-3:2006 • ESD: IEC 61000-4-2:2008 (depending on the chosen switch) • Electrical Inductive Load: 3A (depending on the chosen switch) • Low Level: 10mA @ 30mV (depending on the chosen switch) • Electrical Life: 1 million cycles 5A @ 28 VDC NOTE: All values are nominal resistive snap-action (depending on the chosen switch) • Mechanical Life: 1,000,000 cycles • Action: Momentary, snap-action • Operating Force: 7.5N±2.0N (1.69lbf±0.11lb) • Total Travel: 0.080 inch max • Over Travel: 0.010 inch min FG SERIES N M P D None Momentary Proportional¹ DP/DT² Handle 1 Oval NOTES: 1 2 1 3 A B X None Mechanical paddle Index Trigger Guard 1 2 3 Termination Deadman Lever Index Trigger None Red Black Mounting Hardware 1 2 None Plate and screws 0.5V to 4.5V output Double pole/double throw Above panel sealing up to IP65 available (dependent on handle configuration). Mounting accessories. Screws: 1/4-20 x 1.25in stainless steel screws, lock washers, and hex nuts. Note: The company reserves the right to change specifications without notice. APEM www.apem.com Sealing 22AWG 10in PTFE 28AWG 10in PTFE Customer specified A B None Sealing * Electrical Output or Interface 1 2 5 Voltage output USB, Game Controller USB, Cursor Emulation FG series FIXED GRIP™ hand controllers Overview HANDLE / INDEX TRIGGER INDEX TRIGGER WITH TRIGGER GUARD INDEX TRIGGER NO INDEX TRIGGER 99.10 3.90 14.08 .55 20.32 .80 1/4-20 X 0.75 SHCS 4 PLACES 167.64 6.60 49.16 1.94 14.87 .59 20.96 .83 NOTES 1. Dimensions are in mm/(inch). 2. FACEPLATE: The FG series FIXED GRIP hand controller features a modular faceplate that can be customized for specific applications. Ambidextrous for most configurations, the faceplate may be populated with a variety of thumb actuated switches including momentary pushbuttons, latching pushbuttons, two or three way toggle switches, 4 or 5 way trims, and miniature proportional joysticks. Every FG faceplate is custom configured to order. Please consult factory for options. 3. INDEX TRIGGER The FG series FIXED GRIP controllers may be equipped with or without an index trigger switch. Index trigger configuration options include a single pole normally open momentary switch, a double pole double throw tactile switch, or a proportional Hall effect device. Index Trigger Options: N: None M: Momentary, single pole normally open P: Hall effect, 0.5V to 4.5V proportional output D: Double pole, double throw 4. DEADMAN LEVER Deadman Lever Options: 1: None 2. Mechanical Paddle Note: The company reserves the right to change specifications without notice. www.apem.com APEM FG series FIXED GRIP™ hand controllers Overview USB USB Featuring USB 2.0 HID compliant interface, APEM’s USB joysticks are recognized as standard HID “game controller” devices. Adhering to the HID specification, APEM’s USB joysticks are plug-and-play with most versions of Windows. Joystick button and axis assignments are dependent upon the controlled application. FEATURES • USB 2.0 HID compliant “game controller” device • Easy to install and operate • Functions determined by controlled application SUPPLIED WIRING USB: USB Male Type A Connector with overmolded cable CURSOR EMULATION The Cursor Emulation option converts multi-axis joystick output into a mouse, trackball, or cursor control device. The joystick’s internal microprocessor converts absolute axis position into a cursor velocity, which is translated as a relative trackball or mouse position. APPLICATIONS The Cursor Emulation option is ideal for vehicle applications subjected to dirt and high vibration which makes operating a traditional cursor control device difficult. The Cursor Emulation option is widely used in shipboard and military applications. FEATURES • HID compliant “pointing device” • Plug-and-play with USB option SUPPLIED WIRING USB: USB Male Type A Connector with overmolded cable Note: The company reserves the right to change specifications without notice. APEM www.apem.com FG_JOYST1806R1US Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Apem: FG2035 FG2168
FG2168 价格&库存
很抱歉,暂时无法提供与“FG2168”相匹配的价格&库存,您可以联系我们找货
