67A-DF-3C-060C
67A-DF-3C-060C
    GRAYHILLINC.
    67A-DF-3C-060C
67A-DF-3C-060C 数据手册
Joysticks SERIES 67A Hall Effect Joystick FEATURES • Proportional output • Shaft and panel seal to IP67 • Compact: 1-inch square flange • Long operational life • RoHS compliant APPLICATIONS • Medical • Military vehicles and devices • Mobile electronics for outdoor use DIMENSIONS in inches (and millimeters) TRIANGLE INDICATES +Y DIRECTION FOR JOYSTICK OUTPUT 1.300 [33,02] SQUARE C-BORE, 4 PLACES .180 [4,57] .070 [1,78] 1.000 [25,4] SQUARE 1.000 [25,4] SQUARE .500 [12,7] TYP. [ 1.007 .003 25,58 0,07] 4X HOLE FOR #2 SCREW, SELF-TAPPING OR MACHINE THREAD R.100 [2,54] 4 PLACES .100 [2,54] 4 PLACES RECOMMENDED PANEL CUTOUT Joysticks .520 [13,21] SHAFT TRAVEL 20 ANY DIRECTION 1.115 [28,32] .120 [3,05] MOUNTING SURFACE .727±.015 [ 18,47 0,38 1.000 [25,4] .087 [2,21] SHAFT PIVOT POINT ] .570 .015 [14,48 0,38] PIN HEADER VERSION CONNECTOR IS AMP, P/N 7-215083-6 +Y TRIANGLE MARKING ON MOUNTING BRACKET INDICATES +Y DIRECTION FOR JOYSTICK OUTPUT JOYSTICK OUTPUT WAVEFORM (0,80) 80 (0,1) (-80,0) SLEEP (-1,0) -X ZONE +X (1,0) -20 -5 JOYSTICK OUTPUT ALONG X OR Y AXIS JOYSTICK OPERATIONAL LIMITS 5 (80,0) 20 DEGREES SHAFT TRAVEL, ° (0,-1) NOT TO SCALE (0,-80) -Y -80 NOT TO SCALE Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Joysticks SPECIFICATIONS Electrical Ratings Supply Voltage (VVD): 3.3V ± .0.3V High Level Input Voltage (VIH, Min): 0.7*VDD on SCL & SDA / 0.25*VDD+0.8 on Aln Low Level Input Voltage (VIL, Max): 0.3*VDD on SCL & SDA / 0.15*VDD on Aln Current Draw In Active Mode (IDDI): 3mA Maximum @ VDD = 3.3V Current Draw In Sleep Mode (IDD2): 100uA Maximum @ VDD = 3.3V Maximum Current Sunk By Any I/O Pin: 25mA Leakage Current: ±5 nA Typ., ±125 nA Max Low Level Output Voltage (VOL): 0.6V On INTn & SDA @ IOL = 6mA, @ VDD = 3.3V Measurement Frequency (Active Mode): 50 Samples/Sec Response Time, Active Mode (T1): 20ms* Response Time, Sleep Mode (T2): 80ms* Output @ Maximum Joystick Deflection (XMax, YMax): 80 Units Output With Joystick Shaft Released (Center Position): (0,0) Nominal Startup Time (TP, W): 300ms, Max Storage High Temperature: +100°C, Tested per IEC 68-2-2, Method Ba Physical & Mechanical Ratings Storage Low Temperature: -55°C, Vibration: Random, Tested per MIL-STD-810G, Tested per IEC 68-2-1, Method Aa Method 514.6, Procedure I Humidity: Tested per MIL-STD 202, Mechanical Shock: Tested per MIL-STD 202, Method 103B Method 213B Test Condition A Transit Drop: Tested per MIL-ST-810G, Method Humidity, 85/85: Tested per MIL-STD 202, Method 103B, 500 hours 516.6, Procedure II Solar Radiation: Tested per MIL-STD 810G, Method 505.5, Procedure II Terminal Strength: 10 lbs. Minimum, Tested per MIL-STD-202, Method 211A Chemical Resistance: Tested per Push-Out Force: 60 lbs. Minimum ISO 16750-5 Pull-Out Force: 60 lbs. Minimum Dielectric: Tested per MIL-STD 202G, Shaft Impact: 0.5 lbs. Weight dropped 20x Method 301 from height of 1m Insulation Resistance: Tested per MIL-STD Shaft Side-Load: 45 lbs. Minimum 202G, Method 302 Mounting Torque: 3-5 in-lbs recommended, 8 in-lbs. Maximum EMC Ratings Joystick Life: 1 million cycles minimum** Radiated Immunity: Tested per IEC 61000-4-3 Environmental Ratings Conducted Immunity: Seal: IP67, Tested per IEC 60529 Tested per IEC 61000-4-6 Altitude: Tested per MIL-STD 202, Radiated Emissions: Tested per ANSI C63.4 Method 105C Conducted Emissions: Thermal Shock: Tested per MIL-STD 202, Tested per EN 55022 Method 107G Electrostatic Discharge: Operating High Temperature: +85°C, Tested per IEC 61000-4-2 Tested per IEC 68-2-14, Test Na Power Frequency Magnetic Field: Operating Low Temperature: -40°C, Tested per IEC 61000-4-8 Tested per IEC 68-2-14, Test Na *Response time is the time from joystick movement to when new X,Y position data is available. **One cycle is defined as a complete revolution of the shaft around the fixed perimeter, or one actuation in each of the 4 main directions, with return to center between each actuation. ORDERING INFORMATION Grayhill Series Number Number of Axes: D = Dual Axis (X&Y) Knob Style: F = Fingertip 67A - DF- 3C - 030C Termination: C = .050 Cable with Connector, P = .050 Pin Header Cable Length: 020 = 2.0 inches through 6.0 inches (060). 1 inch increments Leave blank if pinned. Example: 67A-DF-3C-P Interface: C = 12C Voltage: 3 = 3.3V For prices and custom configurations, contact a local sales office, an authorized distributor, or Grayhill's sales department. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Optical Joysticks and Mechanical Encoders Block Diagram
67A-DF-3C-060C 价格&库存
很抱歉,暂时无法提供与“67A-DF-3C-060C”相匹配的价格&库存,您可以联系我们找货
67A-DF-3C-060C
  • 1+1249.948281+161.65230
