67A-DF-3C-030C
67A-DF-3C-030C
    GRAYHILLINC.
    67A-DF-3C-030C
67A-DF-3C-030C 数据手册
Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Joysticks SERIES 67A Hall Effect Joystick FEATURES • Proportional output • Shaft and panel seal to IP67 • Compact: 1-inch square flange • Long operational life • RoHS compliant APPLICATIONS • Medical • Military vehicles and devices • Mobile electronics for outdoor use DIMENSIONS in inches (and millimeters) TRIANGLE INDICATES +Y DIRECTION FOR JOYSTICK OUTPUT 1.300 [33,02] SQUARE C-BORE, 4 PLACES .180 [4,57] .070 [1,78] 1.000 [25,4] SQUARE 1.000 [25,4] SQUARE .500 [12,7] TYP. [ 1.007 .003 25,58 0,07] 4X HOLE FOR #2 SCREW, SELF-TAPPING OR MACHINE THREAD R.100 [2,54] 4 PLACES .100 [2,54] 4 PLACES RECOMMENDED PANEL CUTOUT Joysticks .520 [13,21] SHAFT TRAVEL 20 ANY DIRECTION 1.115 [28,32] .120 [3,05] MOUNTING SURFACE .727±.015 [ 18,47 0,38 1.000 [25,4] .087 [2,21] SHAFT PIVOT POINT ] .570 .015 [14,48 0,38] PIN HEADER VERSION CONNECTOR IS AMP, P/N 7-215083-6 +Y TRIANGLE MARKING ON MOUNTING BRACKET INDICATES +Y DIRECTION FOR JOYSTICK OUTPUT JOYSTICK OUTPUT WAVEFORM (0,80) 80 (0,1) (-80,0) SLEEP (-1,0) -X ZONE +X (1,0) -20 -5 JOYSTICK OUTPUT ALONG X OR Y AXIS JOYSTICK OPERATIONAL LIMITS 5 (80,0) 20 DEGREES SHAFT TRAVEL, ° (0,-1) NOT TO SCALE (0,-80) -Y -80 NOT TO SCALE Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Joysticks SPECIFICATIONS Electrical Ratings Supply Voltage (VVD): 3.3V ± .0.3V High Level Input Voltage (VIH, Min): 0.7*VDD on SCL & SDA / 0.25*VDD+0.8 on Aln Low Level Input Voltage (VIL, Max): 0.3*VDD on SCL & SDA / 0.15*VDD on Aln Current Draw In Active Mode (IDDI): 3mA Maximum @ VDD = 3.3V Current Draw In Sleep Mode (IDD2): 100uA Maximum @ VDD = 3.3V Maximum Current Sunk By Any I/O Pin: 25mA Leakage Current: ±5 nA Typ., ±125 nA Max Low Level Output Voltage (VOL): 0.6V On INTn & SDA @ IOL = 6mA, @ VDD = 3.3V Measurement Frequency (Active Mode): 50 Samples/Sec Response Time, Active Mode (T1): 20ms* Response Time, Sleep Mode (T2): 80ms* Output @ Maximum Joystick Deflection (XMax, YMax): 80 Units Output With Joystick Shaft Released (Center Position): (0,0) Nominal Startup Time (TP, W): 300ms, Max Storage High Temperature: +100°C, Tested per IEC 68-2-2, Method Ba Physical & Mechanical Ratings Storage Low Temperature: -55°C, Vibration: Random, Tested per MIL-STD-810G, Tested per IEC 68-2-1, Method Aa Method 514.6, Procedure I Humidity: Tested per MIL-STD 202, Mechanical Shock: Tested per MIL-STD 202, Method 103B Method 213B Test Condition A Transit Drop: Tested per MIL-ST-810G, Method Humidity, 85/85: Tested per MIL-STD 202, Method 103B, 500 hours 516.6, Procedure II Solar Radiation: Tested per MIL-STD 810G, Method 505.5, Procedure II Terminal Strength: 10 lbs. Minimum, Tested per MIL-STD-202, Method 211A Chemical Resistance: Tested per Push-Out Force: 60 lbs. Minimum ISO 16750-5 Pull-Out Force: 60 lbs. Minimum Dielectric: Tested per MIL-STD 202G, Shaft Impact: 0.5 lbs. Weight dropped 20x Method 301 from height of 1m Insulation Resistance: Tested per MIL-STD Shaft Side-Load: 45 lbs. Minimum 202G, Method 302 Mounting Torque: 3-5 in-lbs recommended, 8 in-lbs. Maximum EMC Ratings Joystick Life: 1 million cycles minimum** Radiated Immunity: Tested per IEC 61000-4-3 Environmental Ratings Conducted Immunity: Seal: IP67, Tested per IEC 60529 Tested per IEC 61000-4-6 Altitude: Tested per MIL-STD 202, Radiated Emissions: Tested per ANSI C63.4 Method 105C Conducted Emissions: Thermal Shock: Tested per MIL-STD 202, Tested per EN 55022 Method 107G Electrostatic Discharge: Operating High Temperature: +85°C, Tested per IEC 61000-4-2 Tested per IEC 68-2-14, Test Na Power Frequency Magnetic Field: Operating Low Temperature: -40°C, Tested per IEC 61000-4-8 Tested per IEC 68-2-14, Test Na *Response time is the time from joystick movement to when new X,Y position data is available. **One cycle is defined as a complete revolution of the shaft around the fixed perimeter, or one actuation in each of the 4 main directions, with return to center between each actuation. ORDERING INFORMATION Grayhill Series Number Number of Axes: D = Dual Axis (X&Y) Knob Style: F = Fingertip 67A - DF- 3C - 030C Termination: C = .050 Cable with Connector, P = .050 Pin Header Cable Length: 020 = 2.0 inches through 6.0 inches (060). 1 inch increments Leave blank if pinned. Example: 67A-DF-3C-P Interface: C = 12C Voltage: 3 = 3.3V For prices and custom configurations, contact a local sales office, an authorized distributor, or Grayhill's sales department. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Optical Joysticks and Mechanical Encoders Block Diagram
67A-DF-3C-030C 价格&库存
很抱歉,暂时无法提供与“67A-DF-3C-030C”相匹配的价格&库存,您可以联系我们找货
67A-DF-3C-030C
    67A-DF-3C-030C
    • 1+1124.161501+145.93444
    • 5+980.549435+127.29126
    • 10+924.3882510+120.00063
    • 25+854.9246325+110.98312
    • 50+805.7570150+104.60036
    • 100+759.31452100+98.57137
    库存:941
    67A-DF-3C-030C
