JOYSTICKS
H
T-
JS
12
23
S-
HS series
Micro switch 5-way thumb controls •
switching technology
DISTINCTIVE FEATURES
2, 4 & 5-way (5-way with pushbutton option) operation
Positive tactile feedback
MOM-OFF-MOM
Connectorized housing
Several handle options available
ENVIRONMENTAL SPECIFICATIONS
• Operating Temperature: -25 °C to +80 °C (-13 °F to +176 °F)
• Storage Temperature: -30 °C to +85 °C (-22 °F to +185 °F)
• Above Panel Sealing: Up to IP67 & IP69K (subject to mounting style
and final specifications)
ELECTRICAL SPECIFICATIONS
• Current Rating: Gold - 10 mA @ 30 VDC; Silver – 100 mA @ 30 VDC
• Insulation Resistance: Min 100 MΩ (250 VDC by insulation
resistance meter)
• Voltage Withstand: 500 VAC for 1 minute
• Contact Resistance: Max 200 mΩ
• Electrical Function: Mom-off-mom
MECHANICAL SPECIFICATIONS
• Operating Force: 5.0 N ± 1.0 N (1.12 lbf ± 0.22 lbf)
• Maximum Vertical Load: 200 N (45 lbf)
• Maximum Horizontal Load: 150 N (33.7 lbf)
• Mechanical Angle of Movement: 30°
• Expected Life: 300,000 lifecycles
• Mass/Weight: 17g (0.60 oz) (Option HS1DXXXA)
• Lever Action (centering): Spring
The company reserves the right to change specifications without notice.
1
JOYSTICKS
HS series
MOUNTING
MATERIALS
• Body: Glass filled nylon
• Metal threaded housing: Black oxide plated brass
PLASTIC HOUSING - DROP-IN CUTOUT
• Handles:
1, 2, 3 - Glass filled nylon
4, 5, 6, 7, 8 - Silicone
B, C ,D - Thermoplastic elastomer
PUSHBUTTON SWITCH
(OPTION 6 HANDLE)
• Electrical Life: 100,000 cycles
• Rating: 50 mA,12 VDC
• Terminal: Brass with silver plating
• Contact Resistance: 100 milliohms max.
• Insulation Resistance: 100 megohms min. 500 VDC
• Dielectric Strength: 250 VAC /1 minute
• The under panel depth for the Drop-in
configuration is 16.02 mm (0.631 in).
PLASTIC HOUSING - REAR MOUNT OPTION CUTOUT
• Contact Arrangement: 1 pole 1 throw
• Operation Force: 1.5 lbf
• Stop Srength: Max 3 kgf vertical static load for 15 seconds
• Operating temperature: -25 °C to +70 °C (-13 °F to +158 °F)
CONNECTIONS
CONNECTOR
POSITION
FUNCTION
WIRE HARNESS
1
Top Switch*
Orange
2
X+Switch
Blue
3
Y+Switch
Yellow
4
X-Switch
Blue/White
5
Y-Switch
Yellow/Black
6
Common
White
• The maximum panel thickness for the Rear
Mount configuration is 2.032 mm (0.08 in).
METAL THREADED HOUSING - DROP-IN CUTOUT
*Optional
TERMINATION
• Manufacturer: Molex
• Manufacturer part number: 501331-0607
• Product range: Pico-Clasp ™
• Circuits: Six
• Pitch: 1.00 mm
• Mating connector: Molex 501330-0600
2
• The under panel depth for the Metal Threaded
Housing configuration is 14.55 mm/(0.573 in).
BUILD YOUR PART NUMBER
HS
A
SERIES
MOUNTING STYLE
HANDLE
LIMITER
None
N
None
2
2-way
1
Castle
D
Drop-in
4
4-way
2
Winged Hat
R
Rear mount
3
Conical
A
4
Finger Tip
Drop-in and Rear
Mount
5
Round Jog
T
Metal
Threaded housing
6
Pushbutton
7
Mushroom1
8
Low Profile1
1: Not available with Metal
Threaded Housing (T)
TERMINATION
1
1.00 mm (0.039 in)
Pitch Molex Connector
2
1.00 mm (0.039 in)
with 10” Mating Harness
CONTACT
S
Silver Plated
G
Gold Plated
3
JOYSTICKS
HS series
JOYSTICKS
HS series
DIMENSIONS
HANDLE OPTIONS
1 Castle
5 Round jog
2 Winged hat
6 Pushbutton
OPTIONAL MATING HARNESS
• Wire type : 28 AWG 25 cm PTFE
• Connector: Molex 501330-0600
• The HS Series tactile toggle switch is fitted with a six
terminal Molex (501331-0607) connector.
• A mating harness is not included, but may be specified at
the time of order for an additional charge.
• The 4-function harness is part number 505-508.
• The 5-function harness, necessary for the Option 6 Handle is
part number 505-509.
4
3 Conical
7 Mushroom
4 Fingertip
6 Low profile
很抱歉,暂时无法提供与“HS1T24SA”相匹配的价格&库存,您可以联系我们找货
