84LS-AB2-112-N
84LS-AB2-112-N
    GRAYHILLINC.
    KEYPAD RUBBER 3X4" LOW PROFILE
84LS-AB2-112-N 数据手册
Standard Keypads Series 84LS Sealed, Low Profile Features • Waterproof Silicone Rubber • Easily Customized Legends • Audible, Tactile Contacts • Low Contact Resistance • Optional RFI/EMI Shielding • 3,000,000 Operations per Button Keyboards and Keypads Description The Series 84LS is the low profile version of Grayhill's popular Series 84S sealed keypads. These keypads are legended by epoxy ink printing the rubber key tops. Custom legends and colors are available at a nominal cost. The Series 84LS is offered with a choice of matrix or single pole/common bus circuitries and EMI shielding. Dimensions In inches (and millimeters) 3x4 Keyboard Matrix Output .750 (19,05) 3 EQ. SPS. TOL. NON-ACCUM. 3.100 ± .020 (78,74 ± 0,51) .425 (10,80) .100 (2,54) TYP. .525 (13,34) SWITCH POSITION IDENTIFICATION 1 2 3 4 5 6 7 8 9 10 11 12 .490 (12,45) SQ. .368 ± .015 (9,35 ± 0,38) .267 ± .015 (6,78 ± 0,38) .425 (10,80) TEMINAL PINS PULLED IN THESE LOCATIONS 1x4 Keyboard #6-32 MTG STUD 4 PLACES 1.500 .750 (38,1) (19,05) 1.500 .750 (38,1) (19,05) LABEL .800 (20,32) .350 (8,89) .350 (8,89) 1.650 (41,91) .357 (9,07) .207 (5,26) 2.350 ± .020 (59,69 ± 0,51) .100 (2,54) TYP. .225 (5,72) #6-32 MTG STUD 4 PLACES .025 ± .002 (0,64 ± 0,05) SQ. TERMINAL PINS LABEL .750 (19,05) 2 EQ. SPS. TOL. NON-ACCUM. .455 (11,56) SQ. PRINTABLE AREA Single Pole/Common Bus 1.650 (41,91) .100 (2,54) REF. TERMINAL PIN HEADER .100 (2,54) REF. TERMINAL PIN HEADER TERMINAL PIN IDENTIFICATION TERMINAL PIN IDENTIFICATION A H B J C K D L E M F N G A B C D E F G .098 (2,49) REF. TERMINAL PIN HEADER .098 (2,49) REF. TERMINAL PIN HEADER E D C B A Single Pole/Common Bus (ORIENTATED PER BOTTOM VIEW) 4.500 [ 114,3 ] SWITCH POSITION .563 INDENTIFICATION [14,29 ] .455 SQ. [11,56 ] R .050 4 PLACES [ 1,27 ] 3.875 [ 98,43 ] 2 3 .500 [ 12,7 ] 3 PLACES .352 [ 8,94 ] 1.125 3 EQ. SPS. [ 28,58 ] TOL. NON-ACCUM. 1 .800 (20,32) 4 .025 SQ. [ 0,64 ] TERMINAL PINS 1.125 [ 28,58 ] .660 SQ. [ 16,76 ] Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois .202 [ 5,13 ] .302 [ 7,67 ] .475 [ 12,07 ] .100 REF. [ 2,54 ] TERMINAL PIN HEADER #4-40 MTG STUD 8 PLACES .500 [ 12,7 ] .313 [ 7,94 ] LABEL 1.125 [ 28,58 ] 3 PLACES SPS. 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Standard Keypads Dimensions In inches (and millimeters) 4x4 Keyboard Matrix Output .750 (19,05) 3 EQ. SPS. TOL. NON-ACCUM. 3.100 ± .020 (78,74 ± 0,51) .425 (10,80) 1 2 3 4 5 6 7 8 9 10 11 12 13 14 .025 ± .002 (0,64 ± 0,05) SQ. TERMINAL .100 PINS (2,54) TYP. .490 (12,45) SQ. .750 (19,05) 3 EQ. SPS. TOL. NON-ACCUM. .455 (11,56) SQ. PRINTABLE AREA 2.250 (57,15) .357 (9,07) 3.100 ± .020 (78,74 ± 0,51) .310 (7,87) 2.120 (53,85) 1x1 Keyboard 1.125 ±.020 .562 1.125 ±.020 .313 .490 SQ. .562 .100 (2,54) REF. TERMINAL PIN HEADER .500 2.250 (57,15) 1.125 (28,58) .800 (20,32) .425 (10,80) .310 (7,87) LABEL 2.120 (53,85) .100 (2,54) REF. TERMINAL PIN HEADER .500 .313 .366 SQ. BUTTON AREA .500 LABEL .270 LABEL .098 (2,49) REF. TERMINAL PIN HEADER TERMINAL PIN IDENTIFICATION F E D B C A G H .425 (10,80) 1.500 (38,1) .098 (2,49) REF. TERMINAL PIN HEADER .207 (5,26) #4-40 MTG STUD (ALSO SERVE AS TERMINALS) .100 (2,54) TYP. 1.125 (28,58) 1.500 (38,1) #6-32 MTG STUD 6 PLACES .750 (19,05) .362 ±.015 A B C D E F G H J K L M N P Q R S TERMINAL PIN IDENTIFICATION Code and Truth Tables The chart indicates the relationship of the terminal pins to each key switch. The dot indicates a closed switch. Terminals are identified on the keyboard. 4 Button Keypads • • • • • • •• A B C D E TERMINAL LOCATION CODES 3x4 1 2 3 4 5 6 7 8 9 10 11 12 • • • • Matrix • • • • • • • • • • • • • • • • • • Single Pole/Common Bus • • • • • • • • • • • • • • • • • • • • • • • • •• C B A G F E D E C B F D A N K H M L J G TERMINAL LOCATION 16 Button Keypads 4x4 BUTTON LOCATION BUTTON LOCATION 1 2 3 4 PINS BUTTON LOCATION CODES 1x4 12 Button Keypads 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 • • • • Matrix • • • • • • • • • • • • • • • • • • • • • • • • • • • • • CODES Single Pole/Common Bus • • • • • • • • • • • • • • • • • • • • • • • • • • • • • •• A B C D E F GH D B A C H F E G K M L J P R Q N S TERMINAL LOCATION Specifications Rating Criteria Rating at 24 Vdc: ≤ 10 milliamps resistive Contact Bounce: 4 milliseconds maximum at make; 10 milliseconds, at break Contact Resistance: MOS, TTL, and DTL compatible. (10 ohms maximum) Operating Temperature: -55°C to 85°C Life Expectancy: 3 million operations/button Insulation Resistance: 1,000 megohms Operating Features Pre-Travel: .030 inches minimum Operating Force: 20 ± 4 ounces Humidity: 0 to 98% (no condensation) Minimum Push Out Force Per Pin: 5 pounds Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois Materials and Finishes Terminal Pins: Copper alloy CDA 725 PC Board: FR-4 glass cloth epoxy Dome Retainer/Rear Seal Sheet: Polyester Mounting Studs: Phosphor bronze Optional Hex Nut: Stainless steel, passivated Optional EMI Shield: Aluminum foil Keypad: Silicone rubber 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Keyboards and Keypads .368 ± .015 (9,35 ± 0,38) .267 ± .015 (6,78 ± 0,38) .425 (10,80) .490 (12,45) #6-32 MTG STUD 6 PLACES .750 (19,05) .775 (19,69) 16 15 Single Pole/Common Bus .490 (12,45) SWITCH POSITION IDENTIFICATION Standard Keypads Frequency Rating MHz in dB 0.1 66.2 10 94.8 100 89.0 400 70.6 800 42.5 2,000 39.5 6,000 32.6 10,000 45.2 18,000 42.2 Shielding Effectiveness Results shown are typical for a standard Grayhill Series 84LS Keyboard. A conductive gasket will generally increase the shielding, depending on the size and shape of the gasket and its material. Data derived for E-Field Radiation. ShieLDinG eFFectiVeneSS oF 84S-ac2 dB 100 80 the frequency source that was radiated from the transmitting antenna to the enclosed receiving antenna. The spacing between antennas was maintained constant throughout the frequency range. The effectiveness rating is determined by establishing a reference reading without obstruction between the two antennas and determining the difference between that reading and the test setup reading. Note: When measured in actual equipment, shielding effectiveness is determined by many factors. This method accurately represents the shielding effectiveness of the Grayhill Series 84LS under ideal test conditions. 60 Test Method: Measurements were made with the keyboard mounted to a brass plate, which in turn was mounted to a shielded enclosure containing the receiving equipment. A signal generator provided 40 Keyboards and Keypads 20 0 0.1 10 100 400 800 2000 6000 10000 18000 MHz Represents shielding effectiveness greater than or equal to line. Standard Legends Available through Grayhill Distributors 1 2 3 1 2 3 c 4 5 6 4 5 6 D 7 8 9 7 8 9 e a 0 B F 0 To order one of the configurations below, use the dash number shown here; select the keypad size and code, and order the part number with the appropriate legend dash number. -112 aBc DeF 3 1 Ghi JKL mno PrS tuV WXY 1 4 B C 5 7 6 8 DeF a Ghi JKL mno B PrS tuV WXY c 4 9 7 D 1 2 3 2 5 8 3 6 9 D OPER 0 0 -113 -301 -016 4 -302 Custom Legends Any reasonable legend can be printed in the key area. Fax a sketch of your requirements to Grayhill. Printing and symbols will be coordinated in keeping with concepts of good design. Or, if required, the details of your submitted artwork aBc OPER -014 A 2 A B C D 1 -201 Header Connectors will be matched as closely as possible. Allow 3 to 4 weeks for custom legend delivery. A nominal charge, depending on the total quantity of keypads ordered and the complexity of the legend, will be assessed. Ordering Information Grayhill Series Number Shielded or Non-Shielded Option S = Shielded SN = Non-Shielded Size Option A = 3x4 B = 4x4 C = 1x1 F = 1x4 Circuitry Option B2 = Matrix in-line pins C2 = Single pole/common bus, in-line pins 84LS-AC2-113-N Mounting Nut Option N = Provided with hex nuts for mounting Blank = Nuts not provided Standard Legend Choices 3x4 Size, choose -112 or -113 4x4 Size, choose -014 or -016 1x4 Size, choose -301 or -302 1x1 Size, choose -201 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois Compatible with: Samtec, Inc. Header Series BCS, BSW, CES, ESW, ESQ, SLW, SSW, SSQ, IDSS and IDSD or equivalent. Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local distributor or Grayhill. 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com 2 3
84LS-AB2-112-N 价格&库存
很抱歉,暂时无法提供与“84LS-AB2-112-N”相匹配的价格&库存,您可以联系我们找货
