88BB2-082
88BB2-082
    GRAYHILLINC.
    SWITCH KEYPAD 16 KEY 0.01A 24V
88BB2-082 数据手册
Standard Keypads SERIES 88 Sealed, Flange Mounted FEATURES • Sealed Keyboard • Colorful Graphic Overlay • Audible, Snap-Dome Contact • User Legendable Styles • 3,000,000 Operations per Button • Optional Panel Seal Gasket to Protect Your Equipment In inches (and millimeters) 3x4 Keyboard .600 ± .010 (15,24 ± 0,25) .128 ± .010 (3,25 ± 0,25) .500 ± .010 (12,7 ± 0,25) (2 EQ. SPS.) TOL. NONACCUM. .150 ± .005 (3,81 ± 0,13) R. .072 ± .010 (1,83 ± 0,25) SWITCH KEY IDENTIFICATION (FOR REF. ONLY) .280 ± .010 (7,11 ± 0,25) .750 ± .010 (19,05 ± 0,25) 1 .500 .010 (12,7 ± 0,25) (3 EQ. SPS) TOL. NONACCUM. 2 3 4 5 6 7 8 9 2.690 + .000/ ROW 2 - .010 (68,33 + .000/ ROW 3 - 0,25) ROW 4 COL 3 .105 ± .010 (2,67 ± 0,25) COL 2 .380 (9,65) SQ. TYP. .025 ± .002 (0,64 ± 0,05) SQUARE TERMINAL ROW 1 10 11 12 COL 1 .055 ± .010 (1,40 ± 0,25) .360 ± .010 (9,14 ± 0,25) 1.990 + .000 - .010 (50,55 + .000 - 0,25) BUTTON AREAS ARE EMBOSSED COL = COLUMN Termination Code and Truth Table In inches (and millimeters) 2.200 ± .015 (55,88 ± 0,38) 3x4 Dots in the chart indicate connected terminals when switch is closed. Terminals are identified on the keyboard. 2.000 ± .010 (50,8 ± 0,25) .100 ± .010 (2,54 ± 0,25) ABC 3.000 ± .015 (76,2 ± 0,38) BUTTON NO. 1 .093 ± .005 (2,36 ± 0,13) DIA. 4 PLS. .100 (2,54) TYP. FGH LMN 2.800 ± .010 (71,12 ± 0,25) CODES 3x4 .220 ± .010 (5,59 ± 25,4) BUTTON LOCATION Keyboards and Keypads DIMENSIONS RETAINING STUDS 1 2 3 4 5 6 7 8 9 10 11 12 Matrix Single Pole/Common Bus • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • F E D K J H G J E A K F B L G C M H D N .200 ± .010 (5,08 ± 0,25) TERMINAL LOCATION CL OF 2.200 (55,88) DIM. .600 1.200 .100 TYP. .100 TYP. Keypads 32 A B CDE F GHJ K L MN DE F GHJ K SINGLE POLE COMMON BUS TERMINAL MATRIX TERMINAL PIN-OUT Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Standard Keypads SERIES 88 Sealed, Flange Mounted FEATURES • Sealed Keyboard • Colorful Graphic Overlay • Audible, Snap-Dome Contact • User Legendable Styles • 3,000,000 Operations per Button • Optional Panel Seal Gasket to Protect Your Equipment Keyboards and Keypads DIMENSIONS In inches (and millimeters) 4x4 Keyboard .600 ± .010 (15,24 ± 0,25) .500 ± .010 (12,7 ± 0,25) (3 EQ. SPS.) TOL. NONACCUM. .150 ± .005 (3,81 ± 0,13) R. .128 ± .010 (3,25 ± 0,25) .072 ± .010 (1,83 ± 0,25) SWITCH KEY IDENTIFICATION (FOR REF. ONLY) .280 ± .010 (7,11 ± 0,25) .750 ± .010 (19,05 ± 0,25) 1 2 5 .500 .010 (12,7 ± 0,25) (3 EQ. SPS) TOL. NONACCUM. 6 3 7 4 8 9 10 11 12 2.690 + .000/ ROW 2 - .010 (68,33 + .000/ - 0,25) ROW 3 ROW 4 COL 4 COL 3 .105 ± .010 (2,67 ± 0,25) COL 2 .380 (9,65) SQ. TYP. COL 1 13 14 15 16 .025 ± .002 (0,64 ± 0,05) SQUARE TERMINAL ROW 1 .055 ± .010 (1,40 ± 0,25) .360 ± .010 (9,14 ± 0,25) 2.490 + .000 - .010 (63,25 + .000 - 0,25) BUTTON AREAS ARE EMBOSSED COL = COLUMN Code and Truth Table In inches (and millimeters) 2.700 ± .010 (68,58 ± 0,25) 4x4 Dots in the chart indicate connected terminals when switch is closed. Terminals are identified on the keyboard. 2.500 ± .010 (63,5 ± 0,25) .100 ± .010 (2,54 ± 0,25) AB 3.000 ± .015 (76,2 ± 0,38) EFG BUTTON NO. 1 .093 ± .005 (2,36 ± 0,13) DIA. 4 PLS. KLM RST 2.800 ± .010 (71,12 ± 0,25) .220 ± .010 (5,59 ± 25,4) RETAINING STUDS .200 ± .010 (5,08 ± 0,25) CODES 4x4 .100 (2,54) TYP. .050 ± .003 (1,27 ± 0,08) BUTTON LOCATION Termination 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 Matrix • • • • • • • • • • • • • • • • • • • • Single Pole/Common Bus • • • • • • • • • • • • • H G F E M L K J CL OF 2.700 (68,58) DIM. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • P J E A R L F B S M H C T N G D K TERMINAL LOCATION 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Keypads 33 Standard Keypads SERIES 88 Sealed, Flange Mounted FEATURES • Sealed Keyboard • Colorful Graphic Overlay • Audible, Snap-Dome Contact • User Legendable Styles • 3,000,000 Operations per Button • Optional Panel Seal Gasket to Protect Your Equipment In inches (and millimeters) 5x4 Keyboard .600 ± .010 (15,24 ± 0,25) .500 ± .010 (12,7 ± 0,25) (4 EQ. SPS.) TOL. NONACCUM. .128 ± .010 (3,25 ± 0,25) .150 ± .005 (3,81 ± 0,13) R. .072 ± .010 (1,83 ± 0,25) SWITCH KEY IDENTIFICATION (FOR REF. ONLY) .280 ± .010 (7,11 ± 0,25) .750 ± .010 (19,05 ± 0,25) 1 2 6 .500 .010 (12,7 ± 0,25) (3 EQ. SPS) TOL. NONACCUM. 7 3 8 4 5 9 10 11 12 13 14 15 .025 ± .002 (0,64 ± 0,05) SQUARE TERMINAL ROW 1 2.690 + .000/ ROW 2 - .010 (68,33 + .000/ 0,25) ROW 3 ROW 4 COL 5 COL 4 .105 ± .010 (2,67 ± 0,25) COL 3 .380 (9,65) SQ. TYP. COL 2 16 17 18 19 20 COL 1 .055 ± .010 (1,40 ± 0,25) .360 ± .010 (9,14 ± 0,25) 2.990 + .000 - .010 (75,95 + .000 - 0,25) BUTTON AREAS ARE EMBOSSED COL = COLUMN Termination 3.200 ± .010 (81,28 ± 0,25) 3.000 ± .010 (76,2 ± 0,25) 5x4 Keyboard .100 ± .010 (2,54 ± 0,25) Dots in the chart indicate connected terminals when switch is closed. Terminals are identified on the keyboard. BUTTON NO. 1 .100 (2,54) TYP. A 3.000 ± .015 (76,2 ± 0,38) Code and Truth Table In inches (and millimeters) DEF JKL PQR .093 ± .005 (2,36 ± 0,13) DIA. 4 PLS. UVW 2.800 ± .010 (71,12 ± 0,25) .220 ± .010 (5,59 ± 25,4) RETAINING STUDS CL OF 3.200 (8,13) DIM. CODES 5x4 BUTTON LOCATION Keyboards and Keypads DIMENSIONS 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 Matrix • • • • • • • • • • • • • • •• • • • • • • • • • Single Pole/Common Bus • • • • • • • • • • • • • • • • P N K G F J L MH • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • •• T P M H D U Q L GC V R K F BW S J E A N TERMINAL LOCATION Keypads 34 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Sealed Keypads SPECIFICATIONS Materials and Finishes Rating Criteria Rating at 24 Vdc: 10 milliamps, resistive Contact Resistance: Compatible with MOS, TTL and DTL (10 ohms maximum) Voltage Breakdown: 250 Vac between mutually insulated parts Life Expectancy: 3,000,000 operations per button STANDARD LEGENDS -143 Operating Features Housing: ABS polycarbonate, black Graphic Overlay: Polyester Contact Dome: Stainless steel, selectively goldplated Terminals: Phosphor bronze Button Travel: 0.015"(0,38 mm) nominal total travel Typical Operating Force: 350 grams continues to look bright and bold throughout the keyboard life. Available through distributors. For instant custom legends, order separate blank keyboards as indicated in the Ordering -152 Information section and choose one of the clear window overlays below; then order a sheet of legend inserts. Or, if you prefer, order the keyboard custom printed by Grayhill; see Ordering Information. -172 88-101 -052 -072 -252 -082 -262 88-001 88AB2, 88AC2 88BB2, 88BC2 88JB2, 88JC2 88-201 SEALING OF KEYBOARDS The graphic legend is silk-screen printed on the second surface of a clear polyester film, providing maximum legend protection. It withstands high humidity, and it is resistant to scratching, marring, and dulling of the surface caused by fingernails, wiping cloths, and cleaning materials. It has excellent solvent resistance to water, petroleum oil, alcohols and aliphatic hydrocarbons. detergent solution, soapy water, 30% hydrogen peroxide, wine, beer, whiskey, coffee, cocoa, milk, tomato juice, lemon juice, etc. Hydrocarbons, ketones and freon do not affect the overlay. But, we recommend that you do not subject the keyboard to these chemicals, since they may affect the switch housing, which is ABS plastic. To discuss a particular solvent, contact Grayhill. These common liquids do not attack the overlay: 5% acetic acid, 5% citric acid, 2% Protect your equipment in outdoor or harsh environmental conditions by sealing the Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois keyboard to the equipment panel. Use an optional gasket with the keyboard. There are two types of gaskets: one for mounting the keyboard beneath the panel, and one for mounting it above the equipment panel. See Panel Seal Gaskets. The contact system is internally sealed by a special adhesive backed sheet that holds the domes in position on the PC board. 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Keypads 35 Keyboards and Keypads Colorful graphic overlays are polyester with a tough acrylic bond to provide maximum protection against dirt and moisture. Second surface printed, the overlay wipes clean and Contact Bounce: Less than 4 milliseconds at make, 10 milliseconds at break Temperature: -40°C to +80°C Standard Keypads PANEL SEAL GASKETS Subpanel Mounting Topside Mounting Weatherproof and waterproof your subpanel and topside mounted keyboards with optional panel seal gaskets. Subpanel keyboard gasket is .062" (1,57 mm) thick; topside keyboard gasket is .094" (2,39 mm). DIM. C 3.200 ± .005 (81,28 ± 0,13) 2.710 ± .005 (68,83 ± 0,13) 2.850 ± .005 (72,39 ± 0,13) DIM. A 2.500 ± .005 (63,5 ± 0,13) Material is cellulose fiber, foam, nitrile rubber. Order gaskets separately from keyboard. Keyboards and Keypads DIM. D DIM. B Subpanel 3x4 Subpanel 4x4 Subpanel 5x4 Part No. 88M2001-2 Part No. 88M2009-2 Part No. 88M2019-1 Topside 3x4 Topside 4x4 Topside 5x4 Part No. 88M2012-1 Part No. 88M2015-1 Part No. 88M2018-1 Size of Keyboard Subpanel Mount Dim. A Dim. B 3x4 2.010 ± .005 (51,05 ± 0,.13) 2.400 ± .005 (60,96 ± 0,13) 1.800 ± .005 (45,72 ± 0,13) 2.040 ± .005 (51,82 ± 0,13) 4x4 2.510 ± .005 (63,75 ± 0,13) 2.900 ± .005 (73,66 ± 0,13) 2.300 ± .005 (58,42 ± 0,13) 2.540 ± .005 (64,52 ± 0,13) 5x4 3.010 ± .005 (76,45 ± 0,13) 3.400 ± .005 (86,36 ± 0,13) 2.800 ± .005 (71,12 ± 0,13) 3.040 ± .005 (77,22 ± 0,13) PRINTED LEGENDS INSTANT CUSTOM LEGENDS Available through Distributors Create your own legends using these 3 items: 1) a blank keyboard, 2) the clear window overlays shown on Standard Legend page and 3) a sheet of legend inserts. Blank Keyboards The numbers below order blank keyboards for the user to legend. For description, refer to the part numbering scheme below. The keyboards and overlays are ordered separately. 3x4 Matrix Part No. 88AB2 3x4 SP/Com Bus Part No. 88AC2 4x4 Matrix Part No. 88BB2 4x4 SP/Com Bus Part No. 88BC2 5x4 Matrix Part No. 88JB2 5x4 SP/Com Bus Part No. 88JC2 Legend Insert Sheet and Dry Transfers Self-adhesive inserts are die-cut to fit the Topside Mount Dim. C Dim. D button. Legends are printed in black on clear film in News Gothic Condensed type style. They include letters A through Z, numbers 069, telephone legends, commonly used words, symbols and blanks. Part No. 87AC2046 Use matching dry transfer lettering on blank inserts of legend sheet: upper and lower case letters, 0-9, and common symbols. Small Print Part No. 87-DT-2096-088 Medium Print Part No. 87-DT-2096-125 Large Print Part No. 87-DT-2096-187 Clear Window Overlays Order separately from keyboards. See also ordering information. 3x4 Overlay Part No. 88-101 4x4 Overlay Part No. 88-001 5x4 Overlay Part No. 88-201 Not available through Distributors. For medium volume applications, or where legends cannot be produced by the self legend method, you can order epoxy ink printed legends. Virtually anything which can be photographed can be printed. Grayhill will print your legend and then add the clear window overlay. Type Simulated I.D. No. Style & Size Character & Line Limitations * 4GH088 ABCDEFGH END DATA 1GH125 ABCDE LAD 3GH187 ABCD ON 2GH250 ABC 15 ORDERING INFORMATION Grayhill Series Number Size Option A = 3x4 B = 4x4 J = 5x4 Circuitry Option B2 = Matrix code C2 = Single pole/common bus Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. 88AB2–152 Standard Legend Choices 3x4 Size: -143, -152, or -172 4x4 Size: -052, -072 or -082 5x4 Size: -252 or -262 Keypads 36 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
88BB2-082 价格&库存
很抱歉,暂时无法提供与“88BB2-082”相匹配的价格&库存,您可以联系我们找货
88BB2-082
  • 1+824.992871+106.78673
88BB2-082
    88BB2-082
