83AB1-102
83AB1-102
    GRAYHILLINC.
    KEYPAD 12 KEY MATRIX NUM W/LEDG
83AB1-102 数据手册
Standard Keypads Series 83 Unsealed, .500" Centers FEATURES • 1/2" Button Centers • Post Mounted • Mount by Grooveless Retaining Ring or Heat Upset Post • Snap-Dome Contact Provides Positive Feedback 3x4 Keyboard .500 – .010 (12,7 – 0,25) 2 EQ. SPS. .510 – .010 (12,95 – 0,25) .350 – .010 (8,89 – 0,25) .290 – .010 (7,37 – 0,25) ROW 1 1 2 3 ROW 2 4 5 6 ROW 3 7 8 9 ROW 4 10 11 12 COL 2 COL 3 .366 – .010 (9,30 – 0,25) SQ. BUTTON COL 1 Keyboards and Keypads Dimensions in inches (and millimeters) RETAINING STUDS 2.080 1.960 – .015 – .015 (52,83 (49,78 – 0,38) – 0,38) .050 (1,27) .500 – .010 (12,7 – 0,25) 3 EQ. SPS. SWITCH KEY IDENTIFICATION FOR REF. ONLY .096 (2,44) 1.460 – .010 (37,08 – 0,25) 1.580 – .015 (40,13 – 0,38) COL = COLUMN Termination BUTTON NO. 1 MOUNTING POSTS .086 (2,18) DIA. 4 PLACES .060 – .010 (1,52 – 0,25) in inches (and millimeters) 3x4 Matrix Output Single Pole/Common Bus .500 – .010 (12,7 – 0,25) BUTTON NO. 1 RETAINING STUDS .025 – .002 (0,64 – 0,05) SQUARE TERMINAL .330 – .010 (8,38 – 0,25) RETAINING STUDS .100 (2,54) TYP. B C D E BUTTON NO. 1 .480 – .010 (12,19 – 0,25) K L M .880 – .010 (22,35 – 0,25) .480 – .010 (12,19 – 0,25) .025 – .002 (0,64 – 0,05) SQUARE TERMINAL .100 (2,54) BETWEEN TERMINALS A B C D E F G H J K M N P .680 – .010 (17,27 – 0,25) .330 – .010 (8,38 – 0,25) .500 – .010 (12,7 – 0,25) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Standard Keypads Series 83 Unsealed, .500" Centers FEATURES • 1/2" Button Centers • Post Mounted • Mount by Grooveless Retaining Ring or Heat Upset Post • Snap-Dome Contact Provides Positive Feedback Keyboards and Keypads Dimensions in inches (and millimeters) 4x4 Keyboard .500 – .010 (12,7 – 0,25) 3 EQ. SPS. .290 – .010 (7,37 – 0,25) ROW 1 1 2 3 4 ROW 2 5 6 7 8 ROW 3 9 10 11 12 ROW 4 13 14 15 16 COL 1 COL 2 COL 3 COL 4 .366 – .010 (9,30 – 0,25) SQ. BUTTON .510 – .010 (12,95 – 0,25) .350 – .010 (8,89 – 0,25) BUTTON NO. 1 MOUNTING POSTS .086 (2,18) DIA. 4 PLACES RETAINING STUDS 2.080 1.960 – .015 – .015 (52,83 (49,78 – 0,38) – 0,38) .050 (1,27) .500 – .010 (12,7 – 0,25) 3 EQ. SPS. SWITCH KEY IDENTIFICATION FOR REF. ONLY .096 (2,44) 1.960 – .010 (49,78 – 0,25) 2.080 – .015 (52,83 – 0,38) COL = COLUMN Termination in inches (and millimeters) 4x4 Matrix Output Single Pole/Common Bus BUTTON NO. 1 BUTTON NO. 1 A B C D .060 – .010 (1,52 – 0,25) E F G RETAINING STUDS .100 (25,4) BETWEEN TERMINALS H .730 ± .010 (18,54 ± 0,25) .480 ± .010 (12,19 ± 0,25) 1.000 ± .010 (25,4 ± 0,25) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois H J K A B C .025 ± .002 (0,64 ± 0,05) SQUARE TERMINAL .330 ± .010 (8,38 ± 0,25) E F G RETAINING STUDS L M N P R S T .100 (25,4) TYP. BETWEEN TERMINALS .680 ± .010 (17,27 ± 0,25) 1.680 ± .010 (42,67 ± 0,25) .025 ± .002 (0,64 ± 0,05) SQUARE TERMINAL U V W .480 ± .010 (12,19 ± 0,25) .080 ± .010 (2,03 ± 0,25) 1.000 ± .010 (25,4 ± 0,25) 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com .330 ± .010 (8,38 ± 0,25) Standard Keypads Code and Truth Tables Dots in the chart indicate connected terminals when switch is closed. Terminals are identified on the keyboard. 12 Button Keypads CODES 1 2 3 4 5 6 7 8 9 10 11 12 • • • • Matrix • • • • • • • • • • • • • • • • • • 4x4 Single Pole/Common Bus • • • • • • • • • • • • • • • • • • • • • • • • •• BUTTON LOCATION Keyboards and Keypads BUTTON LOCATION 3x4 16 Button Keypads K D E B C L M K H A J C B N E F M P G D TERMINAL LOCATION 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 • • • • Matrix • • • • • • • • • • • • • • • • • • • • • • • • • • • • • E F D C A B GH CODES Single Pole/Common Bus • • • • • • • • • • • • • • • • • • • • • • • • • • • • • •• H J K A L M C B T S E F W V UG P TERMINAL LOCATION Specifications Rating Criteria Contact Bounce: Less than 4 milliseconds at make, 10 milliseconds at break Operating Temperature: -40°C to +80°C Rating at 24 Vdc: 10 milliamps, resistive Contact Resistance: Compatible with MOS, TTL and DTL (10 ohms maximum) Voltage Breakdown: 250 Vac between mutually insulated parts Life Expectancy: 3,000,000 operations per button Materials and Finishes Snap-On-Cap: Clear polycarbonate Contact Dome: Stainless steel, selectively gold- plated Terminals: Phosphor bronze Housing: ABS polycarbonate, black Buttons: ABS plastic, white. Legends are black. Operating Features insert. This surface can also be ink stamped by Grayhill in higher volume quantities. When the cap is replaced, the assembly extends approximately .015" (0,38 mm) above the surface. The legend sheet information follows the legend presentation. All other legends incorporate molded-in (two shot) legends. Button Travel: 0.015" (0,38 mm) nominal total travel Typical Operating Force: 350 grams Standard Legends Insertable legend version (legend numbers -101 and -001) has a removable cap. The revealed button surface can be legended by an insert or a dry transfer of a blank legend 1 2 3 4 5 6 7 8 9 aBC DeF 0 1 2 3 ghi JKl mno 4 5 6 7 PrS tuV WXY 8 9 a B C D e F 1 2 4 7 8 6 9 OPER 0 -101 (Insertable) 5 3 0 -102 (Molded-in) -103 (Molded-in) -001 (Insertable) C D e F 1 2 3 C 1 2 3 F 8 9 a B 4 5 6 D 4 5 6 e 4 5 6 7 7 8 9 e 7 8 9 D 0 1 2 3 a 0 B F a 0 B C -003 (Molded-in) -004 (Molded-in) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois -005 (Molded-in) -002 (Molded-in) aBC DeF a ghi JKl mno B PrS tuV WXY C 1 4 7 2 5 8 3 6 9 OPER 0 D -006 (Molded-in) 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Standard Keypads INSERTABLE LEGEND SHEETS For prices and discounts, contact a local Sales For use with -101 or -001 legend option. Legends are die cut to button surface when cap is removed. PRINTED LEGENDS For Maximum Versatility Type No. and Typical Height Sample Style and Typical Sizes 4GH088 .083" ABCDEFGH 4 Characters 2 Lines END DATA 4 Characters 2 Lines END DATA 1GH125 .138" ABCDE 3 Characters 1 Line LAD 3 Characters 1 Line LAD 3GH187 .207" ABCD 2 Characters 1 Line ON 2 Characters 1 Line ON 2GH250 .276" ABC N/A N/A 2 Characters 1 Line 15 Top Surface Character and Line Limitations ORDERING INFORMATION Grayhill Series Number Size Option A = 3x4 B = 4x4 Circuitry Option B1 = Matrix code C1 = Single pole/common bus ORDERING INFORMATION: Special Legends Follow this procedure: 1. Basic Keyboard. Formulate the part number with the exception of the legend 2. Mounting. Standard mounting is shown in our dimensional drawings. These drawings relate the terminal location to the button legend orientation. It is possible to rotate the button legends by 90°, changing the orientation. When mounting the keypad, it would be rotated 90° to have the legends appear upright. A 3x4 keypad thus becomes a 4x3. Sub Surface Character and Line Limitations 83AB1–103 Standard Legend Choices 3x4 Size: -101, -102 or -103 4x4 Size: -001, -002, -003, -004, -005 or -006 Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales an authorized local Distributor or Grayhill. 3. Color. Many colors, other than our standard black housing, are available. Buttons can be made from equivalent plastic in black, red, green, blue and yellow. White legends are used with dark color buttons, black with light ones. Other colors available on special order. 4. Buttons. Legends can be printed on button surface and protected by a snap-on cap in a similar fashion to our insertable legend types. A second option is printing a ‘blank’ button. (One that has the same dimensions as a molded-in legend button with a top surface.) Disadvantage is legend wear over time. A third option is molded-in legends, usually requiring tooling. Molded buttons are available with a or concave top surface. 5. Legends. Specify the legend requirements for each button. Identify buttons per our dimensional drawings. Caution if keypad has been rotated. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Keyboards and Keypads Printing allows you the to create your own legend using whole words and symbols with various type styles. Durable epoxy ink printing bonds to the button cap surface. There are two types of button cap printing: Top Surface Printing: Legend is applied directly to the top of the button. Button is recessed slightly below the keyboard housing. Sub-Surface Printing: For insertable legend models. Provides maximum wear for printed surfaces. Printed internal button cap is protected by clear snap-on cap. Printed Typestyles: The typestyle chart illustrates type style, size and approximate character limits for button caps. Grayhill's library of typefaces includes most popular legends. an authorized local Distributor or Grayhill.
83AB1-102 价格&库存
很抱歉,暂时无法提供与“83AB1-102”相匹配的价格&库存,您可以联系我们找货
83AB1-102
  • 1+416.131541+53.90359
  • 9+308.349169+39.94200
  • 18+302.9182018+39.23850
  • 35+297.4872335+38.53500
  • 100+270.41346100+35.02800
库存:100
83AB1-102
    • 4+373.64643
    • 9+367.26420
    • 18+360.73506
    • 35+354.33650
    • 100+322.09887
    库存:100
